Kubota Tractor M7060DTHC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M7060DTHC Tractor
Number of Pages: 583 Pages
Bloque Motor / Crankcase
Aceite Tapon / Oil Filler Pulg
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Culata Cubierta / Head Cover
Piston Y Ciguenal / Piston And Crankshaft
Compensador / Balancer
Volante / Flywheel
Carril Comun / Common Rail
Termostatoy Tapa / Water Flange And Thermostat
Bomba Agua / Water Pump
Aire Limpiador Brida / Air Cleaner Flange And Throttle Valve
Valvula De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Filtro De Aire / Air Cleaner
Entrada Tubo / Inlet Pipe
Sensor Del Muflfer / Muffler Sensor
Separador De Aceite [Piezas De Componentes] / Oil Separator [Component Parts]
Tubo Separador De Aceite / Oil Separator Pipe
Piezas Electricas Del Motor / Engine Electrical Parts
Kit Juntas Superior / Accelerator Pedal
Deposito Combustible / Fuel Tank [Ec] [Uk]
Deposito Combustible / Fuel Tank [Ita]
Llenador Del Combustible / Fuel Filler
Combustible Tubo (Limpiador) / Fuel Pipe (Filter/Supply Pump)
Combustible Tubo (Bomba) / Fuel Pipe (Fuel Pump)
Combustble Tubo (Refrigerador Del Combustible) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Ventilador / Fan
Manguitoagua / Water Pipe
Alternador / Alternator
Alternador [Componentes] / Alternator [Component Parts]
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Conmutador 2 / Switch/Sensor (Fuel Unit/Horn) [Ec] [Uk]
Conmutador 2 / Switch/Sensor (Fuel Unit/Horn) [Ita]
Conmutador/Sensor (Fronte) / Switch/Sensor (Engine)
Conmutador/Sensor (Cuerpo) / Switch/Sensor (Clutch Housing/Transmission Case)
Conmutador 2 / Switch (Panel)
Rele / Relay
Ecu / Electronic Control Unit
Faro Delantero / Head Light
Adelante Combinacion Luz / Front Combination Light
Luz De Trabajo / Working Light/Beacon Light [Ec] [Ita]
Trasero Combinacion Luz / Rear Combination Light
Luz Matricula / License Lamp
Altavoz De Radio / Radio Speaker [Ec] [Ita]
Limpiador Delantero / Front Wiper
Electrico Cableado (Crs) / Electrical Wiring (Crs)
Electrico Cableado (Interruptor) / Electrical Wiring (Engine)
Instalacion Electrica / Electrical Wiring (Main) [Ec] [Uk]
Instalacion Electrica / Electrical Wiring (Main) [Ita]
Instalacion Electrica / Electrical Wiring (Cab) [Ec] [Ita]
Carcasa De Embrague [Tipo De Cambio Manual] / Clutch Housing
Cajatransmision / Transmission Case [Ec] [Uk]
Cajatransmision / Transmission Case [Ita]
Pedal Embrague / Clutch Pedal
Cable De Embrague / Clutch Cable
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Entrada Eje / Input Shaft
Inversor Embrague [Componente Piezas] [Ds] / Clutch Pack (Shuttle) [Component Parts]
Eje De Inversor [Tipo De Cambio Manual] / Shuttle Shaft
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Accionar Eje(Adelante) / Drive Shaft
Eje Diferencial / Bevel Gear [Ec] [Uk]
Eje Diferencial / Bevel Gear [Ita]
Embrague Tdf / Pto Clutch [Ec] [Uk]
Embrague Tdf / Pto Clutch [Ita]
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Eje Tdf (Con Tdf Intermedia) / Pto Shaft
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Horquilla De Cambio Principal [Tipo De Cambio Manual] / Main Gear Shift Fork
Gama Engranaje Cambio Bfrccn/Mrch My Lnt Engrnj Cmb Bfrccn / Range Gear Shift Fork/Creep Gear Shift Fork
Horquilla De Cambio De Tdf Proporcional [Tdf Proporcional] / Ground Pto Shift Fork [Ita]
Horquilla Diferencial / Rear Differential Lock Shift Fork
Inversor Cable / Shuttle Cable
Palanca De La Cambio De Engran. De La Gama Y Arrastramiento / Range And Creep Gear Shift Lever
Masa Pto Cambio Palanca [Tdf Proporcional] / Ground Pto Shift Lever [Ita]
Eje Trasero / Rear Axle
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Varilla De Freno De Estacionamiento[Tipo Cabina][Tipo Nuevo] / Parking Brake Rod
Arbol De Levas Del Freno De Estacionamiento / Parking Brake Camshaft
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Carcasa Diferencial Delantero / Front Differential Case
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Maneta Direccion / Steering Handle
Orbitrol / Steering Controller
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Cilindro Direccion / Tie Rod/Steering Cylinder
Bomba Hidraulica [Componentes] / Hydraulic Pump [Component Parts]
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Direccion/Tdf) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea (Inversor/Controlador) / Hydraulic Oil Line (Shuttle/Controller)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Pipa De La Valvula De Solenoide / Solenoid Valve Pipe
Hidraulico Piston/Ascenzo Brazo / Hydraulic Lift Arm
Distribuidor / Control Valve
Palanca De Control De Posicion / Position Control Lever
Palanca De Control De Esfuerzo Y Posicion 1 / Draft And Position Control Lever
Palanca De Control De Esfuerzo Y Posicion 2 / Draft And Position Control Rod
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Palanca Alimentacion Trasera / Feed Back Lever
Limpiaparabrisas / Auxiliary Control Vakve
Auxiliar Control Valvula (S/D) [Componente Piezas] / Auxiliary Control Valve (S/D) [Component Parts]
Auxiliar Control Valvula (S/D) [Componente Piezas] / Auxiliary Control Valve (Scd) [Component Parts]
Auxiliar Control Valvula Palanca (1r) / Auxiliary Control Valve Lever (1st)
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever (2nd)
Parte Superior / Top Link
Varillaje 1 Tercer Punto (Brazo Inf) / Lower Link
Estabilizador / Stabilizer
Ascenso Varilla Dcha / Lift Rod Rh
Pto Protector
Parrilla Frontal / Front Grille
Capo Lado / Hood (Bonnet) Upper
Capo Superior (Amortiguador Sano/Aislador) / Hood (Bonnet) Upper (Sound Absorber/Insulator)
Carter / Bonnet Lock
Capo Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte / Bonnet Support
Cabina / Cab Frame [Ec] [Uk]
Cabina / Cab Frame [Ita]
Accesorios Y Servicio Piezas / Step
Adelante Vidrio Y Trasero Vidrio / Front Glass
Puerta Derecha / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Vidrio / Side Window
Cristal Puerta Trasera / Rear Window
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Inspeccion Placa (Adelante) / Inspection Plate [Ec] [Uk]
Inspeccion Placa (Adelante) / Inspection Plate [Ita]
Guardabarros Cubierta Derecho / Fender Cover Rh
Cubierta De Guardabarros Izqd / Fender Cover Lh
Ventilador / Fender
Herramienta Caja / Tool Box
Aire Acondicionador Conducto / Air Conditioner Duct
Modo Caso / Mode Case
Manguitocalentador / Heater Hose
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito / Air Conditioner Hose / Condenser Hose
Compresor / Compressor
Etiqueta 1 / Label (Front)
Etiqueta 2 (Nuevo) / Label (Rear) [Ec] [Uk]
Etiqueta 2 (Nuevo) / Label (Rear) [Ita]
Accesorios Y Servicio Piezas / Accessories
Debajo Silenciador Kit[Opcion] / Under Muffler Kit [Option]
Ecu Kit [Opcion] / Ecu Kit [Option]
Kit De Alternador (Alternador) [Opcion] / Alternator Kit (Alternator) [Option]
Alternador Kit 2(Cable Mazo De Cables)[Opcion] / Alternator Kit (Wire Harness) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Trasero Desempanador Kit [Opcion] / Rear Defogger Kit (Alternator) [Option]
Trasero Desempanador Kit 2 [Opcion] / Rear Defogger Kit (Glass) [Option]
Trasero Desempanador Kit 3 [Opcion] / Rear Defogger Kit (Wire Harness) [Option]
Linea De Aceite Hidraulico (Impulsion) / Rear Wiper Kit [Option]
Kit Fusible [Opcion] / Fuse Kit [Option]
Kit Soporte [Opcion] / Implement Monitor Stay Kit [Option]
Tdf(540/1000) Conversion Kit [Opcion] / Pto(540/1000) Conversion Kit [Option]
Kit De Mejora De Embrague De Tracción A Las 4 Ruedas [Opción] / 4wd Clutch Upgrade Kit [Option]
Embrague De Tracción A Las 4 Ruedas[Componentes] [Opción] / 4wd Clutch [Component Parts] [Option]
Kit De Parachoques Delantero [Opcion] / Front Bumper Kit [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve Kit (Scd) [Option]
Valvula Auxiliar Control (Flotante) [Opcion] / Auxiliary Control Valve Kit (Fd) [Option]
Valvula Auxiliar Control (Flotante) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Auxiliar Control Valvula (Fd) [Componente Piezas] [Opcion] / Valve Auxiliaire (Fd) [Parties Composantes] [Option]
Auxiliar Control Valvula (Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos(Tercero) [Tipo Cabina] [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Remolque Freno Valvula Kit 1 (Valvula/Tubo) [Ita] [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option] [Ec] [Uk]
Remolque Freno Valvula Kit 2 (Entrega Tubo) [Ita] [Opcion] / Trailer Brake Valve Kit 2 (Pipe) [Option] [Ec] [Uk]
Carter / Oil Pan
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Pto Protector
Ventilador / Fender
