Kubota Tractor M7040DTHNBC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7040DTHNBC Tractor
Number of Pages: 419 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve A Nd Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Injeção / Injection Pump Unit
Veio / Fuel Camshaft
Alavanca Do Garfo (Governador) / Fork Lev Er (Governor)
Parafuso De Ajuste De Restrição / Restri Ction Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Valvula Solenoide / Nozzle Holder And Glo W Plug
Bomba Agua E Termostacto / Water Flange A Nd Thermostat
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Clean Er [Component Parts]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe(Turbo Charge R)
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Deposito Combustivel / Fu El Tank
Deposito Combustivel (Drt ) / Fuel Tank Rh
Deposito Combustivel (Esq ) / Fuel Tank Lh
Tubo Combustivel / Fuel P Ipe 1 (Rear) [Ec] [Se]
Tubo Combustivel / Fuel P Ipe 2 (Front)
Separador / Separator
Separador[Peças Component Es] / Separator [Component Parts]
Ventila Dor / Fan
Radiado R / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componen Tes] / Starter [Component Parts]
Bateria / Battery [Old]
Bateria / Battery [New]
Interruptor/Sensor / Swi Tch/Sensor (Front)
Interruptor/Sensor / Swi Tch/Sensor (Rear) [Ec] [Se]
Interruptor / Switch (Pa Nel Board)
Comutador / Switch
Interruptor / Rele / Rel Ay
Painel / Panel Board
Farol Dianteiro / Head L Ight
Farol Frente[Peças Compo Nentes] / Head Light [Component Parts]
Luzes Frontais / Front C Ombination Light
Luzes Trabalho / Working Light/Beacon Light
Braco Traseiro / Rear Co Mbination Light
Farol Matricula / Licens E Lamp
Luz Interior / Room Ligh T
Alta Voz Radio / Radio S Peaker
Depósito De Lavagem / Wa Sher Tank
Escova Limpa Vidro Front Al / Front Wiper
Cablagem Eletrcia (Frent E) / Electrical Wiring (Engine) [Ec] [Se]
Cablagem Electrica / Ele Ctrical Wiring (Main) [Ec] [Se]
Cabalagem Eletrica(Cabin E)[Ec] [G] / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cov Er
Caixa Velocidades / Transmission Case [Ec] [Se]
Mangueira De Resp Iro (Caixa Velocidades) / Breather Hose (Transmissi On Case)
Carter Transmissa O / Transmission Case Rear Cover [Se]
Carter Eixo / Rea R Axle Case
Disco Amortecedor / Damper Disk
Bloqueio Diferenc Ial / Clutch Pedal
Valvula (Inversor ) / Valve Lever (Clutch)
Veio Primario / I Nput Shaft
Embraiagem Invers Or [Peças Componentes] / Shuttle Clutch [Component Parts]
Veio Inversor / S Huttle Shaft
Primeiro Veio / F Irst Shaft
Terceiro Veio / T Hird Shaft
Veio Creeper / Cr Eep Shaft
Diferencial Trase Iro / Differential Rear
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch [Ec] [Se] [Old]
Embraiagem Tdf / Pto Clutch [Ec] [Se] [New]
Valvula Embraiage M Tdf / Pto Clutch Valve
Veio Tdf / Pto Sh Aft
Embraiagem Andame Nto / Front Drive Clutch
Veio Embraiagem[P Eças Componentes] / Front Drive Clutch [Component Parts]
Veio Primario (Tr Aseira) / Front Propeller Shaft (Rear)
Forqu Eta / Main Gear Shift Fork
Forqu Eta Caixa / Creeper / Range And Creep Gear Shift Fo Rk
Alava Nca / Rear Differential Lock Shift Fork
Alava Nca Velocidades / Main Gear Shift Lever
Tiran Te / Main Gear Shift Rod
Alvan Ca Inversor / Shuttle Shift Lever
Cabo Inversor / Shuttle Cable
Alava Nca Velocidades / Range Gear Shift Lever
Alava Nca Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear A Xle
Travão Direita / Brake Rh
Travão Esquerda / Brak E Lh
Tirante Travao / Brake Rod (Brake Pedal)
Tirante Travao 2 / Bra Ke Rod (Brake Cam)
Pedal Travao / Brake P Edal
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal[Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pi Pe
Suporte Eixo Diante Iro / Front Axle Bracket
Veio Frontal / Fron T Propeller Shaft
Caixa Diferencial D Ianteiro / Front Differential Case
Caixas Engrenagens Conica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Conica(Esq) / Bevel Gear Case Lh
Carter Eixo Frente( Drt) / Front Axle Case Rh
Carter Eixo Frente( Esq) / Front Axle Case Lh
Carreto Diferencial (Drt) / Differential Gear Shaft Rh
Carreto Diferencial (Esq) / Differential Gear Shaft Lh
Eixo Frente (Drt) / Front Axle Rh
Eixo Dianteiro / Fr Ont Axle Lh
Direcção Assistida / Direção Punho / Steer Ing Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts] [Old]
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts] [New]
Direcção Assistida / Tie Rod/Steering Cyli Nder
Cilindro Direccao [Peças Componentes(Antig A) / Steering Cylinder [Component Parts] [Old]
Cilindro Direccao [Peças Componentes(Nova) / Steering Cylinder [Component Parts] [New]
Bomba Hidraulico / Hydra Ulic Pump
Bomba Hidraulico[Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic Pi Pe (Delivery)
Radiador Oleo / Oil Cool Er
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Oleo (Valvula Embra Iagem Tdf) / Hydraulic Oil Line (Pto Clutch Valve)
Cilindro Hidraulico / Hy Draulic Cylinder
Braço De Elevação Hidráu Lico / Hydraulic Lift Arm
Valvula Segurança / Safe Ty Valve/Relief Valve
Trinco / Lowering Lock L Ever
Braco Hidraulico [Antiga ] / Control Valve [Old]
Valvula Control [Nova] / Control Valve [New]
Acessorios / Draft And P Osition Control Lever
Veio Posicao Esforço / P Osition And Draft Shaft [Old]
Veio Posicao Esforço / P Osition And Draft Shaft [New]
Alavanca / Feed Back Lev Er
Válvula De Controlo Auxi Liar / Auxiliary Control Valve [Se] [Old]
Válvula De Controlo Auxi Liar / Auxiliary Control Valve [Se] [New]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Fd) [Compon Ent Parts] [Old]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Scd) [Compo Nent Parts] [New]
Flow Priority Valve [Com Ponent Parts] / Flow Priority Valve [Component Part S]
Alavanca Valvula Auxilia R / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Auxilia R 1 Pos / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Ele Vação Esq / 3p-Lift Assist Cylinder Lh [Se] [Old] # # N.º De Série<=94762 S.No.;<=94762 [Note:Order By All Parts Of Fig.No.U87502.] / S.No.<=94762 [Note:O Rder By All Parts Of Fig.No.U87502.]
Cilindro Auxiliar De Ele Vação Esq (Antigo) / 3p-Lift Assist Cylinder Lh [Se ] [New]
Cilindro Auxiliar De Ele Vação Drt / 3p-Lift Assist Cylinder Rh [Se] [Old] # # N.º De Série<=94762 S.No.;<=94762 [Note:Order By All Parts Of Fig.No.U87502.] / S.No.<=94762 [Note:O Rder By All Parts Of Fig.No.U87502.]
Cilindro Auxiliar De Ele Vação Drt (Antigo) / 3p-Lift Assist Cylinder Rh [Se ] [New]
Cilindro Auxiliar De Ele Vacao[Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro Auxiliar De Ele Vacao[Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts] [New]
Par Te Superior / Top Link Bracket
Top Link [Old] / Top Link [Old]
Top Link [New] / Top Link [New]
Low Er Link [Old] / Lower Link [Old]
Lig Acao Inferior / Lower Link [New]
Est Abilizador / Stabilizer [Se] [Old]
Est Abilizador / Stabilizer [Old]
Est Abilizador / Stabilizer [New]
Lif T Rod Rh [Old] / Lift Rod Rh [Old]
Lif T Rod Rh [New] / Lift Rod Rh [New]
Lif T Rod Lh [Old] / Lift Rod Lh [Old]
Bar Ra / Drawbar Bracket [Se]
Pro Teccao Tdf / Pto Shaft Protector [Se]
Grelha Frontal / Front Grille
Capot Superior / Hood(Bonnet) Upper
Amortecedor Capot / Hood(Bonnet) Damper
Trico Capot / Bonnet Lock
Capot Lateral / Hood(Bonnet) Side Cover
Estrutura Cabine / Cab Frame
Vidro Frente E Traseiro / Front Glass
Porta(Drt) / Door Rh
Porta(Esq) / Door Lh
Trinco Porta(Drt) / Door Lock Rh
Trinco Porta(Esq) / Door Lock Lh
Lado Vidro (Drt) / Side Window Rh
Lado Vidro (Esq) / Side Window Lh
Vidro Traseiro / Rear Window (Upper)
Espelho Rectrovisor / Rearview Mirror [Old]
Espelho Rectrovisor / Rearview Mirror [New]
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Piso / Floor Mat
Chapa Inspecção(Frente) / Inspection Plate
Cobertura Guarda Lamas(Drt) / Fender Cover Rh
Cobertura Gurada Lamas(Esq) / Fender Cover Lh
Guarda Lamas / Fender
Dianteira Do Suporte Da Cabine / Cab Bracket Fron T
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Cond Itioner
Tubo Ar Condicionado / Air Conditioner Duct
Tubo Aquecimento / Heater H Ose
Condesador / Condenser
Tubo Ar Condicionado/Tubo C Ondensador / Air Conditioner Hose / Condenser Hose
Compressor / Compressor
Mangueira De Drenagem / Dra In Hose
Etiqueta (Dianteira) / Label (Front )
Etiqueta 2 / Label (Cab Frame)
Etiqueta 2 / Label (Rear) [Ec] [Se]
Acessorios / Accessories And Service Parts
Kit Alternador [Opçao] / Alternator Kit (Altern Ator) [Option]
Alternador [Peças Componentes] [Opcao] / Altern Ator [Component Parts] [Option]
Saída Hidráulica Remota Dianteira (Fixador/Tubo ) [Opção] / Front Remote Hydraulic Outlet (Holder/P Ipe) [Option]
Saída Hidráulica Remota Dianteira (1ª Válvula) [Opção] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Saída Hidráulica Remota Dianteira (2ª Válvula) [Opção] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Kit Distribuidor Serviços Externos[Peças Compon Entes][Opcao] / Auxiliary Control Valve (Fc) [Compo Nent Parts] [Option]
Válvula De Controlo Auxiliar (Scd) [Peças Compo Nentes] [Opção] / Auxiliary Control Valve (Scd) [Co Mponent Parts] [Option] [Old]
Válvula De Controlo Auxiliar (Scd) [Peças Compo Nentes] [Opção] / Auxiliary Control Valve (Scd) [Co Mponent Parts] [Option] [New]
Saída Hidráulica Remota Dianteira (Tampa Da Vál Vula) [Opção] / Front Remote Hydraulic Outlet (Valv E Cover) [Option]
Saída Hidráulica Remota Dianteira (Alavanca De Controlo) [Opção] / Front Remote Hydraulic Outlet ( Control Lever) [Option]
Saída Hid. Remota Dianteira (1ª Válvula Alavanc A De Controlo) [Opção] / Front Remote Hyd. Outlet ( 1st Valve Control Lever) [Option]
Saída Hidráulica Remota Dianteira (2ª Válvula A Lavanca De Controlo) [Opção] / Front Remote Hyd. Ou Tlet (2nd Valve Control Lever) [Option]
Saída Hidráulica Remota Dianteira (Suporte De P Rotecção) [Opção] / Front Remote Hydraulic Outlet ( Cover) [Option]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Old] [Op Tion]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [New] [Op Tion]
Kit Valvula Travao Reboque 2[Peças Componentes] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Kit De Suporte Da Escora [Opção] / Drawbar Brac Ket Kit [Se] [Old] [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [ Se] [Option]
