Kubota Tractor M7040DTHNBC(NEC) Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M7040DTHNBC(NEC) Tractor
Number of Pages: 686 Pages
Frequently Used Items
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Unidad De La Bomba De Inyeccion / Injection Pump Unit
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Restriccion Que Ajusta El Perno / Restriction Adjusting Bolt
Agua Bomba / Water Pump
Valvula De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Pipa De Entrada / Inlet Pipe
Silenciador / Muffler
Aceite Tubo(Turbo Cargador) / Oil Pipe(Turbo Charger)
Acelerador Palanca / Hand Accelerator Lever
Deposito De Combustible Dcha / Fuel Tank Rh
Deposito De Combustible Izqd / Fuel Tank Lh
Combustible Tubo 1 (Deposito) [Ec] [Se] / Fuel Pipe 1 (Rear) [Ec] [Se]
Combustible Tubo 2 (Motor) / Fuel Pipe 2 (Front)
Separador / Separator
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Bateria [Antiguo] / Battery [Old]
Bateria [Nuevo] / Battery [New]
Conmutador/Sensor (Fronte) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) [Ec] [Se] / Switch/Sensor (Rear) [Ec] [Se]
Conmutador(Tablero De Instrumentos) / Switch (Panel Board)
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro / Working Light/Beacon Light
Trasero Combinacion Luz / Rear Combination Light
Licencia Lampara / License Lamp
Limpiador Delantero / Front Wiper
Electrico Cableado (Motor) [Ec] [Se] / Electrical Wiring (Engine) [Ec] [Se]
Electrico Cableado (Principal) [Ec] [Se] / Electrical Wiring (Main) [Ec] [Se]
Electrico Cableado (Cabina) / Electrical Wiring (Cab)
Transmision Caja [Ec] [Se] / Transmission Case [Ec] [Se]
Manguera Del Respiradero (Transmision Caja) / Breather Hose (Transmission Case)
Cubierta Trasera De Caja De Transmision [Se] / Transmission Case Rear Cover [Se]
Valvula Palanca(Embrague) / Valve Lever (Clutch)
Entrada Eje / Input Shaft
Inversor Embrague [Componente Piezas] / Shuttle Clutch [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje De Engranaje Diferencial [Ec] [Se] / Bevel Gear [Ec] [Se]
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Pto Embrague [Ec] [Se] [Antiguo] / Pto Clutch [Ec] [Se] [Old]
Pto Embrague [Ec] [Se] [Nuevo] / Pto Clutch [Ec] [Se] [New]
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula / Pto Clutch Valve
Pto Eje / Pto Shaft
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Pto Eje / Pto Shaft
Eje Propulsor Delantero(Posterior) / Front Propeller Shaft (Rear)
Gama Y Arrastramiento Engranaje Cambio Bifurcacion / Range And Creep Gear Shift Fork
Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Inversor Cambio Palanca / Shuttle Shift Lever
Inversor Cable / Shuttle Cable
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Varilla De Freno (Pedal De Freno) / Brake Rod (Brake Pedal)
Varilla De Freno (Leva De Freno) / Brake Rod (Brake Cam)
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Adelante Helice Eje / Front Propeller Shaft
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Direccion Controlador[Componente Piezas] [Antiguo] / Steering Controller [Component Parts] [Old]
Direccion Controlador[Componente Piezas] [Nuevo] / Steering Controller [Component Parts] [New]
Direccion Cilindro [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Direccion Cilindro [Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Hidraulico Tubo (Entrega) / Hydraulic Pipe (Delivery)
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Hidraulico Aceite Linea (Pto Embrague Valvula) / Hydraulic Oil Line (Pto Clutch Valve)
Latiguillo De Direccion(Impulsion) / Steering Hose (Delivery)
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Control Valvula [Antiguo] / Control Valve [Old]
Distribuidor [Nuevo] / Control Valve [New]
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Distribuidor De Servicios Externos [Se] [Antiguo] / Auxiliary Control Valve [Se] [Old]
Distribuidor De Servicios Externos [Se] [Nuevo] / Auxiliary Control Valve [Se] [New]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [New]
Valvula De Prioridad Del Flujo [Componente Piezas] / Flow Priority Valve [Component Parts]
Auxiliar Control Valvula Palanca (1r) / Auxiliary Control Valve Lever (1st)
Auxiliar Control Valvula Palanca (2do) / Auxiliary Control Valve Lever (2nd)
Cilindro De Ayuda De Elevacion Izquierdo [Se] [Antiguo] / 3p-Lift Assist Cylinder Lh [Se] [Old]
Cilindro De Ayuda De Elevacion Izquierdo [Se] [Nuevo] / 3p-Lift Assist Cylinder Lh [Se] [New]
Cilindro De Ayuda De Elevacion Derecho [Se] [Antiguo] / 3p-Lift Assist Cylinder Rh [Se] [Old]
Cilindro De Ayuda De Elevacion Derecho [Se] [Nuevo] / 3p-Lift Assist Cylinder Rh [Se] [New]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Antiguo] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Nuevo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Manguera Del Respiradero (Cilindro De Ayuda De Elevacion) / Breather Hose (3p Cylinder)
Parte Superior Vinculo [Antiguo] / Top Link [Old]
Parte Superior Vinculo [Nuevo] / Top Link [New]
Bajar Vinculo [Antiguo] / Lower Link [Old]
Bajar Vinculo [Nuevo] / Lower Link [New]
Estabilizador [Se] [Antiguo] / Stabilizer [Se] [Old]
Estabilizador [Antiguo] / Stabilizer [Old]
Estabilizador [Nuevo] / Stabilizer [New]
Varilla De Elevacion Dcha [Antiguo] / Lift Rod Rh [Old]
Varilla De Elevacion Dcha [Nuevo] / Lift Rod Rh [New]
Ascenso Varilla Izquierdo [Antiguo] / Lift Rod Lh [Old]
Ascenso Varilla Izquierdo [Nuevo] / Lift Rod Lh [New]
Ayudar Cilindro Soporte [Se] / Drawbar Bracket [Se]
Protector De Eje De Tdf [Se] / Pto Shaft Protector [Se]
Capo(Capo) Superior / Hood(Bonnet) Upper
Amortiguador De La Capo / Hood(Bonnet) Damper
Capo(Capo)Lado Cubierta / Hood(Bonnet) Side Cover
Capo Soporte / Bonnet Support
Cabina Bastidor / Cab Frame
Capo (Capo)Trasero / Hood (Bonnet) Rear
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana Derecho / Side Window Rh
Lado Ventana Izquierdo / Side Window Lh
Trasero Ventana (Superior) / Rear Window (Upper)
Espejo Retrovisor [Antiguo] / Rearview Mirror [Old]
Espejo Retrovisor [Nuevo] / Rearview Mirror [New]
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Inspeccion Placa / Inspection Plate
Guardabarros Cubierta Derecho / Fender Cover Rh
Cubierta De Guardabarros Izqd / Fender Cover Lh
Guardabarros / Fender
Herramienta Caja / Tool Box
Aire Acondicionador Conducto / Air Conditioner Duct
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito / Air Conditioner Hose / Condenser Hose
Compresor / Compressor
Vaciar Manguito / Drain Hose
Etiqueta (Trasero) / Label (Cab Frame)
Etiqueta (Trasero) [Ec] [Se] / Label (Rear) [Ec] [Se]
Kit De Alternador (Alternador) [Opcion] / Alternator Kit (Alternator) [Option]
Alternador[Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Adelante Control Remoto De Salida Hidraulica(Soporte/Tubo) [Opcion] / Front Remote Hydraulic Outlet (Holder/Pipe) [Option]
Adelante Control Remoto De Salida Hidraulica(1r Valvula) [Opcion] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Adelante Control Remoto De Salida Hidraulica(2do Valvula) [Opcion] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Distribuidor De Servicios Externos (Fc) [Comp. Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos (Scd) [Comp. Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd) [Comp. Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [New]
Adelante Control Remoto De Salida Hidraulica(Cubierta De La Valvula) [Opcion] / Front Remote Hydraulic Outlet (Valve Cover) [Option]
Adelante Control Remoto De Salida Hidraulica(Control Palanca) [Opcion] / Front Remote Hydraulic Outlet (Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica(1r Valvula Palanca De Control) [Opcion] / Front Remote Hyd. Outlet (1st Valve Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica(2do Valvula Palanca De Control) [Opcion] / Front Remote Hyd. Outlet (2nd Valve Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica (Cubierta) [Opcion] / Front Remote Hydraulic Outlet (Cover) [Option]
Kit De Remolque Freno Valvula 1 (Valvula/Tubo) [Antiguo] [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Old] [Option]
Kit De Remolque Freno Valvula 1 (Valvula/Tubo) [Nuevo] [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [New] [Option]
Kit De Remolque Freno Valvula 2 (Tubo) [Opcion] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Ayudar Cilindro Soporte [Se] [Antiguo] [Opcion] / Drawbar Bracket Kit [Se] [Old] [Option]
Protector De Eje De Tdf [Se] [Opcion] / Pto Shaft Protector Kit [Se] [Option]
Volante / Flywheel
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Pto Eje / Pto Shaft
Pto Eje / Pto Shaft
