Kubota Tractor M7040DTHNB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7040DTHNB Tractor
Number of Pages: 377 Pages
Bloco Motor / Crankcase [Old]
Bloco Motor / Crankcase [New]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve An D Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Piston E Cambota / Piston And Crankshaft # # Note:Order By Ref.No.050 And 180 New Parts. / Not E:Order By Ref.No.050 And 180 New Parts.
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Injeção / Injection Pump Unit
Veio / Fuel Camshaft
Alavanca Do Garfo (Governador) / Fork Leve R (Governor)
Parafuso De Ajuste De Restrição / Restric Tion Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Flange An D Thermostat
Acessorios / Water Pump
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleane R [Component Parts]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charge R)
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Componentes Electricos Motor / Engine Elec Trical Parts
Deposito Combustivel / Fue L Tank
Deposito Combustivel (Drt) / Fuel Tank Rh
Deposito Combustivel (Esq) / Fuel Tank Lh
Tubo Combustivel / Fuel Pi Pe 1 (Rear)
Tubo Combustivel / Fuel Pi Pe 2 (Front)
Separador / Separator
Separador[Peças Componente S] / Separator [Component Parts]
Ventilad Or / Fan
Radiador / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Component Es] / Starter [Component Parts]
Bateria / Battery [New] # # N.º De Série>=85054 S.No.;>=85054 / S.No.>=85054 S.No.;>=85054
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor / Swit Ch/Sensor (Front)
Interruptor / Switch (Pan El Board)
Interruptor / Rele / Rela Y
Painel / Panel Board
Farol Dianteiro / Head Li Ght
Farol Frente[Peças Compon Entes] / Head Light [Component Parts]
Luzes Frontais / Front Co Mbination Light
Braco Traseiro / Rear Com Bination Light
Ficha Reboque / Trailer S Ocket
Cablagem Eletrcia (Frente ) / Electrical Wiring (Front) [Ec] [Se]
Cablagem Electrica / Elec Trical Wiring (Rear) [Ec] [Se]
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cove R
Caixa Velocidades / Transmission Case [Ec] [Se]
Mangueira De Respi Ro (Caixa Velocidades) / Breather Hose (Transmissio N Case)
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damper Disk
Bloqueio Diferenci Al / Clutch Pedal
Valvula (Inversor) / Valve Lever (Clutch/Shuttle)
Veio Primario / In Put Shaft
Embraiagem Inverso R [Peças Componentes] / Shuttle Clutch [Component Parts]
Veio Inversor / Sh Uttle Shaft
Primeiro Veio / Fi Rst Shaft
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Grupo Conico / Bev El Gear [Ec] [Se]
Diferencial Trasei Ro / Differential Rear
Veio Tdf / Pto Pro Peller Shaft
Embraiagem Tdf / P To Clutch [Ec] [Se] [Old]
Embraiagem Tdf / P To Clutch [Ec] [Se] [New]
Embraiagem Tdf[Peç As Componentes] / Pto Clutch [Component Parts] [Old ]
Embraiagem Tdf[Peç As Componentes] / Pto Clutch [Component Parts] [New ]
Valvula Embraiagem Tdf / Pto Clutch Valve
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Veio Embraiagem[Pe Ças Componentes] / Front Drive Clutch [Component Pa Rts]
Veio Primario (Tra Seira) / Front Propeller Shaft (Rear)
Forque Ta / Main Gear Shift Fork
Forque Ta Caixa / Creeper / Range And Creep Gear Shift For K
Alavan Ca / Rear Differential Lock Shift Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Main G Ear Shift Cable / Main Gear Shift Cable
Alvanc A Inversor / Shuttle Shift Lever
Cabo I Nversor / Shuttle Cable
Alavan Ca Velocidades / Range Gear Shift Lever
Alavan Ca Tdf / Pto Gear Shift Lever
Pedal Bloqueio Diferenc Ial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Ax Le
Travão Direita / Brake Rh
Travão Esquerda / Brake Lh
Tirante Travao / Brake Rod
Alavanca Travao Mao / P Arking Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Travao Princip Al / Brake Master Cylinder
Cilindro Travao Princip Al[Peças Componentes] / Brake Master Cylinder [Comp Onent Parts]
Tubo Travao / Brake Pip E
Tubo Travao / Brake Mas Ter Cylinder Pipe
Suporte Eixo Diantei Ro / Front Axle Bracket
Veio Frontal / Front Propeller Shaft
Caixa Diferencial Di Anteiro / Front Differential Case
Engrenagem Cónica (D Ianteira) / Bevel Gear (Front)
Diferencial Dianteir O / Differential Front
Caixas Engrenagens C Onica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens C Onica(Esq) / Bevel Gear Case Lh
Carter Eixo Frente(D Rt) / Front Axle Case Rh
Carter Eixo Frente(E Sq) / Front Axle Case Lh
Carreto Diferencial( Drt) / Differential Gear Shaft Rh
Carreto Diferencial( Esq) / Differential Gear Shaft Lh
Eixo Frente (Drt) / Front Axle Rh
Eixo Dianteiro / Fro Nt Axle Lh
Direcção Assistida / Direção Punho / Steeri Ng Handle
Alavanca / Tilt Lever
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts]
Direcção Assistida / Tie Rod/Steering Cylin Der
Cilindro Direccao [Peças Componentes(Antiga ) / Steering Cylinder [Component Parts] [Old]
Cilindro Direccao [Peças Componentes(Nova) / Steering Cylinder [Component Parts] [New]
Bomba Hidraulico[Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic Pip E (Delivery)
Radiador Oleo / Oil Coole R
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Oleo (Valvula Embrai Agem Tdf) / Hydraulic Oil Line (Pto Clutch Valve)
Tubo Direccao / Steering Hose (Delivery)
Caixa Hidraulico / Hydrau Lic Cylinder Case
Braço De Elevação Hidrául Ico / Hydraulic Lift Arm
Valvula Segurança / Safet Y Valve/Relief Valve
Trinco / Lowering Lock Le Ver
Valvula Control / Control Valve [Old]
Valvula Control / Control Valve [New]
Acessorios / Draft And Po Sition Control Lever
Veio Posicao Esforço / Po Sition And Draft Shaft [Old]
Veio Posicao Esforço / Po Sition And Draft Shaft [New]
Alavanca / Feed Back Leve R
Distribuidor Auxiliar / A Uxiliary Control Valve [Se] [Old]
Distribuidor Auxiliar / A Uxiliary Control Valve [Se] [New]
Valvula Auxiliar [Peças C Omponentes] / Auxiliary Control Valve (Fd) [Compone Nt Parts] [Old]
Valvula Auxiliar [Peças C Omponentes] / Auxiliary Control Valve (Scd) [Compon Ent Parts] [New]
Valvula Auxiliar [Peças C Omponentes] / Auxiliary Control Valve (S/D) [Compon Ent Parts]
Flow Priority Valve [Comp Onent Parts] [Old] / Flow Priority Valve [Component Parts] [Old]
Alavanca Valvula Auxiliar / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Elev Ação Esq / 3p-Lift Assist Cylinder Lh [Se] [Old]
Cilindro Auxiliar De Elev Ação Esq (Antigo) / 3p-Lift Assist Cylinder Lh [Se] [New]
Cilindro Auxiliar De Elev Ação Drt / 3p-Lift Assist Cylinder Rh [Se] [Old]
Cilindro Auxiliar De Elev Ação Drt (Antigo) / 3p-Lift Assist Cylinder Rh [Se] [New]
Cilindro Auxiliar De Elev Acao[Peças Componentes] / 3p-Lift Assist Cylinder [ Component Parts] [Old]
Cilindro Auxiliar De Elev Acao[Peças Componentes] / 3p-Lift Assist Cylinder [ Component Parts] [New]
Part E Superior / Top Link Bracket
3-Po Nt Acoplamento (Ligacao Superior) / Top Link [Old]
3-Po Nt Acoplamento (Ligacao Superior) / Top Link [New]
Esta Bilizador / Stabilizer [Se] [Old]
Esta Bilizador / Stabilizer [Se] [New]
Esta Bilizador(Drt) / Lift Rod Rh [Old]
Esta Bilizador(Drt) / Lift Rod Rh [New]
Esta Bilizador(Esq) / Lift Rod Lh [New]
Barr A / Drawbar Bracket [Se]
Prot Eccao Tdf / Pto Shaft Protector [Se]
Grelha Frontal / Front Grille
Capot Superior / Isolador / Hood (Bonnet) U Pper (Sound Absorber/Insulator) [Old]
Capot Superior / Isolador / Hood (Bonnet) U Pper (Sound Absorber/Insulator) [New]
Trico Capot / Bonnet Lock
Protecção / Shield
Capot Traseiro / Hood (Bonnet) Rear (Sound Absorber)
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Degrau Superior Resguardo / Step Upper Cove R
Degrau / Step Mat/Sound Absorber
Degrau Auxiliar / Auxiliary Step
Banco / Seat Bracket [Ec] [Se]
Caixa Ferramenta / Tool Box
Arco Segura Nca / Rops 1 (Mid)
Arco Segura Nca Traseiro / Rops 2 (Rear)
Etiqueta 1 / Label (Front)
Etiqueta 2 / Label (Panel)
Etiqueta 3 / Label (Rear) [Ec] [Se]
Acessorios / Accessories And Service P Arts
Kit Alternador [Opçao] / Alternator Kit 1 (Alter Nator) [Option]
Kit Alternador [Opçao] / Alternator Kit 2 (Wire Harness) [Option]
Alternador [Peças Componentes] [Opcao] / Alterna Tor [Component Parts] [Option]
Saída Hidráulica Remota Dianteira (Fixador/Tubo) [Opção] / Front Remote Hydraulic Outlet (Holder/Pi Pe) [Option]
Saída Hidráulica Remota Dianteira (1ª Válvula) [ Opção] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Saída Hidráulica Remota Dianteira (2ª Válvula) [ Opção] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Kit Distribuidor Serviços Externos[Peças Compone Ntes][Opcao] / Front Remote Hydraulic Outlet (Fc) [ Component Parts] [Option]
Válvula De Controlo Auxiliar (Scd) [Peças Compon Entes] [Opção] / Front Remote Hydraulic Outlet (Scd ) [Component Parts] [Option] [New]
Saída Hidráulica Remota Dianteira (Tampa Da Válv Ula) [Opção] / Front Remote Hydraulic Outlet (Valve Cover) [Option]
Saída Hidráulica Remota Dianteira (Alavanca De C Ontrolo) [Opção] / Front Remote Hydraulic Outlet (C Ontrol Lever) [Option]
Saída Hid. Remota Dianteira (1ª Válvula Alavanca De Controlo) [Opção] / Front Remote Hydraulic Outl Et (1st Valve Control Lever) [Option]
Saída Hidráulica Remota Dianteira (2ª Válvula Al Avanca De Controlo) [Opção] / Front Remote Hydrauli C Outlet (2nd Valve Control Lever) [Option]
Saída Hidráulica Remota Dianteira (Suporte De Pr Otecção) [Opção] / Front Remote Hydraulic Outlet (G Uard Bracket) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3 Rd) [Option]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Kit Valvula Travao Reboque 2[Peças Componentes] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Kit Valvula Travao Reboque 3[Peças Componentes] / Trailer Brake Valve Kit 3 (Cover) [Option]
Drawbar Bracket Kit [Se] [Option] [Old] / Drawba R Bracket Kit [Se] [Option] [Old]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [S E] [Option] [Old]
Step Support Kit [Option] [Old] / Step Support K It [Option] [Old]
