Kubota Tractor M7040DTHNB-NEC Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M7040DTHNB-NEC Tractor
Number of Pages: 685 Pages
NEC Engine 300001 Engine Block Old Crankcase Old Chassis No. 8crz999 S.No. 8crz999 P.
NEC Engine 300002 Engine Block New Crankcase New Chassis No. 8cs0001 S.No. 8cs0001 S.
Engine 301000 Oil Pan
Cylinder Head Not 030 And Fig.No.303000 Ref.No.110 Note
Engine 303000 Inlet And Exhaust Valve Valve Inlet Valve And Exhaust
Engine 304000 Rocker Arm Shaft
Engine 305000 Head Cover
Engine 310000 Front Cover
Engine 311000 Piston And Crankshaft Not 050 And 180
Engine 312000 Camshaft And Idle Gear
Engine 313000 Balancer
Engine 315002 Flywheel
Pump Unit Injection Pump Unit Note Injection Pump Kit Components Fig.No.321000 Dan 325000
Injection Pump Not 010 And Fig.No.322000 Ref.No.015,070 Note
Engine 322000 Fuel Camshaft
Governor Not 050 And Fig.No.324000 Ref.No.060 Note Order
Engine 324000 Fork Lever (Governor)
Engine 325000 Restriction Adjusting Bolt Restriction Adjusting Bolt
Engine 331000 Fuel Filter
Engine 340000 Nozzle Holder And Glow
Engine 345000 Injection Pipe
Engine 360000 Thermostat Water Flange And Thermostat
Engine 361000 Water Pump
Inlet Manifold Note 010 And Fig.No.372200 Ref.No.110 Note
Engine 372000 Exhaust Manifold
Engine 372200 EGR Valve EGR Cooler EGR Valve
Engine 372300 EGR Cooler
Engine 372500 EGR Water Pipe EGR Water Piping
Engine 372600 Turbocharger Turbo Charger
Engine 373002 Air Cleaner
Engine 373500 Air Cleaner Component Parts
Engine 374500 Inlet Pipe (Air Cleaner) Inlet Pipe
Engine 375000 Muffler
Engine 380000 Oil Pipe (Turbo Charger)
Engine 382000 Oil Cooler
Engine 391000 Upper Gasket Kit
Engine 392000 Lower Gasket Kit
Engine 395000 Engine Electrical Parts Engine Electrical Parts
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11000 Fuel Tank
Fuel System A12000 Fuel Tank (Right Side) Fuel Tank Rh
A13000 Fuel Tank (Left Side) Fuel Tank Lh Note 030 And Fig.No.A13000 Ref.No.110
Fuel System A14100 Fuel Pipe 1 (Rear) Fuel Pipe 1 (Rear)
Fuel System A14200 Fuel Pipe 2 (Front) Fuel Pipe 2 (Front)
Fuel System A15100 Separator
Fuel System A16100 Separator Component Parts Separator
Cooling Water System A41000 Fan
Cooling Water System A42000 Water Pipe Water
Cooling Water System A43000 Radiator
Cooling Water System A45000 Reserve Tank Reserve
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts Starter
NEC Electrical System A58001 Battery Old Battery Old Chassis No. 85053 S.No. 85053
NEC Electrical System A58002 Battery New Battery New Chassis No. 85054 S.No. 85054
Electrical System B00100 Switch Sensor (Engine) Switch Sensor
Electrical System B02000 Switch Sensor (Front)
Electrical System B03001 Switch Sensor (Rear) EC Se Switch Sensor
Dashboard) Switch (Panel Board) Note 030 New Part & Fig.No.M15500 Ref.No.100
Electrical System B13002 Relay
Electrical System B14000 Dashboard Panel Board
Electrical System B32000 Outdoor Lighting Head Light
Electrical System B32100 Outdoor Lighting Component Parts Head Light
Electrical System B33900 Front Combination Headlight
Electrical System B36000 Rear Combination Headlight
Electrical System B36500 License Lamp
Electrical System B37002 Trailer Socket
Electrical System B50502 Electrical Cables (Front) EC Se Electrical
Electrical System B51002 Electrical Cables (Rear) EC Se Electrical
Clutch Gear Clutch Transmission C11000 Clutch Housing
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle
Clutch Gear Clutch Transmission C12500 Shift Cover
Clutch Gear Clutch Transmission C14001 Transmission Box EC Se Transmission
Clutch Gear Clutch Transmission C14200 Ventilation Hose (Ventilation Hose)
Clutch Gear Clutch Transmission C15002 Gear Housing Rear Cover Se Transmission
Clutch Gear Clutch Transmission C17000 Rear Axle Housing Rear Axle
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C26500 Valve Lever (Clutch Transmission) Valve Lever
Clutch Gear Clutch Transmission D21500 Input Shaft
NEC Clutch Gear Clutch Transmission D21600 Transmission Clutch Component Parts Shuttle
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23500 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Clutch Gear Clutch Transmission D26001 Bevel Gear Shaft EC Se Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Gear Clutch Transmission D26601 PTO Clutch EC Se Old PTO Clutch EC Se Old Chassis No.
Gear Clutch Transmission D26602 PTO Clutch EC Se New PTO Clutch EC Se New Chassis No.
Clutch Transmission D26701 PTO Clutch Component Parts Old PTO Clutch Component Parts Old
Clutch Transmission D26702 PTO Clutch Component Parts New PTO Clutch Component Parts New
Clutch Gear Clutch Transmission D26802 PTO Clutch Valve PTO Clutch
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
NEC Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Clutch Gear Clutch Transmission D35500 Propeller Shaft (Rear) Front Propeller
Speed Change Shift Fork D41000 Main Transmission
Speed Change Shift Fork D44500 Gear And Creep Range
Speed Change Shift Fork D47000 Differential Lock
Gear Speed Change Shift Fork F11000 Main Gear
Gear Speed Change Shift Fork F11600 Main
Speed Change Shift Fork F12500 Transmission
NEC Vİtes Speed Change Shift Fork F13300
Speed Change Shift Fork F13500 Gear Range
Gear Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20600 Brake (Right Side) Brake Rh
Rear Axle Brake F20700 Brake (Left Side) Brake Lh
Rear Axle Brake F21100 Brake Rod
Rear Axle Brake F22000 Parking Brake Lever Parking Brake
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master
NEC Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33000 Brake Pipe Brake Pipe
Rear Axle Brake F33500 Brake Master Cylinder Pipe Brake Master
Front Axle Chassis G10500 Front Axle Frame Front Axle
Front Axle Chassis G11000 Front Axle Body Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Front Axle Chassis G15000 Front Differential Housing Front
Front Axle Chassis G16000 Bevel Gear (Front) Bevel Gear
Front Axle Chassis G17000 Front Differential Differential
Front Axle Chassis G22100 Bevel Gear Housing (Right Side)
Front Axle Chassis G22200 Bevel Gear Housing (Left Side)
Front Axle Chassis G22300 Front Axle Housing (Right Side) Front Axle
Front Axle Chassis G22400 Front Axle Housing (Left Side) Front Axle
NEC Front Axle Chassis G22800 Differential Transmission Shaft (Right Side)
NEC Front Axle Chassis G22900 Differential Transmission Shaft (Left Side)
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle
Steering H11000 Steering Handle
Steering H12300 Tilt Lever
Steering H13000 Steering Joint Steering Joint
Steering H14000 Steering Control Steering Controller
Steering H15000 Steering Control Component Parts Steering Controller
Steering H16000 Steering Cylinder Tie Rod Steering
H16501 Steering Cylinder Component Parts Old Steering Cylinder Component Parts Old
H16502 Steering Cylinder Component Parts New Steering Cylinder Component Parts New
Hydraulic System J13000 Hydraulic Pump
NEC Hydraulic System J13500 Hydraulic Pump Component Parts
Hydraulic System J22000 Hydraulic Oil Line (Feed)
Hydraulic System J26500 Oil Cooler
Hydraulic System J27500 Hydraulic Pipe (Direction PTO) Hydraulic Oil Line
Hydraulic System J27600 Hydraulic Pipe (Shuttle PTO) Hydraulic Oil Line
NEC Hydraulic System J27900 Hydraulic Pipe (Pto Clutch Valve) Hydraulic Oil
Hydraulic System J28000 Steering Hose (Delivery) Steering
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Lifting Arm Hydraulic Lift
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32300 Lowering Adjustment Valve Lowering Lock
Hydraulic System J35501 Control Valve Old Control Valve Old Chassis No. 96105 S.
Hydraulic System J35502 Control Valve New Control Valve New Chassis No. 96106 S.
Hydraulic System J38000 Draft And Position Control Lever Position
Hydraulic System J38201 Position And Draft Shaft Old Position And Draft Shaft Old Chassis No.
Hydraulic System J38202 Position And Draft Shaft New Chassis No.
Hydraulic System J39200 Feed Back Lever
Hydraulic System J44508 Remote Control Valve Se Old Auxiliary Control Valve Se Old Chassis
Hydraulic System J44509 Remote Control Valve Se New Auxiliary Control Valve Se New Chassis
J44701 Remote Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component Parts
J44703 Remote Control Valve (SCD) Component Parts New Auxiliary Control Valve (SCD) Component
Hydraulic System J44704 Remote Control Valve (S D) Component Parts Auxiliary
System J44900 Flow Priority Valve Component Parts Old Flow Priority Valve Component Parts
NEC Hydraulic System J45400 Support Control Valve Lever (First) Auxiliary
NEC Hydraulic System J45500 Support Control Valve Lever (Second) Auxiliary
3p-Left Lift Assist Cylinder Se Old 3p-Lift Assist Cylinder Lh Se Old Chassis No. 94762 Note Order
Hydraulic System J47104 3p-Left Lift Assist Cylinder Se New 3p-Lift Assist Cylinder Lh Se New
3p-Right Lift Assist Cylinder Se Old 3p-Lift Assist Cylinder Rh Se Old Chassis No. 94762 Note Order
Hydraulic System J47204 3p-Right Lift Support Cylinder Se New 3p-Lift Assist Cylinder Rh Se New
System J47301 3p-Lift Support Cylinder Component Parts Old 3p-Lift Assist Cylinder Component
System J47302 3p-Lift Support Cylinder Component Parts New 3p-Lift Assist Cylinder Component
NEC Hydraulic System J47500 Ventilation Hose (3 Point Cylinder) Breather
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Top Link Bracket
Bar Connection 3-Point Linkage Drawbar Hitch K11001 3 Point Tie (Upper Tie) Old Top Link Old
Connection 3-Point Linkage Drawbar Hitch K11002 3 Point Tie (Upper Tie) Old Top Link Old Chassis No.95180
Bar Connection 3-Point Linkage Drawbar Hitch K11003 3 Point Tie (Upper Tie) New Top Link New
Bağ Drawing Bar Connection 3-Point Linkage Drawbar Hitch K12501 Lower Link Old Chassis
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K12502 Lower Link New Chassis
Linkage Drawbar Hitch K13304 Stabilizer Se Old Stabilizer Se Old Chassis No. 83470 Note Order
Linkage Drawbar Hitch K13305 Stabilizer Se Old Stabilizer Se Old Chassis No.83471 To 89175 Note Order
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K13306 Stabilizer Se New Stabilizer Se New
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K14001 Right Draw Shaft Old Lift Rod Rh Old Chassis
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K14002 Right Draw Shaft New Lift Rod Rh New Chassis
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K14301 Left Draw Shaft Old Lift Rod Lh Old Chassis
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K14302 Left Draw Shaft New Lift Rod Lh New Chassis
Connection 3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket Se Drawbar Bracket Se Not Order
NEC 3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17003 PTO Protective Se
Hood Bonnet M11000 Front Grille
Hood Bonnet M12000 Hood (Bonnet) Upper
M12101 Bone Hood (Sound Absorber Damper Material) Old Hood (Bonnet) Upper (Sound Absorber Insulator)
M12102 Bone Hood (Sound Absorber Damper Material) New Hood (Bonnet) Upper (Sound Absorber Insulator)
Hood Bonnet M12300 Hood (Bonnet) Damper
Hood Bonnet M12400 Bone Lock Bonnet Lock
Hood Bonnet M12700 Bone Side Cover Hood (Bonnet) Side Cover
Hood Bonnet M14000 Bone Support Bonnet Support
Hood Bonnet M14300 Shield Shield
Hood (Bone) Rear Hood (Bonnet) Rear Not 020 And Fig.No.B10500 Ref.No.030
NEC Hood Bonnet M17500 Hood (Bonnet) Rear (Sound Absorbing Damper Material) Hood (Bonnet)
Hood Bonnet M18000 Rearview Mirror
Hood Bonnet M22000 Fender
Hood Bonnet M22300 Floor Sheet
Hood Bonnet M23100 Step
Hood Bonnet M23200 Step Upper Cover
Hood Bonnet M23300 Step Mat Sound Absorber Step Mat Sound Absorber
Hood Bonnet M23400 Auxiliary Step Auxiliary Step
Hood Bonnet M23501 Seat Bracket EC Se Seat Bracket EC Se
Hood Bonnet M27000 Tool Box
ROPS M31100 ROPS 1 (Middle) ROPS 1 (Mid)
ROPS M31200 ROPS 2 (Rear) ROPS 2 (Rear)
Labels S12000 Label (Front)
Labels S13000 Label (Panel) Label (Panel)
Labels S14001 Label (Back) EC Se Label (Rear) EC Se
Accessories Service Parts Accessories T11000 Accessories Service Parts Accessories
Option U11000 Alternator Kit 1 (Alternator) Option Alternator Kit 1 (
Option U11100 Alternator Kit 2 (Wire Harness) Option Alternator Kit 2 (Wire
Option U11300 Alternator Component Parts Option Alternator Component
Option U68000 Front Support Control Valve Kit (Holder Tube) Option Front Remote Hydraulic
Option U68300 Front Support Control Valve Kit (First Valve) Option Front Remote Hydraulic
Option U68400 Front Support Control Valve Kit (Second Valve) Option Front Remote Hydraulic
Option U68500 Front Support Control Valve Kit (FC) Component Parts Option Front Remote Hydraulic
Control Valve Kit (SCD) Component Parts Option Old Front Remote Hydraulic Outlet (SCD) Component
Control Valve Kit (SCD) Component Parts Option New Front Remote Hydraulic Outlet (SCD) Component
Option U68700 Front Support Control Valve Kit (Valve Cover) Option Front Remote Hydraulic
Option U68800 Front Support Control Valve Kit (Control Lever) Option Front Remote Hydraulic
Option U69000 Front Support Control Valve Kit (First Valve Control Lever) Option Front Remote Hydraulic
Option U69200 Front Support Control Valve Kit (Second Valve Control Lever) Option Front Remote Hydraulic
Option U69500 Front Support Control Valve Kit (Housing Bracket) Option Front Remote Hydraulic
NEC Option U71000 Support Control Valve Lever (3rd) Option Auxiliary Control Valve
NEC Option U75000 Trailer Brake Valve Kit 1 (Valve Pipe) Option Trailer Brake Valve
Option U75100 Trailer Brake Valve Kit 2 (Pipe) Option Trailer Brake Valve
Option U75200 Trailer Brake Valve Kit 3 (Cover) Option Trailer Brake Valve Kit
Option U87502 Drawbar Bracket Kit Se Option Old Drawbar Bracket Kit Se Option Old Chassis
U88800 PTO Shaft Protector Kit Se Option Old PTO Shaft Protector Kit Se Option Old Chassis
Option U90500 Step Support Kit Option Old Step Support Kit Option Old Chassis No. 81906 S.
Region: Turkey
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
