Kubota Tractor M7040DTHC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7040DTHC Tractor
Number of Pages: 421 Pages
Bloco Motor / Crankcase [Old]
Bloco Motor / Crankcase [New]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gea R Shaft
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Injeção / Injection Pump Unit
Veio / Fuel Camshaft
Alavanca Do Garfo (Governador) / Fork Lever (Governor)
Parafuso De Ajuste De Restrição / Restrict Ion Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Acessorios / Water Pump
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger )
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Componentes Electricos Motor / Engine Elect Rical Parts
Fornecimento Combustivel / Fuel Filler
Tubo Combustivel / Fuel Pip E
Sedimenter [Old] / Sediment Er [Old]
Separador / Separator [New]
Separador[Peças Componentes ] / Sedimenter [Component Parts] [Old]
Separador[Peças Componentes ] / Separator [Component Parts] [New]
Ventilado R / Fan
Radiador / Water Pipe
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componente S] / Starter [Component Parts]
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor / Switc H/Sensor (Front)
Interruptor/Sensor / Switc H/Sensor (Rear) [Ec] [Se] [Tur]
Interruptor/Sensor / Switc H/Sensor (Rear) [Ita] [Tur]
Interruptor / Switch (Pane L Board)
Interruptor / Switch (Ligh T/Panel)
Interruptor / Rele / Relay
Painel / Panel Board
Luzes Frente / Head Light [Ec] [Se] [Ita] [Tur]
Farol Frente[Peças Compone Ntes] / Head Light [Component Parts] [Ec] [Se] [Ita ] [Tur]
Luzes Frontais / Front Com Bination Light
Luzes Trabalho / Working L Ight/Beacon Light [Ec] [Se] [Ita] [Tur]
Braco Traseiro / Rear Comb Ination Light
Ficha Reboque / Trailer So Cket
Luz Interior / Room Light
Alta Voz Radio / Radio Spe Aker [Ec] [Se] [Ita] [Tur]
Depósito De Lavagem / Wash Er Tank
Escova Limpa Vidro Frontal / Front Wiper
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Electrica / Elect Rical Wiring (Main) [Ec] [Se] [Tur] [Old]
Cablagem Electrica / Elect Rical Wiring (Main) [Ec] [Se] [Tur] [New]
Cablagem Electrica / Elect Rical Wiring (Main) [Ita] [Tur]
Cabalagem Eletrica(Cabine) [Ec] [G] / Electrical Wiring (Cab) [Ec] [Se] [Ita] [Tur]
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Caixa Velocidades / Transmission Case [Ec] [Uk] [Se] [Tur]
Caixa Velocidades / Transmission Case [Ita] [Tur]
Carter Transmissao / Transmission Case Rear Cover [Ec] [Uk] [Ita] [Tur ]
Carter Transmissao / Transmission Case Rear Cover [Se] [Tur]
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damper Disk
Bloqueio Diferencia L / Clutch Pedal
Cabo Embraiagem / C Lutch Cable
Valvula (Inversor) / Valve Lever (Clutch/Shuttle)
Veio Primario / Inp Ut Shaft
Embraiagem Inversor [Peças Componentes] / Shuttle Clutch [Component Pa Rts]
Veio Inversor / Shu Ttle Shaft
Primeiro Veio / Fir St Shaft
Secundario Veio / S Econd Shaft
Terceiro Veio / Thi Rd Shaft
Grupo Conico / Beve L Gear [Ec] [Se] [Tur]
Grupo Conico / Beve L Gear [G-Pto] [Ita] [Tur]
Diferencial Traseir O / Differential Rear
Veio Tdf / Pto Prop Eller Shaft
Embraiagem Tdf / Pt O Clutch [Ec] [Se] [Tur]
Embraiagem Tdf / Pt O Clutch [G-Pto] [Ita] [Tur]
Embraiagem Tdf[Peça S Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Veio Tdf / Pto Shaf T
Embraiagem Andament O / Front Drive Clutch
Veio Embraiagem[Peç As Componentes] / Front Drive Clutch [Component Par Ts]
Veio Primario (Tras Eira) / Front Propeller Shaft (Rear)
Forquet A / Main Gear Shift Fork
Forquet A Caixa / Creeper / Range Gear Shift Fork/Creep Gea R Shift Fork
Forquil Ha Tdf / Ground Pto Shift Fork [G-Pto] [Ita] [Tur]
Alavanc A / Rear Differential Lock Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Princip Al De Transmissão Eixo Da Alavanca / Main Gear Shif T Lever Shaft
Cabo In Versor / Shuttle Cable
Alavanc A Velocidades / Range Gear Shift Lever
Alavanc A Tdf / Pto Gear Shift Lever
Alavanc A / Ground Pto Shift Lever [Ita] [Tur]
Eixo Traseiro / Rear Axl E
Travão Direita / Brake R H
Travão Esquerda / Brake Lh
Alavanca Travao Mao / Pa Rking Brake Lever
Pedal Travao / Brake Ped Al
Cilindro Travao Principa L / Brake Master Cylinder
Cilindro Travao Principa L[Peças Componentes] / Brake Master Cylinder [Compo Nent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteir O / Front Axle Bracket
Veio Frontal / Propel Ler Shaft
Caixa Diferencial Dia Nteiro / Front Differential Case
Engrenagem Cónica (Di Anteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Caixas Engrenagens Co Nica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Co Nica(Esq) / Bevel Gear Case Lh
Carter Eixo Frente(Dr T) / Front Axle Case Rh
Carter Eixo Frente(Es Q) / Front Axle Case Lh
Carreto Diferencial(D Rt) / Differential Gear Shaft Rh
Eixo Frente (Drt) / F Ront Axle Rh
Eixo Dianteiro / Fron T Axle Lh
Direcção Assistida / Direção Punho / Steerin G Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / S Teering Controller [Component Parts]
Direcção Assistida / Tie Rod/Steering Cylind Er
Cilindro Direcção[Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico[Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic Pipe (Delivery) [Old]
Tubo Oleo / Hydraulic Pipe (Delivery) [New]
Circuito Oleo Direcção / H Ydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao / Steering H Ose (Delivery)
Tubo Valvula Solenoide / S Olenoid Valve Pipe
Caixa Hidraulico / Hydraul Ic Cylinder Case
Braço De Elevação Hidráuli Co / Hydraulic Lift Arm
Valvula Segurança / Safety Valve/Relief Valve
Trinco / Lowering Lock Lev Er
Braco Hidraulico / Control Valve
Alavanca Control Posicao / Position Control Lever
Acessorios / Draft And Pos Ition Control Lever
Puxar E Posicionar Suporte De Alavanca De Controlo / Draft And Position Contr Ol Lever Bracket
Veio Posicao Esforço / Pos Ition And Draft Shaft [Old]
Veio Posicao Esforço / Pos Ition And Draft Shaft [New]
Alavanca / Feed Back Lever
Distribuidor Auxiliar [Ec] [Uk] [Ita] / Auxiliary Control Valve [Ec] [Uk] [It A] [Tur]
Distribuidor Auxiliar [Se] / Auxiliary Control Valve [Se] [Tur]
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (Fd) [Componen T Parts][Old]
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (Fd) [Componen T Parts][New]
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (S/D) [Compone Nt Parts]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Cilindro Auxiliar De Eleva Cao(Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Eleva Cao(Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Eleva Cao[Peças Componentes] / 3p-Lift Assist Cylinder [C Omponent Parts]
Parte Superior / Top Link Bracket
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Estab Ilizador / Stabilizer
Estab Ilizador(Drt) / Lift Rod Rh
Estab Ilizador(Esq) / Lift Rod Lh
Barra / Drawbar Bracket [Se] [Tur]
Prote Ccao Tdf / Pto Shaft Protector [Ec] [Uk] [Ita] [Tur ]
Prote Ccao Tdf / Pto Shaft Protector [Se] [Tur]
Trico Capot / Bonnet Lock
Estrutura Cabine [Ec] [Uk] [Se] / Cab Frame [Ec] [U K] [Se] [Tur]
Estrutura Cabine [Ita] / Cab Frame [Ita] [Tur]
Vidro Frente E Traseiro / Front Glass
Porta(Drt) / Door Rh
Porta(Esq) / Door Lh
Trinco Porta(Drt) / Door Lock Rh
Trinco Porta(Esq) / Door Lock Lh
Lado Vidro / Side Window
Vidro Traseiro / Rear Window (Upper)
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Banco / Seat [Se] [Ita] [Tur]
Piso / Floor Mat [Old]
Piso / Floor Mat [New]
Chapa Inspecção(Frente) / Inspection Plate [Ec]
Chapa Inspecção(Frente) / Inspection Plate [Se] [Tu R]
Chapa Inspecção(Frente) / Inspection Plate [Ita] [T Ur]
Isolante / Soundproof Material [Ec] [Se] [Tur]
Isolante / Soundproof Material [G-Pto] [Ita] [Tur]
Cobertura Guarda Lamas(Drt) / Fender Cover Rh
Cobertura Gurada Lamas(Esq) / Fender Cover Lh
Guarda Lamas / Fender
Dianteira Do Suporte Da Cabine / Cab Bracket Front
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Condit Ioner
Tubo Ar Condicionado / Air Co Nditioner Duct
Modo Caixa / Mode Case
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Circulaçao Ar Interior / Inne R Air Recirculation
Tubo Aquecimento / Heater Hos E
Condesador / Condenser
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose [Old ]
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose [New ]
Compressor / Compressor
Etiqueta (Dianteira) / Label (Front)
Etiqueta 2 / Label (Rear) [Ec] [Se] [ Tur]
Etiqueta 2 / Label (Rear) [G-Pro] [It A] [Tur]
Acessorios / Accessories And Service Pa Rts
Kit Alternador [Opçao] / Alternator Kit [Option]
Alternador [Peças Componentes] [Opcao] / Alternat Or [Component Parts] [Option]
Kit Limpa Vidro Traseiros (Opcao) / Rear Wiper Ki T [Option]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Kit Valvula Travao Reboque 2[Peças Componentes] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [Se ] [Tur] [Option]
Escpae / Muffler
Ventilado R / Fan
Tampa / Shift Cover
