Kubota Tractor M7040DTH Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M7040DTH Tractor
Number of Pages: 576 Pages
Bloque Motor [Antiguo] / Crankcase [Old]
Bloque Motor [Nuevo] / Crankcase [New]
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Unidad De La Bomba De Inyeccion / Injection Pump Unit
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Restriccion Que Ajusta El Perno / Restriction Adjusting Bolt
Agua Bomba / Water Pump
Valvula De Egr Y Refrigerador De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Pipa De Entrada / Inlet Pipe
Silenciador / Muffler
Piezas Electricas Del Motor / Engine Electrical Parts
Acelerador Palanca / Hand Accelerator Lever
Llenador Del Combustible / Fuel Filler
Sedimentario [Antiguo] / Sedimenter [Old]
Separador [Nuevo] / Separator [New]
Sedimentario [Componente Piezas] [Antiguo] / Sedimenter [Component Parts] [Old]
Separador [Componente Piezas] [Nuevo] / Separator [Component Parts] [New]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Interruptor/Sensor (Delantero) / Switch/Sensor (Front)
Interruptor/Sensor (Trasero) / Switch/Sensor (Rear)
Conmutador (Tablero De Instrumentos) / Switch (Panel Board)
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Peligro Luz/Cola Luz / Hazard Light/Tail Light
Adelante Combinacion Luz / Front Combination Light
Licencia Lampara / License Lamp
Electrico Cableado (Motor) [Antiguo] / Electrical Wiring (Engine) [Old]
Electrico Cableado (Motor) [Nuevo] / Electrical Wiring (Engine) [New]
Electrico Cableado (Principal) [Antiguo] / Electrical Wiring (Main) [Old]
Electrico Cableado (Principal) [Nuevo] / Electrical Wiring (Main) [New]
Cubierta Trasera De Caja De Transmision [Se] [Tur] / Transmission Case Rear Cover [Se] [Tur]
Valvula Palanca (Embrague/Inversor) / Valve Lever (Clutch/Shuttle)
Entrada Eje / Input Shaft
Inversor Embrague [Componente Piezas] / Shuttle Clutch [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje De Engranaje Diferencial / Bevel Gear
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula / Pto Clutch Valve
Pto Eje / Pto Shaft
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Eje Propulsor Delantero (Posterior) / Front Propeller Shaft (Rear)
Horquilla Cambio Gama Y Cambio Creeper / Range Gear Shift Fork/Creep Gear Shift Fork
Inversor Cambio Palanca / Shuttle Shift Lever
Inversor Cable / Shuttle Cable
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Varilla De Freno (Pedal De Freno) / Brake Rod (Brake Pedal)
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Adelante Helice Eje / Front Propeller Shaft
Adelante Diferencial Caja [Ec] [Se] [Tur] / Front Differential Case [Ec] [Se] [Tur]
Caja De Engranaje Conico Dcha [Ec] [Se] [Tur] / Bevel Gear Case Rh [Ec] [Se] [Tur]
Caja De Engranaje Conico Izqd [Ec] [Se] [Tur] / Bevel Gear Case Lh [Ec] [Se] [Tur]
Adelante Eje Caja Derecho [Ec] [Se] [Tur] / Front Axle Case Rh [Ec] [Se] [Tur]
Adelante Eje Caja Izquierdo [Ec] [Se] [Tur] / Front Axle Case Lh [Ec] [Se] [Tur]
Diferencial Engranaje Eje Derecho [Ec] [Se] [Tur] / Differential Gear Shaft Rh [Ec] [Se] [Tur]
Diferencial Engranaje Eje Izquierdo [Ec] [Se] [Tur] / Differential Gear Shaft Lh [Ec] [Se] [Tur]
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Atar Varilla/Direccion Cilindro [Ec] [Se] [Tur] / Tie Rod/Steering Cylinder [Ec] [Se] [Tur]
Hidraulico Tubo (Entrega) [Antiguo] / Hydraulic Pipe (Delivery) [Old]
Hidraulico Tubo (Entrega) [Nuevo] / Hydraulic Pipe (Delivery) [New]
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Pipa De La Valvula De Solenoide / Solenoid Valve Pipe
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Coloque La Palanca De Mando / Position Control Lever
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Distribuidor De Servicios Externos [Se] [Tur] / Auxiliary Control Valve [Se] [Tur]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] / Auxiliary Control Valve (S/D) [Component Parts]
Valvula De Prioridad Del Flujo [Componente Piezas] / Flow Priority Valve [Component Parts]
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Ayudar Cilindro Soporte [Se] [Spa] [Tur] / Drawbar Bracket [Se] [Spa] [Tur]
Protector De Eje De Tdf [Se] [Spa] [Tur] / Pto Shaft Protector [Se] [Spa] [Tur]
Capo (Capo) Superior / Hood (Bonnet) Upper
Capo Superior (Amortiguador Sano/Aislador) [Antiguo] / Hood (Bonnet) Upper (Sound Absorber/Insulator) [Old]
Capo Superior (Amortiguador Sano/Aislador) [Nuevo] / Hood (Bonnet) Upper (Sound Absorber/Insulator) [New]
Capo(Capo)Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte / Bonnet Support
Capo Posterior / Hood (Bonnet) Rear
Capo Trasero (Amortiguador Sano/Aislador) / Hood (Bonnet) Rear (Sound Absorber)
Guardabarros / Fender
Cambie De Puesto La Cubierta / Shift Lever Guide
Hoja De Piso / Floor Sheet
Peldano / Step
Auxiliar Peldano / Auxiliary Step
Asiento [Se] [Spa] [Tur] / Seat [Se] [Spa] [Tur]
Herramienta Caja / Tool Box
Rops
Etiqueta (Trasero) / Label (Panel)
Etiqueta (Posterior) [Ec] [Uk] / Label (Rear)
Kit De Alternador 1 (Alternador) [Opcion] / Alternator Kit 1 (Alternator) [Option]
Alternador Kit 2 (Cable Mazo De Cables) [Opcion] / Alternator Kit 2 (Wire Harness) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Remolque Freno Valvula Kit 1 (Valvula/Tubo) [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Remolque Freno Valvula Kit 2 (Tubo) [Opcion] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Protector De Eje De Tdf [Se] [Spa] [Tur] [Opcion] / Pto Shaft Protector Kit [Se] [Spa] [Tur] [Option]
Apoyo Del Paso [Opcion] / Step Support Kit [Option]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Pto Eje / Pto Shaft
Peldano / Step
Rops
