Kubota Tractor M7040DTH-SPA Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M7040DTH-SPA Tractor
Number of Pages: 474 Pages
Engine 300003 Crankcase
Engine 301002 Oil Pan
Cylinder Head Not 030 And Fig.No.303000 Ref.No.110 Note
Engine 303000 Inlet And Exhaust Valve Valve Inlet Valve And Exhaust Valve
Engine 304000 Rocker Arm Shaft
Engine 305002 Head Cover
Engine 310000 Front Cover
Engine 311002 Piston And Crankshaft
Engine 312002 Camshaft And Idle Gear
Engine 313002 Balancer
Engine 315003 Flywheel
Pump Unit Injection Pump Unit Note Injection Pump Kit Components Fig.No.321000 To 325000
Engine 321002 Injection Pump
Engine 322002 Fuel Camshaft
Engine 323002 Governor
Engine 324002 Fork Lever (Governor)
Engine 325002 Restriction Adjustment Bolt Restriction Adjusting Bolt
Engine 331002 Fuel Filter
Engine 340000 Nozzle Holder And Glow
Engine 345000 Injection Pipe
Engine 360002 Thermostat Water Flange And Thermostat
Engine 361000 Water Pump
Engine 371002 Inlet Manifold
Engine 372000 Exhaust Manifold
Engine 372202 EGR Valve
Engine 372300 EGR Cooler
Engine 372502 EGR Water Pipe EGR Water Piping
Engine 372600 Turbocharge Turbo Charger
Engine 373002 Air Cleaner
Engine 373500 Air Cleaner Component Parts
Engine 374502 Inlet Pipe Inlet Pipe
Engine 375002 Muffler
Engine 380002 Oil Pipe (Turbo Charger)
Engine 382002 Oil Cooler
Engine 391002 Upper Gasket Kit
Engine 392002 Lower Gasket Kit
Engine 395002 Engine Electrical Parts Engine Electrical Parts
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11000 Fuel Tank
Fuel System A13500 Fuel Feed Fuel Filler
Fuel System A14000 Fuel Pipe
Fuel System A15102 Separator
Fuel System A16102 Separator Component Parts
Cooling Water System A41002 Fan
Cooling Water System A42000 Water Pipe
Cooling Water System A43002 Radiator
Cooling Water System A45000 Reserve Tank Reserve
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56002 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58002 Battery
Electrical System B00102 Switch Sensor (Motor) Switch Sensor
Electrical System B01502 Switch Sensor (Front)
Electrical System B02000 Switch Sensor (Back) Switch Sensor
Control Panel) Switch (Panel Board) Note 030 Width Part And Fig.No.M15501,M15502 Ref.No.105
Electrical System B13002 Relay
Electrical System B14000 Dashboard Panel Board
Electrical System B32002 Head Light
Electrical System B32100 Outdoor Lighting Component Parts Head Light
Electrical System B33500 Dangerous Lamp Rear Lamp Hazard Light
Electrical System B33900 Front Combination Headlight Front Combination
Electrical System B36502 License Lamp
Electrical System B37000 Trailer Socket
Electrical System B50503 Wire Harness (Motor) Electrical Wiring
Electrical System B51003 Electrical Cables (Main) Electrical
Clutch Gear Clutch Transmission C11002 Clutch Case Clutch
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle Gear
Clutch Gear Clutch Transmission C12500 Shift Cover
Clutch Gear Clutch Transmission C14002 Transmission Box Transmission
Spa Clutch Gear Clutch Transmission C15003 Gear Housing Rear Cover Spa Tur Transmission
Clutch Gear Clutch Transmission C17000 Rear Axle Housing Rear Axle
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C26502 Valve Lever (Clutch Transmission) Valve Lever
Clutch Gear Clutch Transmission D21500 Input Shaft
Spa Clutch Gear Clutch Transmission D21600 Transmission Clutch Component Parts Shuttle
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23500 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Clutch Gear Clutch Transmission D26000 Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26600 PTO Clutch
Clutch Gear Clutch Transmission D26700 PTO Clutch Component Parts
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
Spa Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Clutch Gear Clutch Transmission D35500 Propeller Shaft (Rear) Front Propeller
Speed Change Shift Fork D41002 Main Transmission
Slip Lever Speed Change Shift Fork D45000 Range Gear Change Fork Creep
Speed Change Shift Fork D47000 Differential Lock
Gear Speed Change Shift Fork F11002 Main Gear
Speed Change Shift Fork F11500 Main Transmission
Speed Change Shift Fork F12502 Transmission Shuttle
Spa Gear Speed Change Shift Fork F13300
Speed Change Shift Fork F13500 Gear Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20600 Brake (Right Side) Brake Rh
Rear Axle Brake F20700 Brake (Left Side) Brake Lh
Rear Axle Brake F21100 Brake Rod (Brake Pedal) Brake Rod (Brake
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23502 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master
Spa Rear Axle Brake F32002 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33002 Brake Pipe Brake Pipe
Front Axle Chassis G10502 Front Axle Frame Front Axle
Front Axle Chassis G11000 Front Axle Housing Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Spa Front Axle Chassis G15002 Front Differential Housing Spa Tur Front
Front Axle Chassis G16000 Slant Transmission (Front) Bevel Gear (
Front Axle Chassis G17000 Front Differential Differential
Frame Front Axle Chassis G22102 Slant Transmission Housing (Right Side) Spa Tur Type Narrow Bevel
Frame Front Axle Chassis G22202 Slant Transmission Housing (Left Side) Spa Tur Tip Narrow Bevel
Front Axle Chassis G22302 Front Axle Body (Right Side) Spa Tur Tip Narrow Front Axle
Front Axle Chassis G22402 Front Axle Body (Left Side) Spa Tur Tip Narrow Front Axle
Frame Front Axle Chassis G22802 Differential Transmission Shaft (Right Side) Spa Tur Tip Narrow Differential
Frame Front Axle Chassis G22902 Differential Transmission Shaft (Left Side) Spa Tur Tip Narrow Differential
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle
Steering H11002 Steering Handle
Steering H12000 Slip Pedal Tilt Pedal
Steering H13000 Steering Additional Steering Joint
Steering H14000 Steering Control Steering Controller
Steering H15000 Steering Control Component Parts Steering Controller
Steering H16002 Steering Cylinder Spa Tur Tie Rod Steering
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13002 Hydraulic Pump
Spa Hydraulic System J13500 Hydraulic Pump
Hydraulic System J22003 Hydraulic Oil Line (Feed)
Hydraulic System J26500 Oil Cooler
Hydraulic System J27500 Hydraulic Pipe (Direction PTO) Hydraulic Oil Line (
Hydraulic System J27600 Hydraulic Pipe (Shuttle PTO) Hydraulic Oil Line
Hydraulic System J28000 Steering Hose Steering Hose (
Hydraulic System J30502 Solenoid Valve Pipe Solenoid Valve
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Hydraulic Piston Lifting Arm Hydraulic
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32300 Drop Adjustment Valve Lowering Lock
Hydraulic System J35500 Control Valve
Hydraulic System J37800 Position Control Lever Position Control
Hydraulic System J38002 Draft And Position Control Lever Position
Hydraulic System J38203 Position And Draft Shaft Position And Draft
Hydraulic System J39200 Feed Back Lever
Spa Hydraulic System J44503 Remote Control Valve Spa Tur Auxiliary Control
Hydraulic System J44703 Remote Control Valve (S D) Component Parts Auxiliary
Hydraulic System J44704 Remote Control Valve (S D) Component Parts Auxiliary
Spa Hydraulic System J44900 Flow Priority Valve Component Parts Flow Priority
Hydraulic System J45502 Support Control Valve Lever Auxiliary Control
Hydraulic System J47102 3p-Left Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47202 3p-Right Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47300 3p-Lift Support Cylinder Component Parts 3p-Lift Assist
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10502 Top Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11002
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Bottom Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13302 Stabilizer
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Pulling Shaft
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket Se Spa Tur
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17002 PTO Protection Se Spa Tur Pto
Hood Bonnet M11000 Front Grille
Hood Bonnet M12002 Hood (Bonnet) Upper
Spa Hood Bonnet M12103 Bone Hood (Sound Absorbing Damper Material) Hood (Bonnet) Upper (Sound)
Hood Bonnet M12302 Hood (Bonnet) Damper
Hood Bonnet M12400 Bone Lock Bonnet Lock
Hood Bonnet M12700 Bone Side Cover Hood (Bonnet) Side Cover
Hood Bonnet M14002 Bone Support Bonnet Support
Hood (Bone) Rear Hood (Bonnet) Rear Not 020 And Fig.No.B10500 Ref.No.030
Spa Hood Bonnet M17502 Hood (Bonnet) Rear (Sound Absorbing Damper Material) Hood (Bonnet) Rear
Hood Bonnet M18000 Rearview Mirror
Hood Bonnet M22002 Fender
Hood Bonnet M22200 Slide Cover Shift Lever Guide
Hood Bonnet M22302 Floor Sheet
Hood Bonnet M23302 Step
Hood Bonnet M23400 Auxiliary Step Auxiliary Step
Hood Bonnet M23502 Seat Se Spa Tur Seat Se Spa Tur
Hood Bonnet M27002 Tool Box
ROPS M31000 ROPS
Labels S12000 Label (Front)
Labels S13000 Label (Panel)
Labels S14000 Label (Back) Label (Rear)
Accessory Service Part Accessories T11000 Accessory Service Part Accessories And
Option U11000 Alternator Kit 1 (Alternator) Option Alternator Kit 1 (
Option U11100 Alternator Kit 2 (Wire Harness) Option Alternator Kit 2 (Wire
Option U11300 Alternator Kit Component Parts Option Alternator Component
Option U75000 Trailer Brake Valve Kit 1 Option Trailer Brake Valve Kit 1 (Valve
Option U75100 Trailer Brake Valve Kit 2 Option Trailer Brake Valve Kit 2 (
U88800 PTO Shaft Protector Kit Se Spa Tur Option PTO Shaft Protector Kit Se Spa Tur Option
Region: Turkey
ROPS M31000 ROPS
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
