Kubota Tractor M7040DTH-NEC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7040DTH-NEC Tractor
Number of Pages: 338 Pages
Itens Uso Frequen Te / Frequently Used Items
Bloco Motor / Crankcase [Old]
Bloco Motor / Crankcase [New]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Injection Pump Unit / Injection Pump Uni T
Veio / Fuel Camshaft
Alavanca Do Garfo (Governador) / Fork Le Ver (Governor)
Restriction Adjusting Bolt / Restriction Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Valvula Solenoide / Nozzle Holder And Gl Ow Plug
Acessorios / Water Pump
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Clea Ner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Char Ger)
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Componentes Electricos Motor / Engine El Ectrical Parts
Deposito Combustivel / F Uel Tank
Fornecimento Combustivel / Fuel Filler
Tubo Combustivel / Fuel Pipe
Sedimenter [Old] / Sedim Enter [Old]
Separador / Separator [N Ew]
Sedimenter [Component Pa Rts] [Old] / Sedimenter [Component Parts] [Old]
Separador[Peças Componen Tes] / Separator [Component Parts] [New]
Ventil Ador / Fan
Radiad Or / Water Pipe
Radiad Or / Radiator
Deposi To Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Compone Ntes] / Starter [Component Parts]
Interruptor/Sensor (Blo Co Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Dia Nteiro) / Switch/Sensor (Front)
Interruptor/Sensor (Tra Seiro) / Switch/Sensor (Rear)
Interruptor / Switch (P Anel Board)
Interruptor / Rele / Re Lay
Painel / Panel Board
Farol Dianteiro / Head Light
Farol Frente[Peças Comp Onentes] / Head Light [Component Parts]
Hazard Light/Tail Light / Hazard Light/Tail Light
Luzes Frontais / Front Combination Light
Farol Matricula / Licen Se Lamp
Cablagem Eletrcia (Fren Te) / Electrical Wiring (Engine) [Old]
Cablagem Eletrcia (Fren Te) / Electrical Wiring (Engine) [New]
Cabelagem Eletrica (Ver Sao)[Antiga] / Electrical Wiring (Main) [Old]
Cabelagem Eletrica (Ver Sao)[Nova] / Electrical Wiring (Main) [New]
Carter Embraiage M / Clutch Housing
Valvula Inversor / Shuttle Valve
Carretos Inverso R / Shuttle Gear Case
Tampa / Shift Co Ver
Caixa Velocidade S / Transmission Case
Carter Transmiss Ao / Transmission Case Rear Cover [Se] [Tur]
Carter Eixo / Re Ar Axle Case
Disco Amortecedo R / Damper Disk
Valvula (Inverso R) / Valve Lever (Clutch/Shuttle)
Veio Primario / Input Shaft
Embraiagem Inver Sor [Peças Componentes] / Shuttle Clutch [Component Parts]
Veio Inversor / Shuttle Shaft
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Creeper / C Reep Shaft
Grupo Conico / B Evel Gear
Diferencial Tras Eiro / Differential Rear
Veio Tdf / Pto P Ropeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[P Eças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiag Em Tdf / Pto Clutch Valve
Veio Tdf / Pto S Haft
Embraiagem Andam Ento / Front Drive Clutch
Veio Embraiagem[ Peças Componentes] / Front Drive Clutch [Component Parts]
Veio Primario (T Raseira) / Front Propeller Shaft (Rear)
Forq Ueta / Main Gear Shift Fork
Forq Ueta Caixa / Creeper / Range Gear Shift Fork/Creep Gear Shift Fork
Alav Anca / Differential Lock Shift Fork
Alav Anca Velocidades / Main Gear Shift Lever
Alva Nca Inversor / Shuttle Shift Lever
Cabo Inversor / Shuttle Cable
Alav Anca Velocidades / Range Gear Shift Lever
Alav Anca Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear Axle
Travão Direita / Brak E Rh
Travão Esquerda / Bra Ke Lh
Tirante Travao / Brak E Rod (Brake Pedal)
Pedal Travao / Brake Pedal
Cilindro Travao Princ Ipal / Brake Master Cylinder
Cilindro Travao Princ Ipal[Peças Componentes] / Brake Master Cylinder [Co Mponent Parts]
Tubo Travao / Brake P Ipe
Suporte Eixo Frent E / Front Axle Frame
Suporte Eixo Diant Eiro / Front Axle Bracket
Veio Frontal / Fro Nt Propeller Shaft
Caixa Diferencial Dianteiro / Front Differential Case [Ec] [Se] [Tur]
Engrenagem Cónica (Dianteira) / Bevel Gear (Front)
Diferencial Diante Iro / Differential Front
Caixas Engrenagens Conica(Drt) / Bevel Gear Case Rh [Ec] [Se] [Tur]
Caixas Engrenagens Conica(Esq) / Bevel Gear Case Lh [Ec] [Se] [Tur]
Carter Eixo Frente (Drt) / Front Axle Case Rh [Ec] [Se] [Tur]
Carter Eixo Frente (Esq) / Front Axle Case Lh [Ec] [Se] [Tur]
Carreto Diferencia L(Drt) / Differential Gear Shaft Rh [Ec] [Se] [Tur]
Carreto Diferencia L(Esq) / Differential Gear Shaft Lh [Ec] [Se] [Tur]
Eixo Dianteiro / F Ront Axle Lh
Direcção Assistida / Direção Punho / Stee Ring Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steeri Ng Cylinder [Ec] [Se] [Tur]
Cilindro Direcção[Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / Hydr Aulic Pump
Bomba Hidraulico[Peças Componentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic P Ipe (Delivery) [Old]
Tubo Oleo / Hydraulic P Ipe (Delivery) [New]
Radiador Oleo / Oil Coo Ler
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto ) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao / Steerin G Hose (Delivery)
Tubo Valvula Solenoide / Solenoid Valve Pipe
Caixa Hidraulico / Hydr Aulic Cylinder Case
Valvula Segurança / Saf Ety Valve/Relief Valve
Trinco / Lowering Lock Lever
Braco Hidraulico / Cont Rol Valve
Alavanca Control Posica O / Position Control Lever
Acessorios / Draft And Position Control Lever
Veio Posicao Esforço / Position And Draft Shaft [Old]
Veio Posicao Esforço / Position And Draft Shaft [New]
Alavanca / Feed Back Le Ver
Distribuidor Auxiliar / Auxiliary Control Valve [Se] [Tur]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Fd) [Compo Nent Parts] [Old]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Fd) [Compo Nent Parts] [New]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (S/D) [Comp Onent Parts]
Alavanca Valvula Auxili Ar 1 Pos / Auxiliary Control Valve Lever
Cilindro Auxiliar De El Evacao(Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De El Evacao(Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De El Evacao[Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Pa Rte Superior / Top Link Bracket
Li Gacao Superior / Top Link
Li Gacao Inferior / Lower Link
Es Tabilizador / Stabilizer
Es Tabilizador(Esq) / Lift Rod Lh
Pr Oteccao Tdf / Pto Shaft Protector [Se] [Spa] [Tur]
Grelha Frontal / Front Grille
Capot Superior / Isolador / Hood (Bonnet) Upper (Sound Absorber/Insulator) [Old]
Capot Superior / Isolador / Hood (Bonnet) Upper (Sound Absorber/Insulator) [New]
Trico Capot / Bonnet Lock
Capot Traseiro / Hood (Bonnet) Rear (Soun D Absorber)
Guarda Lamas / Fender
Tampa / Shift Lever Guide
Piso / Floor Sheet
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat [Se] [Spa] [Tur]
Caixa Ferramenta / Tool Box
Alavanca Valvula Control Auxiliar 2º [Opcao] / Rops
Etiqueta (Dianteira) / Label (Fron T)
Decalcomania(Painel) / Label (Pane L)
Etiqueta 2 / Label (Rear)
Acessorios / Accessories And Service Parts
Kit Alternador [Opçao] / Alternator Kit 1 (Alt Ernator) [Option]
Kit Alternador [Opçao] / Alternator Kit 2 (Wir E Harness) [Option]
Alternador [Peças Componentes] [Opcao] / Alter Nator [Component Parts] [Option]
Kit Valvula Travao Reboque 1[Peças Componentes ] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Kit Valvula Travao Reboque 2[Peças Componentes ] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [Se] [Spa] [Tur] [Option]
Step Support Kit [Option] / Step Support Kit [ Option]
