Kubota Tractor M6800DT M6800SDT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M6800DT ; M6800SDT Tractor
Number of Pages: 298 Pages
Itens Uso Fre Quente / Frequently Used Items
Bloco Motor / Crankcase [Rops Type]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head [Rops T Ype]
Carreto / Gear Case
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And I Dle Gear Shaft
Piston E Cambota / Piston And Cranks Haft
Volante Motor / Flywheel
Compensador / Balancer
Regulador / Governor [Rops Type]
Valvula Solenoide / Nozzle Holder An D Glow Plug
Suporte Bico [Peças Componentes] / N Ozzle Holder [Component Parts]
Caixa Da Bomba / Pump Housing [Rops Type]
Alavanca Do Garfo (Governador) / For K Lever (Governor)
Parafuso De Ajuste De Governador / G Overnor Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Fla Nge And Thermostat [Rops Type]
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner [Rops Type]
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Escpae / Muffler [Rops Type]
Hydraulic Pump Base / Hydraulic Pump Base
Radiador Oleo / Oil Cooler [Rops Typ E]
Deposito Combustivel / Lower Gasket Kit
Acelarador Mao / Hand Accelerator Le Ver [Rops Type]
Engine Stop Wire [Rops Type] / Engin E Stop Wire [Rops Type]
Deposito Combustivel (Drt) / Fuel Tank Rh [Rops Type]
Deposito Combustivel (Esq) / Fuel Tank Lh [Rops Type]
Tubo Combustivel / F Uel Pipe [Rops Type]
Separador / Separato R
Separador[Peças Comp Onentes] / Separator [Component Parts]
Ve Ntilador / Fan
Tu Bo Agua / Water Pipe [Rops Type]
Ra Diador / Radiator [Rops Type]
De Posito Reserva / Reserve Tank [Rops Type]
Alternador / Altern Ator [Rops Type]
Alternador [Peças C Omponentes] / Alternator [Component Parts] [Rops Ty Pe]
Motor Arranque / St Arter
Motor Arranque [Com Ponentes] / Starter [Component Parts]
Bateria / Battery [ Rops Type]
Interruptor/Sensor / Switch/Sensor [Rops Type] [Old Type]
Interruptor/Sensor / Switch/Sensor [Rops Type] [New Type]
Switch(Panel Board) /Relay [Rops Type] [New Type] / Switch(Panel Board) /Relay [Rops Type] [New Type]
Painel / Panel Boar D [Rops Type] [Old Type]
Painel / Panel Boar D [Rops Type] [New Type]
Painel[Peças Compon Entes] / Panel Board [Component Parts][Rops Type][O Ld Type]
Painel[Peças Compon Entes] / Panel Board [Component Parts][Rops Type][N Ew Type]
Farol Dianteiro / H Ead Light
Hazard Light/Tail L Ight [Rops Type] / Hazard Light/Tail Light [Rops Ty Pe]
Cablagem Electrica / Electrical Wiring [Rops Type] [Old Type]
Cablagem Electrica / Electrical Wiring [Rops Type] [New Type]
Carter Embra Iagem / Clutch Housing [Rops Type] [Old Type]
Carter Embra Iagem / Clutch Housing [Rops Type] [New Type]
Carretos Inv Ersor / Shuttle Gear Case [New Type]
Bearing Hold Er [Old Type] / Bearing Holder [Old Type]
Caixa Veloci Dades / Transmission Case [Rops Type] [Old Type]
Caixa Veloci Dades / Transmission Case [Rops Type] [New Type]
Carter Trans Missao / Transmission Case Rear Cover [Rops Type][O Ld Type]
Carter Trans Missao / Transmission Case Rear Cover [New Type]
Carter Eixo / Rear Axle Case
Caixa Da Tra Nsmissão Dianteira / Front Drive Case
Embraiagem / Clutch [Rops Type] [Old Type]
Embraiagem / Clutch [New Type]
Forqueta Emb Raiagem / Clutch Release Fork [Rops Type] [Old Type ]
Pedal Embrai Agem / Clutch Pedal [Rops Type] [Old Type]
Pedal Embrai Agem / Clutch Pedal [Rops Type] [New Type]
Veio Primari O / Input Shaft [Rops Type] [Old Type]
Veio Primari O / Input Shaft [New Type]
Primeiro Vei O / First Shaft [Rops Type] [Old Type]
Primeiro Vei O / First Shaft [New Type]
Secundario V Eio / Second Shaft [Rops Type] [Old Type]
Secundario V Eio / Second Shaft [New Type]
Terceiro Vei O / Third Shaft [Rops Type] [Old Type]
Terceiro Vei O / Third Shaft [Rops Type] [New Type]
Back Idle Sh Aft [New Type] / Back Idle Shaft [New Type]
Veio Creeper / Creep Shaft
Grupo Conico / Bevel Gear [New Type]
Diferencial Traseiro / Differential Rear
Veio Tdf / P To Propeller Shaft [Rops Type] [Old Type]
Veio Tdf / P To Propeller Shaft [Rops Type] [New Type]
Embraiagem T Df / Pto Clutch [Rops Type] [Old Type]
Embraiagem T Df / Pto Clutch [New Type]
Embraiagem T Df[Peças Componentes] / Pto Clutch [Component Parts ][Rops Type][Old Type]
Embraiagem T Df[Peças Componentes] / Pto Clutch [Component Parts ] [New Type]
Valvula Embr Aiagem Tdf / Pto Clutch Valve [Rops Type] [Old Type ]
Valvula Embr Aiagem Tdf / Pto Clutch Valve [New Type]
Valvula Embr Aiagem Tdf[Peças Componentes] / Pto Clutch Valve [ Component Parts]
Veio Tdf / P To Shaft [Rops Type] [Old Type]
Veio Tdf / P To Shaft [New Type]
Forqueta / Main G Ear Shift Fork [Rops Type] [Old Type]
Forqueta / Main G Ear Shift Fork [New Type]
Forquilha Inverso R / Shuttle Gear Shift Fork [Rops Type] [New Type]
Forqueta Velocida Des / Range Gear Shift Fork [Rops Type] [Old Type]
Forqueta Velocida Des / Range Gear Shift Fork [Rops Type] [New Type]
Eixo Traseiro / R Ear Axle
Travão / Brake
Tirante Travao / Brake Rod [Rops Type]
Alavanca Velocida Des / Main Gear Shift Lever [Rops Type]
Alvanca Inversor / Shuttle Shift Lever [Rops Type] [New Type]
Alavanca Velocida Des / Range Gear Shift Lever [Rops Type] [Old Type]
Alavanca Velocida Des / Range Gear Shift Lever [Rops Type] [New Type]
Range Gear Shift Rod [Rops Type] [Old Type] / Range Gear Shift Rod [ Rops Type] [Old Type]
Pto Clutch Lever [Rops Type] / Pto Clutch Lever [Rops Type]
Alavanca Tdf / Pt O Gear Shift Lever
Alavanca Dupla Tr Accao / Front Wheel Drive Lever [Rops Type]
Pedal Travao / Br Ake Pedal [Rops Type]
Pedal Bloqueio Di Ferencial Traseiro / Rear Differential Lock Pedal [ Rops Type]
Suporte Eixo F Rente / Front Axle Frame [Rops Type] [Old Type]
Suporte Eixo F Rente / Front Axle Frame [Rops Type] [New Type]
Suporte Eixo D Ianteiro / Front Axle Bracket
Veio Primario / Front Propeller Shaft [Rops Type]
Caixa Diferenc Ial Dianteiro / Front Differential Case
Engrenagem Cón Ica (Dianteira) / Bevel Gear (Front)
Diferencial Di Anteiro / Differential Front
Bloqueio Difer Encial Frente / Front Differential Lock Clutch [Rop S Type]
Carter Grupo C Onico / Bevel Gear Case
Carter Eixo / Front Axle Case
Grupo Conico / Differential Gear Shaft
Eixo Dianteiro / Front Axle
Punho Volante / Steering Handle [Rops Type] [Old Type]
Punho Volante / Steering Handle [Rops Type] [New Type]
Distribuidor Direcção(Nova) / Steerin G Controller [Rops Type]
Distribuidor Direcção[Peças Component Es] / Steering Controller [Component Parts]
Direcção / Steering Linkage
Cilindro Direcção[Peças Componentes] / Steering Cylinder [Component Parts] [Old]
Steering Cylinder [Component Parts] [ New] / Steering Cylinder [Component Parts] [New]
Steering [Component Parts] [New] / Steering [Component Parts] [New]
Bomba Hidraulico[Pe Ças Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / H Ydraulic Pipe (Suction) [Rops Type]
Tubo Oleo / Hydraul Ic Pipe (Delivery) [Rops Type]
Circuito Oleo Direc Ção / Hydraulic Oil Line (Steering/Pto) [Rops Type]
Tubo Direccao / Ste Ering Hose (Delivery) [Rops Type]
Cilindro Hidraulico / Hydraulic Cylinder [Rops Type]
Braço De Elevação H Idráulico / Hydraulic Lift Arm
Hydraulic Cylinder Cover [Rops Type] / Hydraulic Cylinder Cover [Rops Type]
Braco Hidraulico / Control Valve
Alavanca Control Es Forço / Draft And Position Control Lever [Rops Type ]
Position Control Sh Aft / Position Control Shaft
Draft Control Shaft / Draft Control Shaft
Alavanca / Feed Bac K Lever
Distribuidor Auxili Ar / Auxiliary Control Valve [Rops Type]
Valvula Auxiliar [P Eças Componentes] / Auxiliary Control Valve [Compon Ent Parts] [Rops Type]
Parte Superior / To P Link Bracket
Ligacao Superior / Top Link [Rops Type]
Ligacao Inferior / Lower Link
Estabilizador / Sta Bilizer [Old Type]
Estabilizador / Sta Bilizer [New Type]
Estabilizador(Drt) / Lift Rod Rh
Estabilizador(Esq) / Lift Rod Lh
Swinging Drawbar / Swinging Drawbar
Proteccao Tdf / Pto Shaft Protector
Hood(Bonnet) Front [Rops Type] / Hood (Bonnet) Front [Rops Type]
Capot Superior / Hood(Bonnet) Upper [ Rops Type]
Lado Do Capot / Hood(Bonnet) Side [Ro Ps Type] [Old Type]
Capot Lateral / Hood(Bonnet) Side Cov Er [Rops Type]
Capot Traseiro / Hood(Bonnet) Rear [R Ops Type] [Old Type]
Capot Traseiro / Hood(Bonnet) Rear [R Ops Type] [New Type]
[Rops Type]
Guarda Lamas / Fender [Rops Type]
Piso / Floor Seat [Rops Type]
Degrau / Step [Rops Type]
Arco / Rops [Rops Type] [Old Type]
Arco / Rops [Rops Type] [New Type]
Banco / Seat [Rops Type]
Caixa Ferramenta / Tool Box [Rops Typ E]
Etiqueta Traseira / Label [Rop S Type] [Old Type]
Etiqueta (Dianteira) / Label 1 [Rops Type] [New Type]
Etiqueta / Label 2 [Rops Type] [New Type]
Acessorios / Accessories And Ser Vice Parts
Kit Luzes Trabalho (Opçao) / Working Light Kit [Option] [Rops Type]
Trailer Socket Kit [Option] [Rops Type] / Trailer Socket Kit [Option] [Rops Type]
Paking Brake Lever Kit [Option] [Rops Type ] [Old Type] / Paking Brake Lever Kit [Option] [Rop S Type] [Old Type]
Paking Brake Lever Kit [Option] [Rops Type ] [New Type] / Paking Brake Lever Kit [Option] [Rop S Type] [New Type]
Front Weight Bumper Kit [Option] / Front W Eight Bumper Kit [Option]
Front Bumper Kit[Option] [New Type] / Fron T Bumper Kit[Option] [New Type]
Auxiliary Control Valve Kit (Scd) [Option] [Rops Type] / Auxiliary Control Valve Kit (Scd) [O Ption] [Rops Type]
Auxiliary Control Valve Kit (Fd) [Option] [Rops Type] / Auxiliary Control Valve Kit (Fd) [Opt Ion] [Rops Type]
Distribuidor Auxiliar[Peças Componentes] / Auxiliary Control Valve (Scd) [Component Parts] [O Ption] [Rops Type]
Distribuidor Auxiliar[Peças Componentes] / Auxiliary Control Valve (Fd) [Component Parts] [Op Tion] [Rops Type]
Step Support Kit [Option] / Step Support K It [Option]
