Kubota Tractor M6800DT M6800SDT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M6800DT ; M6800SDT Tractor
Number of Pages: 497 Pages
Bloque Motor [Tipo Arco] / Crankcase [Rops Type]
Aceite Cacerola / Oil Pan
Culata [Tipo Arco] / Cylinder Head [Rops Type]
Culata Cubierta / Head Cover
Volante / Flywheel
Compensador / Balancer
Regulador [Tipo Arco] / Governor [Rops Type]
Carcasa De Bomba [Tipo Arco] / Pump Housing [Rops Type]
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Brida De Agua Y Termostato [Tipo Arco] / Water Flange And Thermostat [Rops Type]
Bomba De Agua [Tipo Arco] / Water Pump [Rops Type]
Filtro De Aire [Tipo Arco] / Air Cleaner [Rops Type]
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Silenciador [Tipo Arco] / Muffler [Rops Type]
Hidraulico Bomba Base / Hydraulic Pump Base
Radiador De Aceite[Tipo Arco] / Oil Cooler [Rops Type]
Palanca De Acelerador De Mano [Tipo Arco] / Hand Accelerator Lever [Rops Type]
Cable De Parada De Motor [Tipo Arco] / Engine Stop Wire [Rops Type]
Deposito De Combustible Dcha [Tipo Arco] / Fuel Tank Rh [Rops Type]
Deposito De Combustible Izqd [Tipo Arco] / Fuel Tank Lh [Rops Type]
Tubo De Combustible [Tipo Arco] / Fuel Pipe [Rops Type]
Separador / Separator
Separador[Componente Piezas] / Separator [Component Parts]
Ventilador / Fan
Tubo De Agua [Tipo Arco] / Water Pipe [Rops Type]
Radiador [Tipo Arco] / Radiator [Rops Type]
Deposito De Reserva[Tipo Arco] / Reserve Tank [Rops Type]
Alternador [Tipo Arco] / Alternator [Rops Type]
Alternador [Componentes] [Tipo Arco] / Alternator [Component Parts] [Rops Type]
Motor De Arranque / Starter
Bateria [Tipo Arco] / Battery [Rops Type]
Conmutador/Sensor [Tipo Arco] [Tipo Antiguo] / Switch/Sensor [Rops Type] [Old Type]
Conmutador/Sensor [Tipo Arco] [Tipo Nuevo] / Switch/Sensor [Rops Type] [New Type]
Conmutador (Tablero De Instrumentos)/Rele [Tipo Arco] [Tipo Nuevo] / Switch(Panel Board)/Relay [Rops Type] [New Type]
Tablero De Instrumentos [Tipo Arco] [Tipo Antiguo] / Panel Board [Rops Type] [Old Type]
Tablero De Instrumentos [Tipo Arco] [Tipo Nuevo] / Panel Board [Rops Type] [New Type]
Tablero De Instrumentos [Componentes][Tipo Arco][Tipo Antiguo] / Panel Board [Component Parts][Rops Type][Old Type]
Tablero De Instrumentos [Componentes][Tipo Arco][Tipo Nuevo] / Panel Board [Component Parts][Rops Type][New Type]
Culata Luz / Head Light
Luz De Emergencia/Piloto Trasero [Tipo Arco] / Hazard Light/Tail Light [Rops Type]
Cableado Electrico [Tipo Arco] [Tipo Antiguo] / Electrical Wiring [Rops Type] [Old Type]
Cableado Electrico [Tipo Arco] [Tipo Nuevo] / Electrical Wiring [Rops Type] [New Type]
Carcasa De Embrague [Tipo Arco] [Tipo Antiguo] / Clutch Housing [Rops Type] [Old Type]
Carcasa De Embrague [Tipo Arco] [Tipo Nuevo] / Clutch Housing [Rops Type] [New Type]
Caja De Engranajes De Inversor [Tipo Nuevo] / Shuttle Gear Case [New Type]
Portacojinete [Tipo Antiguo] / Bearing Holder [Old Type]
Caja De Transmision [Tipo Arco] [Tipo Antiguo] / Transmission Case [Rops Type] [Old Type]
Caja De Transmision [Tipo Arco] [Tipo Nuevo] / Transmission Case [Rops Type] [New Type]
Cubierta Trasera De Caja De Transmision [Tipo Arco][Tipo Antiguo] / Transmission Case Rear Cover [Rops Type][Old Type]
Cubierta Trasera De Caja De Transmision [Tipo Nuevo] / Transmission Case Rear Cover [New Type]
Trasero Eje Caja / Rear Axle Case
Adelante Accionar Caja / Front Drive Case
Embrague [Tipo Arco] [Tipo Antiguo] / Clutch [Rops Type] [Old Type]
Embrague [Tipo Nuevo] / Clutch [New Type]
Horquilla De Desacoplamiento [Tipo Arco] [Tipo Antiguo] / Clutch Release Fork [Rops Type] [Old Type]
Horquilla De Desacoplamiento [Tipo Arco] [Tipo Nuevo] / Clutch Release Fork [Rops Type] [New Type]
Pedal De Embrague [Tipo Arco] [Tipo Antiguo] / Clutch Pedal [Rops Type] [Old Type]
Pedal De Embrague [Tipo Arco] [Tipo Nuevo] / Clutch Pedal [Rops Type] [New Type]
Eje De Entrada [Tipo Arco] [Tipo Antiguo] / Input Shaft [Rops Type] [Old Type]
Eje De Entrada [Tipo Nuevo] / Input Shaft [New Type]
Primer Eje [Tipo Arco] [Tipo Antiguo] / First Shaft [Rops Type] [Old Type]
Primer Eje [Tipo Nuevo] / First Shaft [New Type]
Segundo Eje [Tipo Arco] [Tipo Antiguo] / Second Shaft [Rops Type] [Old Type]
Segundo Eje [Tipo Nuevo] / Second Shaft [New Type]
Tercer Eje [Tipo Arco] [Tipo Antiguo] / Third Shaft [Rops Type] [Old Type]
Tercer Eje [Tipo Arco] [Tipo Nuevo] / Third Shaft [Rops Type] [New Type]
Eje Del Engranaje Loco Posterior [Tipo Nuevo] / Back Idle Shaft [New Type]
Engranaje Conico [Tipo Antiguo] / Bevel Gear [Old Type]
Engranaje Conico [Tipo Nuevo] / Bevel Gear [New Type]
Diferencial Trasero / Differential Rear
Eje Propulsor De Tdf [Tipo Arco] [Tipo Antiguo] / Pto Propeller Shaft [Rops Type] [Old Type]
Eje Propulsor De Tdf [Tipo Arco] [Tipo Nuevo] / Pto Propeller Shaft [Rops Type] [New Type]
Embrague De Tdf [Tipo Arco] [Tipo Antiguo] / Pto Clutch [Rops Type] [Old Type]
Embrague De Tdf [Tipo Nuevo] / Pto Clutch [New Type]
Embrague De Tdf [Componentes][Tipo Arco][Tipo Antiguo] / Pto Clutch [Component Parts][Rops Type][Old Type]
Embrague De Tdf [Componentes] [Tipo Nuevo] / Pto Clutch [Component Parts] [New Type]
Valvula De Embrague De Tdf [Tipo Arco] [Tipo Antiguo] / Pto Clutch Valve [Rops Type] [Old Type]
Valvula De Embrague De Tdf [Tipo Nuevo] / Pto Clutch Valve [New Type]
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje De Tdf [Tipo Arco] [Tipo Antiguo] / Pto Shaft [Rops Type] [Old Type]
Eje De Tdf [Tipo Nuevo] / Pto Shaft [New Type]
Horquilla De Cambio Principal [Tipo Arco] [Tipo Antiguo] / Main Gear Shift Fork [Rops Type] [Old Type]
Horquilla De Cambio Principal [Tipo Nuevo] / Main Gear Shift Fork [New Type]
Horquilla De Cambio De Inversor [Tipo Arco] [Tipo Nuevo] / Shuttle Gear Shift Fork [Rops Type] [New Type]
Horquilla De Cambio De Gama [Tipo Arco] [Tipo Antiguo] / Range Gear Shift Fork [Rops Type] [Old Type]
Horquilla De Cambio De Gama [Tipo Arco] [Tipo Nuevo] / Range Gear Shift Fork [Rops Type] [New Type]
Eje Trasero / Rear Axle
Freno / Brake
Varilla De Freno [Tipo Arco] / Brake Rod [Rops Type]
Palanca De Cambio Principal [Tipo Arco] / Main Gear Shift Lever [Rops Type]
Palanca De Cambio De Inversor [Tipo Arco] [Tipo Nuevo] / Shuttle Shift Lever [Rops Type] [New Type]
Palanca De Cambio De Gama [Tipo Arco] [Tipo Antiguo] / Range Gear Shift Lever [Rops Type] [Old Type]
Palanca De Cambio De Gama [Tipo Arco] [Tipo Nuevo] / Range Gear Shift Lever [Rops Type] [New Type]
Varilla De Cambio De Gama [Tipo Arco] [Tipo Antiguo] / Range Gear Shift Rod [Rops Type] [Old Type]
Palanca De Embrague De Tdf [Tipo Arco] / Pto Clutch Lever [Rops Type]
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Palanca De Accionamiento De Rueda Delantera [Tipo Arco] / Front Wheel Drive Lever [Rops Type]
Pedal De Freno [Tipo Arco] / Brake Pedal [Rops Type]
Pedal De Bloqueo De Diferencial Trasero [Tipo Arco] / Rear Differential Lock Pedal [Rops Type]
Bastidor De Eje Delantero [Tipo Arco] [Tipo Antiguo] / Front Axle Frame [Rops Type] [Old Type]
Bastidor De Eje Delantero [Tipo Arco] [Tipo Nuevo] / Front Axle Frame [Rops Type] [New Type]
Eje Propulsor Delantero [Tipo Arco] / Front Propeller Shaft [Rops Type]
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Embrague De Bloqueo De Diferencial Delantero [Tipo Arco] / Front Differential Lock Clutch [Rops Type]
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Mango De Direccion [Tipo Arco] [Tipo Antiguo] / Steering Handle [Rops Type] [Old Type]
Mango De Direccion [Tipo Arco] [Tipo Nuevo] / Steering Handle [Rops Type] [New Type]
Distribuidor De Direccion [Tipo Arco] / Steering Controller [Rops Type]
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Cilindro De Direccion [Componentes] [Tipo Antiguo] / Steering Cylinder [Component Parts] [Old]
Cilindro De Direccion [Componentes] [Tipo Nuevo] / Steering Cylinder [Component Parts] [New]
Distribuidor De Direccion [Componente Piezas] / Steering [Component Parts] [New]
Tubo Hidraulico(Aspiracion)[Tipo Arco] / Hydraulic Pipe (Suction) [Rops Type]
Tubo Hidraulico (Impulsion) [Tipo Arco] / Hydraulic Pipe (Delivery) [Rops Type]
Linea De Aceite Hidraulico (Direccion/Tdf) [Tipo Arco] / Hydraulic Oil Line (Steering/Pto) [Rops Type]
Latiguillo De Direccion(Impulsion) [Tipo Arco] / Steering Hose (Delivery) [Rops Type]
Cilindro Hidraulico [Tipo Arco] / Hydraulic Cylinder [Rops Type]
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico [Tipo Arco] / Hydraulic Cylinder Cover [Rops Type]
Palanca De Control De Esfuerzo Y Posicion [Tipo Arco] / Draft And Position Control Lever [Rops Type]
Posicion Control Eje / Position Control Shaft
Esfuerzo Control Eje / Draft Control Shaft
Distribuidor De Servicios Externos [Tipo Arco] / Auxiliary Control Valve [Rops Type]
Distribuidor De Servicios Externos [Componentes] [Tipo Arco] / Auxiliary Control Valve [Component Parts] [Rops Type]
Tercer Punto [Tipo Arco] / Top Link [Rops Type]
Bajar Vinculo / Lower Link
Estabilizador [Tipo Antiguo] / Stabilizer [Old Type]
Estabilizador [Tipo Nuevo] / Stabilizer [New Type]
Ascenso Varilla Derecho / Lift Rod Rh
Oscilacion Barra De Remolque / Swinging Drawbar
Pto Eje Protector / Pto Shaft Protector
Capo Anterior[Tipo Arco] / Hood(Bonnet) Front [Rops Type]
Capo Superior [Tipo Arco] / Hood(Bonnet) Upper [Rops Type]
Capo Lateral [Tipo Arco] [Tipo Antiguo] / Hood(Bonnet) Side [Rops Type] [Old Type]
Capo Lateral [Tipo Nuevo] / Hood(Bonnet) Side [New Type]
Tapa Lateral De Capo [Tipo Arco] / Hood(Bonnet) Side Cover [Rops Type]
Capo Posterior [Tipo Arco] [Tipo Antiguo] / Hood(Bonnet) Rear [Rops Type] [Old Type]
Capo Posterior [Tipo Arco] [Tipo Nuevo] / Hood(Bonnet) Rear [Rops Type] [New Type]
Espejo Retrovisor [Tipo Arco] / Rearview Mirror [Rops Type]
Guardabarros [Tipo Arco] / Fender [Rops Type]
Asiento De Piso [Tipo Arco] / Floor Seat [Rops Type]
Peldano [Tipo Arco] / Step [Rops Type]
Arco De Seguridad [Tipo Arco] [Tipo Antiguo] / Rops [Rops Type] [Old Type]
Arco De Seguridad [Tipo Arco] [Tipo Nuevo] / Rops [Rops Type] [New Type]
Asiento [Tipo Arco] / Seat [Rops Type]
Caja De Herramientas [Tipo Arco] / Tool Box [Rops Type]
Etiqueta [Tipo Arco] [Tipo Antiguo] / Label [Rops Type] [Old Type]
Etiqueta 1 [Tipo Arco] [Tipo Nuevo] / Label 1 [Rops Type] [New Type]
Etiqueta 2 [Tipo Arco] [Tipo Nuevo] / Label 2 [Rops Type] [New Type]
Kit De Faro De Labor [Opcion] [Tipo Arco] / Working Light Kit [Option] [Rops Type]
Kit De Enchufe De Remolque [Opcion] [Tipo Arco] / Trailer Socket Kit [Option] [Rops Type]
Kit De Palanca De Freno De Estacionamiento [Opcion] [Tipo Arco] [Tipo Antiguo] / Paking Brake Lever Kit [Option] [Rops Type] [Old Type]
Kit De Palanca De Freno De Estacionamiento [Opcion] [Tipo Arco] [Tipo Nuevo] / Paking Brake Lever Kit [Option] [Rops Type] [New Type]
Adelante Peso Parachoques Kit[Opcion] / Front Weight Bumper Kit [Option]
Kit De Parachoques Delantero [Opcion] [Tipo Nuevo] / Front Bumper Kit[Option] [New Type]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] [Tipo Arco] / Auxiliary Control Valve Kit (Scd) [Option] [Rops Type]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Tipo Arco] / Auxiliary Control Valve Kit (Fd) [Option] [Rops Type]
Distribuidor De Servicios Externos (Scd) [Componentes] [Opcion] [Tipo Arco] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [Rops Type]
Distribuidor De Servicios Externos (Fd) [Componentes] [Opcion] [Tipo Arco] / Auxiliary Control Valve (Fd) [Component Parts] [Option] [Rops Type]
Apoyo Del Paso [Opcion] / Step Support Kit [Option]
Volante / Flywheel
Ventilador / Fan
Freno / Brake
