Kubota Tractor M6800DT M6800SDT Parts Catalog
Model: Kubota M6800DT M6800SDT Tractor
Number of Pages: 540 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase [Rops Type]
Engine Oil Pan
Engine Cylinder Head [Rops Type] [Old Type] ## S.No.=3u2804 S.No.;=3u2804
Engine Cylinder Head [Rops Type] [New Type] ## S.No.=3w0001 S.No.;=3w0001
Engine Gear Case
Engine Head Cover
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft
Engine Flywheel
Engine Balancer
Engine Injection Pump
Engine Governor [Rops Type]
Engine Nozzle Holder And Glow Plug [Rops Type]
Engine Nozzle Holder [Component Parts]
Engine Pump Housing [Rops Type]
Engine Fork Lever (Governor)
Engine Governor Adjusting Bolt [Rops Type]
Engine Fuel Filter
Engine Water Flange And Thermostat [Rops Type] [Old Type] ## S.No.=3k1944 [Note Order By Fig.No
Engine Water Flange And Thermostat [Rops Type] [New Type] ## S.No.=3l0462 S.No
Engine Water Pump [Rops Type]
Engine Valve And Rocker Arm [Rops Type]
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Air Cleaner [Rops Type]
Engine Air Cleaner [Component Parts]
Engine Muffler [Rops Type] ## Note Order By Ref.No.010 And 080 New Parts.
Engine Hydraulic Pump Base
Engine Oil Cooler [Rops Type]
Engine Upper Gasket Kit [Old Type] ## S.No.=3k1944 S.No.;=3k1944
Engine Upper Gasket Kit [New Type] ## S.No.=3l0462 S.No.;=3l0462
Engine Lower Gasket Kit
Engine Hand Accelerator Lever [Rops Type]
Engine Engine Stop Wire [Rops Type]
Fuel System Fuel Tank Rh [Rops Type]
Fuel System Fuel Tank Lh [Rops Type]
Fuel System Fuel Pipe [Rops Type]
Fuel System Separator
Fuel System Separator [Component Parts]
Cooling Water System Fan
Cooling Water System Water Pipe [Rops Type]
Cooling Water System Radiator [Rops Type]
Cooling Water System Reserve Tank [Rops Type]
Electrical System Alternator [Rops Type]
Electrical System Alternator [Component Parts] [Rops Type]
Electrical System Starter [Rops Type]
Electrical System Starter [Component Parts]
Electrical System Battery [Rops Type]
Electrical System SwitchSensor [Rops Type] [Old Type] ## S.No.=59999 S.No
Electrical System SwitchSensor [Rops Type] [New Type] ## S.No.=60887 S.No
Electrical System Switch(Panel Board)Relay [Rops Type] [Old Type] ## S.No
Electrical System Switch(Panel Board)Relay [Rops Type] [New Type] ## S.No
Electrical System Panel Board [Rops Type] [Old Type] ## S.No.=59999 S.No
Electrical System Panel Board [Rops Type] [New Type] ## S.No.=60887 S.No
Electrical System Panel Board [Component Parts][Rops Type][Old Type] ## S.No
Electrical System Panel Board [Component Parts][Rops Type][New Type] ## S.No
Electrical System Head Light
Electrical System Hazard LightTail Light [Rops Type]
Electrical System Electrical Wiring 1 [Rops Type] [Old Type] ## S.No.=59999 S
Electrical System Electrical Wiring 1 [Rops Type] [New Type] ## S.No.=60887 S
Clutch Transmission Clutch Housing [Rops Type] [Old Type] ## S.No.=59999 S.No
Clutch Transmission Clutch Housing [Rops Type] [New Type] ## S.No.=60887 S.No
Clutch Transmission Shuttle Gear Case [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission Bearing Holder [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission Transmission Case [Rops Type] [Old Type] ## S.No.=59999 S
Clutch Transmission Transmission Case [Rops Type] [New Type] ## S.No.=60887 S
Clutch Transmission Transmission Case Rear Cover [Old Type] ## S.No.=59999 S
Clutch Transmission Transmission Case Rear Cover [New Type] ## S.No.=60887 S
Clutch Transmission Rear Axle Case
Clutch Transmission Front Drive Case [Rops Type]
Clutch Transmission Clutch [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission Clutch [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission Clutch Release Fork [Rops Type] [Old Type] ## S.No
Clutch Transmission Clutch Release Fork [Rops Type] [New Type] ## S.No
Clutch Transmission Clutch Pedal [Rops Type] [Old Type] ## S.No.=59999 S.No
Clutch Transmission Clutch Pedal [Rops Type] [New Type] ## S.No.=60887 S.No
Clutch Transmission Input Shaft [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission Input Shaft [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission First Shaft [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission First Shaft [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission Second Shaft [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission Second Shaft [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission Third Shaft [Rops Type] [Old Type] ## S.No.=59999 S.No
Clutch Transmission Third Shaft [Rops Type] [New Type] ## S.No.=60887 S.No
Clutch Transmission Back Idle Shaft [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission Creep Shaft
Clutch Transmission Bevel Gear [Old Type] ## S.No.=63404 S.No.;=63404
Clutch Transmission Bevel Gear [New Type] ## S.No.=63405 S.No.;=63405
Clutch Transmission Differential Rear [Rops Type]
Clutch Transmission PTO Propeller Shaft [Rops Type] [Old Type] ## S.No
Clutch Transmission PTO Propeller Shaft [Rops Type] [New Type] ## S.No
Clutch Transmission PTO Clutch [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission PTO Clutch [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission PTO Clutch [Component Parts] [Old Type] ## S.No.=59999 S
Clutch Transmission PTO Clutch [Component Parts] [New Type] ## S.No.=60887 S
Clutch Transmission PTO Clutch Valve [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission PTO Clutch Valve [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission PTO Clutch Valve [Component Parts]
Clutch Transmission PTO Shaft [Old Type] ## S.No.=59999 S.No.;=59999
Clutch Transmission PTO Shaft [New Type] ## S.No.=60887 S.No.;=60887
Clutch Transmission Front Propeller Shaft (Rear)
Speed Change Shift Fork Shift Lever Main Gear Shift Fork [Old Type] ## S.No
Speed Change Shift Fork Shift Lever Main Gear Shift Fork [New Type] ## S.No
Speed Change Shift Fork Shift Lever Shuttle Gear Shift Fork [Rops Type] [New Ty
Speed Change Shift Fork Shift Lever Range Gear Shift ForkCreep Gear Shift Fork [Rops Type]
Speed Change Shift Fork Shift Lever PTO Shift Fork
Speed Change Shift Fork Shift Lever Rear Differential Lock Shift Fork
Speed Change Shift Fork Shift Lever Main Gear Shift Lever [Rops Type]
Speed Change Shift Fork Shift Lever Shuttle Shift Lever [Rops Type] [New Type]
Speed Change Shift Fork Shift Lever Range Gear Shift LeverCreep Gear Shift Lever [Rops Typ
Speed Change Shift Fork Shift Lever Range Gear Shift RodCreep Gear Shift Rod [Rops Type] [
Speed Change Shift Fork Shift Lever PTO Clutch Lever [Rops Type]
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever
Speed Change Shift Fork Shift Lever Front Wheel Drive Lever [Rops Type]
Rear Axle Brake Rear Axle
Rear Axle Brake Brake
Rear Axle Brake Brake Rod [Rops Type]
Rear Axle Brake Parking Brake Lever [Rops Type]
Rear Axle Brake Parking Brake Rod [Rops Type] [Old Type] ## S.No.=65360 S.No
Rear Axle Brake Parking Brake Rod [Rops Type] [New Type] ## S.No.=65361 S.No
Rear Axle Brake Brake Pedal [Rops Type]
Rear Axle Brake Rear Differential Lock Pedal [Rops Type]
Front Axle Chassis Front Axle Frame [Rops Type] [Old Type] ## S.No.=59999 S.No
Front Axle Chassis Front Axle Frame [Rops Type] [New Type] ## S.No.=60887 S.No
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Front Propeller Shaft [Rops Type]
Front Axle Chassis Front Differential Case [Rops Type]
Front Axle Chassis Bevel Gear (Front)
Front Axle Chassis Differential Front
Front Axle Chassis Front Differential Lock Clutch [Rops Type]
Front Axle Chassis Bevel Gear Case [Rops Type]
Front Axle Chassis Front Axle Case
Front Axle Chassis Differential Gear Shaft
Steering Steering Handle [Rops Type] [Old Type] ## S.No.=59999 S.No.;=59999
Steering Steering Handle [Rops Type] [New Type] ## S.No.=60887 S.No.;=60887
Steering Steering Controller [Rops Type]
Steering Steering Controller [Component Parts]
Steering Tie RodSteering Cylinder [Rops Type]
Steering Steering Cylinder [Component Parts] [Old Type] ## S.No.=61723 S.No
Steering Steering Cylinder [Component Parts] [New Type] ## S.No.=61724 S.No
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Pipe (Suction) [Rops Type]
Hydraulic System Hydraulic Pipe (Delivery) [Rops Type]
Hydraulic System Hydraulic Oil Line (SteeringPTO) [Rops Type]
Hydraulic System Steering Hose (Delivery) [Rops Type]
Hydraulic System Hydraulic Cylinder [Rops Type]
Hydraulic System Hydraulic Lift Arm
Hydraulic System Hydraulic Cylinder Cover [Rops Type]
Hydraulic System Control Valve
Hydraulic System Draft And Position Control Lever [Rops Type]
Hydraulic System Position Control Shaft
Hydraulic System Draft Control Shaft
Hydraulic System Feed Back Lever [Rops Type]
Hydraulic System Auxiliary Control Valve (Scd) [Rops Type]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts] [Rops Type]
3-Point Linkage Drawbar Hitch Top Link Bracket [Rops Type]
3-Point Linkage Drawbar Hitch Top Link [Rops Type]
3-Point Linkage Drawbar Hitch Lower Link [Rops Type]
3-Point Linkage Drawbar Hitch Stabilizer [Old Type] ## S.No.=64514 S.No
3-Point Linkage Drawbar Hitch Stabilizer [New Type] ## S.No.=64515 S.No
3-Point Linkage Drawbar Hitch Lift Rod Rh
3-Point Linkage Drawbar Hitch Lift Rod Lh
3-Point Linkage Drawbar Hitch Swinging Drawbar
3-Point Linkage Drawbar Hitch PTO Shaft Protector
Hood Bonnet Hood(Bonnet) Front [Rops Type]
Hood Bonnet Hood(Bonnet) Upper [Rops Type]
Hood Bonnet Hood(Bonnet) Side [Rops Type] [Old Type] ## S.No.=59999 S.No
Hood Bonnet Hood(Bonnet) Side [New Type] ## S.No.=60887 S.No.;=60887
Hood Bonnet Hood(Bonnet) Side Cover [Rops Type]
Hood Bonnet Hood(Bonnet) Rear [Rops Type] [Old Type] ## S.No.=59999 S.No
Hood Bonnet Hood(Bonnet) Rear [Rops Type] [New Type] ## S.No.=60887 S.No
Hood Bonnet Rearview Mirror [Rops Type]
Hood Bonnet Fender [Rops Type]
Hood Bonnet Floor Seat [Rops Type]
Hood Bonnet Step [Rops Type]
Hood Bonnet Seat [Rops Type]
Hood Bonnet Tool Box [Rops Type]
Rops Rops [Rops Type] [Old Type] ## S.No.=61723 S.No.;=61723
Rops Rops [Rops Type] [New Type] ## S.No.=61724 S.No.;=61724
Front Rear Tire Front Wheel (9.5-24fl)
Front Rear Tire Rear Wheel (16.9-30fl)
Labels Label (Front) [Rops Type]
Labels Label (Rear) [Rops Type]
Accessories Accessories And Service Parts
Option Under Muffler Kit [Rops Type] [Option]
Option Working Light Kit [Rops Type] [Option]
Option Trailer Socket Kit [Rops Type] [Option]
Option Front Weight Kit [Option]
Option Front Bumper Kit [New Type] [Option] ## S.No.=60887 S.No.;=60887
Option Auxiliary Control Valve Kit (Scd) [Rops Type] [Option]
Option Auxiliary Control Valve Kit (Fd) [Rops Type] [Option]
Option Auxiliary Control Valve (Fd) [Component Parts] [Rops Type] [Option]
Option Step Support Kit [Option]
