Kubota Tractor M6800DT M6800SDT Old Parts Catalog
Model: Kubota M6800DT M6800SDT Old Tractor
Number of Pages: 588 Pages
(Old) Frequently Used Items Frequently Used Items
(Old) Engine Crankcase [Rops Type]
(Old) Engine Oil Pan
(Old) Engine Cylinder Head [Rops Type] [Old Type] ## S.No.=3u2804 S.No
(Old) Engine Cylinder Head [Rops Type] [New Type] ## S.No.=3w0001 S.No
(Old) Engine Gear Case
(Old) Engine Head Cover
(Old) Engine Camshaft And Idle Gear Shaft
(Old) Engine Piston And Crankshaft
(Old) Engine Flywheel
(Old) Engine Balancer
(Old) Engine Injection Pump
(Old) Engine Governor [Rops Type]
(Old) Engine Nozzle Holder And Glow Plug [Rops Type]
(Old) Engine Nozzle Holder [Component Parts]
(Old) Engine Pump Housing [Rops Type]
(Old) Engine Fork Lever (Governor)
(Old) Engine Governor Adjusting Bolt [Old Part] ## S.No.;=4e2638
(Old) Engine Governor Adjusting Bolt [New Type] ## S.No.=4g0001 S.No.;=4g0001
(Old) Engine Fuel Filter [Rops Type]
(Old) Engine Water Flange And Thermostat [Rops Type] [Old Type] ## S.No.=3k1944 [NoteOrder By Fig
(Old) Engine Water Flange And Thermostat [Rops Type] [New Type] ## S.No
(Old) Engine Water Pump [Rops Type]
(Old) Engine Valve And Rocker Arm [Rops Type]
(Old) Engine Inlet Manifold
(Old) Engine Exhaust Manifold
(Old) Engine Air Cleaner [Rops Type]
(Old) Engine Air Cleaner [Component Parts]
(Old) Engine Muffler [Rops Type] ## NoteOrder By Ref.No.010 And 080 New Parts.
(Old) Engine Hydraulic Pump Base
(Old) Engine Oil Cooler [Rops Type]
(Old) Engine Upper Gasket Kit [Old Type] ## S.No.=3k1944 S.No.;C=3k1944
(Old) Engine Upper Gasket Kit [New Type] ## S.No.=3l0462 S.No.;C=3l0462
(Old) Engine Lower Gasket Kit
(Old) Engine Hand Accelerator Lever [Rops Type]
(Old) Engine Engine Stop Wire [Rops Type]
(Old) Fuel System Fuel Tank Rh [Rops Type]
(Old) Fuel System Fuel Tank Lh [Rops Type]
(Old) Fuel System Fuel Pipe [Rops Type]
(Old) Fuel System Separator
(Old) Fuel System Separator [Component Parts]
(Old) Cooling Water System Fan
(Old) Cooling Water System Water Pipe [Rops Type]
(Old) Cooling Water System Radiator [Rops Type]
(Old) Cooling Water System Reserve Tank [Rops Type]
(Old) Electrical System Alternator [Rops Type]
(Old) Electrical System Alternator [Component Parts] [Rops Type]
(Old) Electrical System Starter [Rops Type]
(Old) Electrical System Starter [Component Parts]
(Old) Electrical System Battery [Rops Type]
(Old) Electrical System SwitchSensor [Rops Type] [Old Type] ## S.No.;=59999
(Old) Electrical System SwitchSensor [Rops Type] [New Type] ## S.No.=60001 S
(Old) Electrical System Switch(Panel Board)Relay [Rops Type] [New Type] ## S.No
(Old) Electrical System Panel Board [Rops Type] [Old Type] ## S.No.=59999 S.No
(Old) Electrical System Panel Board [Rops Type] [New Type] ## S.No.=60001 S.No
(Old) Electrical System Panel Board [Component Parts][Rops Type][Old Type] ## S
(Old) Electrical System Panel Board [Component Parts][Rops Type][New Type] ## S
(Old) Electrical System Head Light
(Old) Electrical System Hazard LightTail Light [Rops Type] [Old Type] ## S.No
(Old) Electrical System Hazard LightTail Light [Rops Type] [New Type] ## S.No
(Old) Electrical System Electrical Wiring [Rops Type] [Old Type] ## S.No
(Old) Electrical System Electrical Wiring [Rops Type] [New Type] ## S.No
(Old) Clutch Transmission Clutch Housing [Rops Type] [Old Type] ## S.No
(Old) Clutch Transmission Clutch Housing [Rops Type] [New Type] ## S.No
(Old) Clutch Transmission Shuttle Gear Case [New Type] ## S.No.=60001 S.No
(Old) Clutch Transmission Bearing Holder [Old Type] ## S.No.=59999 S.No
(Old) Clutch Transmission Transmission Case [Rops Type] [Old Type] ## S.No
(Old) Clutch Transmission Transmission Case [Rops Type] [New Type] ## S.No
(Old) Clutch Transmission Transmission Case Rear Cover [Rops Type][Old Type] ## S
(Old) Clutch Transmission Transmission Case Rear Cover [New Type] ## S.No
(Old) Clutch Transmission Rear Axle Case
(Old) Clutch Transmission Front Drive Case
(Old) Clutch Transmission Clutch [Rops Type] [Old Type] ## S.No.=59999 S.No
(Old) Clutch Transmission Clutch [New Type] ## S.No.=60001 S.No.;C=60001
(Old) Clutch Transmission Clutch Release Fork [Rops Type] [Old Type] ## S.No
(Old) Clutch Transmission Clutch Release Fork [Rops Type] [New Type] ## S.No
(Old) Clutch Transmission Clutch Pedal [Rops Type] [Old Type] ## S.No.=59999 S
(Old) Clutch Transmission Clutch Pedal [Rops Type] [New Type] ## S.No.=60001 S
(Old) Clutch Transmission Input Shaft [Rops Type] [Old Type] ## S.No.=59999 S
(Old) Clutch Transmission Input Shaft [New Type] ## S.No.=60001 S.No.;C=60001
(Old) Clutch Transmission First Shaft [Rops Type] [Old Type] ## S.No.=59999 S
(Old) Clutch Transmission First Shaft [New Type] ## S.No.=60001 S.No.;C=60001
(Old) Clutch Transmission Second Shaft [Rops Type] [Old Type] ## S.No.=59999 S
(Old) Clutch Transmission Second Shaft [New Type] ## S.No.=60001 S.No.;C=60001
(Old) Clutch Transmission Third Shaft [WO Creep] [Rops Type] [Old Type] ## S.No
(Old) Clutch Transmission Third Shaft [WO Creep] [Rops Type] [New Type] ## S.No
(Old) Clutch Transmission Back Idle Shaft [New Type] ## S.No.=60001 S.No
(Old) Clutch Transmission Bevel Gear [Old Type] ## S.No.=63404 S.No.;C=63404
(Old) Clutch Transmission Bevel Gear [New Type] ## S.No.=63405 S.No.;C=63405
(Old) Clutch Transmission Differential Rear [Rops Type]
(Old) Clutch Transmission PTO Propeller Shaft [Rops Type] [Old Type] ## S.No
(Old) Clutch Transmission PTO Propeller Shaft [Rops Type] [New Type] ## S.No
(Old) Clutch Transmission PTO Clutch [Rops Type] [Old Type] ## S.No.=59999 S.No
(Old) Clutch Transmission PTO Clutch [New Type] ## S.No.=60001 S.No.;C=60001
(Old) Clutch Transmission PTO Clutch [Component Parts] [Rops Type] [Old Type] ##
(Old) Clutch Transmission PTO Clutch [Component Parts] [New Type] ## S.No
(Old) Clutch Transmission PTO Clutch Valve [Rops Type] [Old Type] ## S.No
(Old) Clutch Transmission PTO Clutch Valve [New Type] ## S.No.=60001 S.No
(Old) Clutch Transmission PTO Clutch Valve [Component Parts]
(Old) Clutch Transmission PTO Shaft
(Old) Clutch Transmission Front Propeller Shaft (Rear)
(Old) Speed Change Shift Fork Shift Lever Main Gear Shift Fork [Rops Type] [Old Type] ## S
(Old) Speed Change Shift Fork Shift Lever Main Gear Shift Fork [New Type] ## S
(Old) Speed Change Shift Fork Shift Lever Shuttle Gear Shift Fork [Rops Type] [New Type] #
(Old) Speed Change Shift Fork Shift Lever Range Gear Shift ForkCreep Gear Shift Fork [Rops Type] [O
(Old) Speed Change Shift Fork Shift Lever Range Gear Shift Fork [Rops Type] [New Type] ##
(Old) Speed Change Shift Fork Shift Lever Rear Differential Lock Shift Fork
(Old) Speed Change Shift Fork Shift Lever Main Gear Shift Lever [Rops Type]
(Old) Speed Change Shift Fork Shift Lever Shuttle Shift Lever [Rops Type] [New T
(Old) Speed Change Shift Fork Shift Lever Range Gear Shift LeverCreep Gear Shift Lever [Rops Type]
(Old) Speed Change Shift Fork Shift Lever Range Gear Shift Lever [Rops Type] [New Type] ##
(Old) Speed Change Shift Fork Shift Lever Range Gear Shift RodCreep Gear Shift Rod [Rops Ty
(Old) Speed Change Shift Fork Shift Lever PTO Clutch Lever [Rops Type]
(Old) Speed Change Shift Fork Shift Lever Front Wheel Drive Lever [Rops Type]
(Old) Rear Axle Brake Rear Axle
(Old) Rear Axle Brake Brake
(Old) Rear Axle Brake Brake Rod [Rops Type]
(Old) Rear Axle Brake Brake Pedal [Rops Type]
(Old) Rear Axle Brake Rear Differential Lock Pedal [Rops Type]
(Old) Front Axle Chassis Front Axle Frame [Rops Type]
(Old) Front Axle Chassis Front Axle Bracket
(Old) Front Axle Chassis Front Propeller Shaft [Rops Type]
(Old) Front Axle Chassis Front Differential Case
(Old) Front Axle Chassis Bevel Gear (Front)
(Old) Front Axle Chassis Differential Front
(Old) Front Axle Chassis Front Differential Lock Clutch [Rops Type]
(Old) Front Axle Chassis Bevel Gear Case [Rops Type]
(Old) Front Axle Chassis Front Axle Case
(Old) Front Axle Chassis Differential Gear Shaft
(Old) Steering Steering Handle [Rops Type] [Old Type] ## S.No.=59999 S.No
(Old) Steering Steering Handle [Rops Type] [New Type] ## S.No.=60001 S.No
(Old) Steering Steering Controller [Rops Type]
(Old) Steering Steering Controller [Component Parts]
(Old) Steering Tie RodSteering Cylinder [Rops Type]
(Old) Steering Steering Cylinder [Component Parts] [Old] ## S.No.=61723 S.No
(Old) Steering Controller Steering Cylinder [Component Parts] [New] ## S.No
(Old) Hydraulic System Hydraulic Pump
(Old) Hydraulic System Hydraulic Pump [Component Parts]
(Old) Hydraulic System Hydraulic Pipe (Suction) [Rops Type]
(Old) Hydraulic System Hydraulic Pipe (Delivery) [Rops Type]
(Old) Hydraulic System Hydraulic Oil Line (SteeringPTO) [Rops Type]
(Old) Hydraulic System Steering Hose (Delivery) [Rops Type]
(Old) Hydraulic System Hydraulic Cylinder [Rops Type]
(Old) Hydraulic System Hydraulic Lift Arm
(Old) Hydraulic System Hydraulic Cylinder Cover [Rops Type]
(Old) Hydraulic System Control Valve
(Old) Hydraulic System Draft And Position Control Lever [Rops Type]
(Old) Hydraulic System Position Control Shaft
(Old) Hydraulic System Draft Control Shaft
(Old) Hydraulic System Feed Back Lever [Rops Type]
(Old) Hydraulic System Auxiliary Control Valve (Scd) [Rops Type]
(Old) Hydraulic System Auxiliary Control Valve (Scd) [Component Parts] [Rops Type
(Old) 3-Point Linkage Drawbar Hitch Top Link Bracket [Rops Type]
(Old) 3-Point Linkage Drawbar Hitch Top Link [Rops Type]
(Old) 3-Point Linkage Drawbar Hitch Lower Link
(Old) 3-Point Linkage Drawbar Hitch Stabilizer [Old Type] ## S.No.=64514 S.No
(Old) 3-Point Linkage Drawbar Hitch Stabilizer [New Type] ## S.No.=64515 S.No
(Old) 3-Point Linkage Drawbar Hitch Lift Rod Rh
(Old) 3-Point Linkage Drawbar Hitch Lift Rod Lh
(Old) 3-Point Linkage Drawbar Hitch Swinging Drawbar
(Old) 3-Point Linkage Drawbar Hitch PTO Shaft Protector [A]
(Old) 3-Point Linkage Drawbar Hitch PTO Shaft Protector [Ca]
(Old) Hood (Bonnet) Front [Rops Type]
(Old) Hood (Bonnet) Upper [Rops Type]
(Old) Hood (Bonnet) Side [Rops Type] [Old Type] ## S.No.=59999 S.No
(Old) Hood (Bonnet) Side [Rops Type] [New Type] ## S.No.=60001 S.No
(Old) Hood (Bonnet) Side Cover [Rops Type]
(Old) Hood (Bonnet) Rear [A] [Rops Type] [Old Type] ## S.No.=59999 S
(Old) Hood (Bonnet) Rear [A] [Rops Type] [New Type] ## S.No.=60001 S
(Old) Hood (Bonnet) Rear [Ca] [Rops Type] [Old Type] ## S.No
(Old) Hood (Bonnet) Rear [Ca] [Rops Type] [New Type] ## S.No
(Old) Hood Bonnet Fender [A] [Rops Type]
(Old) Hood Bonnet Fender [Ca] [Rops Type]
(Old) Hood Bonnet Floor Sheet [A] [Rops Type]
(Old) Hood Bonnet Floor Sheet [Ca] [Rops Type]
(Old) Hood Bonnet Step [Rops Type]
(Old) Hood Bonnet Seat [Rops Type]
(Old) Hood Bonnet Tool Box [Rops Type]
(Old) Hood Bonnet SMV Emblem [Rops Type]
(Old) Rops Rops [Rops Type] [Old Type] ## S.No.=61723 S.No.;C=61723
(Old) Rops Rops [Rops Type] [New Type] ## S.No.=61724 S.No.;C=61724
(Old) Front Rear Tire Front Wheel (9.5-24)
(Old) Front Rear Tire Rear Wheel (16.9-30)
(Old) Labels Label [A] [Rops Type] [Old Type] ## S.No.=59999 [NoteOrder By Fig
(Old) Labels Label [Ca] [Rops Type] [Old Type] ## S.No
(Old) Labels Label (Front) [A] [Rops Type] [New Type] ## S.No.=60001 S.No
(Old) Labels Label (Front) [Ca] [Rops Type] [New Type] ## S.No
(Old) Labels Label (Rear) [A] [Rops Type] [New Type] ## S.No.=60001 S.No
(Old) Labels Label (Rear) [Ca] [Rops Type] [New Type] ## S.No
(Old) Accessories Accessories And Service Parts
(Old) Option Under Muffler Kit [Rops Type] [Option]
(Old) Option Working Light Kit (WG No.M9551) [Rops Type] [Option]
(Old) Option Trailer Socket Kit [Rops Type] [Option]
(Old) Option Creep Speed Kit (GearShaft) [Rops Type] [Old Type] [Option] ## S
(Old) Option Creep Speed Kit (GearShaft) [New Type] [Option] ## S.No.=60001 S
(Old) Option Creep Speed Kit (Shift Fork) [Rops Type] [New Type] [Option] ## S
(Old) Option Creep Speed Kit (Lever) [Rops Type] [New Type] [Option] ## S.No
(Old) Option Front Weight Bumper Kit [Option]
(Old) Option Front Bumper Kit [Option]
(Old) Option Auxiliary Control Valve Kit (Scd) [Rops Type] [Option]
(Old) Option Auxiliary Control Valve Kit (Fd) [Rops Type] [Option]
(Old) Option Auxiliary Control Valve (Fd) [Component Parts] [Rops Type] [Option]
(Old) Option DrawbarHitch [Option]
(Old) Option Step Support Kit [Option]
