Kubota Tractor M6060DTHC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M6060DTHC Tractor
Number of Pages: 340 Pages
Frequently Used It Ems / Frequently Used Items
Crankcase / Crankcase
Oil Filler Pulg / Oil Filler Pulg
Oil Pan / Oil Pan
Cylinder Head / Cylinder Head
Inlet Valve And Exhaust Valve / Inlet Valve And Exhaust Valve
Rocker Arm Shaft / Rocker Arm Shaft
Head Cover / Head Cover
Front Cover / Front Cover
Piston And Crankshaft / Piston And Crankshaft
Camshaft And Idle Gear Shaft / Camshaft And Idle Gear Shaft
Balancer / Balancer
Flywheel / Flywheel
Supply Pump / Supply Pump
Fuel Filter / Fuel Filter
Injector And Glow Plug / Injector And Glow Plug
Injection Pipe / Injection Pipe
Common Rail / Common Rail
Water Flange And Thermostat / Water Flange And T Hermostat
Water Pump / Water Pump
Inlet Manifold / Inlet Manifold
Air Cleaner Flange And Throttle Valve / Air Clea Ner Flange And Throttle Valve
Exhaust Manifold / Exhaust Manifold
Egr Valve / Egr Valve
Egr Cooler / Egr Cooler
Egr Water Piping / Egr Water Piping
Turbo Charger / Turbo Charger
Air Cleaner / Air Cleaner
Air Cleaner [Component Parts] / Air Cleaner [Com Ponent Parts]
Inlet Pipe / Inlet Pipe
Muffler Pipe / Muffler Pipe
Diesel Particulate Filter Muffler / Diesel Parti Culate Filter Muffler
Diesel Particulate Filter Muffler [Component Par Ts] / Diesel Particulate Filter Muffler [Component Parts]
Muffler Sensor / Muffler Sensor
Oil Separator / Oil Separator
Oil Separator [Component Parts] / Oil Separator [Component Parts]
Oil Separator Pipe / Oil Separator Pipe
Oil Pipe (Turbo Charger) / Oil Pipe (Turbo Charg Er)
Oil Cooler / Oil Cooler
Upper Gasket Kit / Upper Gasket Kit
Lower Gasket Kit / Lower Gasket Kit
Engine Electrical Parts / Engine Electrical Part S
Accelerator Lever / Accelerator Lever
Accelerator Pedal / Accelerator Pedal
Fuel Tank [Ec] [Uk] / Fuel Tank [Ec] [ Uk]
Fuel Filler / Fuel Filler
Fuel Pipe (Filter/Supply Pump) / Fuel Pipe (Filter/Supply Pump)
Fuel Pipe (Fuel Pump) / Fuel Pipe (Fue L Pump)
Fuel Pipe (Fuel Cooler) / Fuel Pipe (F Uel Cooler)
Fuel Cooler / Fuel Cooler
Separator / Separator
Separator [Component Parts] / Separato R [Component Parts]
Fan Bracket / Fan Br Acket
Fan / Fan
Water Pipe / Water P Ipe
Radiator / Radiator
Reserve Tank / Reser Ve Tank
Alternator / Alternator
Alternator [Component Part S] / Alternator [Component Parts]
Starter / Starter
Starter [Component Parts] / Starter [Component Parts]
Battery / Battery
Switch/Sensor (Fuel Unit/H Orn) [Ec] [Uk] / Switch/Sensor (Fuel Unit/Horn) [Ec ] [Uk]
Switch/Sensor (Engine) / S Witch/Sensor (Engine)
Switch/Sensor (Clutch Hous Ing/Transmission Case) / Switch/Sensor (Clutch Hous Ing/Transmission Case)
Switch (Panel Board) / Swi Tch (Panel Board)
Switch (Panel) / Switch (P Anel)
Relay / Relay
Electronic Control Unit / Electronic Control Unit
Panel Board / Panel Board
Head Light / Head Light
Head Light [Component Part S] / Head Light [Component Parts]
Front Combination Light / Front Combination Light
Working Light/Beacon Light [Ec] [Ita] / Working Light/Beacon Light [Ec] [Ita]
Rear Combination Light / R Ear Combination Light
License Lamp / License Lam P
Trailer Socket / Trailer S Ocket
Room Light / Room Light
Radio Speaker [Ec] [Ita] / Radio Speaker [Ec] [Ita]
Washer Tank / Washer Tank
Front Wiper / Front Wiper
Electrical Wiring (Crs) / Electrical Wiring (Crs)
Electrical Wiring (Engine) / Electrical Wiring (Engine)
Electrical Wiring (Main) [ Ec] [Uk] / Electrical Wiring (Main) [Ec] [Uk]
Electrical Wiring (Cab) [E C] [Ita] / Electrical Wiring (Cab) [Ec] [Ita]
Clutch Housing / Clutc H Housing
Shuttle Gear Case / Sh Uttle Gear Case
Shift Cover / Shift Co Ver
Transmission Case [Ec] [Uk] / Transmission Case [Ec] [Uk]
Transmission Case Rear Cover / Transmission Case Rear Cover
Rear Axle Case Rh / Re Ar Axle Case Rh
Rear Axle Case Lh / Re Ar Axle Case Lh
Damper Disk / Damper D Isk
Clutch Cable / Clutch Cable
Valve Lever (Clutch) / Valve Lever (Clutch)
Input Shaft / Input Sh Aft
Clutch Pack (Shuttle) [Component Parts] / Clutch Pack (Shuttle) [Componen T Parts]
Shuttle Shaft / Shuttl E Shaft
First Shaft / First Sh Aft
Second Shaft / Second Shaft
Third Shaft / Third Sh Aft
Drive Shaft / Drive Sh Aft
Creep Shaft / Creep Sh Aft
Bevel Gear [Ec] [Uk] / Bevel Gear [Ec] [Uk]
Rear Differential / Re Ar Differential
Pto Propeller Shaft / Pto Propeller Shaft
Pto Clutch [Ec] [Uk] / Pto Clutch [Ec] [Uk]
Pto Clutch [Component Parts] / Pto Clutch [Component Parts]
Pto Clutch Valve / Pto Clutch Valve
Pto Shaft / Pto Shaft
Front Drive Clutch / F Ront Drive Clutch
Front Drive Clutch [Co Mponent Parts] / Front Drive Clutch [Component Part S]
Main Gear Shift Fork / Main Gear Shift Fork
Range Gear Shift Fork/Creep Gear Shift Fork / Range Gear Shift Fork/Creep Gear Shift Fork
Rear Differential Lock Shift Fork / Rea R Differential Lock Shift Fork
Main Gear Shift Lever / Main Gear Shift Lever
Main Gear Shift Rod / Main Gear Shift R Od
Shuttle Shift Lever / Shuttle Shift Lev Er
Shuttle Cable / Shuttle Cable
Range And Creep Gear Shift Lever / Rang E And Creep Gear Shift Lever
Pto Gear Shift Lever / Pto Gear Shift L Ever
Rear Axle / Rear Axle
Brake Rh / Brake Rh
Brake Lh / Brake Lh
Parking Brake Rod / Parking Br Ake Rod
Parking Brake Camshaft / Parki Ng Brake Camshaft
Parking Brake Lever / Parking Brake Lever
Brake Pedal / Brake Pedal
Brake Master Cylinder / Brake Master Cylinder
Brake Master Cylinder [Compone Nt Parts] / Brake Master Cylinder [Component Parts]
Brake Pipe / Brake Pipe
Front Axle Frame / Front Axle Frame
Front Axle Bracket / Fro Nt Axle Bracket
Propeller Shaft / Propel Ler Shaft
Front Differential Case / Front Differential Case
Bevel Gear (Front) / Bev El Gear (Front)
Front Differential / Fro Nt Differential
Bevel Gear Case Rh / Bev El Gear Case Rh
Bevel Gear Case Lh / Bev El Gear Case Lh
Front Axle Case Rh / Fro Nt Axle Case Rh
Differential Gear Shaft Rh / Differential Gear Shaft Rh
Differential Gear Shaft Lh / Differential Gear Shaft Lh
Front Axle Rh / Front Ax Le Rh
Front Axle Lh / Front Ax Le Lh
Steering Handle / Steering Handle
Tilt Pedal / Tilt Pedal
Steering Joint / Steering Joint
Steering Controller / Steering Controller
Steering Controller [Component Parts] / Stee Ring Controller [Component Parts]
Tie Rod/Steering Cylinder / Tie Rod/Steering Cylinder
Steering Cylinder [Component Parts] / Steeri Ng Cylinder [Component Parts]
Hydraulic Pump / Hydraulic P Ump
Hydraulic Pump [Component Pa Rts] / Hydraulic Pump [Component Parts]
Hydraulic Pipe (Delivery) / Hydraulic Pipe (Delivery)
Hydraulic Oil Line (Steering /Pto) / Hydraulic Oil Line (Steering/Pto)
Hydraulic Oil Line (Shuttle/ Controller) / Hydraulic Oil Line (Shuttle/Controlle R)
Steering Hose (Delivery) / S Teering Hose (Delivery)
Solenoid Valve Pipe / Soleno Id Valve Pipe
Hydraulic Cylinder Case / Hy Draulic Cylinder Case
Hydraulic Lift Arm / Hydraul Ic Lift Arm
Safety Valve/Relief Valve / Safety Valve/Relief Valve
Lowering Lock Lever / Loweri Ng Lock Lever
Control Valve / Control Valv E
Position Control Lever / Pos Ition Control Lever
Draft And Position Control L Ever / Draft And Position Control Lever
Draft And Position Control R Od / Draft And Position Control Rod
Position And Draft Shaft / P Osition And Draft Shaft
Feed Back Lever / Feed Back Lever
Auxiliary Control Valve (S/D ) [Component Parts] / Auxiliary Control Valve (S/D) [Component Parts]
Auxiliary Control Valve (Scd ) [Component Parts] / Auxiliary Control Valve (Scd) [Component Parts]
Auxiliary Control Valve Leve R (1st) / Auxiliary Control Valve Lever (1st)
Auxiliary Control Valve Leve R (2nd) / Auxiliary Control Valve Lever (2nd)
3p-Lift Assist Cylinder Lh / 3p-Lift Assist Cylinder Lh
3p-Lift Assist Cylinder Rh / 3p-Lift Assist Cylinder Rh
3p-Lift Assist Cylinder [Com Ponent Parts] / 3p-Lift Assist Cylinder [Component Parts]
To P Link Bracket / Top Link Bracket
To P Link / Top Link
Lo Wer Link / Lower Link
St Abilizer / Stabilizer
Li Ft Rod Rh / Lift Rod Rh
Li Ft Rod Lh / Lift Rod Lh
Pt O Protector / Pto Protector
Front Grille / Front Grille
Hood (Bonnet) Upper / Hood (Bonnet) Up Per
Hood (Bonnet) Upper (Sound Absorber/In Sulator) / Hood (Bonnet) Upper (Sound Absorber/Insu Lator)
Hood (Bonnet) Damper / Hood (Bonnet) D Amper
Bonnet Lock / Bonnet Lock
Hood (Bonnet) Side Cover / Hood (Bonne T) Side Cover
Bonnet Support / Bonnet Support
Cab Frame [Ec] [Uk] / Cab Frame [Ec] [Uk]
Ste P / Step
Hoo D (Bonnet) Rear / Hood (Bonnet) Rear
Fro Nt Glass / Front Glass
Doo R Rh / Door Rh
Doo R Lh / Door Lh
Doo R Lock Rh / Door Lock Rh
Doo R Lock Lh / Door Lock Lh
Sid E Window / Side Window
Rea R Window / Rear Window
Inn Er Roof / Inner Roof
Out Er Roof / Outer Roof
Flo Or Mat / Floor Mat
Ins Pection Plate [Ec] [Uk] / Inspection Plate [Ec] [Uk ]
Fen Der Cover Rh / Fender Cover Rh
Fen Der Cover Lh / Fender Cover Lh
Fen Der / Fender
Cab Bracket Front / Cab Bracket Front
Cab Bracket Rear / Cab Bracket Rear
Too L Box / Tool Box
Air Conditioner / Air Conditio Ner
Air Conditioner Duct / Air Con Ditioner Duct
Mode Case / Mode Case
Dashboard Air Outlets / Dashbo Ard Air Outlets
Inner Air Recirculation / Inne R Air Recirculation
Heater Hose / Heater Hose
Condenser / Condenser
Air Conditioner Hose / Condens Er Hose / Air Conditioner Hose / Condenser Hose
Compressor / Compressor
Label (Rear) [Ec] [Uk] / Label (Rear) [Ec] [Uk]
Accessories / Accessories
Under Muffler Kit [Option] / Under Muffler Kit [ Option]
Ecu Kit [Option] / Ecu Kit [Option]
Alternator Kit (Alternator) [Option] / Alternato R Kit (Alternator) [Option]
Alternator Kit (Wire Harness) [Option] / Alterna Tor Kit (Wire Harness) [Option]
Working Light Kit [Option] / Working Light Kit [ Option]
Rear Defogger Kit (Alternator) [Option] / Rear D Efogger Kit (Alternator) [Option]
Rear Defogger Kit (Glass) [Option] / Rear Defogg Er Kit (Glass) [Option]
Rear Defogger Kit (Wire Harness) [Option] / Rear Defogger Kit (Wire Harness) [Option]
Rear Wiper Kit [Option] / Rear Wiper Kit [Option ]
Fuse Kit [Option] / Fuse Kit [Option]
Implement Monitor Stay Kit [Option] / Implement Monitor Stay Kit [Option]
Pto(540/1000) Conversion Kit [Option] / Pto(540/ 1000) Conversion Kit [Option]
4wd Clutch Upgrade Kit [Option] / 4wd Clutch Upg Rade Kit [Option]
4wd Clutch [Component Parts] [Option] / 4wd Clut Ch [Component Parts] [Option]
Front Bumper Kit [Option] / Front Bumper Kit [Op Tion]
Auxiliary Control Valve Kit (Scd) [Option] / Aux Iliary Control Valve Kit (Scd) [Option]
Auxiliary Control Valve Kit (Fd) [Option] / Auxi Liary Control Valve Kit (Fd) [Option]
Auxiliary Control Valve Kit (Fc) [Option] / Auxi Liary Control Valve Kit (Fc) [Option]
Valve Auxiliaire (Fd) [Parties Composantes] [Opt Ion] / Valve Auxiliaire (Fd) [Parties Composantes] [Option]
Auxiliary Control Valve (Fc) [Component Parts] [ Option] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Auxiliary Control Valve Lever Kit (3rd) [Option] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Trailer Brake Valve Kit 1 (Valve/Pipe) [Option] [Ec] [Uk] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option] [Ec] [Uk]
Trailer Brake Valve Kit 2 (Pipe) [Option] [Ec] [ Uk] / Trailer Brake Valve Kit 2 (Pipe) [Option] [Ec ] [Uk]
Oil Pan / Oil Pan
Balancer / Balancer
Flywheel / Flywheel
Fan / Fan
Radiator / Radiator
Starter / Starter
Battery / Battery
Relay / Relay
Brake Rh / Brake Rh
Brake Lh / Brake Lh
Ste P / Step
Doo R Rh / Door Rh
Doo R Lh / Door Lh
Fen Der / Fender
