Kubota Tractor M6060DTH Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M6060DTH Tractor
Number of Pages: 267 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaus T Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glow Pl Ug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throttle Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar [Peças Componentes] / Air Cleaner [Compo Nent Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Diese L Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [C Omponent Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Separador Oleo / Oil Separator
Separador Oleo [Peças Componentes] / Oil Separator [Component Parts]
Turbo Separador Oleo / Oil Separator Pipe
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Kit Junta (Superior) / Upper Gasket Kit
Kit Junta (Inferior) / Lower Gasket Kit
Componentes Electricos Motor / Engine Electrical P Arts
Deposito Combustivel / Fuel Tan K
Fornecimento Combustivel / Fuel Filler
Tubo Combustivel (Filtro/Bomba) / Fuel Pipe (Filter/Supply Pump)
Tubo Combustivel (Bomba) / Fuel Pipe (Fuel Pump)
Tubo Combustivel (Arrefecedor G Asoleo) / Fuel Pipe (Fuel Cooler)
Arrefecedor Gasoleo / Fuel Cool Er
Separador / Separator
Suporte Ve Ntilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito R Eserva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Interruptor/Sensor (Abastec A Unidade) / Switch/Sensor (Fuel Unit/Horn)
Interruptor/Sensor (Maquina ) / Switch/Sensor (Engine)
Interruptor/Sensor (Carter Embraiagem/Caixa Velocidades) / Switch/Sensor (Clut Ch Housing/Transmission Case)
Interruptor (Painel) / Swit Ch (Panel Board)
Rele / Relay
Unidade Control Electrico / Electronic Control Unit
Painel / Panel Board
Luzes Frontais / Front Comb Ination Light
Braco Traseiro / Rear Combi Nation Lamp
Farol Matricula / License L Amp
Ficha Reboque / Trailer Soc Ket
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Electrica (Frente) / Electrical Wiring (Front)
Cablagem Electrica (Princip Al) / Electrical Wiring (Rear)
Valvula Inversor / S Huttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo Traseiro (Drt) / Rear Axle Case Rh
Disco Amortecedor / Damper Disk
Pedal Embraiagem / C Lutch Pedal
Valvula (Inversor) / Valve Lever (Clutch)
Veio Primario / Inpu T Shaft
Embraiagem Inversor (Inversor) [Peças Componentes] / Clutch Pack (Shutt Le) [Component Parts]
Veio Inversor / Shut Tle Shaft
Primeiro Veio / Firs T Shaft
Secundario Veio / Se Cond Shaft
Terceiro Veio / Thir D Shaft
Veio / Drive Shaft
Veio Creeper / Creep Shaft
Grupo Conico / Bevel Gear
Diferencial Traseiro / Rear Differential
Veio Tdf / Pto Prope Ller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peça S Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem T Df / Pto Clutch Valve
Veio Tdf / Pto Shaft
Embraiagem Andamento / Front Drive Clutch
Veio Embraiagem [Peç As Componentes] / Front Drive Clutch [Component Par Ts]
Forqueta Caixa/Creeper / Range Gear Shift Fork/Creep Gear Sh Ift Fork
Alavanca / Rear Differential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Alvanca I Nversor / Shuttle Shift Lever
Cabo Inve Rsor / Shuttle Cable
Gama E Ti Rante Caixa Creep / Range And Creep Gear Shift Leve R
Eixo Traseiro / Rear Axle
Travao (Drt) / Brake Rh
Travao (Esq) / Brake Lh
Tirante Travao Mao / Park Ing Brake Rod
Veio Bloqueio / Parking B Rake Camshaft
Alavanca Travao Mao / Par King Brake Lever
Pedal Travao / Brake Peda L
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compo Nent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Frente / Front A Xle Frame
Suporte Eixo Dianteiro / Fron T Axle Bracket
Veio Primario / Propeller Sha Ft
Caixa Diferencial Dianteiro / Front Differential Case
Grupo Conico Frente (Frente) / Bevel Gear (Front)
Caixas Engrenagens Conica (Dr T) / Bevel Gear Case Rh
Caixas Engrenagens Conica (Es Q) / Bevel Gear Case Lh
Carter Eixo Frente (Drt) / Fr Ont Axle Case Rh
Carter Eixo Frente (Esq) / Fr Ont Axle Case Lh
Carreto Diferencial (Drt) / D Ifferential Gear Shaft Rh
Carreto Diferencial (Esq) / D Ifferential Gear Shaft Lh
Veio Transmissao (Drt) / Fron T Axle Rh
Veio Transmissao (Esq) / Fron T Axle Lh
Pedal Inclinacao / Tilt Pedal
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / S Teering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering C Ylinder
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico [Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrege) / Hydra Ulic Oil Line (Delivery)
Circuito Oleo Direcção (Dir Eccao/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Controller)
Tubo Direccao (Entrega) / S Teering Hose (Delivery)
Tubo Valvula Solenoide / So Lenoid Valve Pipe
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Hidraulico Braços / Hydraul Ic Lift Arm
Valvula Segurança/Distribui Dor Redução / Safety Valve/Relief Valve
Trinco / Lowering Lock Valv E
Valvula Control / Control V Alve
Alavanca Control Posicao / Position Control Lever
Alavanca Control Esforço / Draft And Position Control Lever
Veio Posicao Esforço / Posi Tion And Draft Shaft
Alimente Alavanca Atras / F Eed Back Lever
Distribuidor Auxiliar / Aux Iliary Control Valve
Alavanca Valvula Auxiliar ( Primeiro) / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Auxiliar ( Segundo) / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Elevac Ao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevac Ao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevac Ao [Peças Componentes] / 3p-Lift Assist Cylinder [C Omponent Parts]
Parte Superior / Top Link Bracket
Ligaca O Superior / Top Link
Ligaca O Inferior / Lower Link
Estabi Lizador / Stabilizer
Estabi Lizador (Drt) / Lift Rod Rh
Estabi Lizador (Esq) / Lift Rod Lh
Barra / Drawbar Bracket
Protec Cao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Absorvente Sao/Isolador) / Ho Od (Bonnet) Upper (Sound Absorber/Insulator)
Trico Capot / Bonnet Lock
Capot Traseiro (Isolador) / Hood (Bonnet) Rea R (Sound Absorber)
Guarda Lamas / Fender
Piso / Floor Sheet
Piso (Isolador) / Floor Sheet (Soundproof Mat Erial)
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Caixa Ferramenta / Tool Box
Ar Co / Rops
Etiqueta (Painel) / Label (Panel)
Acessorios / Accessories
Panela Escape [Opção] / Upper Muffler Kit [Option]
Kit Ecu [Opção] / Ecu Kit [Option]
Kit Alternador (Alternador) [Opção] / Alternator K It (Alternator) [Option]
Kit Alternador (Cablagem Electrica) [Opção] / Alte Rnator Kit (Wire Harness) [Option]
Alternador [Peças Componentes] [Opção] / Alternato R [Component Parts] [Option]
Kit Farios Trabalho [Opção] / Working Light Kit [O Ption]
Kit Conversao Tdf 540/1000 [Opção] / Pto (540/1000 ) Conversion Kit [Option]
Kit De Atualização Para Embraiagem 4x4 [Opção] / 4 Wd Clutch Upgrade Kit [Option]
Embraiagem 4x4 [Peças Componentes] [Opção] / 4wd C Lutch [Component Parts] [Option]
Apoio [Opção] / Front Bumper Kit [Option]
Kit Valvula Control Auxiliar (Scd) [Opção] / Auxil Iary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opção] / Auxili Ary Control Valve Kit (Fc) [Option]
Kit Distribuidor Serviços Externos (Scd) [Peças Co Mponentes] [Opção] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Kit Distribuidor Serviços Externos (Fc) [Peças Com Ponentes] [Opção] / Auxiliary Control Valve (Fc) [C Omponent Parts] [Option]
Kit Alavanca Serviços Externos (Terço) [Opção] / A Uxiliary Control Valve Lever Kit (3rd) [Option]
Kit Valvula Travao Reboque 1 (Valvula/Tubo) [Opção ] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Kit Valvula Travao Reboque 2 (Tubo) [Opção] / Trai Ler Brake Valve Kit 2 (Pipe) [Option]
