Kubota Tractor M6040DTHNB-EC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M6040DTHNB-EC Tractor
Number of Pages: 630 Pages
Frequently Used Items
Bloque Motor [Antiguo] / Crankcase [Old]
Bloque Motor [Nuevo] / Crankcase [New]
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Unidad De La Bomba De Inyeccion / Injection Pump Unit
Bifurcacion Palanca (Regulador) / Fork Lever (Governor)
Restriccion Que Ajusta El Perno / Restriction Adjusting Bolt
Agua Bomba / Water Pump
Valvula De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Pipa De Entrada / Inlet Pipe
Silenciador / Muffler
Piezas Electricas Del Motor / Engine Electrical Parts
Acelerador Palanca / Hand Accelerator Lever
Deposito De Combustible Dcha / Fuel Tank Rh
Deposito De Combustible Izqd / Fuel Tank Lh
Combustible Tubo 1 (Deposito) / Fuel Pipe 1 (Rear)
Combustible Tubo 2 (Motor) / Fuel Pipe 2 (Front)
Separador / Separator
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Bateria [Antiguo] / Battery [Old]
Bateria [Nuevo] / Battery [New]
Conmutador/Sensor (Aderante) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) [Ec] [Se] / Switch/Sensor (Rear) [Ec] [Se]
Conmutador (Tablero De Instrumentos) / Switch (Panel Board)
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Light
Trasero Combinacion Luz / Rear Combination Light
Licencia Lampara / License Lamp
Electrico Cableado (Aderante) [Ec] [Se] / Electrical Wiring (Front) [Ec] [Se]
Electrico Cableado (Trasero) [Ec] [Se] / Electrical Wiring (Rear) [Ec] [Se]
Transmision Caja [Ec] [Se] / Transmission Case [Ec] [Se]
Manguera Del Respiradero (Transmision Caja) / Breather Hose (Transmission Case)
Cubierta Trasera De Caja De Transmision [Ec] [Ita] / Transmission Case Rear Cover [Ec] [Ita]
Valvula Palanca (Embrague) / Valve Lever (Clutch/Shuttle)
Entrada Eje / Input Shaft
Inversor Embrague [Componente Piezas] / Shuttle Clutch [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje De Engranaje Diferencial [Ec] [Se] / Bevel Gear [Ec] [Se]
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Pto Embrague [Ec] [Se] [Antiguo] / Pto Clutch [Ec] [Se] [Old]
Pto Embrague [Ec] [Se] [Nuevo] / Pto Clutch [Ec] [Se] [New]
Tdf Embrague [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Tdf Embrague [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Pto Embrague Valvula / Pto Clutch Valve
Pto Eje / Pto Shaft
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Eje Propulsor Delantero (Trasero) / Front Propeller Shaft (Rear)
Gama Y Arrastramiento Engranaje Cambio Bifurcacion / Range And Creep Gear Shift Fork
Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Cable Del Cambio De Engranaje Principal / Main Gear Shift Cable
Inversor Cambio Palanca / Shuttle Shift Lever
Inversor Cable / Shuttle Cable
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Varilla De Freno / Brake Rod
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Pipa Del Distribuidor Del Freno / Brake Master Cylinder Pipe
Soporte De Eje Delantero / Front Axle Bracket
Adelante Helice Eje / Front Propeller Shaft
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Direccion Cilindro [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Direccion Cilindro [Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Hidraulico Tubo (Entrega) / Hydraulic Pipe (Delivery)
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Hidraulico Aceite Linea (Pto Embrague Valvula) / Hydraulic Oil Line (Pto Clutch Valve)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Control Valvula [Antiguo] / Control Valve [Old]
Control Valvula [Nuevo] / Control Valve [New]
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Alejado Control Valvula [Ec] [Antiguo] / Auxiliary Control Valve [Ec] [Old]
Alejado Control Valvula [Ec] [Nuevo] / Auxiliary Control Valve [Ec] [New]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [New]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] / Auxiliary Control Valve (S/D) [Component Parts]
Valvula De Prioridad Del Flujo [Componente Piezas] [Antiguo] / Flow Priority Valve [Component Parts] [Old]
Auxiliar Control Valvula Palanca (1r) / Auxiliary Control Valve Lever (1st)
Auxiliar Control Valvula Palanca (2do) / Auxiliary Control Valve Lever (2nd)
Cilindro De Ayuda De Elevacion Izquierdo [Ec] [Ita] [Antiguo] / 3p-Lift Assist Cylinder Lh [Ec] [Ita] [Old]
Cilindro De Ayuda De Elevacion Izquierdo [Ec] [Ita] [Nuevo] / 3p-Lift Assist Cylinder Lh [Ec] [Ita] [New]
Cilindro De Ayuda De Elevacion Derecho [Ec] [Ita] [Antiguo] / 3p-Lift Assist Cylinder Rh [Ec] [Ita] [Old]
Cilindro De Ayuda De Elevacion Derecho [Ec] [Ita] [Nuevo] / 3p-Lift Assist Cylinder Rh [Ec] [Ita] [New]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Antiguo] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Nuevo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Manguera Del Respiradero (Cilindro De Ayuda De Elevacion) / Breather Hose (3p Cylinder)
Parte Superior Vinculo [Antiguo] / Top Link [Old]
Parte Superior Vinculo [Nuevo] / Top Link [New]
Bajar Vinculo [Antiguo] / Lower Link [Old]
Bajar Vinculo [Nuevo] / Lower Link [New]
Estabilizador [Ec] [Antiguo] / Stabilizer [Ec] [Old]
Estabilizador [Ec] [Nuevo] / Stabilizer [Ec] [New]
Varilla De Elevacion Dcha [Antiguo] / Lift Rod Rh [Old]
Varilla De Elevacion Dcha [Nuevo] / Lift Rod Rh [New]
Ascenso Varilla Izquierdo [Antiguo] / Lift Rod Lh [Old]
Ascenso Varilla Izquierdo [Nuevo] / Lift Rod Lh [New]
Protector De Eje De Tdf [Ec] [Ita] / Pto Shaft Protector [Ec] [Ita]
Capo (Capo) Superior / Hood (Bonnet) Upper
Capo (Capo) Superior (Amortiguador Sano/Aislador) [Antiguo] / Hood (Bonnet) Upper (Sound Absorber/Insulator) [Old]
Capo (Capo) Superior (Amortiguador Sano/Aislador) [Nuevo] / Hood (Bonnet) Upper (Sound Absorber/Insulator) [New]
Capo (Capo) Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte / Bonnet Support
Protector / Shield
Capo Posterior / Hood (Bonnet) Rear
Capo Trasero (Amortiguador Sano/Aislador) / Hood (Bonnet) Rear (Sound Absorber)
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Peldano / Step
Cubierta Superior Del Paso / Step Upper Cover
Estera Del Paso/Amortiguador Sano / Step Mat/Sound Absorber
Auxiliar Peldano / Auxiliary Step
Asiento [Ec] [Se] / Seat Bracket [Ec] [Se]
Herramienta Caja / Tool Box
Rops 1 (Intermedio) / Rops 1 (Mid)
Rops 2 (Trasero) / Rops 2 (Rear)
Etiqueta 1 (Adelante) / Label (Front)
Etiqueta 2 (Panel) / Label (Panel)
Etiqueta 3 (Posterior) [Ec] [Se] / Label (Rear) [Ec] [Se]
Kit De Alternador 1 (Alternador) [Opcion] / Alternator Kit 1 (Alternator) [Option]
Alternador Kit 2 (Cable Mazo De Cables) [Opcion] / Alternator Kit 2 (Wire Harness) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Adelante Control Remoto De Salida Hidraulica (Soporte/Tubo) [Opcion] / Front Remote Hydraulic Outlet (Holder/Pipe) [Option]
Adelante Control Remoto De Salida Hidraulica (1r Valvula) [Opcion] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Adelante Control Remoto De Salida Hidraulica (2do Valvula) [Opcion] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] / Front Remote Hydraulic Outlet (Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] [Antiguo] / Front Remote Hydraulic Outlet (Scd) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] [Nuevo] / Front Remote Hydraulic Outlet (Scd) [Component Parts] [Option] [New]
Adelante Control Remoto De Salida Hidraulica (Cubierta De La Valvula) [Opcion] / Front Remote Hydraulic Outlet (Valve Cover) [Option]
Adelante Control Remoto De Salida Hidraulica (Control Palanca) [Opcion] / Front Remote Hydraulic Outlet (Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica (1r Valvula Palanca De Control) [Opcion] / Front Remote Hydraulic Outlet (1st Valve Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica (2do Valvula Palanca De Control) [Opcion] / Front Remote Hydraulic Outlet (2nd Valve Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica (Guardia Soporte) [Opcion] / Front Remote Hydraulic Outlet (Guard Bracket) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercera) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Remolque Freno Valvula 1 (Valvula/Tubo) [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Kit De Remolque Freno Valvula 2 (Tubo) [Opcion] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Kit De Remolque Freno Valvula 3 (Cubierta) [Opcion] / Trailer Brake Valve Kit 3 (Cover) [Option]
Ayudar Cilindro Soporte [Ec] [Opcion] [Antiguo] / Drawbar Bracket Kit [Ec] [Option] [Old]
Apoyo Del Paso [Opcion] [Antiguo] / Step Support Kit [Option] [Old]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Pto Eje / Pto Shaft
Protector / Shield
Peldano / Step
