7,392
Kubota Tractor M6040DTHC Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M6040DTHC Tractor
Number of Pages: 711 Pages
Engine 301000 Oil Pan
Cylinder Head Not 030 And Fig.No.303000 Ref.No.110 Note Order
Engine 303000 Inlet And Exhaust Valve Valve Inlet Valve And Exhaust Valve
Engine 304000 Rocker Arm Shaft Rocker Arm Shaft
Engine 305000 Head Cover Not 010,030 Note
Engine 310000 Front Cover
Engine 311000 Piston And Crankshaft Not 050,180 Note
Engine 312000 Camshaft And Idle Gear
Engine 313000 Balancer
Engine 315001 Flywheel
Pump Unit Injection Pump Unit Note Injection Pump Kit Components Fig.No.321000 To 325000
Injection Pump Not 010 And Fig.No.322000 Ref.No.015,070 Note
Engine 322000 Fuel Camshaft
Governor Not 050 And Fig.No.324000 Ref.No.060 Note Order By
Engine 324000 Fork Lever (Governor)
Engine 325000 Restriction Adjusting Bolt Restriction Adjusting Bolt
Engine 331000 Fuel Filter
Engine 340000 Nozzle Holder And Glow
Engine 345000 Injection Pipe Injection Pipe
Engine 360000 Thermostat Water Flange And Thermostat
Engine 361000 Water Pump
Inlet Manifold Not 010 And Fig.No.372200 Ref.No.110 Note Order
Engine 372000 Exhaust Manifold
Engine 372200 EGR Valve EGR Valve
Engine 372300 EGR Cooler EGR Cooler
Engine 372500 EGR Water Pipe EGR Water Piping
Engine 372600 Turbocharge Turbo Charger
Engine 373000 Air Cleaner
Engine 373500 Air Cleaner Component Parts
Engine 374500 Inlet Pipe (Air Cleaner) Inlet Pipe
Engine 375000 Muffler
Engine 380000 Oil Pipe (Turbo Charger)
Engine 382000 Oil Cooler Oil Cooler
Engine 391000 Upper Gasket Kit
Engine 392000 Lower Gasket Kit
Engine 395000 Engine Electrical Parts Engine Electrical Parts
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11000 Fuel Tank
Fuel System A13500 Fuel Feed Fuel Filler
Fuel System A14000 Fuel Pipe
Fuel System A15000 Sedimenter Old Sedimenter Old Chassis No. 80252 S.No. 80252
Fuel System A15100 Separator New Separator New Chassis No. 80253 S.No. 80253
Fuel System A16000 Sedimenter Component Parts Old Sedimenter Component Parts Old Chassis No.
Fuel System A16100 Separator Component Parts New Separator Component Parts New Chassis No.
Cooling Water System A41001 Fan
Cooling Water System A42000 Water Pipe
Cooling Water System A43000 Radiator
Cooling Water System A45000 Reserve Tank Reserve
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58001 Battery
Electrical System B00100 Switch Sensor (Motor) Switch Sensor
Electrical System B01500 Switch Sensor (Front) Switch Sensor (
Electrical System B02001 Switch Sensor (Rear) EC Uk Tur Switch Sensor
Electrical System B10500 Switch (Control Panel) Switch (Panel)
Electrical System B11000 Switch (Light)
Electrical System B13000 Relay
Electrical System B14000 Dashboard Panel Board
Electrical System B32001 Far EC Se Ita Tur Head Light EC Se
Electrical System B32101 Outdoor Lighting Component Parts EC Se Ita Tur Head Light
Electrical System B33900 Front Combination Headlight Front Combination
Electrical System B35001 Working Light Torch Light EC Se Ita Tur Working Light
Electrical System B36000 Rear Combination Headlight
Electrical System B36501 License Lamp
Electrical System B37000 Trailer Socket Note 020,030 And 050
Electrical System B41000 Interior Lighting Room Light
Electrical System B42500 Radio Speaker EC Se Ita Tur Radio Speaker
Electrical System B43000 Rondela Tank Washer Tank
Electrical System B44100 Front Wiper Front Wiper
Electrical System B50500 Electrical Cables (Motor) Electrical
System B51001 Electrical Cables (Main) EC Uk Tur Old Electrical Wiring (Main) EC Uk Tur Old
System B51002 Electrical Cables (Main) EC Uk Tur New Electrical Wiring (Main) EC Uk Tur New
Electrical System B52001 Electrical Cables (Cabin) EC Se Ita Tur Electrical
Clutch Gear Clutch Transmission C11001 Clutch Housing
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle Gear
Clutch Gear Clutch Transmission C12500 Shift Cover
Clutch Gear Clutch Transmission C14001 Transmission Box EC Uk Tur Transmission
Clutch Gear Clutch Transmission C15001 Gear Housing Rear Cover EC Uk Ita Tur Transmission
Clutch Gear Clutch Transmission C17000 Rear Axle Housing Rear Axle
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C26000 Clutch Cable Clutch Cable
Clutch Gear Clutch Transmission C26500 Valve Lever (Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21600 Transmission Clutch Component Parts Shuttle Clutch
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23500 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Clutch Gear Clutch Transmission D26001 Bevel Gear Shaft EC Uk Tur Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft PTO Propeller
Clutch Gear Clutch Transmission D26601 PTO Clutch EC Uk Tur PTO Clutch EC
Clutch Gear Clutch Transmission D26700 PTO Clutch Component Parts PTO Clutch
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch Valve
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Clutch Gear Clutch Transmission D35500 Front Propeller Shaft (Rear) Front Propeller
Speed Change Shift Fork D41000 Main Transmission
Slip Lever Speed Change Shift Fork D45000 Range Gear Change Fork Crawl Gear
Speed Change Shift Fork D47000 Differential Lock Transmission
Gear Speed Change Shift Fork F11000 Main Gear
Speed Change Shift Fork F11500 Main Transmission
Speed Change Shift Fork F12000 Main Transmission
Speed Change Shift Fork F12501 Transmission Shuttle
Gear Speed Change Shift Fork F13300 Shuttle
Speed Change Shift Fork F13500 Gear Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20600 Brake (Right Side) Brake Rh
Rear Axle Brake F20700 Brake (Left Side) Brake Lh
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master Cylinder
Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master Cylinder
Rear Axle Brake F33000 Brake Pipe Brake Pipe
Front Axle Chassis G10500 Front Axle Frame
Front Axle Chassis G11000 Front Axle Housing Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft
Front Axle Chassis G15000 Front Differential Housing Front Differential
Front Axle Chassis G16000 Bevel Gear (Front) Bevel Gear (
Front Axle Chassis G17000 Front Differential Differential Front
Front Axle Chassis G22100 Inclination Transmission Housing (Right Side) Bevel
Front Axle Chassis G22200 Inclination Transmission Housing (Left Side) Bevel
Front Axle Chassis G22300 Front Axle Housing (Right Side) Front Axle
Front Axle Chassis G22400 Front Axle Housing (Left Side) Front Axle
Front Axle Chassis G22800 Differential Transmission Shaft (Right Side) Differential
Front Axle Chassis G22900 Differential Transmission Shaft (Left Side) Differential
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle Rh
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle Lh
Steering H11000 Steering Handle
Steering H12001 Slip Pedal Tilt Pedal
Steering H13000 Steering Joint Steering Joint
Steering H14000 Steering Control Steering Controller
Steering H15000 Steering Control Component Parts Steering Controller
Steering H16000 Rubber Tie Rod Steering Cylinder Tie Rod Steering
Steering H16500 Steering Cylinder Component Parts Steering Cylinder
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
Hydraulic System J22001 Hydraulic Oil Line (Feed) Old Hydraulic Pipe (Delivery) Old Chassis No.
Hydraulic System J22002 Hydraulic Oil Line (Feed) New Hydraulic Pipe (Delivery) New Chassis
Hydraulic System J26500 Oil Cooler
Hydraulic System J27500 Hydraulic Pipe (Direction PTO) Hydraulic Oil Line (
Hydraulic System J27600 Hydraulic Pipe (Shuttle PTO) Hydraulic Oil Line (
Hydraulic System J28000 Steering Hose (Delivered) Steering Hose
Hydraulic System J30500 Solenoid Valve Pipe Solenoid Valve
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Lifting Arm Hydraulic Lift Arm
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32300 Lowering Adjustment Valve Lowering Lock Lever
Hydraulic System J35500 Control Valve
Hydraulic System J37801 Position Control Lever Position Control
Hydraulic System J38000 Traction And Position Control Arm Draft And Position
Hydraulic System J38100 Traction And Position Control Arm Bracket Draft And Position
Mil Old Position And Draft Shaft Old Chassis No. 83348 Note 140 And Fig.Noj38202 Ref.No.140,310
Hydraulic System J38202 Position And Draft Shaft New Chassis No.
Hydraulic System J39200 Feed Back Lever
Hydraulic System J44501 Remote Control Valve EC Uk Tur Auxiliary Control
J44701 Remote Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component
J44702 Remote Control Valve (FD) Component Parts New Auxiliary Control Valve (FD) Component
Hydraulic System J44703 Remote Control Valve (S D) Component Parts Auxiliary Control
Hydraulic System J44900 Current Priority Valve Component Parts Flow Priority
Hydraulic System J45500 Support Control Valve Lever Auxiliary Control
Hydraulic System J47100 3p-Left Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47200 3p-Right Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47300 3p-Right Lift Support Cylinder Component Parts 3p-Lift Assist
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Upper Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11000 3 Point Link (Upper
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Lower Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13300 Stabilizer
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Draw Shaft
Bağ Drawing Bar Connection 3-Point Linkage Drawbar Hitch L17001 PTO Protective EC Uk Ita Tur Pto
Hood Bonnet M11000 Front Grille
Hood Bonnet M12000 Hood (Bonnet) Upper
Hood Bonnet M12300 Hood (Bonnet) Damper
Hood Bonnet M12400 Bone Lock Bonnet Lock
Hood Bonnet M12700 Bone Side Cover Hood (Bonnet) Side Cover
Hood Bonnet M14001 Bone Support Bonnet Support
Cabin Cab N11001 Cabin Frame EC Uk Tur Cab Frame EC Uk Tur
Cabin Cab N11700 Rear Hood (Bonnet) Rear
Cabin Cab N12000 Windshield Front Glass
Cabin Cab N12500 Door (Right Side) Door Rh
Cabin Cab N13000 Door (Left Side) Door Lh
Cab N13500 Door Lock (Right Side) Door Lock Rh
Cab N14000 Door Lock (Left Side) Door Lock Lh
Cab N14500 Side Window Side Window
Cab N15000 Rear Window Rear Window (Upper)
Cab N16001 Inner Ceiling Inner Roof
Cab N16500 Outer Ceiling Outer Roof
Cab N17501 Floor Mat Old Floor Mat Old Chassis No. 80252 S.No. 80252 S.No. 80252
Cab N17502 Floor Mat Old Floor Mat Old Chassis No.80253 To 80488 S.No.80253 To 80488 S.No.80253
Cab N17503 Floor Mat New Floor Mat New Chassis No. 80489 S.No. 80489 S.No. 80489
Cab N18001 Inspection Plate EC Uk Tur Inspection Plate EC Uk Tur
Cab N18201 Soundproof Material EC Uk Tur Soundproof Material EC
Cab N21000 Fender Cover (Right Side) Fender Cover Rh
Cab N21500 Fender Cover (Left Side) Fender Cover Lh
Cab N22400 Fender
Cab N24000 Cab Bracket Front Cab Bracket Front
Cab N24500 Cab Bracket Rear Cab Bracket Rear
Cab N25001 Tool Box
Air Conditioner Air Conditioner P11500 Air Conditioner Air Conditioner
Air Conditioner Air Conditioner P14000 Air Conditioner Tube Air Conditioner Duct
Air Conditioner Air Conditioner P14100 Mod Box Mode Case
Air Conditioner Air Conditioner P14300 Air Outlets Indicator Dashboard Air
Air Conditioner Air Conditioner P14700 Inner Air Recirculation Inner Air Recirculation
Air Conditioner Air Conditioner P15000 Heater Hose Heater Hose
Air Conditioner Air Conditioner P15501 Condenser Condenser
P15701 Air Conditioner Hose Condenser Hose Old Air Conditioner Hose Condenser Hose Old
P15702 Air Conditioner Hose Condenser Hose New Air Conditioner Hose Condenser Hose New
Air Conditioner Air Conditioner P16000 Compressor Compressor
Labels S12000 Label (Front)
Labels S13001 Label (Back) EC Uk Tur Label (Rear) EC Uk Tur
Accessories Service Parts Accessories T11000 Accessories Service Parts Accessories And
Option U11000 Alternator Kit Option Alternator Kit Option
Option U11300 Alternator Component Parts Option Alternator Component
Option U19000 Rear Wiper Kit Option Rear Wiper Kit Option
Option U75000 Trailer Brake Valve Kit 1 ( Valve Pipe) Option Trailer Brake Valve Kit
Option U75100 Trailer Brake Valve Kit 2 (Pipe) Option Trailer Brake Valve Kit 2
