Kubota Tractor M6040DTHC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M6040DTHC Tractor
Number of Pages: 659 Pages
Frequently Used Items
Bloque Motor [Antiguo] / Crankcase [Old]
Bloque Motor [Nuevo] / Crankcase [New]
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Unidad De La Bomba De Inyeccion / Injection Pump Unit
Bifurcacion Palanca (Regulador) / Fork Lever (Governor)
Restriccion Que Ajusta El Perno / Restriction Adjusting Bolt
Inyector Y Bujia Precalent / Nozzle Holder And Glow Plug
Agua Bomba / Water Pump
Valvula De Egr Y Refrigerador De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Pipa De Entrada / Inlet Pipe
Silenciador / Muffler
Piezas Electricas Del Motor / Engine Electrical Parts
Acelerador Palanca / Hand Accelerator Lever
Llenador Del Combustible / Fuel Filler
Sedimentario [Antiguo] / Sedimenter [Old]
Separador [Nuevo] / Separator [New]
Separador [Componente Piezas] [Antiguo] / Sedimenter [Component Parts] [Old]
Separador [Componente Piezas] [Nuevo] / Separator [Component Parts] [New]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Motor/Unidad Del Combustible) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) [Ec] [Uk] [Tur] / Switch/Sensor (Rear) [Ec] [Uk] [Tur]
Conmutador (Tablero De Instrumentos) / Switch (Panel Board)
Conmutador (Luz/Panel) / Switch (Light/Panel)
Rele / Relay
Tablero Panel / Panel Board
Culata Luz [Ec] [Se] [Ita] [Tur] / Head Light [Ec] [Se] [Ita] [Tur]
Faro Delantero [Componente Piezas] [Ec] [Se] [Ita] [Tur] / Head Light [Component Parts] [Ec] [Se] [Ita] [Tur]
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro [Ec] [Se] [Ita] [Tur] / Working Light/Beacon Light [Ec] [Se] [Ita] [Tur]
Trasero Combinacion Luz / Rear Combination Light
Licencia Lampara / License Lamp
Altavoz De Radio [Ec] [Se] [Ita] [Tur] / Radio Speaker [Ec] [Se] [Ita] [Tur]
Limpiador Delantero / Front Wiper
Electrico Cableado (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Principal) [Ec] [Uk] [Tur] [Antiguo] / Electrical Wiring (Main) [Ec] [Uk] [Tur] [Old]
Electrico Cableado (Principal) [Ec] [Uk] [Tur] [Nuevo] / Electrical Wiring (Main) [Ec] [Uk] [Tur] [New]
Electrico Cableado (Cabina) [Ec] [Se] [Ita] [Tur] / Electrical Wiring (Cab) [Ec] [Se] [Ita] [Tur]
Cajatransmision [Ec] [Uk] [Tur] / Transmission Case [Ec] [Uk] [Tur]
Cubierta Trasera De Caja De Transmision [Ec] [Uk] [Ita] [Tur] / Transmission Case Rear Cover [Ec] [Uk] [Ita] [Tur]
Cable De Embrague / Clutch Cable
Valvula Palanca (Embrague/Inversor) / Valve Lever (Clutch/Shuttle)
Entrada Eje / Input Shaft
Inversor Embrague [Componente Piezas] / Shuttle Clutch [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje De Engranaje Diferencial [Ec] [Uk] [Tur] / Bevel Gear [Ec] [Uk] [Tur]
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Pto Embrague [Ec] [Uk] [Tur] / Pto Clutch [Ec] [Uk] [Tur]
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula / Pto Clutch Valve
Pto Eje / Pto Shaft
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Eje Propulsor Delantero (Posterior) / Front Propeller Shaft (Rear)
Horquilla Cambio Gama Y Cambio Creeper / Range Gear Shift Fork/Creep Gear Shift Fork
Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Eje De Palanca De Cambio Principal / Main Gear Shift Lever Shaft
Inversor Cambio Palanca / Shuttle Shift Lever
Inversor Cable / Shuttle Cable
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Adelante Helice Eje / Propeller Shaft
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Direccion Controlador / Steering Controller
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Hidraulico Tubo (Entrega) [Antiguo] / Hydraulic Pipe (Delivery) [Old]
Hidraulico Tubo (Entrega) [Nuevo] / Hydraulic Pipe (Delivery) [New]
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Pipa De La Valvula De Solenoide / Solenoid Valve Pipe
Brazo De Elevacion / Hydraulic Lift Arm
Coloque La Palanca De Mando / Position Control Lever
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Esfuerzo Y Posicion Control Varilla / Draft And Position Control Lever Bracket
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Distribuidor De Servicios Externos [Ec] [Uk] [Tur] / Auxiliary Control Valve [Ec] [Uk] [Tur]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts][Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts][New]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] / Auxiliary Control Valve (S/D) [Component Parts]
Valvula De Prioridad Del Flujo [Componente Piezas] / Flow Priority Valve [Component Parts]
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Protector De Eje De Tdf [Ec] [Uk] [Ita] [Tur] / Pto Shaft Protector [Ec] [Uk] [Ita] [Tur]
Capo (Capo) Superior / Hood (Bonnet) Upper
Capo (Capo) Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte / Bonnet Support
Cabina Bastidor [Ec] [Uk] [Tur] / Cab Frame [Ec] [Uk] [Tur]
Capo (Capo) Trasero / Hood (Bonnet) Rear
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana / Side Window
Trasero Ventana (Superior) / Rear Window (Upper)
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera [Antiguo] / Floor Mat [Old]
Piso Estera [Nuevo] / Floor Mat [New]
Inspeccion Placa [Ec] [Uk] [Tur] / Inspection Plate [Ec] [Uk] [Tur]
Material Insonoro [Ec] [Uk] [Tur] / Soundproof Material [Ec] [Uk] [Tur]
Guardabarros Cubierta Derecho / Fender Cover Rh
Cubierta De Guardabarros Izqd / Fender Cover Lh
Guardabarros / Fender
Herramienta Caja / Tool Box
Aire Acondicionador Conducto / Air Conditioner Duct
Modo Caso / Mode Case
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito [Antiguo] / Air Conditioner Hose/Condenser Hose [Old]
Aire Acondicionador Manguito/Condensador Manguito [Nuevo] / Air Conditioner Hose/Condenser Hose [New]
Compresor / Compressor
Etiqueta (Trasero) [Ec] [Uk] [Tur] / Label (Rear) [Ec] [Uk] [Tur]
Kit De Alternador [Opcion] / Alternator Kit [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Remolque Freno Valvula Kit 1 (Valvula/Tubo) [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Remolque Freno Valvula Kit 2 (Tubo) [Opcion] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Pto Eje / Pto Shaft
