Kubota Tractor M6040DTH Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M6040DTH Tractor
Number of Pages: 631 Pages
Engine 300001 Engine Block Old Crankcase Old Chassis No. 8crz999 S.No. 8crz999 S.No.
Engine 300002 Engine Block New Crankcase New Chassis No. 8cs0001 S.No. 8cs0001 S.No.
Engine 301001 Oil Pan
Cylinder Head Note 030 And Fig.No.303000 Ref.No.110 Note Order
Engine 303000 Inlet Valve And Exhaust Valve
Engine 304000 Rocker Arm Shaft
Head Cover Not 010,030 Note
Engine 310000 Front Cover
Piston And Crankshaft Note Order By Ref.No.050 And 180 New Parts. Note
Engine 312001 Camshaft And Idle Gear
Engine 313001 Balancer
Engine 315001 Flywheel
Pump Unit Injection Pump Unit Note Injection Pump Kit Components From Fig.No.321000 To 325000
Injection Pump Note 010 And Fig.No.322000 Ref.No.015.070 Note
Engine 322001 Fuel Camshaft
Engine 323001 Governor
Engine 324001 Fork Lever (Governor)
Engine 325001 Restriction Adjusting Bolt Restriction Adjusting Bolt
Engine 331001 Fuel Filter
Engine 340000 Nozzle Holder And Glow
Engine 345000 Injection Pipe
Engine 360001 Thermostat Water Flange And Thermostat
Engine 361000 Water Pump
Inlet Manifold Note 010 And Fig.No.372201 Ref.No.110 Note Order
Engine 372000 Exhaust Manifold
Engine 372201 EGR Valve
Engine 372300 EGR Cooler
Engine 372501 EGR Water Pipe EGR Water Piping
Engine 372600 Turbocharger Turbo Charger
Engine 373001 Air Cleaner
Engine 373500 Air Cleaner Component Parts
Engine 374501 Inlet Pipe Inlet Pipe
Engine 375001 Muffler
Engine 380001 Oil Pipe (Turbo Charger)
Engine 382001 Oil Cooler
Engine 391001 Upper Gasket Kit
Engine 392001 Lower Gasket Kit
Engine 395001 Engine Electrical Parts Engine Electrical Parts
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11000 Fuel Tank
Fuel System A13500 Fuel Supply Fuel Filler
Fuel System A14000 Fuel Pipe
Fuel System A15000 Sedimentary Old Sedimentary Old Chassis No. 80252 S.No. 80252
Fuel System A15101 Separator New Separator New Chassis No. 80253 S.No. 80253
Fuel System A16000 Sedimenter Component Parts Old Chassis No.
Fuel System A16101 Separator Component Parts New Separator Component Parts New Chassis No.
Cooling Water System A41001 Fan
Cooling Water System A42000 Water Pipe
Cooling Water System A43001 Radiator
Cooling Water System A45000 Reserve Tank
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56001 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58001 Battery
Electrical System B00101 Switch Sensor (Motor) Switch Sensor
Electrical System B01501 Switch Sensor (Front) (
Electrical System B02000 Switch Sensor (Rear) Switch Sensor
Panel) Switch (Panel Board) Note 030 Width Part And Fig.No.M15501,M15502 Ref.No.105
Electrical System B13001 Relay
Electrical System B14000 Dashboard Panel Board
Electrical System B32001 Head Light
Electrical System B32100 Outdoor Lighting Component Parts Head Light
Electrical System B33500 Dangerous Lamp Rear Lamp Hazard Light
Electrical System B33900 Front Combination Headlight Front Combination
Electrical System B36501 License Lamp
Electrical System B37000 Trailer Socket
Electrical System B50501 Wire Harness (Engine) Old Electrical Wiring (Engine) Old Chassis No. 80252
Electrical System B50502 Wire Harness (Motor) New Electrical Wiring (Engine) New Chassis No.
Electrical System B51001 Electrical Wiring (Main) Old Chassis No.
Electrical System B51002 Electrical Wiring (Main) New Chassis No.
Clutch Gear Clutch Transmission C11001 Clutch Housing
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle Gear
Clutch Gear Clutch Transmission C12500 Shift Cover
Clutch Gear Clutch Transmission C14001 Transmission Box Transmission
Clutch Gear Clutch Transmission C15001 Gear Housing Back Cover EC Transmission Case
Clutch Gear Clutch Transmission C15002 Gear Housing Rear Cover Se Tur Transmission Case
Clutch Gear Clutch Transmission C17000 Rear Axle Case
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C26501 Valve Lever (Clutch Gear Clutch Transmission) Valve Lever (
Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21600 Transmission Clutch Component Parts Shuttle Clutch
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23500 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Clutch Gear Clutch Transmission D26000 Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26600 PTO Clutch
Clutch Gear Clutch Transmission D26700 PTO Clutch Component Parts
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch Valve
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Clutch Gear Clutch Transmission D35500 Propeller Shaft (Rear) Front Propeller
Speed Change Shift Fork D41001 Main Transmission
Slide Lever Speed Change Shift Fork D45000 Range Gear Change Fork
Speed Change Shift Fork D47000 Differential Lock
Speed Change Shift Fork F11001 Main Gear
Speed Change Shift Fork F11500 Main Transmission
Speed Change Shift Fork F12501 Transmission Shuttle
Gear Speed Change Shift Fork F13300 Shuttle
Speed Change Shift Fork F13500 Gear Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20600 Brake (Right Side) Brake Rh
Rear Axle Brake F20700 Brake (Left Side) Brake Lh
Rear Axle Brake F21100 Brake Rod (Brake Pedal)
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23501 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master Cylinder
Rear Axle Brake F32001 Brake Master Cylinder Component Parts Brake Master Cylinder
Rear Axle Brake F33001 Brake Pipe Brake Pipe
Front Axle Chassis G10501 Front Axle Frame
Front Axle Chassis G11000 Front Axle Housing Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Front Axle Chassis G15001 Front Differential Housing EC Se Tur Front Differential
Front Axle Chassis G16000 Bevel Gear (Front Axle Chassis G17000 Front Differential Front
Front Axle Chassis G22101 Inclination Transmission Housing (Right Side) EC Se Tur Bevel
Front Axle Chassis G22201 Inclination Transmission Housing (Left Side) EC Se Tur Bevel
Front Axle Chassis G22301 Front Axle Housing (Right Side) EC Se Tur Front Axle
Front Axle Chassis G22401 Front Axle Housing (Left Side) EC Se Tur Front Axle
Axle Frame Front Axle Chassis G22801 Differential Transmission Shaft (Right Side) EC Se Tur Differential
Axle Frame Front Axle Chassis G22901 Differential Transmission Shaft (Left Side) EC Se Tur Differential
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle Rh
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle Lh
Steering H11001 Steering Handle Not 150 And 170 Note
Steering H12000 Sliding Pedal Tilt Pedal
Steering H13000 Steering Joint Steering H14000 Steering Control Steering Controller
Steering H15000 Steering Control Component Parts Steering Controller
Steering H16001 Rubber Tie Rod Steering Cylinder EC Se Tur Tie Rod Steering
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13001 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
Hydraulic System J22001 Hydraulic Oil Line (Feed) Old Hydraulic Pipe (Delivery) Old Chassis No.
Hydraulic System J22002 Hydraulic Oil Line (Feed) New Hydraulic Pipe (Delivery) New Chassis No.
Hydraulic System J26500 Oil Cooler
Hydraulic System J27500 Hydraulic Pipe (Direction PTO) Hydraulic Oil Line (
Hydraulic System J27600 Hydraulic Pipe (Shuttle PTO) Hydraulic Oil Line (
Hydraulic System J28000 Steering Hose Steering Hose (
Hydraulic System J30501 Solenoid Valve Pipe Solenoid Valve
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Hydraulic Piston Lifting Arm Hydraulic
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32300 Lowering Adjustment Valve Lowering Lock Lever
Hydraulic System J35500 Control Valve
Hydraulic System J37800 Position Control Lever Position Control
Hydraulic System J38001 Draft And Position Control Lever Draft And Position
Hydraulic System J38201 Position And Draft Shaft Old Position And Draft Shaft Old Chassis No. 83348
Hydraulic System J38202 Position And Draft Shaft New Position And Draft Shaft New Chassis No. 83349
Hydraulic System J39200 Feed Back Lever
Hydraulic System J44501 Remote Control Valve EC Auxiliary Control
Hydraulic System J44502 Remote Control Valve Se Tur Auxiliary Control
J44701 Remote Control Valve (S D) Component Parts Old Auxiliary Control Valve (FD) Component
J44702 Remote Control Valve (S D) Component Parts New Auxiliary Control Valve (FD) Component
Hydraulic System J44704 Remote Control Valve (S D) Component Parts Auxiliary Control
Hydraulic System J44900 Current Priority Valve Component Parts Flow Priority
Hydraulic System J45501 Support Control Valve Lever Auxiliary Control
Hydraulic System J47101 3p-Left Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47201 3p-Right Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47300 3p-Lift Support Cylinder Component Parts 3p-Lift Assist
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10501 Upper Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11001 3 Point Linkage
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Old Baj Lower
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13301 Stabilizer
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Draw Shaft
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket Se Spa Tur
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17001 PTO Protective EC Pto
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17002 PTO Protection Se Spa Tur Pto
Hood Bonnet M11000 Front Grille
Hood Bonnet M12001 Hood (Bonnet) Upper
Bone Hood (Bonnet) Upper (Sound Absorber Insulator) Old
Bone Hood (Sound Absorber Damper Material) New Hood (Bonnet) Upper (Sound Absorber Insulator) New
Hood Bonnet M12301 Hood (Bonnet) Damper
Hood Bonnet M12400 Bone Lock Bonnet Lock
Hood Bonnet M12700 Bone Side Cover Hood (Bonnet) Side Cover
Hood Bonnet M14001 Bone Support Bonnet Support
Hood (Bone) Rear Hood (Bonnet) Rear Not 020 And Fig.No.B10500 Ref.No.030 Note
Hood Bonnet M17501 Hood (Bonnet) Rear (Sound Absorbing Damper Material) Hood (Bonnet) Rear
Hood Bonnet M18000 Rearview Mirror
Hood Bonnet M22001 Fender
Hood Bonnet M22200 Slide Cover Shift Lever Guide
Hood Bonnet M22301 Floor Sheet
Hood Bonnet M23301 Step
Hood Bonnet M23400 Auxiliary Step Auxiliary Step
Hood Bonnet M23501 Seat EC Seat EC
Hood Bonnet M23502 Seat Se Spa Tur Seat Se Spa Tur
Hood Bonnet M27001 Tool Box
ROPS M31000 ROPS
Labels S12000 Label (Front)
Labels S13000 Label (Panel)
Labels S14000 Label (Back) Label (Rear)
Accessory Service Part Accessories T11000 Accessory Service Part Accessories And
Option U11000 Alternator Kit 1 (Alternator) Option Alternator Kit 1 (Alternator)
Option U11100 Alternator Kit 2 (Wire Harness) Option Alternator Kit 2 (Wire
Option U11300 Alternator Kit Component Parts Option Alternator Component
Option U75000 Trailer Brake Valve Kit 1 Option Trailer Brake Valve Kit 1 (Valve
Option U75100 Trailer Brake Valve Kit 2 Option Trailer Brake Valve Kit 2 (Pipe)
U88800 PTO Shaft Protector Kit Se Spa Tur Option PTO Shaft Protector Kit Se Spa Tur Option Chassis
Option U90500 Step Support Kit Option Step Support Kit Option Chassis No. 81189 S.No. 81189
Region: Turkey
ROPS M31000 ROPS
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
