Kubota Tractor M6040DTH Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M6040DTH Tractor
Number of Pages: 346 Pages
Bloco Motor / Crankcase [Old]
Bloco Motor / Crankcase [New]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Injection Pump Unit / Injection Pump Unit
Veio / Fuel Camshaft
Alavanca Do Garfo (Governador) / Fork Lever (Governor)
Restriction Adjusting Bolt / Restriction Adj Usting Bolt
Filtro Gasoleo / Fuel Filter
Valvula Solenoide / Nozzle Holder And Glow P Lug
Acessorios / Water Pump
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Componentes Electricos Motor / Engine Electr Ical Parts
Fornecimento Combustivel / F Uel Filler
Tubo Combustivel / Fuel Pipe
Sedimenter [Old] / Sedimente R [Old]
Separador / Separator [New]
Sedimenter [Component Parts] [Old] / Sedimenter [Component Parts] [Old]
Separador[Peças Componentes] / Separator [Component Parts] [New]
Ventilador / Fan
Radiador / Water Pipe
Deposito R Eserva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Componentes ] / Starter [Component Parts]
Interruptor/Sensor (Bloco M Otor) / Switch/Sensor (Engine)
Interruptor/Sensor (Diantei Ro) / Switch/Sensor (Front)
Interruptor/Sensor (Traseir O) / Switch/Sensor (Rear)
Interruptor / Switch (Panel Board)
Interruptor / Rele / Relay
Painel / Panel Board
Farol Dianteiro / Head Ligh T
Farol Frente[Peças Componen Tes] / Head Light [Component Parts]
Hazard Light/Tail Light / H Azard Light/Tail Light
Luzes Frontais / Front Comb Ination Light
Farol Matricula / License L Amp
Ficha Reboque / Trailer Soc Ket
Cablagem Eletrcia (Frente) / Electrical Wiring (Engine) [Old]
Cablagem Eletrcia (Frente) / Electrical Wiring (Engine) [New]
Cabelagem Eletrica (Versao) [Antiga] / Electrical Wiring (Main) [Old]
Cabelagem Eletrica (Versao) [Nova] / Electrical Wiring (Main) [New]
Valvula Inversor / S Huttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Carter Transmissao / Transmission Case Rear Cover [Ec]
Carter Transmissao / Transmission Case Rear Cover [Se] [Tur]
Carter Eixo / Rear A Xle Case
Disco Amortecedor / Damper Disk
Bloqueio Diferencial / Clutch Pedal
Valvula (Inversor) / Valve Lever (Clutch/Shuttle)
Veio Primario / Inpu T Shaft
Embraiagem Inversor [Peças Componentes] / Shuttle Clutch [Component Par Ts]
Veio Inversor / Shut Tle Shaft
Primeiro Veio / Firs T Shaft
Secundario Veio / Se Cond Shaft
Terceiro Veio / Thir D Shaft
Veio Creeper / Creep Shaft
Grupo Conico / Bevel Gear
Diferencial Traseiro / Differential Rear
Veio Tdf / Pto Prope Ller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem T Df / Pto Clutch Valve
Veio Tdf / Pto Shaft
Veio Embraiagem[Peça S Componentes] / Front Drive Clutch [Component Part S]
Veio Primario (Trase Ira) / Front Propeller Shaft (Rear)
Forqueta Caixa / Creeper / Range Gear Shift Fork/Creep Gear Shift Fork
Alavanca / Differential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Cabo Inv Ersor / Shuttle Cable
Alavanca Velocidades / Range Gear Shift Lever
Eixo Traseiro / Rear Axle
Travão Direita / Brake Rh
Travão Esquerda / Brake L H
Tirante Travao / Brake Ro D (Brake Pedal)
Alavanca Travao Mao / Par King Brake Lever
Pedal Travao / Brake Peda L
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compon Ent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteiro / Front Axle Bracket
Veio Frontal / Front P Ropeller Shaft
Caixa Diferencial Dian Teiro / Front Differential Case [Ec] [Se] [Tur]
Engrenagem Cónica (Dia Nteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Caixas Engrenagens Con Ica(Esq) / Bevel Gear Case Lh [Ec] [Se] [Tur]
Carter Eixo Frente(Drt ) / Front Axle Case Rh [Ec] [Se] [Tur]
Carter Eixo Frente(Esq ) / Front Axle Case Lh [Ec] [Se] [Tur]
Carreto Diferencial(Dr T) / Differential Gear Shaft Rh [Ec] [Se] [Tur]
Carreto Diferencial(Es Q) / Differential Gear Shaft Lh [Ec] [Se] [Tur]
Eixo Frente (Drt) / Fr Ont Axle Rh
Eixo Dianteiro / Front Axle Lh
Direcção Assistida / Direção Punho / Steering Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / St Eering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering C Ylinder [Ec] [Se] [Tur]
Cilindro Direcção[Peças Componentes] / Steeri Ng Cylinder [Component Parts]
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico[Peças Comp Onentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic Pipe (Delivery) [Old]
Tubo Oleo / Hydraulic Pipe (Delivery) [New]
Circuito Oleo Direcção / Hy Draulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao / Steering Ho Se (Delivery)
Tubo Valvula Solenoide / So Lenoid Valve Pipe
Caixa Hidraulico / Hydrauli C Cylinder Case
Braço De Elevação Hidráulic O / Hydraulic Lift Arm
Valvula Segurança / Safety Valve/Relief Valve
Trinco / Lowering Lock Leve R
Braco Hidraulico / Control Valve
Alavanca Control Posicao / Position Control Lever
Acessorios / Draft And Posi Tion Control Lever
Veio Posicao Esforço / Posi Tion And Draft Shaft [Old]
Veio Posicao Esforço / Posi Tion And Draft Shaft [New]
Alavanca / Feed Back Lever
Distribuidor Auxiliar / Aux Iliary Control Valve [Ec]
Distribuidor Auxiliar / Aux Iliary Control Valve [Se] [Tur]
Valvula Auxiliar [Peças Com Ponentes] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Valvula Auxiliar [Peças Com Ponentes] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Valvula Auxiliar [Peças Com Ponentes] / Auxiliary Control Valve (S/D) [Componen T Parts]
Flow Priority Valve [Compon Ent Parts] / Flow Priority Valve [Component Parts]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Cilindro Auxiliar De Elevac Ao(Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevac Ao(Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevac Ao[Peças Componentes] / 3p-Lift Assist Cylinder [Co Mponent Parts]
Parte Superior / Top Link Bracket
Ligaca O Superior / Top Link
Ligaca O Inferior / Lower Link
Estabi Lizador / Stabilizer
Estabi Lizador(Drt) / Lift Rod Rh
Estabi Lizador(Esq) / Lift Rod Lh
Barra / Drawbar Bracket [Se] [Spa] [Tur]
Protec Cao Tdf / Pto Shaft Protector [Ec]
Protec Cao Tdf / Pto Shaft Protector [Se] [Spa] [Tur]
Grelha Frontal / Front Grille
Capot Superior / Isolador / Hood (Bonnet) Upp Er (Sound Absorber/Insulator) [Old]
Capot Superior / Isolador / Hood (Bonnet) Upp Er (Sound Absorber/Insulator) [New]
Trico Capot / Bonnet Lock
Capot Traseiro / Hood (Bonnet) Rear (Sound Ab Sorber)
Guarda Lamas / Fender
Tampa / Shift Lever Guide
Piso / Floor Sheet
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat [Ec]
Banco / Seat [Se] [Spa] [Tur]
Caixa Ferramenta / Tool Box
Alavanca Valv Ula Control Auxiliar 2º [Opcao] / Rops
Etiqueta (Dianteira) / Label (Front)
Decalcomania(Painel) / Label (Panel)
Etiqueta 2 / Label (Rear)
Acessorios / Accessories And Service Par Ts
Kit Alternador [Opçao] / Alternator Kit 1 (Alterna Tor) [Option]
Kit Alternador [Opçao] / Alternator Kit 2 (Wire Ha Rness) [Option]
Alternador [Peças Componentes] [Opcao] / Alternato R [Component Parts] [Option]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option]
Kit Valvula Travao Reboque 2[Peças Componentes] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [Se] [Spa] [Tur] [Option]
Step Support Kit [Option] / Step Support Kit [Opti On]
