Kubota Tractor M6-142 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M6-142 Tractor
Number of Pages: 465 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor (Superior) / Crankcase (Upper)
B Loco Motor (Inferior) / Crankcase (Lower)
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
T Ampa Cabeça / Head Cover
C Obertura Frontal / Front Cover
P Iston E Cambota / Piston And Crankshaft
C Ompensador / Balancer
V Olante Motor / Flywheel
F Iltro Gasoleo / Fuel Filter
B Omba De Abastecimento / Supply Pump
I Njector E Vela Aquecimento / Injector And Glow Plug
T Ubo Injector / Injection Pipe
C Ommon Rail / Common Rail
B Omba Agua / Water Pump
R Adiador Oleo / Oil Cooler
S Eparador De Óleo / Oil Separator
S Eparador De Óleo [Peças Componentes] / Oil Separato R [Component Parts]
T Ubo Do Separador De Óleo / Oil Separator Pipe
F Iltro Ar / Air Cleaner
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cle Aner)
T Urbo Compressor / Turbo Charger
I Ntercooler / Inter Cooler
F Lange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
T Ubos De Água Egr / Egr Water Piping
C Olector Escape / Exhaust Manifold
P Anela Escape / Muffler Pipe
S Ilenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
S Uporte (Filtro De Partículas Diesel) / Muffler Brac Ket (Diesel Particulate Filter)
T Ubo Pressao / Pressure Pipe
P Anela Escape (Filtro De Partículas Diesel) / Muffle R Pipe (Diesel Particulate Filter)
S Ilenciador Da Redução Catalítica Seletiva / Selecti Ve Catalytic Reduction Muffler
P Laca De Isolamento (Silenciador Da Redução Catalíti Ca Seletiva) / Insulation Plate (Selective Catalyti C Reduction Muffler)
E Strutura Da Redução Catalítica Seletiva / Selective Catalytic Reduction Frame
R Esguardo Da Redução Catalítica Seletiva / Selective Catalytic Reduction Cover
I Ndicador Resguardo Da Redução Catalítica Seletiva / Selective Catalytic Reduction Injector Cover
E Strutura Da Redução Catalítica Seletiva / Selective Catalytic Reduction Main Frame
B Omba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
D Epósito Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Tank
D Epósito Do Fluido De Escape De Diesel [Peças Compon Entes] / Diesel Exhaust Fluid Tank [Component Parts ]
D Epósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
S Istema De Arrefecimento Egr (Sistema De Redução Cat Alítica Seletiva) / Egr Cooler (Selective Catalytic Reduction System)
T Ubos De Água Egr (Sistema De Redução Catalítica Sel Etiva) / Egr Water Piping (Selective Catalytic Redu Ction System)
C Obertura De Arranque Motor / Starter Cover
C Omponentes Electricos Motor (Sensor/Ecu) / Engine E Lectrical Parts (Sensor/Ecu)
C Omponentes Electricos Motor (Panela Escape) / Engin E Electrical Parts (Muffler)
C Ablagem Injector / Injector Harness
P Edal Acelarador / Accelerator Pedal
Deposito Combustivel / Fuel Ta Nk
Suporte Deposito Combustivel / Fuel Tank Bracket
Tubo Combustivel (Depósito Do Fluido De Escape De Diesel De Respiro) / Fuel Pipe (Diesel Exhaust Fluid Breather)
Tubo Do Combustível (Enchiment O Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Deposito Com Bustivel Respiro) / Fuel Pipe (Fuel Tank Breather)
Arrefecedor Gasoleo / Fuel Coo Ler
Separador / Separator
Bomba Gasoleo / Fuel Pump
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Suporte Vent Ilador / Fan Bracket
Polia De Aci Onamento Da Ventoinha / Fan Drive Pulley
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Mot Or Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bloco Mot Or Direita) / Switch/Sensor (Engine Rh)
Componenetes Electricos Resgua Rdo / Electrical Parts Cover
Sensor Da Redução Catalítica Seletiva (Bloco Motor) / Selective Catalytic Reduct Ion Sensor (Engine)
Sensor Da Redução Catalítica Seletiva (Corpo) / Selective Catalytic Reduction Se Nsor (Body)
Interruptor/Sensor (Suspensão ) / Switch/Sensor (Suspension)
Interruptor/Sensor (Frente ) / Switch/Sensor (Front)
Interruptor/Sensor (Corpo) [E Xceto Arrasto] / Switch/Sensor (Body) [Except [Cree P]]
Interruptor/Sensor (Corpo) [A Rrasto] / Switch/Sensor (Body) [Creep]
Sensor (Travão) / Sensor (Bra Ke)
Sensor Da Conicidade / Draft Sensor
Interruptor/Sensor (Traseira) [Ec] [Uk] / Switch/Sensor (Rear) [Ec] [Uk]
Interruptor/Sensor (Traseira) [Ge] / Switch/Sensor (Rear) [Ge]
Interruptor (Operação) / Swit Ch (Operation)
Interruptor Principal / Main Switch/Lever Control Switch
Relé / Relay
Unidade Control Electrico (Bl Oco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Co Rpo) / Electrical Control Unit (Body)
Placa / Board
Quadro [Peças Componentes] / Board [Component Parts]
Quadro Do Painel / Panel Boar D
Apoio Braço / Armrest
Apoio De Braço [Peças Compone Ntes] / Armrest [Component Parts]
Painel Control / Control Pane L
Luzes Frente / Head Light
Lâmpada Farol / Beacon Lamp
Luzes Frontais / Front Combin Ation Lamp
Luzes Trabalho (Dianteiro) / Working Light (Front)
Farois Trabalho (Traseira) / Work Light (Rear)
Farol Traseiro / Tail Light
Farol Matricula / License Lam P
Luz Degrau / Step Light
Luz Interior / Room Light
Alta Voz Radio / Radio Speake R
Escova / Wiper
Traseira Da Motor / Electrica L Wiring (Engine Rear)
Cablagem Elétrica (Corte De B Ateria) / Electrical Wiring (Battery Cut)
Cablagem Eletrcia (Lampada Ca Beça) / Electrical Wiring (Head Light)
Cablagem Electrica (Painel) / Electrical Wiring (Panel)
Cablagem Elétrica (Quadro/Ecu ) / Electrical Wiring (Board/Ecu)
Cablagem Elétrica (Painel Con Trl/Lado Direito Da Farol Traseiro) / Electrical Wi Ring (Control Panel/Tail Light Rh)
Cablagem Elétrica (Ar Condici Onado/Alavanca Travao Mao/Lado Esquerdo Da Farol Tr Aseiro) / Electrical Wiring (Air Conditioner/Parkin G Brake Lever/Tail Light Lh)
Cablagem Electrica (Braco) / Electrical Wiring (Armrest)
Cablagem Electrica (Coluna) / Electrical Wiring (Pillar)
Cablagem Electrica (Corpo) [E Xceto Arrasto] [Ec] [Uk] / Electrical Wiring (Body) [Except [Creep]] [Ec] [Uk]
Cablagem Electrica (Corpo) [E Xceto Arrasto] [Ge] / Electrical Wiring (Body) [Exc Ept [Creep]] [Ge]
Cablagem Electrica (Corpo) [A Rrasto] [Ec] [Uk] / Electrical Wiring (Body) [Creep ] [Ec] [Uk]
Cablagem Electrica (Corpo) [A Rrasto] [Ge] / Electrical Wiring (Body) [Creep] [Ge ]
Cablagem Electrica (Valvula S Uspensão Frontal) / Electrical Wiring (Front Suspen Sion Valve)
Cablagem Electrica (Cabine) / Electrical Wiring (Cab)
Carter Embraiagem / Cl Utch Housing
Valvula Powershift / P Ower Shift Valve
Valvula Powershift (Co Rpo) [Peças Componentes] / Power Shift Valve (Body) [Component Parts]
Valvula Powershift (Su Perior) [Peças Componentes] / Power Shift Valve (Up Per) [Component Parts]
Caixa Intermedia [Exce To [Arrasto]] / Mid Case [Except [Creep]]
Caixa Intermedia [Arra Sto] / Mid Case [Creep]
Caixa Da Transmissão / Transmission Case
Carter Transmissao / T Ransmission Case Rear Cover
Carter Eixo Traseiro D Rt / Rear Axle Case Rh
Carter Eixo Traseiro E Sq / Rear Axle Case Lh
Disco Amortecedor / Da Mper Disk
Pedal Embraiagem / Clu Tch Pedal
Plato De Embraiagem / Clutch Plate
Cobertura Frontal / Fr Ont Cover
F-R Embraiagem / F-R C Lutch
Veio Primario / Input Shaft
Veio Inversor / Shuttl E Shaft
Primeira/Segunda Mudan Ça / First/Second Shift Gear
Primeiro Veio / First Shaft
Carreto Terceira/Quart A / Third/Fourth Shift Gear
Veio Secundario / Coun Tershaft
Eixo Alta-Baixa [Excet O Arrasto] / Hi-Lo Shaft [Except [Creep]]
Eixo Alta-Baixa [Arras To] / Hi-Lo Shaft [Creep]
Kit Embraiagem Alta / Hi Clutch
Kit Embraiagem Baixa / Lo Clutch
Veio Primeiro Auxiliar [Exceto [Arrasto]] / Sub First Shaft [Except [Cree P]]
Veio Primeiro Auxiliar [Arrasto] / Sub First Shaft [Creep]
Veio Segundo Auxiliar / Sub Second Shift
Veio Terceiro Auxiliar [Exceto [Arrasto]] / Sub Third Shaft [Except [Cree P]]
Veio Terceiro Auxiliar /Veio Creeper [Arrasto] / Sub Third Shaft/Creep Sha Ft [Creep]
Veio De Transmissão Bo Mba / Pump Drive Shaft
Grupo Conico / Bevel G Ear
Suporte Rolamento De D Iferencial Traseira / Rear Differential Bearing Sup Port
Diferencial Traseiro / Rear Differential
Embraiagem Tdf / Pto C Lutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf (Corpo) [Peças Componentes] / Pto Clutch Valve (Bo Dy) [Component Parts]
Valvula Embraiagem Tdf (Interruptor/Conector) [Peças Componentes] / Pto C Lutch Valve (Switch/Connector) [Component Parts]
Valvula Embraiagem Tdf (Pistão) [Peças Componentes] / Pto Clutch Valve (P Iston) [Component Parts]
Veio Principal Tdf / P To Drive Shaft
Veio Tdf / Pto Shaft
Eixo De Transmissão Du Pla / Dt Shaft
Embraiagem Andamento / Front Drive Clutch
Embraiagem Andamento [ Peças Componentes] / Front Drive Clutch [Component Parts]
Embraiagem Hidraulica / Hydraulic Clutch
Forqueta Ve Locidades / Range Gear Shift Fork
Forqueta Cr Eeper [Arrasto] / Creep Shift Fork [Creep]
Alvanca Tdf / Pto Shift Fork
Alvanca Inv Ersor / Shuttle Shift Lever
Alavanca Da S Mudanças Lentas [Arrasto] / Creep Gear Shift Leve R [Creep]
Alavanca Td F / Pto Gear Shift Lever
Eixo Traseiro / Rear Axle S Haft
Travão / Brake
Caixa De Travões /Direito / Brake Case Rh
Caixa De Travões /Esquerdo / Brake Case Lh
Alavanca Travao Mao / Parki Ng Brake Lever
Travão De Estacionamento / Parking Brake
Pedal Travao / Brake Pedal
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [ Peças Componentes] / Brake Master Cylinder [Compone Nt Parts]
Tubo Do Travão [Ge] / Brake Pipe [Ge]
Tubo Travao / Brake Master Cylinder Pipe
Quadro Eixo Frente / Fro Nt Axle Frame
Suporte De Carregador Di Anteiro / Front Loader Bracket
Suporte Eixo Frente / Fr Ont Axle Bracket
Veio Primario (Frente/Me Io) / Propeller Shaft (Front/Mid)
Veio Primario [Peças Com Ponentes] / Mid Propeller Shaft [Component Parts]
Veio Primario (Traseira) / Propeller Shaft (Rear)
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Dif Ferential Front
Suporte Diferencial Fren Te / Differential Front Support
Caixas Engrenagens Conic A Drt / Bevel Gear Case Rh
Caixas Engrenagens Conic A Esq / Bevel Gear Case Lh
Carter Eixo Frente / Fro Nt Axle Case
Eixo Dianteiro / Front A Xle
Veio Carreto Diferencial / Differential Gear Shaft
Tampa Coluna Direccao / Steering Post Cover
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cyl Inder
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico (Corpo) [Peç As Componentes] / Hydraulic Pump (Body) [Component Parts]
Bomba Hidraulico (Pistão) [Pe Ças Componentes] / Hydraulic Pump (Piston) [Compone Nt Parts]
Bomba Hidraulico (Valvula) [P Eças Componentes] / Hydraulic Pump (Valve) [Compone Nt Parts]
Válvula De Prioridade [Ec] [U K] / Priority Valve [Ec] [Uk]
Válvula De Prioridade [Ge] / Priority Valve [Ge]
Válvula De Prioridade (Base) [Peças Componentes] [Ec] [Uk] / Priority Valve (Bas E) [Component Parts] [Ec] [Uk]
Válvula De Prioridade (Base) [Peças Componentes] [Ge] / Priority Valve (Base) [C Omponent Parts] [Ge]
Válvula De Prioridade (Pv1/Pv 2/Pv3) [Peças Componentes] / Priority Valve (Pv1/Pv 2/Pv3) [Component Parts]
Válvula De Prioridade (Descar Ga/Redução/Inversor) [Peças Componentes] / Priority Valve (Relief/Reducing/Shuttle) [Component Parts]
Circuito Oleo Direcção (Sucçã O) / Hydraulic Pipe (Suction)
Circuito Oleo Direcção (Válvu La De Prioridade) / Hydraulic Pipe (Priority Valve)
Tubo Hidraulico (Travao Reboq Ue) [Ec] [Uk] / Hydraulic Pipe (Trailer Brake) [Ec] [Uk]
Tubo Oleo (Tdf) / Hydraulic P Ipe (Pto)
Circuito Oleo Direcção (Bomba Hidraulico) / Hydraulic Pipe (Hydraulic Pump)
Valvula Travao Reboque [Ec] [ Uk] / Trailer Brake Valve [Ec] [Uk]
Valvula Segurança / Safety Va Lve
Circuito Oleo Hidraulico (Dif Erencial Traseiro) / Hydraulic Oil Line (Rear Diffe Rential)
Circuito Oleo Hidraulico (Dif Erencial Frente) / Hydraulic Oil Line (Front Differ Ential)
Radiador Oleo / Oil Cooler
Circuito Oleo Radiador (Radia Dor Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcção (Direc Ção) / Hydraulic Oil Line (Steering)
Tubo Direccao (Entrega) / Ste Ering Hose (Delivery)
Valvula Da Suspensão Frontal / Front Suspension Valve
Valvula Da Suspensão Frontal (Valvula Descarga) [Peças Componentes] / Front Susp Ension Valve (Relief/Check) [Component Parts]
Valvula Da Suspensão Frontal (Segurança) [Peças Componentes] / Front Suspension Valve (Safety) [Component Parts]
Valvula Da Suspensão Frontal (Junta) [Peças Componentes] / Front Suspension Valv E (Joint) [Component Parts]
Tubo Da Suspensão Frontal Val Vula / Front Suspension Valve Hose
Cilindro Da Suspensão Frontal / Front Suspension Cylinder
Cilindro Da Suspensão Frontal Direita [Peças Componentes] / Front Suspension Cyl Inder Rh [Component Parts]
Cilindro Da Suspensão Frontal Esquerda [Peças Componentes] / Front Suspension Cy Linder Lh [Component Parts]
Caixa Cilindro Hidraulico [Ec ] [Uk] / Hydraulic Cylinder Case [Ec] [Uk]
Caixa Cilindro Hidraulico [Ge ] / Hydraulic Cylinder Case [Ge]
Válvula Do Sensor De Carga / Load Sensing Valve
Válvula Do Sensor De Carga (C Orpo) [Peças Componentes] / Load Sensing Valve (Bod Y) [Component Parts]
Válvula Do Sensor De Carga (P Ara Cima) [Peças Componentes] / Load Sensing Valve (Up) [Component Parts]
Válvula Do Sensor De Carga (P Ara Baixo) [Peças Componentes] / Load Sensing Valve (Down) [Component Parts]
Válvula Do Sensor De Carga (A Lavanca) [Peças Componentes] / Load Sensing Valve ( Lever) [Component Parts]
Válvula Do Sensor De Carga (F C) [Peças Componentes] / Load Sensing Valve (Fc) [C Omponent Parts]
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Trinco / Lowering Lock Lever
Válvula De Controle Alavanca (Scd/Fd) / Auxiliary Control Valve (Scd/Fd)
Válvula De Controle Alavanca (Scd Con Fc) [Peças Componentes] / Auxiliary Contro L Valve (Scd With Fc) [Component Parts]
Válvula De Controle Alavanca (Fd Con Fc) [Peças Componentes] / Auxiliary Control Valve (Fd With Fc) [Component Parts]
Tampa Da Válvula De Controlo Auxiliar / Auxiliary Control Valve Cap
Alavanca Da Válvula De Contro Lo Auxiliar / Auxiliary Control Lever
Cilindro Auxiliar De Elevacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevacao [Peças Componentes] / 3p-Lift Assist Cylinder [Com Ponent Parts]
Parte Su Perior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link
Estabili Zador (Manual) / Stabilizer (Manual)
Estabili Zador (Automatico) / Stabilizer (Automatic)
Estabili Zador Drt / Lift Rod Rh
Estabili Zador Esq / Lift Rod Lh
Cilndro Eleveção [Peças Componentes] / Lift Cylinder [Compo Nent Parts]
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / Hood (Bonnet) (Sound Absorber/Insulator)
Estrutura Capot / Hood (Bonnet) Frame
Suporte Capot / Hood (Bonnet) Support
Capot Inferior (Direito) / Hood (Bonnet) Side L Ower Rh
Capot Inferior (Esquerdo) / Hood (Bonnet) Side Lower Lh
Est Rutura Cabine [Exceto [Arrasto]] / Cab Frame [Excep T [Creep]]
Est Rutura Cabine [Arrasto] / Cab Frame [Creep]
Deg Rau / Step
Cap Ot Traseiro / Hood (Bonnet) Rear
Vid Ro Frente / Front Glass
Por Ta Drt / Door Rh
Por Ta Esq / Door Lh
Tri Nco Porta Esq / Door Lock Lh
Vid Ro Traseiro Da Escotilha / Hatch Back Glass
Pro Tetor De Para-Sol / Sunshade
Tej Adilho / Sun Roof
Esp Elho Rectrovisor / Rearview Mirror
Vis Or Solar / Sun Visor
Tec To Interior / Inner Roof
Cob Ertura Exterior Do Tejadilho / Outer Roof
Ban Co / Seat
Ban Co (Coxim) [Peças Componentes] / Seat (Cushion) [Co Mponent Parts]
Ban Co (Apoio Braço/Costas Banco) [Peças Componentes] / Seat (Armrest/Backrest) [Component Parts]
Ban Co (Suspensão) [Peças Componentes] / Seat (Suspensi On) [Component Parts]
Ban Co De Passageiro / Passenger Seat
Tap Ete Do Piso / Floor Mat
Cha Pa Inspecção (Frente) / Inspection Plate (Front)
Cob Ertura Piso / Floor Sheet Cover
Cob Ertura De Mudança [Exceto [Arrasto]] / Shift Cover [Except [Creep]]
Cob Ertura De Mudança [Arrasto] / Shift Cover [Creep]
Cob Ertura Gurada Lamas Esq / Fender Cover Lh
Gua Rda Lamas (Direito) / Fender Rh
Gua Rda Lamas (Esquerda) / Fender Lh
Sup Orte De Montagem Da Cabine (Frente) / Cab Mount Bra Cket Front
Tra Seira Do Suporte Da Cabine (Direito) / Cab Bracket Rear (Rh)
Tra Seira Do Suporte Da Cabine (Esquerdo) / Cab Bracket Rear (Lh)
Cai Xa Ferramenta / Tool Box
Ar Condicionado / Air Conditioner
Cuberto Tubo Air Condicionado / A Ir Conditioner Duct Cover
Tubo Ar Condicionado (Frente) / A Ir Conditioner Duct (Front)
Modo Caixa / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaçao Ar Interior / Inner Ai R Recirculation
Condesador / Condenser
Compressor (Ar Condicionado) / Co Mpressor (Air Conditioner)
Etiqueta (Traseira/Cabine) 1 / Label (Rear/Cab) 1
Etiqueta (Traseira/Cabine) 2 [Exceto [Arrasto]] / Label (Rear/Cab) 2 [Except [Creep]]
Etiqueta (Traseira/Cabine) 2 [Arrasto] / Label ( Rear/Cab) 2 [Creep]
Etiqueta (Estrutura Da Cabine) / Label (Cab Fram E)
P Eça De Acessorio E Serviço Peças / Accessories And Service Parts
K It Alternador [Opçao] / Alternator Kit [Option]
A Lternador [Peças Componentes] [Opção] / Alternator [Component Parts] [Option]
L Uzes Frente (Farol De Repetição) [Ec] [Ge] [Opçao] / Head Light Kit (Repeat Head Light) [Ec] [Ge] [Opt Ion]
L Uzes Frente (Farol De Repetição) [Uk] [Opçao] / Hea D Light Kit (Repeat Head Light) [Uk] [Option]
K It Farios Trabalho (Led) (Frente) [Opção] / Working Light Kit (Led) (Front) [Option]
K It Farios Trabalho (Led) (Traseira-Superior) [Opção ] / Working Light Kit (Led) (Rear-Upper) [Option]
K It Farios Trabalho (Led) (Traseira-Inferior) [Opção ] / Working Light Kit (Led) (Rear-Lower) [Option]
K It Cobertuta Deposito Gasoleo [Opção] / Fuel Tank C Over Kit [Option]
K It Do Terminal [Opção] / Terminal Kit [Option]
K It Do Conector (Isobus) [Opção] / Connector Kit (Is Obus) [Option]
K It De 21 Estrias De Tdf [Opção] / 21 Spline Pto Kit [Option]
K It De Powr Beyond (3 Válvulas) [Opção] / Power Beyo Nd Kit (3 Valves) [Option]
K It De Powr Beyond (4 Válvulas) [Opção] / Power Beyo Nd Kit (4 Valves) [Option]
V Álvula De Controle Alavanca Kit (Scd Con Fc) [Opção ] / Auxiliary Control Valve Kit (Scd With Fc) [Opti On]
V Álvula De Controle Alavanca Kit (Fd Con Fc) [Opção] / Auxiliary Control Valve Kit (Fd With Fc) [Option ]
V Álvula De Controle Alavanca (Scd Con Fc) [Peças Com Ponentes] [Opção] / Auxiliary Control Valve (Scd Wi Th Fc) [Component Parts] [Option]
V Álvula De Controle Alavanca (Fd Con Fc) [Peças Comp Onentes] [Opção] / Auxiliary Control Valve (Fd With Fc) [Component Parts] [Option]
A Uxiliar Do Alavanca De Válvula De Controlo Kit (4ª) [Opção] / Auxiliary Control Valve Lever Kit (4th) [Option]
P Laca Sinalizadora [Opção] / Signal Plate [Option]
