Kubota Tractor M5700DTN Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5700DTN Tractor
Number of Pages: 224 Pages
Frequently Used Ite Ms / Frequently Used Items
Crankcase / Crankcase
Oil Pan / Oil Pan
Cylinder Head / Cylinder Head
Gear Case / Gear Case
Head Cover / Head Cover
Main Bearing Case / Main Bearing Case
Camshaft And Idle Gear Shaft / Camshaft And Idle Gear Shaft
Piston And Crankshaft / Piston And Crankshaft
Flywheel / Flywheel
Engine Stop Lever / Engine Stop Lever
Injection Pump / Injection Pump
Governor / Governor
Speed Control Plate / Speed Control Plate
Nozzle Holder And Glow Plug / Nozzle Holder And G Low Plug
Nozzle Holder [Component Parts] / Nozzle Holder [Component Parts]
Water Flange And Thermostat / Water Flange And Th Ermostat
Water Pump / Water Pump
Valve And Rocker Arm / Valve And Rocker Arm
Inlet Manifold / Inlet Manifold
Exhaust Manifold / Exhaust Manifold
Air Cleaner / Air Cleaner
Air Cleaner [Component Parts] / Air Cleaner [Comp Onent Parts]
Muffler / Muffler
Upper Gasket Kit / Upper Gasket Kit
Lower Gasket Kit / Lower Gasket Kit
Hand Accelerator Lever / Hand Accelerator Lever
Stop Solenoid/Engine Stop Wire / Stop Solenoid/En Gine Stop Wire
Fuel Tank / Fuel Tank
Fuel Filter / Fuel Filter
Fuel Filter [Component Parts] / Fuel Fi Lter [Component Parts]
Fan / Fan
Water Pipe / Water Pi Pe
Radiator / Radiator
Reserve Tank / Reserv E Tank
Alternator / Alternator
Alternator [Component Parts ] / Alternator [Component Parts]
Starter / Starter
Starter [Component Parts] / Starter [Component Parts]
Battery / Battery
Switch/Sensor / Switch/Sens Or
Switch (Panel Board)/Relay / Switch (Panel Board)/Relay
Panel Board / Panel Board
Panel Board [Component Part S] / Panel Board [Component Parts]
Head Light / Head Light
Flasher Light / Flasher Lig Ht
Tail Light / Tail Light
Clutch Housing / Clutch Housing
Shuttle Gear Case / Shu Ttle Gear Case
Transmission Case / Tra Nsmission Case
Transmission Case Rear Cover / Transmission Case Rear Cover
Rear Axle Case / Rear A Xle Case
Front Drive Case / Fron T Drive Case
Clutch / Clutch
Clutch Release Fork / C Lutch Release Fork
Clutch Pedal / Clutch P Edal
Input Shaft / Input Sha Ft
First Shaft / First Sha Ft
Second Shaft / Second S Haft
Third Shaft / Third Sha Ft
Back Idle Shaft / Back Idle Shaft
Creep Shaft / Creep Sha Ft
Bevel Gear [Old Type] / Bevel Gear [Old Type]
Bevel Gear [New Type] / Bevel Gear [New Type]
Differential Rear / Dif Ferential Rear
Pto Propeller Shaft / P To Propeller Shaft
Pto Clutch / Pto Clutch
Pto Clutch [Component Parts] / Pto Clutch [Component Parts]
Pto Clutch Valve / Pto Clutch Valve
Pto Clutch Valve [Comp Onent Parts] / Pto Clutch Valve [Component Parts]
Pto Shaft / Pto Shaft
Front Propeller Shaft ( Rear) / Front Propeller Shaft (Rear)
Main Gear Shift Fork / Main Gear Shift Fork
Shuttle Gear Shift Fork / Shuttle Gear Shift Fork
Range Gear Shift Fork / Range Gear Shift Fork
Rear Differential Lock Shift Fork / Rear Differential Lock Shift Fork
Rear Axle / Rear Axle
Brake / Brake
Brake Rod / Brake Rod
Main Gear Shift Lever / Main Ge Ar Shift Lever
Shuttle Shift Lever / Shuttle S Hift Lever
Range Gear Shift Lever / Range Gear Shift Lever
Range Gear Shift Rod / Range Ge Ar Shift Rod
Pto Clutch Lever / Pto Clutch L Ever
Pto Gear Shift Lever / Pto Gear Shift Lever
Front Wheel Drive Lever / Front Wheel Drive Lever
Brake Pedal / Brake Pedal
Rear Differential Lock Pedal / Rear Differential Lock Pedal
Front Axle Frame / Front Axle Frame
Front Axle Bracket / Fron T Axle Bracket
Front Axle Case / Front A Xle Case
Differential Front / Diff Erential Front
Differential Gear Shaft / Differential Gear Shaft
Front Axle / Front Axle
Steering Handle / Steering Handle
Steering Controller / Steering Controller
Steering Controller [Component Parts] / Steer Ing Controller [Component Parts]
Steering Linkage / Steering Linkage
Steering Cylinder [Component Parts] / Steerin G Cylinder [Component Parts]
Hydraulic Pump / Hydraulic Pu Mp
Hydraulic Pump [Component Par Ts] / Hydraulic Pump [Component Parts]
Hydraulic Pipe (Suction) / Hy Draulic Pipe (Suction)
Hydraulic Pipe (Delivery) / H Ydraulic Pipe (Delivery)
Hydraulic Oil Line (Steering/ Pto) / Hydraulic Oil Line (Steering/Pto)
Steering Hose (Delivery) / St Eering Hose (Delivery)
Hydraulic Cylinder / Hydrauli C Cylinder
Hydraulic Lift Arm / Hydrauli C Lift Arm
Hydraulic Cylinder Cover / Hy Draulic Cylinder Cover
Control Valve / Control Valve
Draft And Position Control Le Ver / Draft And Position Control Lever
Draft And Position Control Le Ver Bracket / Draft And Position Control Lever Brac Ket
Position Control Shaft / Posi Tion Control Shaft
Draft Control Shaft / Draft C Ontrol Shaft
Feed Back Lever / Feed Back L Ever
Auxiliary Control Valve / Aux Iliary Control Valve
Top Link Bracket / Top Link B Racket
Top Link / Top Link
Lower Link / Lower Link
Lift Rod Rh / Lift Rod Rh
Lift Rod Lh / Lift Rod Lh
Swinging Drawbar / Swinging D Rawbar
Pto Shaft Protector / Pto Sha Ft Protector
Hood(Bonnet) Front / Hood(Bonnet) Front
Hood(Bonnet) Upper / Hood(Bonnet) Upper
Hood(Bonnet) Side / Hood(Bonnet) Side
Hood(Bonnet) Side Cover / Hood(Bonnet) Side Cover
Hood(Bonnet) Rear / Hood(Bonnet) Rear
Rearview Mirror / Rearview Mirror
Floor Seat / Floor Seat
Step / Step
Seat / Seat
Tool Box / Tool Box
Rops 1 (Mid) [Old Type] / Rops 1 (Mid) [Old Type]
Rops 1 (Mid) [New Type] / Rops 1 (Mid) [New Type]
Rops 2 (Rear) [Old Type] / Rops 2 (Rear ) [Old Type]
Rops 2 (Rear) [New Type] / Rops 2 (Rear ) [New Type]
Front Wheel (8-16 ) / Front Wheel (8-16)
Front Wheel (9.5- 16) [Option] / Front Wheel (9.5-16) [Option]
Rear Wheel (12.4- 24fl) / Rear Wheel (12.4-24fl)
Rear Wheel (14.9- 24fl) [Option] / Rear Wheel (14.9-24fl) [Option]
Label / Label
Accessories And Service Parts / Accesso Ries And Service Parts
Working Light Kit [Option] / Working Light Kit [O Ption]
Paking Brake Lever Kit [Option] [Old Type] / Paki Ng Brake Lever Kit [Option] [Old Type]
Front Weight Bumper Kit [Option] / Front Weight B Umper Kit [Option]
Auxiliary Control Valve Kit [Option] / Auxiliary Control Valve Kit [Option]
Auxiliary Control Valve [Component Parts][Option] / Auxiliary Control Valve [Component Parts][Option ]
Oil Pan / Oil Pan
Flywheel / Flywheel
Governor / Governor
Muffler / Muffler
Fan / Fan
Radiator / Radiator
Starter / Starter
Battery / Battery
Clutch / Clutch
Brake / Brake
Top Link / Top Link
Step / Step
Seat / Seat
Tool Box / Tool Box
Label / Label
