Kubota Tractor M5700DTN Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5700DTN Tractor
Number of Pages: 371 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Volante / Flywheel
Motor Parar Palanca / Engine Stop Lever
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Air Cleaner [Component Parts]
Silenciador / Muffler
Palanca Acelerador / Hand Accelerator Lever
Solenoide De Parada/Cable De Parada De Motor[Tipo Cabina] / Stop Solenoid/Engine Stop Wire
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Accesorios / Switch (Panel Board)/Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Luz Intermitente[Tipo Arco] / Flasher Light
Cola Luz / Tail Light
Adelante Accionar Caja / Front Drive Case
Embrague / Clutch
Embrague Palanca / Clutch Release Fork
Entrada Eje / Input Shaft
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Del Engranaje Loco Posterior [Tipo Nuevo] / Back Idle Shaft
Diferencial Engranaje Eje / Bevel Gear [Old Type]
Diferencial Engranaje Eje / Bevel Gear [New Type]
Diferencial Trasero / Differential Rear
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Tdf Eje / Pto Shaft
Eje Propulsor Delantero(Posterior) / Front Propeller Shaft (Rear)
Inversor Cambio Bifurcacion / Shuttle Gear Shift Fork
Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Freno / Brake
Freno Varilla / Brake Rod
Inversor Cambio Palanca / Shuttle Shift Lever
Gama Engranaje Cambio Varilla / Range Gear Shift Rod
Palanca De Embrague De Tdf / Pto Clutch Lever
Freno Pedal / Brake Pedal
Adelante Helice Eje / Front Propeller Shaft
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Hidraulico Tubo(Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Aceite Linea (Direccion/Tdf) / Hydraulic Oil Line (Steering/Pto)
Direccion Manguito / Steering Hose (Delivery)
Hidraulico Piston/Ascenzo Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico / Hydraulic Cylinder Cover
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Esfuerzo Y Posicion Control Varilla / Draft And Position Control Lever Bracket
Eje De Control De Posicion[Tipo Arco] / Position Control Shaft
Eje De Control De Esfuerzo[Tipo Arco] / Draft Control Shaft
Alejado Control Valvula / Auxiliary Control Valve
Auxiliar Control Valvula (S/D) [Componente Piezas] / Auxiliary Control Valve [Component Parts]
Bajar Vinculo / Lower Link
Barra De Remolque Oscilante[Tipo Cabina] / Swinging Drawbar
Tdf Protector / Pto Shaft Protector
Capo(Capo)Adelante / Hood(Bonnet) Front
Capo / Hood(Bonnet) Upper
Capo Lado / Hood(Bonnet) Side
Capo Lado Cubierta / Hood(Bonnet) Side Cover
Capo Trasero / Hood(Bonnet) Rear
Guardabarros / Fender
Hoja De Piso / Floor Seat
Peldano / Step
Hoja / Seat
Herramienta Caja / Tool Box
Arco Seguridad 1 (Intermedio) [Tipo Arco][Tipo Nuevo][Except Tipo Cab.] / Rops 1 (Mid) [Old Type]
Arco Seguridad 1 (Intermedio) [Tipo Arco][Tipo Nuevo][Except Tipo Cab.] / Rops 1 (Mid) [New Type]
Arco Seguridad 2 (Posteropr) [Tipo Arco][Tipo Nuevo][Except Tipo Cab.] / Rops 2 (Rear) [Old Type]
Arco Seguridad 2 (Posteropr) [Tipo Arco][Tipo Nuevo][Except Tipo Cab.] / Rops 2 (Rear) [New Type]
Rueda Delantera (22*8,50-12) / Front Wheel (8-16)
Rueda Delantera (22*8,50-12) / Front Wheel (9.5-16) [Option]
Rueda Trasera (31*13,5-15) / Rear Wheel (12.4-24fl)
Rueda Trasera (31*13,5-15) / Rear Wheel (14.9-24fl) [Option]
Etiqueta / Label
Funcionamiento Luz Kit / Working Light Kit [Option]
Remolque Vaso Kit[Opcion] / Trailer Socket Kit [Option]
Kit Palanca Freno De Mano (Opcion( (Viejo) / Paking Brake Lever Kit [Option] [Old Type]
Kit Palanca Freno De Mano (Opcion) (Nuevo) / Paking Brake Lever Kit [Option] [New Type]
Peso Delantero / Front Weight Bumper Kit [Option]
Auxiliar Control Valvula Kit[Opcion] / Auxiliary Control Valve Kit [Option]
Valvula Auxiliar Control [Componentes] [Opcion] / Auxiliary Control Valve [Component Parts][Option]
Apoyo Del Paso [Opcion] / Step Support Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Embrague / Clutch
Tdf Eje / Pto Shaft
Freno / Brake
Peldano / Step
Hoja / Seat
Etiqueta / Label
