Kubota Tractor M5700DT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5700DT Tractor
Number of Pages: 216 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head [Rops Type]
Carreto / Gear Case
Tampa Cabeça / Head Cover
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft
Regulador Velocidade / Engine Stop Lever
Vela Pre Aquecimento / Nozzle Holder And Glow Plug [Rops Type]
Suporte Bico [Peças Componentes] / Nozzle Holder [ Component Parts]
Bomba Agua E Termostacto / Water Flange And Thermos Tat [Rops Type]
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Colector Escape / Exhaust Manifold [Rops Type]
Filtro Ar / Air Cleaner [Rops Type]
Filtro Ar [Peças Componentes] / Air Cleaner [Compon Ent Parts]
Escpae / Muffler [Rops Type]
Kit De Junta Superior [Opção] / Upper Gasket Kit [O Ption]
Kit De Junta Inferior [Opção / Lower Gasket Kit [Op Tion]
Acelarador Mao / Hand Accelerator Lever [Rops Type]
Deposito Combustivel / Fuel T Ank [Rops Type]
Tubo Combustivel / Fuel Pipe [Rops Type]
Ventoinha / Fan [Rops Type]
Tubo Agua / Water Pipe [Rops Type]
Radiador / Radiator [Rops Type]
Deposito Re Serva / Reserve Tank [Rops Type]
Alternador / Alternator [Rop S Type]
Alternador [Peças Componente S] / Alternator [Component Parts] [Rops Type]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Bateria / Battery [Rops Type ]
Interruptor/Sensor / Switch/ Sensor [Rops Type]
Interruptor / Switch (Panel Board) [Rops Type]
Painel / Panel Board [Rops T Ype]
Painel[Peças Componentes] / Panel Board [Component Parts] [Rops Type]
Farol Dianteiro / Head Light
Hazard Light/Tail Light [Rop S Type] / Hazard Light/Tail Light [Rops Type]
Cablagem Electrica / Electri Cal Wiring 1 [Rops Type]
Carter Embraiagem / C Lutch Housing [Rops Type]
Carretos Inversor / S Huttle Gear Case
Caixa Velocidades / T Ransmission Case [Rops Type]
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Ax Le Case
Caixa Da Transmissão Dianteira / Front Drive Case
Compensador / Clutch
Forqueta Embraiagem / Clutch Release Fork [Rops Type]
Pedal Embraiagem / Cl Utch Pedal [Rops Type]
Veio Primario / Input Shaft
Primeiro Veio / First Shaft
Secundario Veio / Sec Ond Shaft
Terceiro Veio / Third Shaft [Rops Type]
Back Idle Shaft / Bac K Idle Shaft
Veio Creeper / Creep Shaft
Grupo Conico / Bevel Gear [Old Type]
Grupo Conico / Bevel Gear [New Type]
Diferencial Traseiro / Differential Rear
Veio Tdf / Pto Propel Ler Shaft [Rops Type]
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Td F / Pto Clutch Valve
Valvula Embraiagem Td F[Peças Componentes] / Pto Clutch Valve [Component Parts]
Forquilha Inversor / Shuttle Gear Shift Fork
Forqueta Velocidades / Range Gear Shift Fork [Rops Type]
Alvanca T Df / Pto Shift Fork
Alavanca / Rear Differential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever [Rops Type]
Alvanca I Nversor / Shuttle Shift Lever [Rops Type]
Alavanca Velocidades / Range Gear Shift Lever [Rops Type]
Alavanca Embraiagem Tdf / Pto Clutch Lever [Rops Type]
Alavanca Dupla Traccao / Front Wheel Drive Lever [Rops Type]
Eixo Traseiro / Rear Axle
Travão / Brake
Tirante Travao / Brake Rod [Rops Type]
Pedal Travao / Brake Pedal [Rops Type]
Pedal Bloqueio Diferencial Traseiro / Rear Differential Lock Pedal [Rops Type ]
Suporte Eixo Frente / F Ront Axle Frame [Rops Type]
Suporte Eixo Dianteiro / Front Axle Bracket
Veio Frontal / Front Pr Opeller Shaft
Caixa Diferencial Diant Eiro / Front Differential Case
Engrenagem Cónica (Dian Teira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Carter Eixo / Front Axl E Case
Grupo Conico / Differen Tial Gear Shaft
Punho Volante / Steering Handle [Rops Type]
Distribuidor Direcção(Nova) / Steering Control Ler [Rops Type]
Distribuidor Direcção[Peças Componentes] / Ste Ering Controller [Component Parts]
Direcção / Steering Linkage
Cilindro Direcção[Peças Comp Onentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico[Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraulic Pipe (Suction) [Rops Type]
Tubo Oleo / Hydraulic Pipe ( Delivery) [Rops Type]
Circuito Oleo Radiador / Hyd Raulic Oil Line (Oil Cooler) [Rops Type]
Circuito Oleo Direcção / Hyd Raulic Oil Line (Steering/Pto) [Rops Type]
Tubo Direccao / Steering Hos E (Delivery) [Rops Type]
Cilindro Hidraulico / Hydrau Lic Cylinder [Rops Type]
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Resguardo Cilindro Hidráulic O / Hydraulic Cylinder Cover [Rops Type]
Braco Hidraulico / Control V Alve
Alavanca Control Esforço / D Raft And Position Control Lever [Rops Type]
Draft Control Shaft / Draft Control Shaft
Alavanca / Feed Back Lever
Distribuidor Auxiliar / Auxi Liary Control Valve [Rops Type]
Valvula Auxiliar [Peças Comp Onentes] / Auxiliary Control Valve [Component Parts ] [Rops Type]
Parte S Uperior / Top Link Bracket [Rops Type]
Ligacao Superior / Top Link [Rops Type]
Ligacao Inferior / Lower Link [Rops Type] [Old Type]
Ligacao Inferior / Lower Link [Rops Type] [New Type]
Estabil Izador(Drt) / Lift Rod Rh
Estabil Izador(Esq) / Lift Rod Lh
Barra D E Engate Oscilante / Swinging Drawbar [Rops Type]
Protecc Ao Tdf / Pto Shaft Protector
Hood(Bonnet) Front [Rops Type] / Hood(Bonnet) Front [Rops Type]
Capot Superior / Hood(Bonnet) Upper [Rops Type ]
Lado Do Capot / Hood(Bonnet) Side [Rops Type]
Capot Lateral / Hood(Bonnet) Side Cover [Rops Type]
Capot Traseiro / Hood(Bonnet) Rear [Rops Type]
Espelho Rectrovisor / Rearview Mirror [Rops Ty Pe]
Guarda Lamas / Fender [Rops Type]
Piso / Floor Seat [Rops Type]
Degrau / Step [Rops Type]
Arco / Rops [R Ops Type] [Old Type]
Arco / Rops [R Ops Type] [New Type]
Ba Nco / Seat [Rops Type]
Ca Ixa Ferramenta / Tool Box [Rops Type]
Roda Frente / Front Wheel (9.5-22) [ Option]
Roda Frente / Front Wheel (8.3-24) [ Option]
Roda Traseira / Rear Wheel (16.9-28) [Option]
Roda Traseira / Rear Wheel (14.9-28) [Option]
Etiqueta Traseira / Label [Rops Type]
Acessorios / Accessories And Service Part S
Kit Farios Trabalho (Opçao) / Working Light Kit [Ro Ps Type] [Option]
Trailer Socket Kit [Rops Type] [Option] / Trailer S Ocket Kit [Rops Type] [Option]
Paking Brake Lever Kit [Rops Type] [Option] [New Ty Pe] / Paking Brake Lever Kit [Rops Type] [Option] [ New Type]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Scd) [Rops Type] [Option]
Auxiliary Control Valve Kit(Fd)[Rops Type] [Option] / Auxiliary Control Valve Kit(Fd)[Rops Type] [Opti On]
Distribuidor Auxiliar[Peças Componentes] / Auxiliar Y Control Valve(Scd)[Component Parts][Rops Type][Op Tion]
Distribuidor Auxiliar[Peças Componentes] / Auxiliar Y Control Valve(Fd)[Component Parts][Rops Type][Opt Ion]
