Kubota Tractor M5700DT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5700DT Tractor
Number of Pages: 371 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata [Tipo Arco] / Cylinder Head [Rops Type]
Culata Cubierta / Head Cover
Volante / Flywheel
Motor Parar Palanca / Engine Stop Lever
Speed Control Plate
Portainyector Y Bujia De Calentamiento [Tipo Arco] / Nozzle Holder And Glow Plug [Rops Type]
Brida De Agua Y Termostato [Tipo Arco] / Water Flange And Thermostat [Rops Type]
Agua Bomba / Water Pump
Colector De Escape [Tipo Arco] / Exhaust Manifold [Rops Type]
Filtro De Aire [Tipo Arco] / Air Cleaner [Rops Type]
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Silenciador [Tipo Arco] / Muffler [Rops Type]
Superior Junta Kit[Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit[Opcion] / Lower Gasket Kit [Option]
Palanca De Acelerador De Mano [Tipo Arco] / Hand Accelerator Lever [Rops Type]
Solenoide De Parada/Cable De Parada De Motor [Tipo Arco] / Stop Solenoid/Engine Stop Wire [Rops Type]
Deposito De Combustible [Tipo Arco] / Fuel Tank [Rops Type]
Tubo De Combustible [Tipo Arco] / Fuel Pipe [Rops Type]
Filtro De Combustible [Componentes] [Tipo Arco] / Fuel Filter [Component Parts] [Rops Type]
Ventilador [Tipo Arco] / Fan [Rops Type]
Tubo De Agua [Tipo Arco] / Water Pipe [Rops Type]
Radiador [Tipo Arco] / Radiator [Rops Type]
Deposito De Reserva[Tipo Arco] / Reserve Tank [Rops Type]
Alternador [Tipo Arco] / Alternator [Rops Type]
Alternador [Componentes] [Tipo Arco] / Alternator [Component Parts] [Rops Type]
Motor De Arranque / Starter
Bateria [Tipo Arco] / Battery [Rops Type]
Conmutador/Sensor [Tipo Arco] / Switch/Sensor [Rops Type]
Conmutador (Tablero De Instrumentos) [Tipo Arco] / Switch (Panel Board) [Rops Type]
Tablero De Instrumentos [Tipo Arco] / Panel Board [Rops Type]
Tablero De Instrumentos [Componentes] [Tipo Arco] / Panel Board [Component Parts] [Rops Type]
Culata Luz / Head Light
Luz De Emergencia/Piloto Trasero [Tipo Arco] / Hazard Light/Tail Light [Rops Type]
Cableado Electrico 1 [Tipo Arco] / Electrical Wiring 1 [Rops Type]
Carcasa De Embrague [Tipo Arco] / Clutch Housing [Rops Type]
Inversor Engranaje Caja / Shuttle Gear Case
Caja De Transmision [Tipo Arco] / Transmission Case [Rops Type]
Transmision Caja Trasero Cubierta / Transmission Case Rear Cover
Trasero Eje Caja / Rear Axle Case
Adelante Accionar Caja / Front Drive Case
Embrague / Clutch
Horquilla De Desacoplamiento [Tipo Arco] / Clutch Release Fork [Rops Type]
Pedal De Embrague [Tipo Arco] / Clutch Pedal [Rops Type]
Entrada Eje / Input Shaft
Primero Eje / First Shaft
Segundo Eje / Second Shaft
Tercer Eje [Tipo Arco] / Third Shaft [Rops Type]
Trasero Punto Muerto Eje / Back Idle Shaft
Engranaje Conico [Tipo Antiguo] / Bevel Gear [Old Type]
Engranaje Conico [Tipo Nuevo] / Bevel Gear [New Type]
Diferencial Trasero / Differential Rear
Eje Propulsor De Tdf [Tipo Arco] / Pto Propeller Shaft [Rops Type]
Tdf Embrague / Pto Clutch
Pto Embrague[Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Eje / Pto Shaft
Adelante Helice Eje(Trasero) / Front Propeller Shaft (Rear)
Inversor Engranaje Cambio Bifurcacion / Shuttle Gear Shift Fork
Horquilla De Cambio De Gama [Tipo Arco] / Range Gear Shift Fork [Rops Type]
Pto Cambio Bifurcacion / Pto Shift Fork
Trasero Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Palanca De Cambio Principal [Tipo Arco] / Main Gear Shift Lever [Rops Type]
Palanca De Cambio De Inversor [Tipo Arco] / Shuttle Shift Lever [Rops Type]
Palanca De Cambio De Gama [Tipo Arco] / Range Gear Shift Lever [Rops Type]
Palanca De Embrague De Tdf [Tipo Arco] / Pto Clutch Lever [Rops Type]
Palanca De Accionamiento De Rueda Delantera [Tipo Arco] / Front Wheel Drive Lever [Rops Type]
Eje Trasero / Rear Axle
Freno / Brake
Varilla De Freno [Tipo Arco] / Brake Rod [Rops Type]
Pedal De Freno [Tipo Arco] / Brake Pedal [Rops Type]
Pedal De Bloqueo De Diferencial Trasero [Tipo Arco] / Rear Differential Lock Pedal [Rops Type]
Bastidor De Eje Delantero [Tipo Arco] / Front Axle Frame [Rops Type]
Adelante Helice Eje / Front Propeller Shaft
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Mango De Direccion [Tipo Arco] / Steering Handle [Rops Type]
Distribuidor De Direccion [Tipo Arco] / Steering Controller [Rops Type]
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Tubo Hidraulico(Aspiracion)[Tipo Arco] / Hydraulic Pipe (Suction) [Rops Type]
Tubo Hidraulico (Impulsion) [Tipo Arco] / Hydraulic Pipe (Delivery) [Rops Type]
Linea De Aceite Hidraulico (Radiador De Aceite) [Tipo Arco] / Hydraulic Oil Line (Oil Cooler) [Rops Type]
Linea De Aceite Hidraulico (Direccion/Tdf) [Tipo Arco] / Hydraulic Oil Line (Steering/Pto) [Rops Type]
Latiguillo De Direccion(Impulsion) [Tipo Arco] / Steering Hose (Delivery) [Rops Type]
Cilindro Hidraulico [Tipo Arco] / Hydraulic Cylinder [Rops Type]
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico[Tipo Arco] / Hydraulic Cylinder Cover [Rops Type]
Palanca De Control De Esfuerzo Y Posicion [Tipo Arco] / Draft And Position Control Lever [Rops Type]
Posicion Control Eje / Position Control Shaft
Esfuerzo Control Eje / Draft Control Shaft
Distribuidor De Servicios Externos [Tipo Arco] / Auxiliary Control Valve [Rops Type]
Distribuidor De Servicios Externos [Componentes] [Tipo Arco] / Auxiliary Control Valve [Component Parts] [Rops Type]
Soporte De Tercer Punto [Tipo Arco] / Top Link Bracket [Rops Type]
Tercer Punto [Tipo Arco] / Top Link [Rops Type]
Barra De Tiro [Tipo Arco] [Tipo Antiguo] / Lower Link [Rops Type] [Old Type]
Barra De Tiro [Tipo Arco] [Tipo Nuevo] / Lower Link [Rops Type] [New Type]
Ascenso Varilla Derecho / Lift Rod Rh
Barra De Remolque Oscilante [Tipo Arco] / Swinging Drawbar [Rops Type]
Pto Eje Protector / Pto Shaft Protector
Capo Anterior[Tipo Arco] / Hood(Bonnet) Front [Rops Type]
Capo Superior [Tipo Arco] / Hood(Bonnet) Upper [Rops Type]
Capo Lateral [Tipo Arco] / Hood(Bonnet) Side [Rops Type]
Tapa Lateral De Capo [Tipo Arco] / Hood(Bonnet) Side Cover [Rops Type]
Capo Posterior [Tipo Arco] / Hood(Bonnet) Rear [Rops Type]
Espejo Retrovisor [Tipo Arco] / Rearview Mirror [Rops Type]
Guardabarros [Tipo Arco] / Fender [Rops Type]
Asiento De Piso[Tipo Arco] / Floor Seat [Rops Type]
Peldano [Tipo Arco] / Step [Rops Type]
Arco De Seguridad [Tipo Arco] [Tipo Antiguo] / Rops [Rops Type] [Old Type]
Arco De Seguridad [Tipo Arco] [Tipo Nuevo] / Rops [Rops Type] [New Type]
Asiento [Tipo Arco] / Seat [Rops Type]
Caja De Herramientas [Tipo Arco] / Tool Box [Rops Type]
Rueda Delantera (9.5-22) [Opcion] / Front Wheel (9.5-22) [Option]
Rueda Delantera (8,3-24) [Opcion] / Front Wheel (8.3-24) [Option]
Rueda Trasera (16,9-28) [Opcion] / Rear Wheel (16.9-28) [Option]
Rueda Trasera (14,9-28) [Opcion] / Rear Wheel (14.9-28) [Option]
Etiqueta [Tipo Arco] / Label [Rops Type]
Kit De Faro De Labor [Tipo Arco] [Opcion] / Working Light Kit [Rops Type] [Option]
Kit De Enchufe De Remolque [Tipo Arco] [Opcion] / Trailer Socket Kit [Rops Type] [Option]
Kit De Palanca De Freno De Estacionamiento [Tipo Arco] [Opcion] [Tipo Antiguo] / Paking Brake Lever Kit [Rops Type] [Option] [Old Type]
Kit De Palanca De Freno De Estacionamiento [Tipo Arco] [Opcion] [Tipo Nuevo] / Paking Brake Lever Kit [Rops Type] [Option] [New Type]
Kit De Distribuidor De Servicios Externos(Scd)[Tipo Arco][Opcion] / Auxiliary Control Valve Kit (Scd) [Rops Type] [Option]
Kit De Distribuidor De Servicios Externos (Fd) [Tipo Arco] [Opcion] / Auxiliary Control Valve Kit(Fd)[Rops Type] [Option]
Distribuidor De Servicios Externos (Scd) [Componentes][Tipo Arco][Opcion] / Auxiliary Control Valve(Scd)[Component Parts][Rops Type][Option]
Distribuidor De Servicios Externos (Fd) [Componentes][Tipo Arco][Opcion] / Auxiliary Control Valve(Fd)[Component Parts][Rops Type][Option]
Apoyo Del Paso [Opcion] / Step Support Kit [Option]
Volante / Flywheel
Speed Control Plate
Embrague / Clutch
Pto Eje / Pto Shaft
Freno / Brake
