Kubota Tractor M5700DT-CAB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5700DT-CAB Tractor
Number of Pages: 511 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata [Tipo Cabina] / Cylinder Head [Cab Type]
Culata Cubierta / Head Cover
Volante / Flywheel
Motor Parar Palanca / Engine Stop Lever
Speed Control Plate
Portainyector Y Bujia De Calentamiento [Tipo Cabina] / Nozzle Holder And Glow Plug [Cab Type]
Brida De Agua Y Termostato [Tipo Cabina] / Water Flange And Thermostat [Cab Type]
Agua Bomba / Water Pump
Colector De Escape [Tipo Cabina] / Exhaust Manifold [Cab Type]
Filtro De Aire [Tipo Cabina] / Air Cleaner [Cab Type]
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Silenciador [Tipo Cabina] / Muffler [Cab Type]
Superior Junta Kit[Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit[Opcion] / Lower Gasket Kit [Option]
Palanca De Acelerador De Mano [Tipo Cabina] / Hand Accelerator Lever [Cab Type]
Pedal De Acelerador [Tipo Cabina] / Accelerator Pedal [Cab Type]
Varilla De Acelerador [Tipo Cabina] / Accelerator Rod [Cab Type]
Solenoide De Parada/Cable De Parada De Motor [Tipo Cabina] / Stop Solenoid/Engine Stop Wire [Cab Type]
Deposito De Combustible Dcha [Tipo Cabina] / Fuel Tank Rh [Cab Type]
Deposito De Combustible Izqd [Tipo Cabina] / Fuel Tank Lh [Cab Type]
Tubo De Combustible 1 (Posterior) [Tipo Cabina] / Fuel Pipe 1 (Rear) [Cab Type]
Tubo De Combustible 2 (Anterior) [Tipo Cabina] [Tipo Antiguo] / Fuel Pipe 2 (Front) [Cab Type] [Old Type]
Tubo De Combustible 2 (Anterior) [Tipo Cabina] [Tipo Nuevo] / Fuel Pipe 2 (Front) [Cab Type] [New Type]
Decantador [Tipo Cabina] / Separator [Cab Type]
Decantador [Componentes] [Tipo Cabina] / Separator [Component Parts] [Cab Type]
Filtro De Combustible [Componentes] [Tipo Cabina] / Fuel Filter [Component Parts] [Cab Type]
Ventilador [Tipo Cabina] / Fan [Cab Type]
Tubo De Agua [Tipo Cabina] / Water Pipe [Cab Type]
Radiador [Tipo Cabina] / Radiator [Cab Type]
Deposito De Reserva[Tipo Cabina] / Reserve Tank [Cab Type]
Alternador [Tipo Cabina] / Alternator [Cab Type]
Alternador [Componentes] [Tipo Cabina] / Alternator [Component Parts] [Cab Type]
Motor De Arranque / Starter
Bateria [Tipo Cabina] / Battery [Cab Type]
Conmutador/Sensor [Tipo Cabina] / Switch/Sensor [Cab Type]
Conmutador (Tablero De Instrumentos) [Tipo Cabina] / Switch (Panel Board) [Cab Type]
Conmutador [Tipo Cabina] / Switch [Cab Type]
Rele [Tipo Cabina] / Relay [Cab Type]
Rele De Arranque [Tipo Cabina] / Starter Relay [Cab Type]
Tablero De Instrumentos [Tipo Cabina] / Panel Board [Cab Type]
Tablero De Instrumentos [Componentes] [Tipo Cabina] / Panel Board [Component Parts] [Cab Type]
Culata Luz / Head Light
Luz De Emergencia [Tipo Cabina] / Hazard Light [Cab Type]
Faro De Labor [Tipo Cabina] / Work Light [Cab Type]
Luces Combinadas Traseras [Tipo Cabina] / Rear Combination Light [Cab Type]
Luz De Habitaculo [Tipo Cabina] / Room Light [Cab Type]
Deposito De Lavaparabrisas [Tipo Cabina] / Washer Tank [Cab Type]
Limpiaparabrisas [Tipo Cabina] / Wiper [Cab Type]
Cableado Electrico 1 [Tipo Cabina] / Electrical Wiring 1 [Cab Type]
Cableado Electrico(Cabina) [Tipo Cabina] / Electrical Wiring (Cab) [Cab Type]
Carcasa De Embrague [Tipo Cabina] / Clutch Housing [Cab Type]
Inversor Engranaje Caja / Shuttle Gear Case
Caja Intermedia [Tipo Cabina] / Mid Case [Cab Type]
Caja De Transmision [Tipo Cabina] / Transmission Case [Cab Type]
Transmision Caja Trasero Cubierta / Transmission Case Rear Cover
Trasero Eje Caja / Rear Axle Case
Adelante Accionar Caja / Front Drive Case
Embrague / Clutch
Horquilla De Desacoplamiento [Tipo Cabina] / Clutch Release Fork [Cab Type]
Pedal De Embrague [Tipo Cabina] / Clutch Pedal [Cab Type]
Entrada Eje / Input Shaft
Primero Eje / First Shaft
Segundo Eje / Second Shaft
Tercer Eje [Tipo Cabina] / Third Shaft [Cab Type]
Trasero Punto Muerto Eje / Back Idle Shaft
Engranaje Conico [Tipo Antiguo] / Bevel Gear [Old Type]
Engranaje Conico [Tipo Nuevo] / Bevel Gear [New Type]
Diferencial Trasero / Differential Rear
Eje Propulsor De Tdf [Tipo Cabina] / Pto Propeller Shaft [Cab Type]
Tdf Embrague / Pto Clutch
Pto Embrague[Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Eje / Pto Shaft
Adelante Helice Eje(Trasero) / Front Propeller Shaft (Rear)
Inversor Engranaje Cambio Bifurcacion / Shuttle Gear Shift Fork
Horquilla De Cambio De Gama [Tipo Cabina] / Range Gear Shift Fork [Cab Type]
Pto Cambio Bifurcacion / Pto Shift Fork
Trasero Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Palanca De Cambio Principal [Tipo Cabina] / Main Gear Shift Lever [Cab Type]
Varilla De Cambio Principal [Tipo Cabina] / Main Gear Shift Rod [Cab Type]
Eje De Palanca De Cambio Principal [Tipo Cabina] / Main Gear Shift Lever Shaft [Cab Type]
Palanca De Cambio De Inversor [Tipo Cabina] / Shuttle Shift Lever [Cab Type]
Varilla De Cambio De Inversor [Tipo Cabina] / Shuttle Shift Rod [Cab Type]
Palanca De Cambio De Gama [Tipo Cabina] / Range Gear Shift Lever [Cab Type]
Palanca De Embrague De Tdf [Tipo Cabina] / Pto Clutch Lever [Cab Type]
Palanca De Accionamiento De Rueda Delantera [Tipo Cabina] / Front Wheel Drive Lever [Cab Type]
Eje Trasero / Rear Axle
Freno / Brake
Varilla De Freno 1 [Tipo Cabina] / Brake Rod 1 [Cab Type]
Varilla De Freno 2 [Tipo Cabina] / Brake Rod 2 [Cab Type]
Palanca De Freno De Estacionamiento [Tipo Cabina] / Parking Brake Lever [Cab Type]
Varilla De Freno De Estacionamiento [Tipo Cabina] [Tipo Antiguo] / Parking Brake Rod [Cab Type] [Old Type]
Varilla De Freno De Estacionamiento [Tipo Cabina] [Tipo Nuevo] / Parking Brake Rod [Cab Type] [New Type]
Pedal De Freno [Tipo Cabina] / Brake Pedal [Cab Type]
Pedal De Bloqueo De Diferencial Trasero [Tipo Cabina] / Rear Differential Lock Pedal [Cab Type]
Bastidor De Eje Delantero [Tipo Cabina] / Front Axle Frame [Cab Type]
Adelante Helice Eje / Front Propeller Shaft
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Mango De Direccion [Tipo Cabina] / Steering Handle [Cab Type]
Junta De Direccion [Tipo Cabina] / Steering Joint [Cab Type]
Distribuidor De Direccion [Tipo Cabina] / Steering Controller [Cab Type]
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Tubo Hidraulico(Aspiracion)[Tipo Cabina] / Hydraulic Pipe (Suction) [Cab Type]
Tubo Hidraulico (Impulsion) [Tipo Cabina] / Hydraulic Pipe (Delivery) [Cab Type]
Linea De Aceite Hidraulico (Radiador De Aceite) [Tipo Cabina] / Hydraulic Oil Line (Oil Cooler) [Cab Type]
Linea De Aceite Hidraulico (Direccion/Tdf) [Tipo Cabina] / Hydraulic Oil Line (Steering/Pto) [Cab Type]
Latiguillo De Direccion(Impulsion) [Tipo Cabina] / Steering Hose (Delivery) [Cab Type]
Cilindro Hidraulico [Tipo Cabina] / Hydraulic Cylinder [Cab Type]
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico [Tipo Cabina] / Hydraulic Cylinder Cover [Cab Type]
Palanca De Control De Esfuerzo Y Posicion [Tipo Cabina] / Draft And Position Control Lever [Cab Type]
Esfuerzo Y Posicion Control Palanca Soporte / Draft And Position Control Lever Bracket
Posicion Control Eje / Position Control Shaft
Esfuerzo Control Eje / Draft Control Shaft
Distribuidor De Servicios Externos [Tipo Cabina] / Auxiliary Control Valve [Cab Type]
Distribuidor De Servicios Externos [Componentes][Tipo Cabina] / Auxiliary Control Valve[Component Parts][Cab Type]
Palanca De Distribuidor De Servicios Externos [Tipo Cabina] / Auxiliary Contorol Valve Lever [Cab Type]
Soporte De Tercer Punto [Tipo Cabina] / Top Link Bracket [Cab Type]
Tercer Punto [Tipo Cabina] / Top Link [Cab Type]
Barra De Tiro [Tipo Cabina] [Tipo Antiguo] / Lower Link [Cab Type] [Old Type]
Barra De Tiro [Tipo Cabina] [Tipo Nuevo] / Lower Link [Cab Type] [New Type]
Ascenso Varilla Derecho / Lift Rod Rh
Barra De Remolque Oscilante [Tipo Cabina] / Swinging Drawbar [Cab Type]
Pto Eje Protector / Pto Shaft Protector
Capo Anterior [Tipo Cabina] / Hood(Bonnet) Front [Cab Type]
Capo Superior [Tipo Cabina] / Hood(Bonnet) Upper [Cab Type]
Capo Lateral [Tipo Cabina] / Hood(Bonnet) Side [Cab Type]
Tapa Lateral De Capo [Tipo Cabina] / Hood(Bonnet) Side Cover [Cab Type]
Soporte De Capo [Tipo Cabina] / Bonnet Support [Cab Type]
Bastidor De Cabina [Tipo Cabina] / Cab Frame [Cab Type]
Panel Frame [Tipo Cabina] / Panel Frame [Cab Type]
Luna Delantera [Tipo Cabina] / Front Glass [Cab Type]
Puerta Dcha [Tipo Cabina] / Door Rh [Cab Type]
Puerta Izqd [Tipo Cabina] / Door Lh [Cab Type]
Cerradura De Puerta Dcha [Tipo Cabina] / Door Lock Rh [Cab Type]
Cerradura De Puerta Izqd [Tipo Cabina] / Door Lock Lh [Cab Type]
Ventanilla Lateral [Tipo Cabina] / Side Window [Cab Type]
Ventanilla Trasera [Tipo Cabina] / Rear Window [Cab Type]
Espejo Retrovisor [Tipo Cabina] / Rearview Mirror [Cab Type]
Techo Interior [Tipo Cabina] / Inner Roof [Cab Type]
Techo Exterior [Tipo Cabina] / Outer Roof [Cab Type]
Asiento [Tipo Cabina] / Seat [Cab Type]
Alfombrilla De Piso [Tipo Cabina] / Floor Mat [Cab Type]
Placa De Inspeccion [Tipo Cabina] / Inspection Plate [Cab Type]
Cubierta De Guardabarros Dcha [Tipo Cabina] / Fender Cover Rh [Cab Type]
Cubierta De Guardabarros Izqd [Tipo Cabina] / Fender Cover Lh [Cab Type]
Cubierta De Montante [Tipo Cabina] / Pillar Cover [Cab Type]
Guardabarros Dcha [Tipo Cabina] / Fender Rh [Cab Type]
Guardabarros Izqd [Tipo Cabina] / Fender Lh [Cab Type]
Soporte Anterior De Cabina [Tipo Cabina] / Cab Bracket Front [Cab Type]
Soporte Posterior De Cabina [Tipo Cabina] / Cab Bracket Rear [Cab Type]
Caja De Herramientas [Tipo Cabina] / Tool Box [Cab Type]
Aire Acondicionado [Tipo Cabina] / Air Conditioner [Cab Type]
Manguito De Calefaccion [Tipo Cabina] / Heater Hose [Cab Type]
Condensador [Tipo Cabina] [Tipo Antiguo] / Condenser [Cab Type] [Old Type]
Condensador [Tipo Cabina] [Tipo Nuevo] / Condenser [Cab Type] [New Type]
Compresor [Tipo Cabina] [Tipo Antiguo] / Compressor [Cab Type] [Old Type]
Compresor[Tipo Cabina][Tipo Nuevo] / Compressor [Cab Type] [New Type]
Rueda Delantera (9.5-22) [Opcion] / Front Wheel (9.5-22) [Option]
Rueda Delantera (8,3-24) [Opcion] / Front Wheel (8.3-24) [Option]
Rueda Trasera (16,9-28) [Opcion] / Rear Wheel (16.9-28) [Option]
Rueda Trasera (14,9-28) [Opcion] / Rear Wheel (14.9-28) [Option]
Etiqueta 1 [Tipo Cabina] / Label 1 [Cab Type]
Etiqueta 2 [Tipo Cabina] / Label 2 [Cab Type]
Kit De Tirante De Articulacion De Palanca / Lever Joint Stay Kit
Kit De Enchufe De Remolque [Tipo Cabina] [Opcion] / Trailer Socket Kit [Cab Type] [Option]
Kit De Radiocasete [Tipo Cabina] [Opcion] / Radio Cassette Kit [Cab Type] [Option]
Kit De Limpiaparabrisas Trasero [Tipo Cabina] [Tipo Antiguo] [Opcion] / Rear Wiper Kit [Cab Type] [Old Type] [Option]
Kit De Limpiaparabrisas Trasero [Tipo Cabina] [Tipo Nuevo] [Opcion] / Rear Wiper Kit [Cab Type] [New Type] [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Tipo Cabina] [Opcion] / Auxiliary Control Valve Kit(Scd)[Cab Type] [Option]
Kit De Distribuidor De Servicios Externos (Fd) [Tipo Cabina] [Opcion] / Auxiliary Control Valve Kit(Fd) [Cab Type] [Option]
Kit De Distribuidor De Servicios Externos(Scd/Fc)[Tipo Cabina][Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Cab Type] [Option]
Distribuidor De Servicios Externos (Scd) [Componentes][Tipo Cabina][Opcion] / Auxiliary Control Valve(Scd)[Component Parts][Cab Type][Option]
Distribuidor De Servicios Externos (Fd) [Componentes][Tipo Cabina][Opcion] / Auxiliary Control Valve(Fd)[Component Parts][Cab Type][Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componentes] [Tipo Cabina] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts][Cab Type][Option]
Kit De Palanca De Distribuidor De Servicios Externos(Segundo) [Tipo Cabina] [Opcion] / Auxilairy Control Valve Lever Kit (2nd)[Cab Type] [Option]
Kit De Palanca De Distribuidor De Servicios Externos(Tercero) [Tipo Cabina] [Opcion] / Auxilairy Control Valve Lever Kit (3rd) [Cab Type] [Option]
