Kubota Tractor M5700DT-CAB Parts Catalog
Model: Kubota M5700DT-CAB Tractor
Number of Pages: 540 Pages
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head [Cab Type]
Engine Gear Case
Engine Head Cover [Old Type] ## S.No.;E=3u0371
Engine Head Cover [New Type] ## S.No.;E=3w0001
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft ## NoteOrder By Ref.No.010 And 040 New Parts.
Engine Flywheel
Engine Fuel Camshaft
Engine Engine Stop Lever
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug [Cab Type]
Engine Nozzle Holder [Component Parts]
Engine Water Flange And Thermostat [Cab Type]
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold [Cab Type]
Engine Air Cleaner [Cab Type]
Engine Air Cleaner [Component Parts]
Engine Muffler [Cab Type]
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Hand Accelerator Lever [Cab Type]
Engine Accelerator Pedal [Cab Type]
Engine Accelerator Rod [Cab Type]
Engine Stop SolenoidEngine Stop Wire [Cab Type]
Fuel System Fuel Tank Rh [Cab Type]
Fuel System Fuel Tank Lh [Cab Type]
Fuel System Fuel Pipe 1 (Rear) [Cab Type]
Fuel System Fuel Pipe 2 (Front) [Cab Type]
Fuel System Separator [Cab Type]
Fuel System Separator [Component Parts] [Cab Type]
Fuel System Fuel Filter [Cab Type]
Cooling Water System Fan [Cab Type]
Cooling Water System Water Pipe [Cab Type]
Cooling Water System Radiator [Cab Type]
Cooling Water System Reserve Tank [Cab Type]
Electrical System Alternator [Cab Type]
Electrical System Alternator [Component Parts] [Cab Type]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery [Cab Type]
Electrical System SwitchSensor [Cab Type]
Electrical System Switch (Panel Board) [Cab Type]
Electrical System Switch [Cab Type]
Electrical System Relay [Cab Type]
Electrical System Starter Relay [Cab Type]
Electrical System Panel Board [Cab Type]
Electrical System Panel Board [Component Parts] [Cab Type]
Electrical System Head Light
Electrical System Hazard Light [Cab Type]
Electrical System Work Light [Cab Type]
Electrical System Rear Combination Light [Cab Type]
Electrical System Room Light [Cab Type]
Electrical System Radio Cassette [Cab Type] [Old Type] ## S.No.;=54061
Electrical System Radio Cassette [Cab Type] [New Type] ## S.No.;=54062
Electrical System Washer Tank [Cab Type]
Electrical System Wiper [Cab Type] [Old Type] ## S.No.;E=53837
Electrical System Wiper [Cab Type] [New Type] ## S.No.;E=53838
Electrical System Electrical Wiring 1 [Cab Type]
Electrical System Electrical Wiring (Cab) [Cab Type]
Clutch Transmission Clutch Housing [Cab Type]
Clutch Transmission Shuttle Gear Case
Clutch Transmission Mid Case [Cab Type]
Clutch Transmission Transmission Case [Cab Type]
Clutch Transmission Transmission Case Rear Cover
Clutch Transmission Rear Axle Case
Clutch Transmission Front Drive Case
Clutch Transmission Clutch Release Fork [Cab Type]
Clutch Transmission Clutch Pedal [Cab Type]
Clutch Transmission Input Shaft
Clutch Transmission First Shaft
Clutch Transmission Second Shaft
Clutch Transmission Third Shaft [Cab Type]
Clutch Transmission Back Idle Shaft
Clutch Transmission Creep Shaft
Clutch Transmission Bevel Gear [Old Type] ## S.No.;E=52954
Clutch Transmission Bevel Gear [New Type] ## S.No.;E=52955
Clutch Transmission Differential Rear
Clutch Transmission PTO Propeller Shaft [Cab Type]
Clutch Transmission PTO Clutch
Clutch Transmission PTO Clutch [Component Parts]
Clutch Transmission PTO Clutch Valve
Clutch Transmission PTO Clutch Valve [Component Parts]
Clutch Transmission PTO Shaft
Clutch Transmission Front Propeller Shaft (Rear)
Speed Change Shift Fork Shift Lever Main Gear Shift Fork
Speed Change Shift Fork Shift Lever Shuttle Gear Shift Fork
Speed Change Shift Fork Shift Lever Range Gear Shift ForkCreep Gear Shift Fork [Cab
Speed Change Shift Fork Shift Lever PTO Gear Shift Fork
Speed Change Shift Fork Shift Lever Rear Differential Lock Shift Fork
Speed Change Shift Fork Shift Lever Main Gear Shift Lever [Cab Type]
Speed Change Shift Fork Shift Lever Main Gear Shift Rod [Cab Type]
Speed Change Shift Fork Shift Lever Main Gear Shift Lever Shaft [Cab Type]
Speed Change Shift Fork Shift Lever Shuttle Shift Lever [Cab Type]
Speed Change Shift Fork Shift Lever Shuttle Shift Rod [Cab Type]
Speed Change Shift Fork Shift Lever Range Gear Shift LeverCreep Gear Shift Lever [C
Speed Change Shift Fork Shift Lever PTO Clutch Lever [Cab Type]
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever
Speed Change Shift Fork Shift Lever Front Wheel Drive Lever [Cab Type]
Rear Axle Brake Rear Axle
Rear Axle Brake Brake
Rear Axle Brake Brake Rod (Brake Pedal) [Cab Type]
Rear Axle Brake Brake Rod (Brake Cam) [Cab Type]
Rear Axle Brake Parking Brake Lever [Cab Type]
Rear Axle Brake Parking Brake Rod [Cab Type] [Old Type] ## S.No.;E=53881
Rear Axle Brake Parking Brake Rod [Cab Type] [New Type] ## S.No.;E=53882
Rear Axle Brake Brake Pedal [Cab Type]
Rear Axle Brake Rear Differential Lock Pedal [Cab Type]
Front Axle Chassis Front Axle Frame [Cab Type]
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Front Propeller Shaft [Cab Type]
Front Axle Chassis Front Differential Case
Front Axle Chassis Bevel Gear (Front)
Front Axle Chassis Differential Front
Front Axle Chassis Front Axle Case
Front Axle Chassis Differential Gear Shaft
Steering Steering Handle [Cab Type]
Steering Steering Joint [Cab Type]
Steering Steering Controller [Cab Type]
Steering Steering Controller [Component Parts]
Hydraulic System Tie RodSteering Cylinder
Hydraulic System Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Pipe (Suction) [Cab Type]
Hydraulic System Hydraulic Pipe (Delivery) [Cab Type]
Hydraulic System Hydraulic Oil Line (Oil Cooler) [Cab Type]
Hydraulic System Hydraulic Oil Line (SteeringPTO) [Cab Type]
Hydraulic System Steering Hose (Delivery) [Cab Type]
Hydraulic System Hydraulic Cylinder [Cab Type]
Hydraulic System Hydraulic Lift Arm
Hydraulic System Hydraulic Cylinder Cover [Cab Type]
Hydraulic System Control Valve
Hydraulic System Draft And Position Control Lever [Cab Type]
Hydraulic System Draft And Position Control Lever Bracket [Cab Type]
Hydraulic System Position Control Shaft
Hydraulic System Draft Control Shaft
Hydraulic System Feed Back Lever
Hydraulic System Auxiliary Control Valve [Cab Type]
Hydraulic System Auxiliary Control Valve [Component Parts] [Cab Type]
Hydraulic System Auxiliary Contorol Valve Lever [Cab Type]
3-Point Linkage Drawbar Hitch Top Link Bracket [Cab Type]
3-Point Linkage Drawbar Hitch Top Link [Cab Type]
3-Point Linkage Drawbar Hitch Lower Link [Cab Type] [Old Type] ## S.No.;E=53522
3-Point Linkage Drawbar Hitch Lower Link [Cab Type] [New Type] ## S.No.;E=53523
3-Point Linkage Drawbar Hitch Lift Rod Rh [Cab Type]
3-Point Linkage Drawbar Hitch Lift Rod Lh [Cab Type]
3-Point Linkage Drawbar Hitch Swinging Drawbar [Cab Type]
3-Point Linkage Drawbar Hitch PTO Shaft Protector
Hood Bonnet Hood(Bonnet) Front [Cab Type]
Hood Bonnet Hood(Bonnet) Upper [Cab Type]
Hood Bonnet Hood(Bonnet) Side [Cab Type]
Hood Bonnet Hood(Bonnet) Side Cover [Cab Type]
Hood Bonnet Bonnet Support [Cab Type]
Cab Cab Frame [Cab Type]
Cab Panel Frame [Cab Type]
Cab Front Glass [Cab Type]
Cab Door Rh [Cab Type]
Cab Door Lh [Cab Type]
Cab Door Lock Rh [Cab Type]
Cab Door Lock Lh [Cab Type]
Cab Side Window [Cab Type]
Cab Rear Window [Cab Type]
Cab Rearview Mirror [Cab Type]
Cab Inner Roof [Cab Type]
Cab Outer Roof [Cab Type]
Cab Seat [Cab Type]
Cab Floor Mat [Cab Type]
Cab Inspection Plate [Cab Type]
Cab Fender Cover Rh [Cab Type]
Cab Fender Cover Lh [Cab Type]
Cab Pillar Cover [Cab Type]
Cab Fender Rh [Cab Type]
Cab Fender Lh [Cab Type]
Cab Cab Bracket Front [Cab Type]
Cab Cab Bracket Rear [Cab Type]
Cab Tool Box [Cab Type]
Air Conditioner Air Conditioner [Cab Type] [Old Type] ## S.No.;E=52752
Air Conditioner Air Conditioner [Cab Type] [New Type] ## S.No.;E=52753
Air Conditioner Heater Hose [Cab Type]
Air Conditioner Condenser [Cab Type] [Old Type] ## S.No.;E=52752
Air Conditioner Condenser [Cab Type] [New Type] ## S.No.;E=52753
Air Conditioner Compressor [Cab Type] [Old Type] ## S.No.;E=52752
Air Conditioner Compressor [Cab Type] [New Type] ## [NoteOrder By Ref.No
Front Rear Tire Front Wheel (9.5-22)
Front Rear Tire Rear Wheel (16.9-28)
Labels Label 1 (Front) [Cab Type]
Labels Label 2 (Rear) [Cab Type]
Accessories Accessories And Service Parts
Option Trailer Socket Kit [Cab Type] [Option]
Option Lever Joint Stay Kit [Cab Type] [Option] ## S.No.; To 51034
Option Front Weight Bumper Kit [Option]
Option Front Bumper Kit [Option]
Option Auxiliary Control Valve Kit (Scd) (WG No.M9517) [Cab Type] [Option]
Option Auxiliary Control Valve Kit (Fd) [Cab Type] [Option]
Option Auxiliary Control Valve Kit (ScdFc) (WG No.M9587) [Cab Type] [Option]
Option Auxiliary Control Valve (Fd) [Component Parts] [Cab Type] [Option]
Option Auxiliary Control Valve (ScdFc) [Component Parts] [Cab Type] [Option]
Option Auxiliary Control Valve (Fc) [Component Parts] [Cab Type] [Option]
Option Auxiliary Control Valve Lever Kit (2nd) [Cab Type] [Option]
Option Auxiliary Control Valve Lever Kit (3rd) [Cab Type] [Option]
Engine Crankcase
Engine Oil Pan
Engine Gear Case
Engine Flywheel
Engine Governor
Engine Water Pump
Cab Seat [Cab Type]
