Kubota Tractor M5400DT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5400DT Tractor
Number of Pages: 469 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Volante / Flywheel
Tobera Soporte/Bujia De Calentamiento Tapon / Nozzle Holder/Glow Plug
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Tapa De Balancines / Cylinder Head Cover
Filtro De Aire (Doble) / Air Cleaner (Double)
Filtro De Aire (Doble) [Componentes] / Air Cleaner (Double) [Component Parts]
Silenciador Inferior [Tipo Antiguo] [Gr][Po] / Under Muffler [Old Type] [Gr][Po]
Silenciador Inferior [Tipo Nuevo] [Gr][Po] / Under Muffler [New Type] [Gr][Po]
Silenciador [Excepto[Gr][Po]] / Muffler [Except[Gr][Po]]
Tubo Del Silenciador Inferior [Excepto[Gr][Po]] [Opcion] / Under Muffler Pipe [Except[Gr][Po]] [Option]
Arbol De Levas / Camshaft
Agua Bomba / Water Pump
Motor Parar Palanca / Engine Stop Lever
Speed Control Plate
Mano Acelerador Palanca / Hand Accelerator Lever
Motor Parar Cable / Engine Stop Wire
Filtro De Combustible/Tubo De Combustible / Fuel Filter/Fuel Pipe
Filtro De Combustible [Componentes] / Fuel Filter [Component Parts]
Agua Tubo / Water Pipe
Ventilador / Fan
Alternador / Alternator
Alternador [Componentes] [Tipo Antiguo] / Alternator [Component Parts] [Old Type]
Alternador [Componentes] [Tipo Nuevo] / Alternator [Component Parts] [New Type]
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Tablero De Instrumentos [Gr][Po] / Panel Board [Gr][Po]
Tablero De Instrumentos [Excepto[Gr][Po]] / Panel Board [Except[Gr][Po]]
Tablero De Instrumentos [Componentes] [Gr][Po] / Panel Board [Component Parts] [Gr][Po]
Tablero De Instrumentos [Componentes] [Excepto[Gr][Po]] / Panel Board [Component Parts] [Except[Gr][Po]]
Conmutador [Gr][Po] / Switch [Gr][Po]
Conmutador [Excepto[Gr][Po]] / Switch [Except[Gr][Po]]
Luz [Gr][Po] / Light [Gr][Po]
Luz [Excepto[Gr][Po]] / Light [Except[Gr][Po]]
Faro De Labor [Tipo Antiguo] [Opcion] / Working Light [Old Type] [Option]
Faro De Labor [Tipo Nuevo] [Opcion] / Working Light [New Type] [Option]
Remolque Vaso Kit[Opcion] / Trailer Socket Kit [Option]
Cableado Electrico [Gr][Po] / Electrical Wiring [Gr][Po]
Cableado Electrico [Excepto[Gr][Po]] / Electrical Wiring [Except[Gr][Po]]
Embrague / Clutch
Rodamiento Soporte / Bearing Holder
Eje De Entrada/Primer Eje [Con Marcha Muy Lenta] [Gr][Po] / Input Shaft/First Shaft [With Creep] [Gr][Po]
Eje De Entrada/Primer Eje[Sin Marcha Muy Lenta][Excepto[Gr][Po]] / Input Shaft/First Shaft[W/O Creep][Except[Gr][Po]]
Segundo Eje / Second Shaft
Tercer Eje [Con Marcha Muy Lenta] [Gr][Po] / Third Shaft [With Creep] [Gr][Po]
Tercer Eje [Sin Marcha Muy Lenta] [Excepto[Gr][Po]] / Third Shaft [W/O Creep] [Except[Gr][Po]]
Marcha Muy Lenta [Con Marcha Muy Lenta] [Gr][Po] / Creep [With Creep] [Gr][Po]
Kit De Engranaje De Marcha Muy Lenta [Excepto[Gr][Po]] [Opcion] / Creep Gear Kit [Except[Gr][Po]] [Option]
Pto Helice Eje / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje De Tdf/Protector De Eje De Tdf / Pto Shaft/Pto Shaft Protector
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Palanca De Control De Embrague De Tdf [Tipo Antiguo] / Pto Clutch Control Lever [Old Type]
Palanca De Control De Embrague De Tdf [Tipo Nuevo] / Pto Clutch Control Lever [New Type]
Engranaje Conico (Posterior) / Bevel Gear (Rear)
Diferencial (Posterior) / Differential (Rear)
Trasero Eje Caja / Rear Axle Case
Eje Trasero / Rear Axle
Kit De Ancho De Via De 72 Pulg. [Opcion] / 72inch Tread Kit [Option]
Rueda Trasera (16,9-28) / Rear Wheel (16.9-28)
Disco De Rueda Trasera (14,9-24) [Gr][Po] [Opcion] / Rear Wheel Disk (14.9-24) [Gr][Po] [Option]
Disco De Rueda Trasera (14,9-28) [Gr][Po] [Opcion] / Rear Wheel Disk (14.9-28) [Gr][Po] [Option]
Disco De Rueda Trasera (16.9-28) [Gr][Po] [Opcion] / Rear Wheel Disk (16.9-28) [Gr][Po] [Option]
Freno [Gr][Po] / Brake [Gr][Po]
Freno [Excepto[Gr][Po]] / Brake [Except[Gr][Po]]
Freno Pedal / Brake Pedal
Freno Varilla / Brake Rod
Freno De Estacionamiento [Gr][Po] [Opcion] / Parking Brake [Gr][Po] [Option]
Lastre Delantero [Excepto[Gr][Po]] [[Gr][Po]Opcion] / Front Weight [Except[Gr][Po]] [[Gr][Po]Option]
Adelante Rueda Accionar Eje / Front Wheel Drive Shaft
Eje Propulsor [Tipo Antiguo] / Propeller Shaft [Old Type]
Eje Propulsor [Tipo Nuevo] / Propeller Shaft [New Type]
Diferencial(Adelante) / Differential (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Rueda Delantera (8.3-24) [Excepto[Gr][Po]] / Front Wheel (8.3-24) [Except[Gr][Po]]
Rueda Delantera (9.5-22) [Gr][Po] / Front Wheel (9.5-22) [Gr][Po]
Rueda Delantera (11.2-20) [Gr][Po] [Opcion] / Front Wheel (11.2-20) [Gr][Po] [Option]
Disco De Rueda Delantera (7,5-18) [Gr][Po] [Opcion] / Front Wheel Disk (7.5-18) [Gr][Po] [Option]
Disco De Rueda Delantera (8.3-24) [Gr][Po] [Opcion] / Front Wheel Disk (8.3-24) [Gr][Po] [Option]
Varillaje De Direccion [Tipo Antiguo] / Steering Linkage [Old Type]
Varillaje De Direccion [Tipo Nuevo] / Steering Linkage [New Type]
Cilindro De Direccion [Componentes] [Tipo Antiguo] / Steering Cylinder [Component Parts] [Old Type]
Cilindro De Direccion [Componentes] [Tipo Nuevo] / Steering Cylinder [Component Parts] [New Type]
Mango De Direccion/Distribuidor De Direccion [Tipo Antiguo] / Steering Handle/Steering Controller [Old Type]
Mango De Direccion/Distribuidor De Direccion [Tipo Nuevo] / Steering Handle/Steering Controller [New Type]
Distribuidor De Direccion [Componentes] [Tipo Antiguo] / Steering Controller [Component Parts] [Old Type]
Distribuidor De Direccion [Componentes] [Tipo Nuevo] / Steering Controller [Component Parts] [New Type]
Hidraulico Aceite Linea(Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Bomba Hidraulica [Tipo Antiguo] / Hydraulic Pump [Old Type]
Bomba Hidraulica [Tipo Nuevo] / Hydraulic Pump [New Type]
Bomba Hidraulica [Componentes] [Tipo Antiguo] / Hydraulic Pump [Component Parts] [Old Type]
Bomba Hidraulica [Componentes] [Tipo Nuevo] / Hydraulic Pump [Component Parts] [New Type]
Linea De Aceite Hidraulico[Tipo Antiguo] / Hydraulic Oil Line [Old Type]
Linea De Aceite Hidraulico[Tipo Nuevo] / Hydraulic Oil Line [New Type]
Cilindro Hidraulico [Gr][Po] / Hydraulic Cylinder [Gr][Po]
Cilindro Hidraulico [Excepto[Gr][Po]] / Hydraulic Cylinder [Except[Gr][Po]]
Cubierta De Cilindro Hidraulico [Tipo Antiguo] / Hydraulic Cylinder Cover [Old Type]
Cubierta De Cilindro Hidraulico [Tipo Nuevo] / Hydraulic Cylinder Cover [New Type]
Valvula De Seguridad/Valvula De Sobrepresion [Componentes] / Safety Valve/Relief Valve [Component Parts]
Palanca De Elevacion Hidraulica [Gr][Po] / Hydraulic Lift Lever [Gr][Po]
Palanca De Elevacion Hidraulica [Excepto[Gr][Po]] / Hydraulic Lift Lever [Except[Gr][Po]]
Palanca De Reaccion 1 / Feed Back Lever 1
Palanca De Reaccion 2 / Feed Back Lever 2
Palanca De Reaccion 3 / Feed Back Lever 3
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Auxiliar Control Valvula / Auxiliary Control Valve
Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve (Scd) [Option]
Distribuidor De Servicios Externos(Flotante)[Opcion] / Auxiliary Control Valve (Flowting) [Option]
Auxiliar Control Valvula[Componente Piezas] / Auxiliary Control Valve [Component Parts]
Distribuidor De Servicios Externos (Scd) [Componentes] / Auxiliary Control Valve (Scd) [Component Parts]
Distribuidor De Servicios Externos (Flotante) [Componentes] / Auxiliary Control Valve(Flowting)[Component Parts]
Articulacion De Elevacion Hidraulica 1 (Tercer Punto/Barra De Tiro) / Hydraulic Lift Link 1 (Top Link/Lower Link)
Articulacion De Elevacion Hidraulica 2 (Varilla De Elevacion) [Tipo Antiguo] / Hydraulic Lift Link 2 (Lift Rod) [Old Type]
Oscilacion Barra De Remolque / Swinging Drawbar
Capo Anterior[Gr][Po] / Bonnet(Hood) Front [Gr][Po]
Capo Anterior [Excepto[Gr][Po]] / Bonnet(Hood) Front [Except[Gr][Po]]
Capo Superior / Bonnet(Hood) Upper
Capo Lateral / Bonnet(Hood) Side
Tapa Lateral De Capo [Tipo Nuevo] / Bonnet(Hood) Side Cover [New Type]
Capo Posterior / Bonnet(Hood) Rear
Guardabarros [Gr][Po] / Fender [Gr][Po]
Guardabarros [Excepto[Gr][Po]] / Fender [Except[Gr][Po]]
Asiento De Piso [Gr][Po] / Floor Seat [Gr][Po]
Asiento De Piso [Excepto[Gr][Po]] / Floor Seat [Except[Gr][Po]]
Hoja / Seat
Peldano / Step
Espejo Retrovisor [Gr][Po] / Rearview Mirror [Gr][Po]
Espejo Retrovisor [Excepto[Gr][Po]] / Rearview Mirror [Except[Gr][Po]]
Caja De Herramientas [Tipo Antiguo] / Tool Box [Old Type]
Caja De Herramientas [Tipo Nuevo] / Tool Box [New Type]
Arco De Seguridad [Tipo Antiguo] / Rops [Old Type]
Arco De Seguridad [Tipo Nuevo] / Rops [New Type]
Lona [Excepto[Gr][Po]] [[Gr][Po]Option] / Canopy [Except[Gr][Po]] [[Gr][Po]Option]
Etiquetas [Gr][Po] / Labels [Gr][Po]
Etiquetas [Excepto[Gr][Po]] / Labels [Except[Gr][Po]]
Accesorios Y Servicio Piezas / Step Support Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Embrague / Clutch
Hoja / Seat
Peldano / Step
