Kubota Tractor M5400DT Parts Catalog
Model: Kubota M5400DT Tractor
Number of Pages: 401 Pages
Engine Crankcase
Engine Oil Pan
Engine Piston And Crankshaft ## NoteOrder By Ref.No.010 And 040 New Part.
Engine Main Bearing Case
Engine Flywheel
Engine Cylinder Head
Engine Valve And Rocker Arm
Engine Nozzle HolderGlow Plug
Engine Nozzle Holder [Component Parts]
Engine Cylinder Head Cover
Engine Inlet Manifold
Engine Air Cleaner (Double)
Engine Air Cleaner (Double) [Component Parts]
Engine Exhaust Manifold
Engine Muffler
Engine Under Muffler Pipe [Option]
Engine Camshaft
Engine Gear Case
Engine Water Pump
Engine Water Flange And Thermostat
Engine Fuel Camshaft
Engine Injection Pump
Engine Engine Stop Lever
Engine Speed Control Plate
Engine Governor
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Hand Accelerator Lever
Engine Engine Stop Wire
Fuel System Fuel Tank
Fuel System Fuel FilterFuel Pipe
Fuel System Fuel Filter [Component Parts]
Cooling Water System Radiator
Cooling Water System Water Pipe
Cooling Water System Fan
Electrical System Alternator
Electrical System Alternator [Component Parts] [Old Type] ## S.No.;=62228
Electrical System Alternator [Component Parts] [New Type] ## S.No.;=80001
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Panel Board [Au]
Electrical System Panel Board [Except[Au]]
Electrical System Panel Board [Component Parts] [Au]
Electrical System Panel Board [Component Parts] [Except[Au]]
Electrical System Switch [Au]
Electrical System Switch [Except[Au]]
Electrical System Light
Electrical System Working Light [Old Type] [Sr] [Except[Sr]Option] ## S.No.;=61626
Electrical System Working Light [New Type] [Sr] [Except[Sr]Option] ## S.No.;=61627
Electrical System Trailer Socket Kit [Option]
Electrical System Electrical Wiring [Old Type] [Au] ## S.No.=80566 S.No.;=80566
Electrical System Electrical Wiring [New Type] [Au] ## S.No.;=80567
Electrical System Electrical Wiring [Except[Au]]
Clutch Clutch
Clutch Clutch Pedal
Clutch Clutch Housing
Transmission Transmission Case
Transmission Bearing Holder
Transmission Input ShaftFirst Shaft [With Creep] [Au]
Transmission Input ShaftFirst Shaft [WO Creep] [Except[Au]]
Transmission Second Shaft
Transmission Third Shaft [With Creep] [Au]
Transmission Third Shaft [WO Creep] [Except[Au]]
Transmission Creep [With Creep] [Au]
Transmission Creep Gear Kit [Except[Au]] [Option]
Transmission PTO Propeller Shaft
Transmission PTO Clutch
Transmission PTO Clutch Valve
Transmission PTO Clutch Valve [Component Parts]
Transmission PTO ShaftPTO Shaft Protector
Main Sp-Change Lever Main Gear Shift Lever
Main Sp-Change Lever Range Gear Shift Fork
Main Sp-Change Lever Range Gear Shift Lever
Main Sp-Change Lever PTO Gear Shift Lever
Main Sp-Change Lever PTO Clutch Control Lever [Old Type] ## S.No.;=62228
Main Sp-Change Lever PTO Clutch Control Lever [New Type] ## S.No.;=80001
Main Sp-Change Lever Bevel Gear (Rear)
Main Sp-Change Lever Differential (Rear)
Main Sp-Change Lever Differential Lock Pedal
Rear Axle Rear Wheel Rear Axle Case
Rear Axle Rear Wheel 72inch Tread Kit [Option]
Rear Axle Rear Wheel Rear Wheel (14.9-28) [Except[Sr]]
Rear Axle Rear Wheel Rear Wheel (16.9-28)
Brake Brake [Au]
Brake Brake [Except[Au]]
Brake Brake Pedal [Au]
Brake Brake Pedal [Except[Au]]
Brake Brake Rod
Brake Parking Brake [Au]
Front Axle Chassis Front Weight [Except[Au]] [[Au]Option]
Front Axle Chassis Front Axle Frame
Front Axle Chassis Front Wheel Drive Shaft
Front Axle Chassis Propeller Shaft [Old Type] ## S.No.=81174 S.No.;=81174
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Differential (Front)
Front Axle Chassis Differential Gear Shaft
Front Axle Chassis Bevel Gear Case [Old Type] ## S.No.;=62228
Front Axle Chassis Bevel Gear Case [New Type] ## S.No.;=80001
Front Axle Chassis Front Axle [Old Type] ## S.No.;=62228
Front Axle Chassis Front Axle [New Type] ## S.No.;=80001
Front Axle Chassis Front Wheel Drive Lever
Front Axle Chassis Front Wheel (8.3-24)
Front Axle Chassis Front Wheel (9.5-22) [Au]
Steering Steering Linkage [Old Type] ## S.No.;=62228
Steering Steering Linkage [New Type] ## S.No.;=80001
Steering Steering Cylinder [Component Parts] [Old Type] ## S.No.;=62228
Steering Steering Cylinder [Component Parts] [New Type] ## S.No.;=80001
Steering Steering HandleSteering Controller [Old Type][Au] ## S.No.;=62228
Steering Steering HandleSteering Controller [New Type][Au] ## S.No.;=80001
Steering Steering HandleSteering Controller [Old Type] ## [Except[Au]]
Steering Steering HandleSteering Controller [New Type] ## [Except[Au]]
Steering Steering Controller [Component Parts] [Old Type] ## S.No.=62228 S.No.;=62228
Steering Steering Controller [Component Parts] [New Type] ## S.No.=80001 S.No.;=80001
Hydraulic System Hydraulic Oil Line (SteeringPTO)
Hydraulic System Hydraulic Pump [Old Type] ## S.No.=62228 S.No.;=62228
Hydraulic System Hydraulic Pump [New Type] ## S.No.;=80001
Hydraulic System Hydraulic Pump [Component Parts] [Old Type] ## S.No.=62228 S.No
Hydraulic System Hydraulic Pump [Component Parts] [New Type] ## S.No.;=80001
Hydraulic System Hydraulic Oil Line [Old Type] ## S.No.=62228 S.No.;=62228
Hydraulic System Hydraulic Oil Line [New Type] ## S.No.;=80001
Hydraulic System Hydraulic Cylinder
Hydraulic System Hydraulic Cylinder Cover [Old Type] ## S.No.;=80201
Hydraulic System Hydraulic Cylinder Cover [New Type] ## S.No.;=80202
Hydraulic System Safety ValveRelief Valve [Component Parts] ## S.No.=80201 [Old Type]
Hydraulic System Safety ValveRelief Valve [Component Parts] ## S.No.=80202 [New Type]
Hydraulic System Hydraulic Lift Lever
Hydraulic System Control Valve
Hydraulic System Feed Back Lever 1
Hydraulic System Feed Back Lever 2
Hydraulic System Feed Back Lever 3
Hydraulic System Draft And Position Control Lever
Hydraulic System Auxiliary Control Valve
Hydraulic System Auxiliary Control Valve (Scd) [Option]
Hydraulic System Auxiliary Control Valve (Flowting) [Option]
Hydraulic System Auxiliary Control Valve [Component Parts]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts] ## [Old Type] [Option]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts] ## [New Type] [Option]
Hydraulic System Auxiliary Control Valve(Flowting)[Component Parts] ## [Option]
Hydraulic System Hydraulic Lift Link 1 (Top LinkLower Link) ## [Old Type][Except[Sr]]
Hydraulic System Hydraulic Lift Link 1 (Top LinkLower Link) ## [New Type][Except[Sr]]
Hydraulic System Hydraulic Lift Link 2 (Lift Rod) [Old Type] ## [Except[Sr]]
Hydraulic System Hydraulic Lift Link 2 (Lift Rod) [New Type] ## [Except[Sr]]
Hydraulic System Top Link Bracket [Except[Sr]]
3-Point Linkage Drawbar Hitch Swinging Drawbar [Except[Sr]]
Hood Bonnet Hood(Bonnet)Front
Hood Bonnet Hood(Bonnet)Upper
Hood Bonnet Hood(Bonnet)Side
Hood Bonnet Hood(Bonnet)Side Cover [Old Type] [Au] ## S.No.60952to62228 S.No
Hood Bonnet Hood(Bonnet)Side Cover [New Type] ## S.No.=80001 S.No.;=80001
Hood Bonnet Hood(Bonnet)Rear
Hood Bonnet Fender
Hood Bonnet Floor Seat [Au]
Hood Bonnet Floor Seat [Except[Au]]
Hood Bonnet Seat
Hood Bonnet Step
Hood Bonnet Rearview Mirror [Au]
Hood Bonnet Rearview Mirror [Except[Au]]
Hood Bonnet Tool Box [Except[Sr]Old Type] [Sr] ## S.No.;=62228
Hood Bonnet Tool Box [New Type] [Except[Sr]] ## S.No.;=80001
Hood Bonnet Rops [Au] [Old Type] ## S.No.=81207 S.No.;=81207
Hood Bonnet Rops [Au] [New Type] ## S.No.=81208 S.No.;=81208
Hood Bonnet Canopy [Except[Au]] [[Au]Option]
Labels Labels [Au]
Labels Labels [Except[Au]]
Accessories Accessories And Service Parts
Option Step Support Kit [Option]
Engine Crankcase
Engine Oil Pan
Engine Flywheel
Engine Muffler
Engine Camshaft
Engine Gear Case
Engine Water Pump
Engine Governor
Clutch Clutch
Clutch Clutch Pedal
Brake Brake [Au]
Brake Brake Rod
Hood Bonnet Fender
Hood Bonnet Seat
Hood Bonnet Step
Labels Labels [Au]
