Kubota Tractor M5400DT-N-EU Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5400DT-N-EU Tractor
Number of Pages: 341 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Volante / Flywheel
Tobera Soporte/Bujia De Calentamiento Tapon / Nozzle Holder/Glow Plug
Tapa De Balancines / Cylinder Head Cover
Filtro De Aire (Doble) / Air Cleaner (Double)
Filtro De Aire (Doble) [Componentes] / Air Cleaner (Double) [Component Parts]
Debajo Silenciador / Under Muffler
Arbol De Levas / Camshaft
Agua Bomba / Water Pump
Motor Parar Palanca / Engine Stop Lever
Speed Control Plate
Mano Acelerador Palanca / Hand Accelerator Lever
Motor Parar Cable / Engine Stop Wire
Filtro De Combustible/Tubo De Combustible / Fuel Filter/Fuel Pipe
Filtro De Combustible[Componente Piezas] / Fuel Filter [Compnent Parts]
Agua Tubo / Water Pipe
Ventilador / Fan
Alternador / Alternator
Alternador[Componente Piezas][Viejo Tipo] / Alternator [Compnent Parts][Old Type]
Alternador[Componente Piezas][Nuevo Tipo] / Alternator [Compnent Parts][New Type]
Motor De Arranque / Starter
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Conmutador / Switch
Culata Luz / Head Light
Luz / Light
Funcionamiento Luz Kit[Opcion] / Working Light Kit [Option]
Remolque Vaso Kit[Opcion] / Trailer Socket Kit [Option]
Embrague / Clutch
Rodamiento Soporte / Bearing Holder
Entrada Eje/Primero Eje / Input Shaft/First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Marcha Muy Lenta / Creep
Pto Helice Eje / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje De Tdf/Tdf Protector / Pto Shaft/Pto Protector
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Palanca De Control De Embrague De Tdf [Tipo Antiguo] / Pto Clutch Control Lever [Old Type]
Palanca De Control De Embrague De Tdf [Tipo Nuevo] / Pto Clutch Control Lever [New Type]
Engranaje Conico (Posterior) / Bevel Gear (Rear)
Diferencial (Posterior) / Differential (Rear)
Trasero Eje Caja / Rear Axle Case
Eje Trasero / Rear Axle
Rueda Trasera (12,4-24fl) / Rear Wheel (12.4-24fl)
Rueda Trasera (14.9-24fl) / Rear Wheel (14.9-24fl)
Freno / Brake
Freno Pedal / Brake Pedal
Freno Varilla / Brake Rod
Freno De Estacionamiento[Opcion] / Parking Brake Kit [Option]
Adelante Rueda Accionar Eje / Front Wheel Drive Shaft
Eje Propulsor [Tipo Antiguo] / Propeller Shaft [Old Type]
Eje Propulsor [Tipo Nuevo] / Propeller Shaft [New Type]
Diferencial(Adelante) / Differential (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Rueda Delantera (8-16) / Front Wheel (8-16)
Rueda Delantera (9.5-16) / Front Wheel (9.5-16)
Direccion Varillaje / Steering Linkage
Direccion Volante/Direccion Controlador / Steering Handle/Steering Controller
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Hidraulico Aceite Linea(Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea / Hydraulic Oil Line
Cubierta De Cilindro Hidraulico [Tipo Antiguo] / Hydraulic Cylinder Cover [Old Type]
Cubierta De Cilindro Hidraulico [Tipo Nuevo] / Hydraulic Cylinder Cover [New Type]
Valvula De Seguridad/Valvula De Sobrepresion [Componentes] / Safety Valve/Relief Valve [Component Parts]
Hidraulico Ascenso Palanca / Hydraulic Lift Lever
Palanca De Reaccion 1 / Feed Back Lever 1
Palanca De Reaccion 2 / Feed Back Lever 2
Palanca De Reaccion 3 / Feed Back Lever 3
Palanca De Control De Esfuerzo Y Posicion 1 / Draft And Position Control Lever 1
Palanca De Control De Esfuerzo Y Posicion 2 / Draft And Position Control Lever 2
Auxiliar Control Valvula(Scd) / Auxiliary Control Valve (Scd)
Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve (Scd) [Option]
Distribuidor De Servicios Externos (Scd) [Componentes] / Auxiliary Control Valve (Scd) [Component Parts]
Hidraulico Vinculo De Elevador 1(Vinculo Superior) / Hydraulic Lift Link 1 (Top Link)
Hidraulico Vinculo De Elevador 2(Vinculo De Abajo) / Hydraulic Lift Link 2 (Lower Link)
Hidraulico Vinculo De Elevador 3(Varilla De Elevador) / Hydraulic Lift Link 3 (Lift Rod)
Oscilacion Barra De Remolque/Enganche / Swinging Drawbar/Hitch
Capo Adelante / Bonnet (Hood) Front
Capo Superior / Bonnet (Hood) Upper
Capo Lado / Bonnet (Hood) Side
Cubierta De Capo Lado[Tipo Nuevo] / Bonnet (Hood) Side Cover [New Type]
Capo Trasero / Bonnet (Hood) Rear
Guardabarros / Fender
Piso Asiento / Floor Seat
Hoja / Seat
Peldano / Step
Caja De Herramienta / Tool Box/Top Link Holder
Accesorios / Rops
Etiquetas / Labels
Accesorios / Step Support Kit [Option]
