652
1,893,758
Kubota Tractor M5112L-ITA Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5112L-ITA Tractor
Number of Pages: 281 Pages
Itens Usado S Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Common Rail / Common Rail
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Sepa Rator [Component Parts]
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cleaner)
Intercooler / Inter Cooler
Flange Filtro Ar E Valvula Acelarador / Air Clea Ner Flange And Throttle Valve
Valvula Egr / Egr Valve
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Suporte (Filtro De Partículas Diesel) / Muffler Bracket (Diesel Particulate Filter)
Tubo Pressao / Pressure Pipe
Panela Escape (Filtro De Partículas Diesel) / Mu Ffler Pipe (Diesel Particulate Filter)
Silenciador Da Redução Catalítica Seletiva / Sel Ective Catalytic Reduction Muffler
Estrutura Da Redução Catalítica Seletiva / Selec Tive Catalytic Reduction Frame
Bomba Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Co Mponentes] / Diesel Exhaust Fluid Tank [Component Parts]
Tampa Da Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank Cover
Depósito Do Fluido De Escape De Diesel Tubo / Di Esel Exhaust Fluid Hose
Depósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / E Ngine Electrical Parts (Muffler)
Diagmaster / Diagmaster
Deposito Combustivel / Fue L Tank
Suporte Deposito Combustiv El / Fuel Tank Bracket
Porta De Fornecimento De C Ombustível / Fuel Supply Port
Tubo Do Combustível (Enchi Mento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Do Combustível (Bomba Do Combustível/Separador) / Fuel Pipe (Fuel Pump/S Eparator)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compo Nentes] / Fuel Pump [Component Parts]
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Sensor (Panela Escape) / Sensor (Muffler)
Interruptor/Sensor (Travã O) / Switch/Sensor (Brake)
Interruptor/Sensor (Frent E) / Switch/Sensor (Front)
Interruptor/Sensor (Trase Ira) / Switch/Sensor (Rear)
Interruptor/Sensor (Carte R Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor/Sensor (Quadr O Do Painel) / Switch/Sensor (Panel Board)
Interruptor / Rele / Rela Y
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Quadro Do Painel / Panel Board
Luzes Frente / Head Light
Luzes Frente [Peças Compo Nentes] / Head Light [Component Parts]
Luzes Frontais / Front Co Mbination Lamp
Farois Trabalho (Grelha F Rontal) / Work Light (Front Grille)
Braco Traseiro / Rear Com Bination Lamp
Ficha Reboque / Trailer S Ocket
Cablagem Electrica (Frent E Direito) / Electrical Wiring (Front Rh)
Cablagem Electrica (Frent E Esquerdo) / Electrical Wiring (Front Lh)
Cablagem Eletrcia (Lampad A Cabeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Corpo ) / Electrical Wiring (Body)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cove R
Caixa Da Transmiss Ão / Transmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Axle Case
Cabo Embraiagem / Clutch Cable
Valvula Alavanca ( Embraiagem) / Valve Lever (Clutch)
Veio Primario / In Put Shaft
Embraiagem (Lançad Eira) [Peças Componentes] / Clutch Pack (Shuttle) [ Component Parts]
Veio Inversor / Sh Uttle Shaft
Primeiro Veio / Fi Rst Shaft
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Veio De Acionament O / Drive Shaft
Grupo Conico / Bev El Gear
Diferencial Trasei Ro / Rear Differential
Embraiagem Bloquei O Diferencial Traseiro / Rear Differential Lock Clu Tch
Veio Tdf / Pto Pro Peller Shaft
Embraiagem Tdf / P To Clutch
Embraiagem Tdf [Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compon Ent Parts]
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Embraiagem Andamen To [Peças Componentes] / Front Drive Clutch [Compon Ent Parts]
Cobertura Da Embra Iagem De Transmissão Frontal / Front Drive Clutch C Over
Embraiagem De Dupl A Velocidade / Bi-Speed Turn Clutch
Embraiagem De Dupl A Velocidade [Peças Componentes] / Bi-Speed Turn Cl Utch [Component Parts]
Forquet A / Main Gear Shift Fork
Forquet A Velocidades / Range Gear Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Le Ver
Alavanc A De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Pedal Bloqueio Diferenc Ial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Ax Le
Travão / Brake
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / P Arking Brake Lever
Alavanca De Freio Secun Dária / Secondary Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Travao Princip Al / Brake Master Cylinder
Cilindro Travao Princip Al [Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pip E
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Prop Eller Shaft
Caixa Diferencial Fr Ente / Front Differential Case
Grupo Conico (Frente ) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens C Onica Drt / Bevel Gear Case Rh
Caixas Engrenagens C Onica Esq / Bevel Gear Case Lh
Carter Eixo Frente D Rt / Front Axle Case Rh
Carter Eixo Frente E Sq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Drt / Fr Ont Axle Rh
Eixo Frente Esq / Fr Ont Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tampa Bomba Hidráulica / Hydraulic Pump Cover
Tubo Oleo (Entrega) / Hyd Raulic Pipe (Delivery)
Radiador Oleo / Oil Coole R
Circuito Oleo Direcção (D Irecção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor) / Hy Draulic Oil Line (Shuttle)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidrául Ico / Hydraulic Lift Arm
Valvula Segurança/Descarg A Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Le Ver
Suporte De Controlo De Po Sição / Position Control Bracket
Puxar E Posicionar Alavan Ca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Po Sition And Draft Shaft
Alavanca / Feed Back Leve R
Válvula De Controlo Auxil Iar / Auxiliary Control Valve
Válvula De Controle Alava Nca (Scd) [Peças Componentes] / Auxiliary Control V Alve (Scd) [Component Parts]
Válvula De Controle Alava Nca (Fd) [Peças Componentes] / Auxiliary Control Va Lve (Fd) [Component Parts]
Alavanca De Válvula De Co Ntrolo Auxiliar (1º) / Auxiliary Control Valve Leve R (1st)
Alavanca De Válvula De Co Ntrolo Auxiliar (2º) / Auxiliary Control Valve Leve R (2nd)
Cilindro Auxiliar De Elev Acao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elev Acao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elev Acao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Part E Superior / Top Link Bracket
Liga Cao Superior / Top Link
Liga Cao Inferior / Lower Link
Esta Bilizador / Stabilizer
Esta Bilizador Drt / Lift Rod Rh
Esta Bilizador Esq / Lift Rod Lh
Prot Eccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) ( Insulator)
Lado Do Capot / Bonnet Side
Suporte Capot / Hood (Bonnet) Support
Protecção / Shield
Guarda Lamas / Fender
Tampa / Shift Cover
Piso (Som Absorvedor/Isolador) / Floor Shee T (Sound Absorber/Insulator)
Cobertura Do Guarda-Lamas / Fender Cover
Degrau / Step
Degrau Superior Resguardo / Step Upper Cove R
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Isolante / Soundproof Material
Caixa Ferramenta / Tool Box
Caobertura / Guard
Estrutura De Protecção (Frente) / Rops (Upper)
Estrutura De Protecção (Traseira) / Rops (Lower)
Etiqueta (Dianteiro) / Label (Front)
A Cessorios Y Peças De Serviço / Accessories And Serv Ice Parts
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Kit De Lubrificaçao Para Terceiro Ponto [Opção] / Lubrication Kit For 3rd Shaft [Option]
Conjunto De Parafusos Para Montagem Da Carcaça D A Embreagem [Opção] / Bolt Kit For Clutch Housing A Ssembly [Option]
Kit Apoio Peso Frente [Opção] / Front Bumper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção ] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Válvula De Controle Alavanca (Fc) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Fc) [Compo Nent Parts] [Option]
Válvula De Controle Alavanca (Scd) [Peças Compon Entes] [Opção] / Auxiliary Control Valve (Scd) [Com Ponent Parts] [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3 Rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Acoplam Ento) [Opção] / Trailer Brake Valve Mounting Kit (C Oupler) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvula ) [Opção] / Trailer Brake Valve Mounting Kit (Valve ) [Option]
Montagem Da Válvula Do Freio Do Reboque (Travão Reboque) [Opção] / Trailer Brake Valve Mounting Kit (Trailer Brake) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablage M Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
