Kubota Tractor M5112L-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5112L-EC Tractor
Number of Pages: 291 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Separ Ator [Component Parts]
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Ch Arger)
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cleaner)
Intercooler / Inter Cooler
Flange Filtro Ar E Valvula Acelarador / Air Clean Er Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Suporte (Filtro De Partículas Diesel) / Muffler B Racket (Diesel Particulate Filter)
Tubo Pressao / Pressure Pipe
Panela Escape (Filtro De Partículas Diesel) / Muf Fler Pipe (Diesel Particulate Filter)
Silenciador Da Redução Catalítica Seletiva / Sele Ctive Catalytic Reduction Muffler
Estrutura Da Redução Catalítica Seletiva / Select Ive Catalytic Reduction Frame
Bomba Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel E Xhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Com Ponentes] / Diesel Exhaust Fluid Tank [Component Pa Rts]
Tampa Da Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank Cover
Depósito Do Fluido De Escape De Diesel Tubo / Die Sel Exhaust Fluid Hose
Componentes Electricos Motor (Sensor/Ecu) / Engin E Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / En Gine Electrical Parts (Muffler)
Diagmaster / Diagmaster
Suporte Deposito Combustive L / Fuel Tank Bracket
Porta De Fornecimento De Co Mbustível / Fuel Supply Port
Tubo Do Combustível (Enchim Ento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Do Combustível (Bomba Do Combustível/Separador) / Fuel Pipe (Fuel Pump/Se Parator)
Tubo Combustivel (Arrefeced Or Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Componente S] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compon Entes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filte R
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Sensor (Panela Escape) / S Ensor (Muffler)
Interruptor/Sensor (Travão ) / Switch/Sensor (Brake)
Interruptor/Sensor (Frente ) / Switch/Sensor (Front)
Interruptor/Sensor (Trasei Ra) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor/Sensor (Quadro Do Painel) / Switch/Sensor (Panel Board)
Interruptor / Rele / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Quadro Do Painel / Panel B Oard
Luzes Frente / Head Light
Luzes Frente [Peças Compon Entes] / Head Light [Component Parts]
Luzes Frontais / Front Com Bination Lamp
Farois Trabalho (Grelha Fr Ontal) / Work Light (Front Grille)
Braco Traseiro / Rear Comb Ination Lamp
Ficha Reboque / Trailer So Cket
Cablagem Electrica (Frente Direito) / Electrical Wiring (Front Rh)
Cablagem Electrica (Frente Esquerdo) / Electrical Wiring (Front Lh)
Cablagem Eletrcia (Lampada Cabeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Carretos Inversor / Shuttle Gear Case
Caixa Da Transmissã O / Transmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damper Disk
Cabo Embraiagem / C Lutch Cable
Valvula Alavanca (E Mbraiagem) / Valve Lever (Clutch)
Veio Primario / Inp Ut Shaft
Embraiagem (Lançade Ira) [Peças Componentes] / Clutch Pack (Shuttle) [C Omponent Parts]
Primeiro Veio / Fir St Shaft
Secundario Veio / S Econd Shaft
Terceiro Veio / Thi Rd Shaft
Veio Creeper / Cree P Shaft
Veio De Acionamento / Drive Shaft
Grupo Conico / Beve L Gear
Diferencial Traseir O / Rear Differential
Embraiagem Bloqueio Diferencial Traseiro / Rear Differential Lock Clut Ch
Veio Tdf / Pto Prop Eller Shaft
Embraiagem Tdf / Pt O Clutch
Embraiagem Tdf [Peç As Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compone Nt Parts]
Veio Tdf / Pto Shaf T
Embraiagem Andament O / Front Drive Clutch
Embraiagem Andament O [Peças Componentes] / Front Drive Clutch [Compone Nt Parts]
Cobertura Da Embrai Agem De Transmissão Frontal / Front Drive Clutch Co Ver
Embraiagem De Dupla Velocidade / Bi-Speed Turn Clutch
Embraiagem De Dupla Velocidade [Peças Componentes] / Bi-Speed Turn Clu Tch [Component Parts]
Forqueta Velocidades / Range Gear Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Gama E T Irante Caixa Creep / Range And Creep Gear Shift Lev Er
Alavanca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Pedal Bloqueio Diferenci Al Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axl E
Travão / Brake
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / Pa Rking Brake Lever
Alavanca De Freio Secund Ária / Secondary Brake Lever
Pedal Travao / Brake Ped Al
Cilindro Travao Principa L / Brake Master Cylinder
Cilindro Travao Principa L [Peças Componentes] / Brake Master Cylinder [Comp Onent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Prope Ller Shaft
Caixa Diferencial Fre Nte / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Co Nica Drt / Bevel Gear Case Rh
Caixas Engrenagens Co Nica Esq / Bevel Gear Case Lh
Carter Eixo Frente Dr T / Front Axle Case Rh
Carreto Diferencial D Rt / Differential Gear Shaft Rh
Eixo Frente Drt / Fro Nt Axle Rh
Eixo Frente Esq / Fro Nt Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Tampa Bomba Hidráulica / H Ydraulic Pump Cover
Tubo Oleo (Entrega) / Hydr Aulic Pipe (Delivery)
Tubo Hidraulico (Travao Re Boque) (Frente ) / Hydraulic Pipe (Trailer Brake) (Front)
Tubo Hidraulico (Travao Re Boque) (Traseira) / Hydraulic Pipe (Trailer Brake) (Rear)
Valvula Travao Reboque / T Railer Brake Valve
Circuito Oleo Direcção (Di Recção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor) / Hyd Raulic Oil Line (Shuttle)
Tubo Direccao (Forneciment O) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidráuli Co / Hydraulic Lift Arm
Valvula Segurança/Descarga Valvula / Safety Valve/Relief Valve
Suporte De Controlo De Pos Ição / Position Control Bracket
Puxar E Posicionar Alavanc A De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Pos Ition And Draft Shaft
Alavanca / Feed Back Lever
Válvula De Controlo Auxili Ar / Auxiliary Control Valve
Válvula De Controle Alavan Ca (Fd) [Peças Componentes] / Auxiliary Control Val Ve (Fd) [Component Parts]
Alavanca De Válvula De Con Trolo Auxiliar (1º) / Auxiliary Control Valve Lever (1st)
Alavanca De Válvula De Con Trolo Auxiliar (2º) / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Eleva Cao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Eleva Cao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Eleva Cao [Peças Componentes] / 3p-Lift Assist Cylinder [ Component Parts]
Parte Superior / Top Link Bracket
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Estab Ilizador / Stabilizer
Estab Ilizador Drt / Lift Rod Rh
Estab Ilizador Esq / Lift Rod Lh
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) (I Nsulator)
Suporte Capot / Hood (Bonnet) Support
Protecção / Shield
Capot Traseiro (Isolador) / Hood (Bonnet) Re Ar (Insulator)
Guarda Lamas / Fender
Tampa / Shift Cover
Piso / Floor Sheet
Piso (Som Absorvedor/Isolador) / Floor Sheet (Sound Absorber/Insulator)
Cobertura Do Guarda-Lamas / Fender Cover
Degrau / Step
Degrau Superior Resguardo / Step Upper Cover
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Isolante / Soundproof Material
Caixa Ferramenta / Tool Box
Caobertura / Guard
E Strutura De Protecção (Frente) / Rops (Upper)
E Strutura De Protecção (Traseira) / Rops (Lower)
Etiqueta (Dianteiro) / Label (Front)
Etiqueta (Traseiros) / Label (Rear)
Ac Essorios Y Peças De Serviço / Accessories And Servi Ce Parts
Kit Farios Trabalho [Opção] / Working Light Kit [ Option]
Kit De Lubrificaçao Para Terceiro Ponto [Opção] / Lubrication Kit For 3rd Shaft [Option]
Conjunto De Parafusos Para Montagem Da Carcaça Da Embreagem [Opção] / Bolt Kit For Clutch Housing As Sembly [Option]
Kit Conversao Tdf (Engrenagem) (540/1000) [Opção] / Pto Conversion Kit (Gear) (540/1000) [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / A Uxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / A Uxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Válvula De Controle Alavanca (Fc) [Peças Componen Tes] [Opção] / Auxiliary Control Valve (Fc) [Compon Ent Parts] [Option]
Válvula De Controle Alavanca (Scd) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Scd) [Comp Onent Parts] [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit ( 3ª) [Opção] / Auxiliary Control Valve Lever Kit (3r D) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [O Pção] / Trailer Brake Valve Mounting Kit (Pipe) [Op Tion]
Montagem Da Válvula Do Freio Do Reboque (Valvula) [Opção] / Trailer Brake Valve Mounting Kit (Valve) [Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [ Opção] / Trailer Brake Valve Mounting Kit (Gasket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablagem Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
