Kubota Tractor M5111HC-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5111HC-EC Tractor
Number of Pages: 767 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Piston/Cambota / Piston/Crankshaft
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Common Rail / Common Rail
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Sepa Rator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Filtro Ar / Air Cleaner
Tubo De Entrada (Filtro Ar) / Inlet Pipe (Air Cl Eaner)
Intercooler / Inter Cooler
Flange Filtro Ar E Valvula Acelarador / Air Clea Ner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Panela Escape (Filtro De Particulas Diesel) / Mu Ffler Pipe (Diesel Particulate Filter)
Silenciador Da Redução Catalítica Seletiva / Sel Ective Catalytic Reduction Muffler
Estrutura Da Redução Catalítica Seletiva / Selec Tive Catalytic Reduction Frame
Bomba Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Co Mponentes] / Diesel Exhaust Fluid Tank [Component Parts]
Depósito Do Fluido De Escape De Diesel Tubo / Di Esel Exhaust Fluid Hose
Componentes Electricos Motor (Motor/Ecu) / Engin E Electrical Parts (Engine/Ecu)
Componentes Electricos Motor (Panela Escape) / E Ngine Electrical Parts (Muffler)
Diagmaster / Diagmaster
Suporte Deposito Combustiv El / Fuel Tank Bracket
Tubo Combustivel (Enchimen To) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Bomba/Se Parador) / Fuel Pipe (Fuel Pump/Separator)
Tubo Combustivel (Deposito Combustivel Respiro) / Fuel Pipe (Fuel Tank Breath Er)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador [Peças Component Es] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compo Nentes] / Fuel Pump [Component Parts]
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Silen Ciador) / Switch/Sensor (Muffler)
Interruptor/Sensor (Capot ) / Switch/Sensor (Bonnet)
Interruptor/Sensor (Travã O) / Switch/Sensor (Brake)
Interruptor/Sensor (Trase Ira) / Switch/Sensor (Rear)
Interruptor/Sensor (Carte R Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Quadro Do Pa Inel) / Switch (Panel Board)
Comutador (Painel) / Swit Ch (Panel)
Rele / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Quadro Do Painel / Panel Board
Lampada Cabeça / Head Lig Ht
Lampada Cabeça [Peças Com Ponentes] / Head Light [Component Parts]
Luzes Frontais / Front Co Mbination Light
Luzes Trabalho (Grelha Fr Ontal) / Working Light (Front Grille)
Farois Trabalho (Cabine) / Work Light (Cab)
Braco Traseiro / Rear Com Bination Light
Farol Matricula/Lâmpada F Arol / License Lamp/Beacon Lamp
Ficha Reboque / Trailer S Ocket
Alta Voz Radio / Radio Sp Eaker
Depósito De Lavagem / Was Her Tank
Escova Limpa Vidro Fronta L / Front Wiper
Cablagem Eletrcia (Motor Direito) / Electrical Wiring (Engine Rh)
Cablagem Eletrcia (Motor Esquerdo) / Electrical Wiring (Engine Lh)
Cablagem Eletrcia (Lampad A Cabeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Princ Ipal) Frente [Velho] / Electrical Wiring (Main) Fro Nt [Old]
Cablagem Electrica (Princ Ipal) Frente [Novo] / Electrical Wiring (Main) Fron T [New]
Cablagem Electrica (Princ Ipal) Traseira [Velho] / Electrical Wiring (Main) R Ear [Old]
Cablagem Electrica (Princ Ipal) Traseira [Novo] / Electrical Wiring (Main) Re Ar [New]
Cablagem Electrica (Corpo ) / Electrical Wiring (Body)
Cablagem Electrica (Cabin E) / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cove R
Valva Dual Speed / Dual Speed Valve
Caixa Da Transmiss Ão / Transmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula Alavanca ( Embraiagem) / Valve Lever (Clutch)
Veio Primario / In Put Shaft
Kit Embraiagem (Al To-Baixo) [Peças Componentes] / Clutch Pack (Hi-Lo) [Component Parts]
Veio Inversor / Sh Uttle Shaft
Embraiagem Inverso R [Peças Componentes] / Clutch Pack (Shuttle) [Comp Onent Parts]
Primeiro Veio / Fi Rst Shaft
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Veio De Acionament O / Drive Shaft
Grupo Conico / Bev El Gear
Diferencial Trasei Ro / Rear Differential
Embraiagem Bloquei O Diferencial Traseiro / Rear Differential Lock Clu Tch
Veio Tdf / Pto Pro Peller Shaft
Embraiagem Tdf / P To Clutch
Embraiagem Tdf [Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compon Ent Parts]
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Embraiagem Andamen To [Peças Componentes] / Front Drive Clutch [Compon Ent Parts]
Cobertura Da Embra Iagem De Transmissão Frontal / Front Drive Clutch C Over
Forquet A Velocidades De Principal / Main Gear Shift Fork
Forquet A Velocidades / Range Gear Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Tirante Velocidades / Main Gear Shift Rod
Gama Al Avanca De Velocidades / Range Gear Shift Lever
Alavanc A Velocidades Tdf / Pto Gear Shift Lever
Tirante Velocidades Tdf / Pto Gear Shift Rod
Pedal Bloqueio Diferenc Ial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Ax Le Shaft
Travão / Brake
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / P Arking Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Travao Princip Al / Brake Master Cylinder
Cilindro Travao Princip Al [Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pip E
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Fron T Propeller Shaft
Caixa Diferencial Fr Ente / Front Differential Case
Grupo Conico (Frente ) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens C Onica Drt / Bevel Gear Case Rh
Caixas Engrenagens C Onica Esq / Bevel Gear Case Lh
Carter Eixo Frente D Rt / Front Axle Case Rh
Carter Eixo Frente E Sq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Drt / Fr Ont Axle Rh
Eixo Frente Esq / Fr Ont Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tubo Hidraulico (Entrega) / Hydraulic Pipe (Delivery)
Tubo Hidraulico (Travao R Eboque) (Frente) / Hydraulic Pipe (Trailer Brake) ( Front)
Tubo Hidraulico (Travao R Eboque) (Traseiro) / Hydraulic Pipe (Trailer Brake) (Rear)
Valvula Travao Reboque / Trailer Brake Valve
Oleo Radiador / Oil Coole R
Circuito Oleo Direcção (V Alva Dupla Velocidades) / Hydraulic Oil Line (Dual Speed Valve)
Circuito Oleo Direcção (D Irecção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Circuito Oleo Direcção (I Nversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direcção (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico [Velho] / Hydraulic Cylinder Case [Old]
Caixa Cilindro Hidraulico [Novo] / Hydraulic Cylinder Case [New]
Braco Hidraulico / Lift A Rm
Valvula Segurança/Distrib Uidor Redução / Safety Valve/Relief Valve
Trinco Alavanca / Lowerin G Lock Lever
Puxar E Posicionar Alavan Ca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Po Sition And Draft Shaft
Alavanca / Feed Back Leve R
Válvula De Controlo Auxil Iar [Novo] / Auxiliary Control Valve [New]
Válvula De Controlo Auxil Iar (Scd) [Peças Componentes] / Auxiliary Control V Alve (Scd) [Component Parts]
Válvula De Controlo Auxil Iar (Fd) [Peças Componentes] / Auxiliary Control Va Lve (Fd) [Component Parts]
Alavanca Valvula Control Auxiliar (Primeiro) / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Control Auxiliar (Secundario) / Auxiliary Control Valve Lev Er (2nd)
Cilindro Auxiliar De Elev Acao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elev Acao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elev Acao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Part E Superior / Top Link Bracket
Liga Cao Superior / Top Link
Liga Cao Inferior / Lower Link
Esta Bilizador / Stabilizer
Esta Bilizador Esq / Lift Rod Lh
Prot Eccao Tdf / Pto Shaft Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) ( Insulator)
Lado Do Capot / Bonnet Side
Estrutura Cabine / Cab Frame
Degrau / Step
Capot Traseira / Hood (Bonnet) Rear
Vidro Frente / Front Glass
Porta Esquerdo / Door Lh
Trinco Porta Direito / Door Lock Rh
Lado Vidro / Side Window
Vidro Traseiro / Rear Window
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Składowanie Materiałów/Piso / Damp Material/Floor Mat
Chapa Inspecção / Inspection Plate
Cobertura Guarda Lamas Direito / Fender Cover Rh
Cobertura Gurada Lamas Esquerdo / Fender Cover Lh
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Condi Tioner
Tubo Ar Condicionado / Air C Onditioner Duct
Modo Caixa / Mode Case
Entradas Ar Painel Instrumen Tos / Dashboard Air Outlets
Circulaçao Ar Interior / Inn Er Air Recirculation
Tubo Aquecimento / Heater Ho Se
Condesador / Condenser
Tubo Ar Condicionado/Tubo Co Ndensador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Suporte Compressor / Compres Sor Bracket
Etiqueta (Painel) / Label (Panel)
Etiqueta (Cabine Interior) / Label (Cab Inte Rior)
Etiqueta (Cabine Exterior) / Label (Cab Exte Rior)
Aces Sorios E Peças Serviço [Velho] / Accessories And Se Rvice Parts [Old]
Aces Sorios E Peças Serviço [Novo] / Accessories And Ser Vice Parts [New]
Panela Escape [Opção] / Under Muffler Kit [Optio N]
Kit Tampa Da Depósito Do Fluido De Escape De Die Sel (Resguardo) [Opção] / Diesel Exhaust Fluid Tank Cover Kit (Cover) [Option]
Kit Tampa Da Depósito Do Fluido De Escape De Die Sel (Isolamento) [Opção] / Diesel Exhaust Fluid Tan K Cover Kit (Insulation) [Option]
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Desempanador (Vidro) [Opção] / Rear Defogger Kit (Glass) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper K It [Option]
Kit De Lubrificaçao Para Terceiro Ponto [Opção] / Lubrication Kit For 3rd Shaft [Option]
Conjunto De Parafusos Para Montagem Da Carcaça D A Embreagem [Opção] / Bolt Kit For Clutch Housing A Ssembly [Option]
Kit Conversao Tdf (Engrenagem) (540/1000) [Opção ] / Pto Conversion Kit (Gear) (540/1000) [Option]
Kit Apoio Peso Frente [Opção] / Front Bumper Kit [Option]
Kit Valvula Control Auxiliar (Scd) [Opção] / Aux Iliary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fd) [Opção] / Auxi Liary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opção] / Auxi Liary Control Valve Kit (Fc) [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Kit Valvula Control Auxiliar (Scd) [Peças Compon Entes] [Opção] / Auxiliary Control Valve (Scd) [Com Ponent Parts] [Option]
Kit Valvula Control Auxiliar (Fd) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Fd) [Compo Nent Parts] [Option]
Kit Valvula Control Auxiliar (Fc) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Fc) [Compo Nent Parts] [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Peças Com Ponentes] [Opção] / Auxiliary Control Valve (Scd/Fc ) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3 Rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [ Opção] / Trailer Brake Valve Mounting Kit (Pipe) [O Ption]
Montagem Da Válvula Do Freio Do Reboque (Valvula ) [Opção] / Trailer Brake Valve Mounting Kit (Valve ) [Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [Opção] / Trailer Brake Valve Mounting Kit (Gasket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablage M Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Banco Passageiro (Banco) [Opção] / Instructional Seat Kit (Seat) [Option]
Banco Passageiro (Suporte) [Opção] / Instruction Al Seat Kit (Bracket) [Option]
Kit De Espelho De Sala [Opção] / Room Mirror Kit [Option]
Bkidk5167 >> M5111hc-Ec
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Deposito Combustivel / Fue L Tank
Fornecimento Combustivel / Fuel Supply
Separador / Separator
Travão De Estacionament O / Secondary Brake
Junta Direcção / Steering Joint
Válvula De Controlo Auxil Iar [Velho] / Auxiliary Control Valve [Old]
Esta Bilizador Drt / Lift Rod Rh
Porta Direito / Door Rh
Trinco Porta Esquerdo / Door Lock Lh
Carreto / Gear Case
Ventoinh A / Fan
Rele / Relay
Travão / Brake
Degrau / Step
