Kubota Tractor M5111H Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5111H Tractor
Number of Pages: 335 Pages
Itens Uso Frequente / F Requently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
B Raço / Rocker Arm Shaft
T Ampa Cabeça / Head Cover
C Arreto / Gear Case
P Iston/Cambota / Piston/Crankshaft
C Ompensador / Balancer
V Olante Motor / Flywheel
B Omba Alimentacao / Supply Pump
T Ubo Injector / Injection Pipe
C Ommon Rail / Common Rail
B Omba Agua / Water Pump
R Adiador Oleo / Oil Cooler
S Eparador De Óleo / Oil Separator
S Eparador De Óleo [Peças Componentes] / Oil Separato R [Component Parts]
T Ubo Do Separador De Óleo / Oil Separator Pipe
T Ubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charg Er)
F Iltro Ar / Air Cleaner
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cle Aner)
T Urbo Compressor / Turbo Charger
A Rrefecedor Oleo / Inter Cooler
F Lange Filtro Ar / Air Cleaner Flange And Throttle V Alve
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
C Olector Escape / Exhaust Manifold
P Anela Escape / Muffler Pipe
S Ilenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
T Ubo Pressao / Pressure Pipe
P Anela Escape (Filtro De Partículas Diesel) / Muffle R Pipe (Diesel Particulate Filter)
S Ilenciador Da Redução Catalítica Seletiva / Selecti Ve Catalytic Reduction Muffler
E Strutura Da Redução Catalítica Seletiva / Selective Catalytic Reduction Frame
B Omba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
D Epósito Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Tank
D Epósito Do Fluido De Escape De Diesel [Peças Compon Entes] / Diesel Exhaust Fluid Tank [Component Parts ]
D Epósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
C Omponentes Electricos Motor (Sensor/Ecu) / Engine E Lectrical Parts (Sensor/Ecu)
C Omponentes Electricos Motor (Panela Escape) / Engin E Electrical Parts (Muffler)
C Ablagem Injector / Injector Harness
D Iagmaster / Diagmaster
A Celarador Mao / Hand Accelerator Lever
A Celarador / Accelerator Pedal
T Irante Do Acelerador / Accelerator Rod
Deposito Combustivel / Fuel Ta Nk
Suporte Deposito Combustivel / Fuel Tank Bracket
Fornecimento Combustivel / Fue L Supply
Tubo Combustivel (Deposito Com Bustivel Respiro) / Fuel Pipe (Fuel Tank Breather)
Tubo Combustivel (Enchimento C Ombustivel) / Fuel Pipe (Fuel Filler)
Tubo Combustivel (Bomba Gasole O/Separador) / Fuel Pipe (Fuel Pump/Separator)
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Component Es] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filter
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Motor Esq Uerda) / Switch/Sensor (Muffler)
Interruptor/Sensor (Capot) / Switch/Sensor (Bonnet)
Interruptor/Sensor (Travao) / Switch/Sensor (Brake)
Interruptor/Sensor (Traseira) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter Em Braiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Painel Borda) / Switch (Panel Board)
Rele / Relay
Unidade Control Electrico (Mo Tor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Co Rpo) / Electronic Control Unit (Body)
Painel / Panel Board
Lampada Cabeça / Head Light
Lampada Cabeça [Peças Compone Ntes] / Head Light [Component Parts]
Luzes Frontais / Front Combin Ation Lamp
Luzes Trabalho (Grelha Fronta L) / Working Light (Front Grille)
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula / License Lam P
Ficha Reboque / Trailer Socke T
Cablagem Electrica (Frente Di Reito) / Electrical Wiring (Front Rh)
Cablagem Electrica (Frente Es Querdo) / Electrical Wiring (Front Lh)
Cablagem Electrica (Lampada C Abeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Traseiros ) / Electrical Wiring (Rear)
Carter Embraiagem / Cl Utch Housing
Valvula Inversor / Shu Ttle Valve
Carretos Inversor / Sh Uttle Gear Case
Tampa / Shift Cover
Caixa Velocidades / Tr Ansmission Case
Carter Transmissao / T Ransmission Case Rear Cover
Carter Eixo / Rear Axl E Case
Disco Amortecedor / Da Mper Disk
Pedal Embraiagem / Clu Tch Pedal
Cabo Embraiagem / Clut Ch Cable
Valvula Alavanca (Embr Aiagem) / Valve Lever (Clutch)
Veio Primario / Input Shaft
Kit Embraiagem (Invers Or) [Peças Componentes] / Clutch Pack (Shuttle) [Co Mponent Parts]
Veio Inversor / Shuttl E Shaft
Primeiro Veio / First Shaft
Secundario Veio / Seco Nd Shaft
Terceiro Veio / Third Shaft
Veio Creeper / Creep S Haft
Veio De Acionamento / Drive Shaft
Grupo Conico / Bevel G Ear
Diferencial Traseiro / Rear Differential
Embraiagem Bloqueio Di Ferencial Traseiro / Rear Differential Lock Clutch
Veio Tdf / Pto Propell Er Shaft
Embraiagem Tdf / Pto C Lutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Embraiagem Andamento / Front Drive Clutch
Veio Embraiagem [Peças Componentes] / Front Drive Clutch [Component Parts ]
Cobertura Da Embraiage M De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Ve Locidades / Main Gear Shift Fork
Forqueta Ve Locidades / Range Gear Shift Fork
Alavanca Ve Locidades / Main Gear Shift Lever
Tirante Vel Ocidades / Main Gear Shift Rod
Alvanca Inv Ersor / Shuttle Shift Lever
Gama E Tira Nte Caixa Creep / Range And Creep Gear Shift Lever
Alavanca De Mudança De Velocidades De Tomada De Força / Pto Ge Ar Shift Rod
Pedal Bloqueio Diferencial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle S Haft
Travão / Brake
Veio Bloqueio / Parking Bra Ke Camshaft
Alavanca Travao Mao / Parki Ng Brake Lever
Travão De Estacionamento / Secondary Brake
Pedal Travao / Brake Pedal
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [ Peças Componentes] / Master Cylinder [Component Par Ts]
Suporte Eixo Frente / Fr Ont Axle Frame
Suporte Eixo Frente / Fr Ont Axle Bracket
Veio Primario / Front Pr Opeller Shaft
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Dif Ferential Front
Caixas Engrenagens Conic A Direito / Bevel Gear Case Rh
Caixas Engrenagens Conic A Esquerdo / Bevel Gear Case Lh
Carter Eixo Frente Direi To / Front Axle Case Rh
Carter Eixo Frente Esque Rdo / Front Axle Case Lh
Carreto Diferencial Dire Ito / Differential Gear Shaft Rh
Carreto Diferencial Esqu Erdo / Differential Gear Shaft Lh
Eixo Frente Direito / Fr Ont Axle Rh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Controlador Da Direção [Peças Componentes][Anti Ga] / Steering Controller [Component Parts] [Old] # # N.º De Série<=55272 S.No.;<=55272 / S.No.<=55272 S.No.;<=55272
Controlador Da Direção [Peças Componentes][Nova ] / Steering Controller [Component Parts] [New]
Rotula/Cilindro Direcção / Tie Rod/Steering Cyl Inder
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico [Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Tampa Bomba Hidráulica [Velho ] / Hydraulic Pump Cover [Old]
Tampa Bomba Hidráulica [Novo] / Hydraulic Pump Cover [New]
Tubo Oleo (Entrega) / Hydraul Ic Pipe (Delivery)
Tubo Hidraulico (Travao Reboq Ue) (Frente) / Hydraulic Pipe (Trailer Brake) (Fron T)
Tubo Hidraulico (Travao Reboq Ue) (Traseira) / Hydraulic Pipe (Trailer Brake) (Re Ar)
Valvula Travao Reboque / Trai Ler Brake Valve
Oleo Radiador / Oil Cooler
Tubo Oleo (Inversor) / Hydrau Lic Oil Line (Shuttle)
Tubo Direccao (Entrega) / Ste Ering Hose (Delivery)
Caixa Valvula Hidraulico / Hy Draulic Valve Case
Hidraulico Braços / Hydraulic Lift Arm
Valvula Segurança / Safety Va Lve/Relief Valve
Trinco / Lowering Lock Lever
Valvula Control / Control Val Ve
Puxar E Posicionar Alavanca D E Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Positi On And Draft Shaft
Alavanca / Feed Back Lever
Valvula Control Auxiliar [Ant Iga] / Auxiliary Control Valve [Old]
Valvula Control Auxiliar [Nov A] / Auxiliary Control Valve [New]
Alavanca De Válvula De Contro Lo Auxiliar (Primeiro) / Auxiliary Control Valve Le Ver (1st)
Alavanca Valvula Control Auxi Liar (Secundario) / Auxiliary Control Valve Lever ( 2nd)
Cilindro Auxiliar De Elevacao Esquerdo / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevacao Direito / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevacao [Peças Componentes] / 3p-Lift Assist Cylinder [Com Ponent Parts]
Parte Su Perior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link
Estabili Zador / Stabilizer
Estabili Zador Direito / Lift Rod Rh
Estabili Zador Esquerdo / Lift Rod Lh
Protecca O Tdf / Pto Shaft Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) (Insu Lator)
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Capot Traseiro (Isolante) / Hood (Bonnet) Rear (Sound Absorber)
Guarda Lamas / Fender
Piso / Floor Sheet
Piso (Silenciador/Isolante) / Floor Sheet (Soun Dproof Material/Insulator)
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Caixa Ferramenta / Tool Box
Caobertura / Guard
Arco Seguranca (Superior) / Rops (Upper)
Arco Seguranca (Inferior) / Rops (Lower)
Decalcomania (Traseira) / Label (Rear)
Acess Orios Y Peças De Serviço / Accessories And Service Parts
P Anela Escape [Opçao] / Upper Muffler Kit [Option]
K It Tampa Da Depósito Do Fluido De Escape De Diesel (Resguardo) [Opção] / Diesel Exhaust Fluid Tank Cov Er Kit (Cover) [Option]
K It Tampa Da Depósito Do Fluido De Escape De Diesel (Isolamento) [Opção] / Diesel Exhaust Fluid Tank Co Ver Kit (Insulation) [Option]
K It Farios Trabalho [Opção] / Working Light Kit [Opt Ion]
K It De Lubrificaçao Para Terceiro Ponto [Opção] / Lu Brication Kit For 3rd Shaft [Option]
C Onjunto De Parafusos Para Montagem Da Carcaça Da Em Breagem [Opção] / Bolt Kit For Clutch Housing Assem Bly [Option]
K It Conversao Tdf (Engrenagem Box) (540/1000) [Opção ] / Pto Conversion Kit (Gear Case) (540/1000) [Opti On]
K It Conversao Tdf (Engrenagem) (540/1000) [Opção] / Pto Conversion Kit (Gear) (540/1000) [Option]
K It Apoio Peso Frente [Opção] / Front Bumper Kit [Op Tion]
K It Valvula Control Auxiliar (Scd) [Opção] / Auxilia Ry Control Valve Kit (Scd) [Option]
K It Valvula Control Auxiliar (Fc) [Opção] / Auxiliar Y Control Valve Kit (Fc) [Option]
K It Valvula Control Auxiliar (Scd/Fc) [Opção] / Auxi Liary Control Valve Kit (Scd/Fc) [Option]
K It Valvula Control Auxiliar (Fd) [Peças Componentes ] [Opção] / Auxiliary Control Valve (Fd) [Component Parts] [Option]
K It Valvula Control Auxiliar (Fc) [Peças Componentes ] [Opção] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
K It Valvula Control Auxiliar (Scd/Fc) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Scd/Fc) [C Omponent Parts] [Option]
A Uxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
M Ontagem Da Válvula Do Freio Do Reboque (Tubo) [Opçã O] / Trailer Brake Valve Mounting Kit (Pipe) [Optio N]
M Ontagem Da Válvula Do Freio Do Reboque (Valvula) [O Pção] / Trailer Brake Valve Mounting Kit (Valve) [O Ption]
M Ontagem Da Válvula Do Freio Do Reboque (Junta) [Opç Ão] / Trailer Brake Valve Mounting Kit (Gasket) [Op Tion]
M Ontagem Da Válvula Do Freio Do Reboque (Cablagem El Ectrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
