Kubota Tractor M5101NC-NEC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5101NC-NEC Tractor
Number of Pages: 382 Pages
Itens Usad Os Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exh Aust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Compensador / Balancer
Volante Motor / Flywheel
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throt Tle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [Co Mponent Parts]
Tubo De Entrada (Filtro Ar) / Inlet Pipe (Air C Leaner)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Di Esel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peç As Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor/Ecu) / Eng Ine Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape Sen Sor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combusti Vel / Fuel Tank Bracket
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Fornecimento Combustivel [Ec] / Fuel Supply [Ec]
Tubo Combustivel (Deposit O Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Combustivell (Enchim Ento Do Combustivel) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Bomba D O Combustivel/Separador) / Fuel Pipe (Fuel Pump/Sep Arator)
Tubo Combustivel (Deposit O Combustivel Respiro) [Antiga] / Fuel Pipe (Fuel T Ank Breather) [Old]
Tubo Combustivel (Deposit O Combustivel Respiro) [Nova] / Fuel Pipe (Fuel Tan K Breather) [New]
Tubo Combustivel (Arrefec Edor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Componen Tes] / Separator [Component Parts]
Filtro Gasoleo / Fuel Fil Ter
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor/Sensor (Bloc O Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Fren Te) / Switch/Sensor (Front)
Interruptor/Sensor (Tras Eira) [Ec] / Switch/Sensor (Rear) [Ec]
Interruptor/Sensor (Cart Er Embraiagem) [Ec] / Switch/Sensor (Clutch Housing ) [Ec]
Interruptor (Painel) / S Witch (Panel Board)
Interruptor (Tecto Inter Ior) / Switch (Inner Roof)
Interruptor (Lado Panel) / Switch (Side Panel)
Relé / Relay
Unidade Control Electric O (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electric O (Corpo) / Electronic Control Unit (Body)
Painel [Antiga] / Panel [Old]
Luzes Frente [Ec] / Head Light [Ec]
Luzes Frente [Peças Comp Onentes] / Head Light [Component Parts]
Luzes Frontais / Front C Ombination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Co Mbination Lamp
Farol Matricula/Lâmpada Farol / License Lamp/Beacon Lamp
Luz Interior / Room Ligh T
Alta Voz Radio / Radio S Peaker
Depósito De Lavagem [Ec] / Washer Tank [Ec]
Escova Limpa Vidro Front Al / Front Wiper
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Eletrcia (Princ Ipal/Motor) [Ec] / Electrical Wiring (Main/Engine) [Ec]
Cablagem Electrica (Prin Cipal) [Ec] / Electrical Wiring (Main) [Ec]
Cablagem Electrica (Corp O) [Ds] [Ec] / Electrical Wiring (Body) [Ds] [Ec]
Cablagem Electrica (Corp O) [Exceto [Ds]] / Electrical Wiring (Body) [Except [Ds]]
Cablagem Electrica (Cabi Ne) [Ec] / Electrical Wiring (Cab) [Ec]
Carter Embraiagem [Ds] [Ec] / Clutch Housing [Ds] [Ec]
Carter Embraiagem [Exceto [Ds]] / Clutch Housing [Except [Ds]]
Valvula Inversor / Shuttle Valve
Carretos Inversor [Ds] / Shuttle Gear Case [Ds]
Carretos Inversor [Exceto [Ds]] / Shuttle Gear Case [Except [Ds]]
Tampa / Shift Cov Er
Valva Dupla Veloc Idades [Ds] / Dual Speed Valve [Ds]
Caixa Da Transmis São [Ec] / Transmission Case [Ec]
Mangueira De Resp Iro (Caixa Velocidades) / Breather Hose (Transmissi On Case)
Carter Transmissa O [Ec] / Transmission Case Rear Cover [Ec]
Carter Eixo / Rea R Axle Case
Disco Amortecedor [Ds] / Damper Disk [Ds]
Disco Amortecedor [Exceto [Ds]] / Damper Disk [Except [Ds]]
Cabo Embraiagem / Clutch Cable
Valvula Alavanca (Embraiagem) / Valve Lever (Clutch)
Veio Primario [Ds ] / Input Shaft [Ds]
Veio Primario [Ex Ceto [Ds]] / Input Shaft [Except [Ds]]
Kit Embraiagem (H I-Lo) [Peças Componentes] [Ds] / Clutch Pack (Hi-Lo ) [Component Parts] [Ds]
Kit Embraiagem (H I-Lo) [Peças Componentes] [Exceto [Ds]] / Clutch Pa Ck (Hi-Lo) [Component Parts] [Except [Ds]]
Veio Inversor [Ds ] / Shuttle Shaft [Ds]
Kit Embraiagem (I Nversor) [Peças Componentes] [Ds] / Clutch Pack (Sh Uttle) [Component Parts] [Ds]
Primeiro Veio [Ds ] / First Shaft [Ds]
Primeiro Veio [Ex Ceto [Ds]] / First Shaft [Except [Ds]]
Terceiro Veio / T Hird Shaft
Veio Creeper / Cr Eep Shaft
Veio De Acionamen To / Drive Shaft
Grupo Conico [Ec] / Bevel Gear [Ec]
Diferencial Trase Iro / Rear Differential
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf [E C] / Pto Clutch [Ec]
Embraiagem Tdf [P Eças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiage M Tdf / Pto Clutch Valve
Valvula Embraiage M Tdf [Peças Componentes] / Pto Clutch Valve [Compo Nent Parts]
Embraiagem Andame Nto / Front Drive Clutch
Embraiagem Andame Nto [Peças Componentes] / Front Drive Clutch [Compo Nent Parts]
Embraiagem Hidrau Lica [Peças Componentes] / Hydraulic Clutch (Bi-Spe Ed Turn) [Component Parts]
Forque Ta / Main Gear Shift Fork
Forque Ta Velocidades / Range Gear Shift Fork
Bloque Io Diferencial De Forqueta / Differential Lock Shif T Fork
Alavan Ca Velocidades [Ds] [Ec] / Main Gear Shift Lever [D S] [Ec]
Alavan Ca Velocidades [Exceto [Ds]] / Main Gear Shift Leve R [Except [Ds]]
Tirant E / Main Gear Shift Rod
Alvanc A Inversor [Ec] / Shuttle Shift Lever [Ec]
Alavan Ca Velocidades [Ec] / Range Gear Shift Lever [Ec]
Alavan Ca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Eixo Traseiro / Rear A Xle
Travao Drt / Brake Rh
Travao Esq / Brake Lh
Veio Bloqueio / Parkin G Brake Camshaft
Veio Travao Mao / Park Ing Brake Shaft
Alavanca De Freio Secu Ndária / Secondary Brake Lever
Pedal Travao [Ec] / Br Ake Pedal [Ec]
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal [Peças Componentes] / Brake Master Cylinder [Co Mponent Parts]
Tubo Travao / Brake Pi Pe
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Pro Peller Shaft
Grupo Conico (Frent E) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Drt / F Ront Axle Rh
Eixo Frente Esq / F Ront Axle Lh
Tampa Coluna Direccao / Steering Post Cove R
Pedal Inclinacao / Tilt Pedal
Junta Direcção / Steering Joint
Distribuidor Direcção / Steering Controlle R
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steerin G Cylinder
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Bomba Hidraulico [Peças Componentes] [Ec] / Hydraulic Pump [Component Parts ] [Ec]
Tubo Oleo (Entrega) / Hy Draulic Pipe (Delivery)
Radiador Oleo [Antiga] / Oil Cooler [Old]
Radiador Oleo [Nova] / O Il Cooler [New]
Circuito Oleo Direcção ( Valva Dupla Velocidades) [Ds] / Hydraulic Oil Line (Dual Speed Valve) [Ds]
Circuito Oleo Direcção ( Direcção/Tdf) [Ds] / Hydraulic Oil Line (Steering/P To) [Ds]
Circuito Oleo Direcção ( Direcção/Tdf) [Exceto [Ds]] / Hydraulic Oil Line (S Teering/Pto) [Except [Ds]]
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulic O / Hydraulic Cylinder Case
Braço De Elevação Hidráu Lico / Hydraulic Lift Arm
Valvula Segurança/Descar Ga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock L Ever
Valvula Control / Contro L Valve
Puxar E Posicionar Alava Nca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / P Osition And Draft Shaft
Alavanca / Feed Back Lev Er
Válvula De Controle Alav Anca (Fd/Scd) / Auxiliary Control Valve (Fd/Scd)
Válvula De Controle Alav Anca [Peças Componentes] (Fd) / Auxiliary Control V Alve [Component Parts] (Fd)
Válvula De Controle Alav Anca [Peças Componentes] (Scd) / Auxiliary Control Valve [Component Parts] (Scd)
Alavanca Valvula Control Auxiliar / Auxiliary Control Valve Lever
Cilindro Auxiliar De Ele Vacao Esq [Antiga] / 3p-Lift Assist Cylinder Lh [Ol D]
Cilindro Auxiliar De Ele Vacao Esq [Nova] / 3p-Lift Assist Cylinder Lh [New]
Cilindro Auxiliar De Ele Vacao Drt [Antiga] / 3p-Lift Assist Cylinder Rh [Ol D]
Cilindro Auxiliar De Ele Vacao Drt [Nova] / 3p-Lift Assist Cylinder Rh [New]
Cilindro Auxiliar De Ele Vacao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Mangueira De Respiro (3p Cilindro) / Breather Hose (3p Cylinder)
Par Te Superior / Top Link Bracket
Lig Acao Superior / Top Link
Lig Acao Inferior [Antiga] / Lower Link [Old]
Lig Acao Inferior [Nova] / Lower Link [New]
Est Abilizador Drt / Lift Rod Rh
Est Abilizador Esq / Lift Rod Lh
Bar Ra De Engate Oscilante [Antiga] / Swinging Drawbar [Old]
Bar Ra De Engate Oscilante [Nova] / Swinging Drawbar [N Ew]
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / Hood (Bonnet) (Sound Absorber/Insulator)
Capot Lateral [Ec] / Hood (Bonnet) Side Co Ver [Ec]
Suporte Capot / Hood (Bonnet) Support
Estrutura Cabine [Ec] / Cab Frame [Ec]
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro Drt / Side Window Rh
Lado Vidro Esq / Side Window Lh
Vidro Traseiro / Hatch Back Glass
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Suporte Do Assento / Seat Bracket
Składowanie Materiałów/Piso / Damp Material/Floor Mat
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Resguardo Coluna / Pillar Cover
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Condit Ioner
Tubo Ar Condicionado / Air C Onditioner Duct
Tubo Aquecimento / Heater Ho Se
Condesador / Condenser
Tubo Ar Condicionado/Tubo Co Ndensador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Suporte Compressor / Compres Sor Bracket
Mangueira De Drenagem / Drai N Hose
Etiqueta (Painel) / Label (Panel)
Etiqueta (Traseira) [Ec] / Label (Rear) [Ec ]
Panela Escape [Opçao] / Upper Muffler Kit [Opti On]
Alternador Kit (Alternador) [Opção] / Alternato R Kit (Alternator) [Option]
Alternador Kit (Cablagem Electrica) [Opção] / A Lternator Kit (Electrical Wiring) [Option]
Alternador [Peças Componentes] [Opção] / Altern Ator [Component Parts] [Option]
Kit Interruptor (Bomba) [Opção] / Switch Kit (P Umpa) [Option]
Desempanador [Opção] / Rear Defogger Kit [Optio N]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Kit [Option]
Kit Conversao Tdf (Carreto) (540/540e/1000) [Op Ção] / Pto Conversion Kit (Gear) (540/540e/1000) [O Ption]
Kit Conversao Tdf (Palanca) (540/540e/1000) [Op Ção] / Pto Conversion Kit (Lever) (540/540e/1000) [ Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (S/D) [Opção] / Auxiliary Control Valve Kit (S/D) [Option]
Válvula De Controle Alavanca [Peças Componentes ] (Fc) [Opção] / Auxiliary Control Valve [Component Parts] (Fc) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit ( 3rd) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (4ª) [Opção] / Auxiliary Control Valve Lever Kit ( 4th) [Option]
Kit De Engate Dianteiro (1ª) [Opção] / Front Co Upler Kit (1st) [Option]
Kit De Engate Dianteiro (2ª) [Opção] / Front Co Upler Kit (2nd) [Option]
Kit De Engate Dianteiro (3ª) [Opção] / Front Co Upler Kit (3rd) [Option]
Kit De Engate Dianteiro (4ª) [Opção] / Front Co Upler Kit (4th) [Option]
Kit De Engate Dianteiro (5ª) [Opção] / Front Co Upler Kit (5th) [Option]
Kit De Engate Dianteiro (Dreno) [Opção] / Front Coupler Kit (Drain) [Option]
Conjunto De Drenagem Traseira [Opção] / Rear Dr Ain Kit [Option]
Kit De Válvula Do Travão Do Reboque (Valvula) [ Opção] [Ec] / Traler Brake Valve Kit (Valve) [Optio N] [Ec]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo) [Opção] [Ds] / Traler Brake Valve Kit (Hydraulic P Ipe) [Option] [Ds]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo) [Opção] [Exceto [Ds] / Traler Brake Valve Kit (Hyd Raulic Pipe) [Option] [Except [Ds]
Kit De Válvula Do Travão Do Reboque (Acoplament O) [Opção] / Traler Brake Valve Kit (Coupler) [Opti On]
Montagem Da Válvula Do Freio Do Reboque (Suport E) [Opção] / Trailer Brake Valve Mounting Kit (Brac Ket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvul A/Tubo) [Opção] / Trailer Brake Valve Mounting Kit (Valve/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Acopla Dor/Tubo) [Opção] / Trailer Brake Valve Mounting Ki T (Coupler/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablag Em Electrica) [Opção] / Trailer Brake Valve Mountin G Kit (Electrical Wiring) [Option]
Estabilizador [Opção] / Stabilizer [Option]
