Kubota Tractor M5101NC-EC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5101NC-EC Tractor
Number of Pages: 671 Pages
ArtCulos Utilizados Frecuentemente / Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Engranaje Caja / Gear Case
Compensador / Balancer
Volante / Flywheel
Carril Comun / Common Rail
Agua Bomba / Water Pump
Aire Limpiador Brida / Air Cleaner Flange And Throttle Valve
Valvula De Egr / Egr Valve
Aire Limpiador / Air Cleaner
Tubo De Entrada (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador Del Filtro De PartCulas DiSel / Diesel Particulate Filter Muffler
Soporte Del Muflfer / Muffler Bracket
Silenciador Del Filtro De PartCulas DiSel [Componente Piezas] / Diesel Particulate Filter Muffler [Component Parts]
Intercooler / Inter Cooler
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Piezas Electricas Del Motor (Silencioso Sensor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster
Varilla Acelerador / Accelerator Rod
Combustible Deposito Soporte / Fuel Tank Bracket
Deposito De Combustible Derecho / Fuel Tank Rh
Deposito De Combustible Izquierdo / Fuel Tank Lh
Llenador Del Combustible [Ec] / Fuel Supply [Ec]
Llenador Del Combustible [Ita] / Fuel Supply [Ita]
Tubo De Combustible (Deposito Combustible) / Fuel Pipe (Fuel Tank)
Tubo De Combustible (Bomba De Combustible/Separador) / Fuel Pipe (Fuel Pump/Separator)
Tubo De Combustible (Deposito Combustible Respiradero) [Antiguo] / Fuel Pipe (Fuel Tank Breather) [Old]
Tubo De Combustible (Deposito Combustible Respiradero) [Nuevo] / Fuel Pipe (Fuel Tank Breather) [New]
Tubo De Combustible (Refrigerador Del Combustible) [Ec] / Fuel Pipe (Fuel Cooler) [Ec]
Tubo De Combustible (Refrigerador Del Combustible) [Ita] / Fuel Pipe (Fuel Cooler) [Ita]
Separador / Separator
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Silencioso) / Switch/Sensor (Muffler)
Conmutador/Sensor (Adelante) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) [Ec] / Switch/Sensor (Rear) [Ec]
Conmutador/Sensor (Trasero) [Ita] / Switch/Sensor (Rear) [Ita]
Conmutador/Sensor (Embrague Carcasa) [Ec] / Switch/Sensor (Clutch Housing) [Ec]
Conmutador/Sensor (Embrague Carcasa) [Ita] / Switch/Sensor (Clutch Housing) [Ita]
Conmutador (Interno Techo) / Switch (Inner Roof)
Conmutador (Lado Panel) / Switch (Side Panel)
Rele / Relay
Rele [Ita] / Relay [Ita]
Unidad De Control Electronico (Cuerpo) / Electronic Control Unit (Body)
Panel [Antiguo] / Panel [Old]
Panel [Nuevo] / Panel [New]
Faro Delantero [Ec] / Head Light [Ec]
Faro Delantero [Ita] / Head Light [Ita]
Trabajo Luz / Working Light
LMpara De MatrCula/LMpara De Faro Luminoso / License Lamp/Beacon Lamp
Arandela Deposito [Ec] / Washer Tank [Ec]
Arandela Deposito [Ita] / Washer Tank [Ita]
Limpiador Delantero / Front Wiper
Instalacion Electrica (Crs) / Electrical Wiring (Crs)
Instalacion Electrica (Principal/Motor) [Ec] / Electrical Wiring (Main/Engine) [Ec]
Instalacion Electrica (Principal/Motor) [Ita] / Electrical Wiring (Main/Engine) [Ita]
Instalacion Electrica (Principal) [Ec] / Electrical Wiring (Main) [Ec]
Instalacion Electrica (Principal) [Ita] / Electrical Wiring (Main) [Ita]
Instalacion Electrica (Cuerpo) [Ds] [Ec] / Electrical Wiring (Body) [Ds] [Ec]
Instalacion Electrica (Cuerpo) [Ds] [Ita] / Electrical Wiring (Body) [Ds] [Ita]
Instalacion Electrica (Cabina) [Ec] / Electrical Wiring (Cab) [Ec]
Instalacion Electrica (Cabina) [Ita] / Electrical Wiring (Cab) [Ita]
Embrague Carcasa [Ds] [Ec] / Clutch Housing [Ds] [Ec]
Embrague Carcasa [Ds] [Ita] / Clutch Housing [Ds] [Ita]
Engranajes De Inversor Caja [Ds] / Shuttle Gear Case [Ds]
Valvula De Doble Velocidad [Ds] / Dual Speed Valve [Ds]
Cajatransmision [Ec] / Transmission Case [Ec]
Cajatransmision [Ita] / Transmission Case [Ita]
Manguera Del Respiradero (Transmision Caja) / Breather Hose (Transmission Case)
Cubierta Trasera De Caja De Transmision [Ec] / Transmission Case Rear Cover [Ec]
Cubierta Trasera De Caja De Transmision [Ita] / Transmission Case Rear Cover [Ita]
Amortiguador Disco [Ds] / Damper Disk [Ds]
Amortiguador Disco [Excepto [Ds]] / Damper Disk [Except [Ds]]
Cable De Embrague / Clutch Cable
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Entrada Eje [Ds] / Input Shaft [Ds]
Paquete Del Embrague (Hi-Lo) [Componente Piezas] [Ds] / Clutch Pack (Hi-Lo) [Component Parts] [Ds]
Eje De Inversor [Ds] / Shuttle Shaft [Ds]
Paquete Del Embrague (Inversor) [Componente Piezas] [Ds] / Clutch Pack (Shuttle) [Component Parts] [Ds]
Primer Eje [Ds] / First Shaft [Ds]
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Propulsor / Drive Shaft
Diferencial Engranaje Eje [Ec] / Bevel Gear [Ec]
Diferencial Engranaje Eje [Ita] / Bevel Gear [Ita]
Tdf Embrague [Ec] / Pto Clutch [Ec]
Tdf Embrague [Ita] / Pto Clutch [Ita]
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Valvula De Embrague De Tdf [Componente Piezas] / Pto Clutch Valve [Component Parts]
Tdf Eje / Pto Shaft
Adelante Accionar Embrague [Componente Piezas] / Front Drive Clutch [Component Parts]
Embrague Hidraulico [Componente Piezas] / Hydraulic Clutch (Bi-Speed Turn) [Component Parts]
Horquilla De Cambio De Tdf Proporcional [Ita] / Ground Pto Shift Fork [Ita]
Principal Engranaje Cambio Palanca [Ds] [Ec] / Main Gear Shift Lever [Ds] [Ec]
Principal Engranaje Cambio Palanca [Ds] [Ita] / Main Gear Shift Lever [Ds] [Ita]
Palanca Cambio Inversor [Ec] / Shuttle Shift Lever [Ec]
Palanca Cambio Inversor [Ita] / Shuttle Shift Lever [Ita]
Gama Engranaje Cambio Palanca [Ec] / Range Gear Shift Lever [Ec]
Gama Engranaje Cambio Palanca [Ita] / Range Gear Shift Lever [Ita]
Varilla De Cambios De Engranajes De La Tdf / Pto Gear Shift Rod
Masa Tdf Cambio Palanca [Ita] / Ground Pto Shift Lever [Ita]
Trasero Eje / Rear Axle
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Arbol De Levas Del Freno De Estacionamiento / Parking Brake Camshaft
Eje De Freno De Estacionamiento / Parking Brake Shaft
Palanca De Freno Secundario / Secondary Brake Lever
Freno Pedal [Ec] / Brake Pedal [Ec]
Freno Pedal [Ita] / Brake Pedal [Ita]
Freno Tubo / Brake Pipe
Caja De Engranaje Conico Derecho / Bevel Gear Case Rh
Caja De Engranaje Conico Izquierdo / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Cubierta Del Poste De Manejo / Steering Post Cover
Distribuidor De Direccion [Componente Piezas] / Steering Controller [Component Parts]
Bomba Hidraulica [Componente Piezas] [Ec] / Hydraulic Pump [Component Parts] [Ec]
Bomba Hidraulica [Componente Piezas] [Ita] / Hydraulic Pump [Component Parts] [Ita]
Aceite Refrigerador [Antiguo] / Oil Cooler [Old]
Aceite Refrigerador [Nuevo] / Oil Cooler [New]
Hidraulico Aceite Linea (Valvula De Doble Velocidad) [Ds] / Hydraulic Oil Line (Dual Speed Valve) [Ds]
Hidraulico Aceite Linea (Direccion/Tdf) [Ds] / Hydraulic Oil Line (Steering/Pto) [Ds]
Hidraulico Aceite Linea (Inversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Brazo De Elevacion / Hydraulic Lift Arm
Distribuidor / Control Valve
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Montaje De Distribuidor De Servicios Externos / Auxiliary Control Valve Mounting Base
Distribuidor De Servicios Externos (Fd Con Fc/Scd Con Fc) / Auxiliary Control Valve (Fd With Fc/Scd With Fc)
Montaje De Distribuidor De Servicios Externos [Componente Piezas] / Auxiliary Control Valve Mounting Base [Component Parts]
Distribuidor De Servicios Externos [Componente Piezas] (Fd Con Fc) / Auxiliary Control Valve [Component Parts] (Fd With Fc)
Distribuidor De Servicios Externos [Componente Piezas] (Scd Con Fc) / Auxiliary Control Valve [Component Parts] (Scd With Fc)
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Auxiliar Control Control De Flujo De Cable / Auxiliary Control Flow Control Wire
Cilindro De Ayuda De Elevacion Izquierdo [Antiguo] / 3p-Lift Assist Cylinder Lh [Old]
Cilindro De Ayuda De Elevacion Izquierdo [Nuevo] / 3p-Lift Assist Cylinder Lh [New]
Cilindro De Ayuda De Elevacion Derecho [Antiguo] / 3p-Lift Assist Cylinder Rh [Old]
Cilindro De Ayuda De Elevacion Derecho [Nuevo] / 3p-Lift Assist Cylinder Rh [New]
Manguera Del Respiradero (Cilindro De Ayuda De Elevacion) / Breather Hose (3p Cylinder)
Bajar Vinculo [Antiguo] / Lower Link [Old]
Bajar Vinculo [Nuevo] / Lower Link [New]
Varilla De Elevacion Derecho / Lift Rod Rh
Varilla De Elevacion Izquierdo / Lift Rod Lh
Barra De Remolque Oscilante [Antiguo] / Swinging Drawbar [Old]
Barra De Remolque Oscilante [Nuevo] / Swinging Drawbar [New]
Tdf Protector / Pto Protector
Capo Superior / Hood (Bonnet) Upper
Capo Superior (Amortiguador Sano/Aislador) / Hood (Bonnet) (Sound Absorber/Insulator)
Capo Lado Cubierta [Ec] / Hood (Bonnet) Side Cover [Ec]
Capo Soporte / Hood (Bonnet) Support
Cabina Bastidor [Ec] / Cab Frame [Ec]
Cabina Bastidor [Ita] / Cab Frame [Ita]
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izquierdo / Door Lh
Cerradura De Puerta Derecho / Door Lock Rh
Lado Ventana Derecho / Side Window Rh
Lado Ventana Izquierdo / Side Window Lh
Trasero Ventana / Hatch Back Glass
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Soporte Del Asiento / Seat Bracket
Amortiguamiento Material/Piso Estera / Damp Material/Floor Mat
Guardabarros Cubierta Derecho / Fender Cover Rh
Guardabarros Cubierta Izquierdo / Fender Cover Lh
Cubierta De Montante / Pillar Cover
Guardabarros / Fender
Herramienta Caja / Tool Box
Conducto Aire Acondicionador / Air Conditioner Duct
Condensador / Condenser
Compressor Soporte / Compressor Bracket
Vaciar Manguito / Drain Hose
Etiquetta (Adelante) / Label (Front)
Etiquetta (Panel) / Label (Panel)
Etiquetta (Cabina) / Label (Cab Frame)
Etiquetta (Posterior) [Ec] / Label (Rear) [Ec]
Etiquetta (Posterior) [Ita] / Label (Rear) [Ita]
Superior Silenciador Kit [Opcion] / Upper Muffler Kit [Option]
Kit De Alternador (Alternador) [Opcion] / Alternator Kit (Alternator) [Option]
Kit De Alternador (Instalacion Electrica) [Opcion] / Alternator Kit (Electrical Wiring) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Kit Conmutador (Bomba) [OpciN] / Switch Kit (Pumpa) [Option]
Trasero Desempanador Kit [Opcion] / Rear Defogger Kit [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Tdf Conversion Kit (Engranaje) (540/540e/1000) [Opcion] / Pto Conversion Kit (Gear) (540/540e/1000) [Option]
Tdf Conversion Kit (Palanca) (540/540e/1000) [Opcion] / Pto Conversion Kit (Lever) (540/540e/1000) [Option]
Kit De Distribuidor De Servicios Externos (Fd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Kit De Distribuidor De Servicios Externos (Scd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Kit De Distribuidor De Servicios Externos (S/D Con Fc) [Opcion] / Auxiliary Control Valve Kit (S/D With Fc) [Option]
Distribuidor De Servicios Externos [Componente Piezas] (S/D Con Fc) [Opcion] / Auxiliary Control Valve [Component Parts] (S/D With Fc) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercera) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (4) [Opcion] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (5) [Opcion] / Auxiliary Control Valve Lever Kit (5th) [Option]
Kit De Enganche Delantero (Primero) [Opcion] / Front Coupler Kit (1st) [Option]
Kit De Enganche Delantero (Segundo) [Opcion] / Front Coupler Kit (2nd) [Option]
Kit De Enganche Delantero (Tercero) [Opcion] / Front Coupler Kit (3rd) [Option]
Kit De Enganche Delantero (4) [Opcion] / Front Coupler Kit (4th) [Option]
Kit De Enganche Delantero (5) [Opcion] / Front Coupler Kit (5th) [Option]
Kit De Enganche Delantero (Desage) [Opcion] / Front Coupler Kit (Drain) [Option]
Kit De Drenaje Posterior [Opcion] / Rear Drain Kit [Option]
Kit De Valvulas De Freno De Remolque (Valvula) [Opcion] [Ec] / Traler Brake Valve Kit (Valve) [Option] [Ec]
Kit De Valvulas De Freno De Remolque (Valvula) [Opcion] [Ita] / Traler Brake Valve Kit (Valve) [Option] [Ita]
Kit De Valvulas De Freno De Remolque (Linea De Aceite Hidraulico) [Opcion] [Ds] / Traler Brake Valve Kit (Hydraulic Pipe) [Option] [Ds]
Kit De Valvulas De Freno De Remolque (Acoplador) [Opcion] / Traler Brake Valve Kit (Coupler) [Option]
Montaje De La VLvula De Freno Del Remolque (Soporte) [Opcion] / Trailer Brake Valve Mounting Kit (Bracket) [Option]
Montaje De La VLvula De Freno Del Remolque ((VLvula/TuberA) [Opcion] / Trailer Brake Valve Mounting Kit (Valve/Pipe) [Option]
Montaje De La VLvula De Freno Del Remolque (Acoplador/TuberA) [Opcion] / Trailer Brake Valve Mounting Kit (Coupler/Pipe) [Option]
Montaje De La VLvula De Freno Del Remolque (Electrico Cableado) [Opcion] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Estabilizador [Opcion] / Stabilizer [Option]
Volante / Flywheel
Diagmaster
Ventilador / Fan
Rele / Relay
Tdf Eje / Pto Shaft
