Kubota Tractor M5092HC-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5092HC-EC Tractor
Number of Pages: 334 Pages
Itens Usado S Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Common Rail / Common Rail
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Sepa Rator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cleaner)
Intercooler / Inter Cooler
Flange Filtro Ar E Valvula Acelarador / Air Clea Ner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Suporte (Filtro De Partículas Diesel) / Muffler Bracket (Diesel Particulate Filter)
Tubo Pressao / Pressure Pipe
Panela Escape (Filtro De Partículas Diesel) / Mu Ffler Pipe (Diesel Particulate Filter)
Silenciador Da Redução Catalítica Seletiva / Sel Ective Catalytic Reduction Muffler
Estrutura Da Redução Catalítica Seletiva / Selec Tive Catalytic Reduction Frame
Bomba Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Co Mponentes] / Diesel Exhaust Fluid Tank [Component Parts]
Tampa Da Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank Cover
Depósito Do Fluido De Escape De Diesel Tubo / Di Esel Exhaust Fluid Hose
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Diagmaster / Diagmaster
Deposito Combustivel / Fue L Tank
Suporte Deposito Combustiv El / Fuel Tank Bracket
Porta De Fornecimento De C Ombustível / Fuel Supply Port
Tubo Do Combustível (Enchi Mento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Do Combustível (Bomba Do Combustível/Separador) / Fuel Pipe (Fuel Pump/S Eparator)
Tubo Combustivel (Deposito Combustivel Respiro) / Fuel Pipe (Fuel Tank Breath Er)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compo Nentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filt Er
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panel A Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Frent E) / Switch/Sensor (Front)
Interruptor/Sensor (Trase Ira) / Switch/Sensor (Rear)
Interruptor/Sensor (Carte R Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Quadro Do Pa Inel) / Switch (Panel Board)
Interruptor (Cobertura Do Guarda-Lamas/Tejadilho Interior) / Switch (Fender Cover/Inner Roof)
Interruptor (Direcção) / Switch (Steering)
Interruptor / Rele / Rela Y
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Quadro Do Painel / Panel Board
Luzes Frente / Head Light
Luzes Frente [Peças Compo Nentes] / Head Light [Component Parts]
Luzes Frontais / Front Co Mbination Lamp
Farois Trabalho (Grelha F Rontal) / Work Light (Front Grille)
Farois Trabalho (Cabine) / Work Light (Cab)
Braco Traseiro / Rear Com Bination Lamp
Farol Matricula/Lâmpada F Arol / License Lamp/Beacon Lamp
Ficha Reboque / Trailer S Ocket
Luz Interior / Room Light
Alta Voz Radio / Radio Sp Eaker
Depósito De Lavagem / Was Her Tank
Escova Limpa Vidro Fronta L / Front Wiper
Cablagem Eletrcia (Motor Direito) / Electrical Wiring (Engine Rh)
Cablagem Eletrcia (Motor Esquerdo) / Electrical Wiring (Engine Lh)
Cablagem Eletrcia (Lampad A Cabeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Princ Ipal) Frente / Electrical Wiring (Main) Front
Cablagem Electrica (Princ Ipal) Traseira / Electrical Wiring (Main) Rear
Cablagem Electrica (Corpo ) / Electrical Wiring (Body)
Cablagem Electrica (Cabin E) / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cove R
Valva Dupla Veloci Dades / Dual Speed Valve
Caixa Da Transmiss Ão / Transmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula Alavanca ( Embraiagem/Inversor) / Valve Lever (Clutch)
Kit Embraiagem Hi- Lo [Peças Componentes] / Clutch Pack (Hi-Lo) [Comp Onent Parts]
Veio Inversor / Sh Uttle Shaft
Embraiagem Inverso R [Peças Componentes] / Clutch Pack (Shuttle) [Comp Onent Parts]
Primeiro Veio / Fi Rst Shaft
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Veio De Acionament O / Drive Shaft
Veio Grupo Conico / Bevel Gear Shaft
Diferencial Trasei Ro / Rear Differential
Embraiagem Bloquei O Diferencial Traseiro / Rear Differential Lock Clu Tch
Veio Tdf / Pto Pro Peller Shaft
Embraiagem Tdf [Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Embraiagem Andamen To [Peças Componentes] / Front Drive Clutch [Compon Ent Parts]
Cobertura Da Embra Iagem De Transmissão Frontal / Front Drive Clutch C Over
Forquet A / Main Gear Shift Fork
Forquet A Velocidades / Range Gear Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Le Ver
Alavanc A Tdf / Pto Gear Shift Lever
Alavanc A De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Pedal Bloqueio Diferenc Ial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Ax Le Shaft
Travão / Brake
Alavanca Travao Mao / P Arking Brake Lever
Alavanca De Freio Secun Dária / Secondary Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Travao Princip Al / Brake Master Cylinder
Cilindro Travao Princip Al [Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pip E
Suporte Eixo Frente / Front Axle Bracket
Caixa Diferencial Fr Ente / Front Differential Case
Grupo Conico (Frente ) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens C Onica Drt / Bevel Gear Case Rh
Caixas Engrenagens C Onica Esq / Bevel Gear Case Lh
Carter Eixo Frente D Rt / Front Axle Case Rh
Carter Eixo Frente E Sq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Esq / Fr Ont Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hyd Raulic Pipe (Delivery)
Tubo Hidraulico (Travao R Eboque) (Frente ) / Hydraulic Pipe (Trailer Brake) (Front)
Tubo Hidraulico (Travao R Eboque) (Traseira) / Hydraulic Pipe (Trailer Brake) (Rear)
Valvula Travao Reboque / Trailer Brake Valve
Radiador Oleo / Oil Coole R
Tubo Oleo (Valva Dupla Ve Locidades) / Hydraulic Oil Line (Dual Speed Valve)
Circuito Oleo Direcção (D Irecção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor) / Hy Draulic Oil Line (Shuttle)
Tubo Direccao (Fornecimen To) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidrául Ico / Hydraulic Lift Arm
Valvula Segurança/Descarg A Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Le Ver
Suporte De Controlo De Po Sição / Position Control Bracket
Puxar E Posicionar Alavan Ca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Po Sition And Draft Shaft
Alavanca / Feed Back Leve R
Válvula De Controlo Auxil Iar / Auxiliary Control Valve
Válvula De Controle Alava Nca (Scd) [Peças Componentes] / Auxiliary Control V Alve (Scd) [Component Parts]
Válvula De Controle Alava Nca (Fd) [Peças Componentes] / Auxiliary Control Va Lve (Fd) [Component Parts]
Alavanca De Válvula De Co Ntrolo Auxiliar (1º) / Auxiliary Control Valve Leve R (1st)
Alavanca De Válvula De Co Ntrolo Auxiliar (2º) / Auxiliary Control Valve Leve R (2nd)
Cilindro Auxiliar De Elev Acao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elev Acao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elev Acao [Peças Componentes] [Velho] / 3p-Lift Assist C Ylinder [Component Parts] [Old]
Cilindro Auxiliar De Elev Acao [Peças Componentes] [Novo] / 3p-Lift Assist Cy Linder [Component Parts] [New]
Part E Superior / Top Link Bracket
Liga Cao Inferior / Lower Link
Esta Bilizador / Stabilizer
Esta Bilizador Esq / Lift Rod Lh
Prot Eccao Tdf / Pto Protector
Capot Superior (Isolador) / Hood (Bonnet) ( Insulator)
Lado Do Capot / Bonnet Side
Suporte Capot / Hood (Bonnet) Support
Estrutura Cabine / Cab Frame
Degrau / Step
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro / Side Window
Vidro Traseiro Da Escotilha / Hatch Back Glass
Tecto Interior / Inner Roof
Cobertura Exterior Do Tejadilho / Outer Roof
Składowanie Materiałów/Piso / Damp Material/Floor Mat
Chapa Inspecção / Inspection Plate
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Conditi Oner
Conduta Do Ar Condicionado / Air Conditioner Duct
Modo Caixa / Mode Case
Circulaçao Ar Interior / Inne R Air Recirculation
Tubo Aquecimento / Heater Hos E
Condesador / Condenser
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Suporte Compressor / Compress Or Bracket
Etiqueta (Dianteiro) / Label (Front)
Decalcomania(Painel) / Label (Panel)
Decalcomania (Cabine Interior) / Label (Cab Interior)
Decalcomania (Cabine Exterior) / Label (Cab Exterior)
Peça De Acessorio E Serviço Peças / Accessories And Service Parts
Panela Escape [Opçao] / Under Muffler Kit [Optio N]
Kit Farios Trabalho (Led) [Opção] / Working Ligh T Kit (Led) [Option]
Desempanador (Vidro) [Opção] / Rear Defogger Kit (Glass) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper K It [Option]
Kit De Lubrificaçao Para Terceiro Ponto [Opção] / Lubrication Kit For 3rd Shaft [Option]
Conjunto De Parafusos Para Montagem Da Carcaça D A Embreagem [Opção] / Bolt Kit For Clutch Housing A Ssembly [Option]
Kit Conversao Tdf (540/1000) (Engrenagem Box) [O Pção] / Pto Conversion Kit (540/1000) (Gear Case) [ Option]
Kit Conversao Tdf (540/1000) (Engrenagem) [Opção ] / Pto Conversion Kit (540/1000) (Gear) [Option]
Kit Apoio Peso Frente [Opção] / Front Bumper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção ] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Válvula De Controle Alavanca Kit (Scd) [Peças Co Mponentes] [Opção] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Auxiliar Do Válvula De Controlo (Fd) [Peças Comp Onentes] [Opção] / Auxiliary Control Valve (Fd) [Co Mponent Parts] [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Peças Componentes] [Opção] / Auxiliary Control Valve (Sc D/Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3 Rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [ Opção] / Trailer Brake Valve Mounting Kit (Pipe) [O Ption]
Montagem Da Válvula Do Freio Do Reboque (Valvula ) [Opção] / Trailer Brake Valve Mounting Kit (Valve ) [Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [Opção] / Trailer Brake Valve Mounting Kit (Gasket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablage M Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Banco Passageiro (Banco) [Opção] / Passenger Sea T Kit (Seat) [Option]
Banco Passageiro (Suporte) [Opção] / Passenger S Eat Kit (Bracket) [Option]
Kit De Espelho De Sala [Opção] / Room Mirror Kit [Option]
