Kubota Tractor M5092H Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5092H Tractor
Number of Pages: 293 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
B Raço / Rocker Arm Shaft
T Ampa Cabeça / Head Cover
C Arreto / Gear Case
P Iston E Cambota / Piston And Crankshaft
C Ompensador / Balancer
V Olante Motor / Flywheel
B Omba De Abastecimento / Supply Pump
T Ubo Injector / Injection Pipe
C Ommon Rail / Common Rail
B Omba Agua / Water Pump
R Adiador Oleo / Oil Cooler
S Eparador De Óleo / Oil Separator
S Eparador De Óleo [Peças Componentes] / Oil Separato R [Component Parts]
T Ubo Do Separador De Óleo / Oil Separator Pipe
T Ubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charg Er)
F Iltro Ar / Air Cleaner
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cle Aner)
T Urbo Compressor / Turbo Charger
I Ntercooler / Inter Cooler
F Lange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
C Olector Escape / Exhaust Manifold
P Anela Escape / Muffler Pipe
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
S Uporte (Filtro De Partículas Diesel) / Muffler Brac Ket (Diesel Particulate Filter)
T Ubo Pressao / Pressure Pipe
P Anela Escape (Filtro De Partículas Diesel) / Muffle R Pipe (Diesel Particulate Filter)
S Ilenciador Da Redução Catalítica Seletiva / Selecti Ve Catalytic Reduction Muffler
E Strutura Da Redução Catalítica Seletiva / Selective Catalytic Reduction Frame
B Omba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
D Epósito Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Tank
D Epósito Do Fluido De Escape De Diesel [Peças Compon Entes] / Diesel Exhaust Fluid Tank [Component Parts ]
T Ampa Da Depósito Do Fluido De Escape De Diesel / Di Esel Exhaust Fluid Tank Cover
D Epósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
C Omponentes Electricos Motor (Sensor/Ecu) / Engine E Lectrical Parts (Sensor/Ecu)
C Omponentes Electricos Motor (Panela Escape) / Engin E Electrical Parts (Muffler)
C Ablagem Injector / Injector Harness
D Iagmaster / Diagmaster
A Celarador Mao / Accelerator Lever
P Edal Acelarador / Accelerator Pedal
T Irante Do Acelerador / Accelerator Rod
Deposito Combustivel / Fuel Ta Nk
Suporte Deposito Combustivel / Fuel Tank Bracket
Porta De Fornecimento De Combu Stível / Fuel Supply Port
Tubo Combustivel (Deposito Com Bustivel Respiro) / Fuel Pipe (Fuel Tank Breather)
Separador / Separator
Bomba Gasoleo / Fuel Pump
Filtro Gasoleo / Fuel Filter
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Mot Or) / Switch/Sensor (Engine)
Interruptor/Sensor (Panela Es Cape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Frente ) / Switch/Sensor (Front)
Interruptor/Sensor (Traseira) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter Em Braiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Quadro Do Painel ) / Switch (Panel Board)
Interruptor (Direcção) / Swit Ch (Steering)
Interruptor (Cobertura De Mud Ança) / Switch (Shift Cover)
Interruptor / Rele / Relay
Unidade Control Electrico (Bl Oco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Co Rpo) / Electronic Control Unit (Body)
Quadro Do Painel / Panel Boar D
Luzes Frente / Head Light
Luzes Frente [Peças Component Es] / Head Light [Component Parts]
Luzes Frontais / Front Combin Ation Lamp
Farois Trabalho (Grelha Front Al) / Work Light (Front Grille)
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula / License Lam P
Ficha Reboque / Trailer Socke T
Cablagem Electrica (Frente Dr T) / Electrical Wiring (Front Rh)
Cablagem Electrica (Frente Es Q) / Electrical Wiring (Front Lh)
Cablagem Eletrcia (Lampada Ca Beça) / Electrical Wiring (Head Light)
Cablagem Electrica (Traseira) / Electrical Wiring (Rear)
Carter Embraiagem / Cl Utch Housing
Valvula Inversor / Shu Ttle Valve
Tampa / Shift Cover
Caixa Da Transmissão / Transmission Case
Carter Transmissao / T Ransmission Case Rear Cover
Carter Eixo / Rear Axl E Case
Disco Amortecedor / Da Mper Disk
Pedal Embraiagem / Clu Tch Pedal
Cabo Embraiagem / Clut Ch Cable
Valvula Alavanca (Embr Aiagem/Inversor) / Valve Lever (Clutch)
Veio Primario / Input Shaft
Embraiagem Inversor [P Eças Componentes] / Clutch Pack (Shuttle) [Componen T Parts]
Veio Inversor / Shuttl E Shaft
Primeiro Veio / First Shaft
Secundario Veio / Seco Nd Shaft
Terceiro Veio / Third Shaft
Veio Creeper / Creep S Haft
Veio De Acionamento / Drive Shaft
Veio Grupo Conico / Be Vel Gear Shaft
Diferencial Traseiro / Rear Differential
Embraiagem Bloqueio Di Ferencial Traseiro / Rear Differential Lock Clutch
Veio Tdf / Pto Propell Er Shaft
Embraiagem Tdf / Pto C Lutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Component Parts]
Veio Tdf / Pto Shaft
Embraiagem Andamento / Front Drive Clutch
Cobertura Da Embraiage M De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Ve Locidades / Range Gear Shift Fork
Alavanca Ve Locidades / Main Gear Shift Lever
Tirante / M Ain Gear Shift Rod
Alvanca Inv Ersor / Shuttle Shift Lever
Gama E Tira Nte Caixa Creep / Range And Creep Gear Shift Lever
Alavanca De Mudança De Velocidades De Tomada De Força Tdf / Pt O Gear Shift Rod
Pedal Bloqueio Diferencial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle S Haft
Travão / Brake
Veio Bloqueio / Parking Bra Ke Camshaft
Alavanca Travao Mao / Parki Ng Brake Lever
Pedal Travao / Brake Pedal
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [ Peças Componentes] / Brake Master Cylinder [Compone Nt Parts]
Tubo Travao / Brake Pipe
Quadro Eixo Frente / Fro Nt Axle Frame
Suporte Eixo Frente / Fr Ont Axle Bracket
Veio Primario / Propelle R Shaft
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Dif Ferential Front
Caixas Engrenagens Conic A Drt / Bevel Gear Case Rh
Caixas Engrenagens Conic A Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Esq / Front Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Ste Ering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cyl Inder
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico [Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Tampa Bomba Hidráulica / Hydr Aulic Pump Cover
Tubo Oleo (Entrega) / Hydraul Ic Pipe (Delivery)
Tubo Hidraulico (Travao Reboq Ue) (Frente ) / Hydraulic Pipe (Trailer Brake) (Front)
Tubo Hidraulico (Travao Reboq Ue) (Traseira) / Hydraulic Pipe (Trailer Brake) (Re Ar)
Valvula Travao Reboque / Trai Ler Brake Valve
Radiador Oleo / Oil Cooler
Circuito Oleo Direcção (Direc Ção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor) / Hydrau Lic Oil Line (Shuttle)
Tubo Direccao (Fornecimento) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / H Ydraulic Cylinder Case
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Valvula Segurança/Descarga Va Lvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Lever
Valvula Control / Control Val Ve
Suporte De Controlo De Posiçã O / Position Control Bracket
Puxar E Posicionar Alavanca D E Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Positi On And Draft Shaft
Alavanca / Feed Back Lever
Válvula De Controlo Auxiliar / Auxiliary Control Valve
Válvula De Controle Alavanca (Fd) [Peças Componentes] / Auxiliary Control Valve (Fd) [Component Parts]
Alavanca De Válvula De Contro Lo Auxiliar (1º) / Auxiliary Control Valve Lever (1 St)
Alavanca De Válvula De Contro Lo Auxiliar (2º) / Auxiliary Control Valve Lever (2 Nd)
Cilindro Auxiliar De Elevacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevacao [Peças Componentes] [Velho] / 3p-Lift Assist Cylin Der [Component Parts] [Old]
Cilindro Auxiliar De Elevacao [Peças Componentes] [Novo] / 3p-Lift Assist Cylind Er [Component Parts] [New]
Parte Su Perior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link
Estabili Zador / Stabilizer
Estabili Zador Drt / Lift Rod Rh
Estabili Zador Esq / Lift Rod Lh
Protecca O Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) (Insu Lator)
Lado Do Capot / Bonnet Side
Suporte Capot / Hood (Bonnet) Support
Capot Traseiro / Hood (Bonnet) Rear (Sound Abso Rber)
Guarda Lamas / Fender
Piso / Floor Sheet
Piso (Silenciador/Isolante) / Floor Sheet (Soun Dproof Material/Sound Absorber)
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Caixa Ferramenta / Tool Box
Caobertura / Guard
Estr Utura De Protecção (Frente) / Rops (Upper)
Estr Utura De Protecção (Traseira) / Rops (Lower)
Etiqueta (Dianteiro) / Label (Front)
Etiqueta (Traseiros) / Label (Rear)
P Eça De Acessorio E Serviço Peças / Accessories And Service Parts
P Anela Escape [Opçao] / Upper Muffler Kit [Option]
K It Farios Trabalho [Opção] / Working Light Kit [Opt Ion]
K It De Lubrificaçao Para Terceiro Ponto [Opção] / Lu Brication Kit For 3rd Shaft [Option]
C Onjunto De Parafusos Para Montagem Da Carcaça Da Em Breagem [Opção] / Bolt Kit For Clutch Housing Assem Bly [Option]
K It Conversao Tdf (540/1000) (Engrenagem Box) [Opção ] / Pto Conversion Kit (540/1000) (Gear Case) [Opti On]
K It Conversao Tdf (540/1000) (Engrenagem) [Opção] / Pto Conversion Kit (540/1000) (Gear) [Option]
K It Apoio Peso Frente [Opção] / Front Bumper Kit [Op Tion]
V Álvula De Controle Alavanca Kit (Scd) [Opção] / Aux Iliary Control Valve Kit (Scd) [Option]
V Álvula De Controle Alavanca Kit (Fd) [Opção] / Auxi Liary Control Valve Kit (Fd) [Option]
V Álvula De Controle Alavanca Kit (Fc) [Opção] / Auxi Liary Control Valve Kit (Fc) [Option]
V Álvula De Controle Alavanca Kit (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
V Álvula De Controle Alavanca Kit (Scd) [Peças Compon Entes] [Opção] / Auxiliary Control Valve (Scd) [Com Ponent Parts] [Option]
V Álvula De Controle Alavanca Kit (Fc) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Fc) [Compo Nent Parts] [Option]
V Álvula De Controle Alavanca Kit (Scd/Fc) [Peças Com Ponentes] [Opção] / Auxiliary Control Valve (Scd/Fc ) [Component Parts] [Option]
A Uxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
M Ontagem Da Válvula Do Freio Do Reboque (Tubo) [Opçã O] / Trailer Brake Valve Mounting Kit (Pipe) [Optio N]
M Ontagem Da Válvula Do Freio Do Reboque (Valvula) [O Pção] / Trailer Brake Valve Mounting Kit (Valve) [O Ption]
M Ontagem Da Válvula Do Freio Do Reboque (Junta) [Opç Ão] / Trailer Brake Valve Mounting Kit (Gasket) [Op Tion]
M Ontagem Da Válvula Do Freio Do Reboque (Cablagem El Ectrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
