Kubota Tractor M5091UNC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5091UNC Tractor
Number of Pages: 347 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaus T Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Bomba Agua / Water Pump
Flange Filtro Ar E Valvula Acelarador / Air Cleane R Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Compo Nent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air C Leaner)
Panela Escape (Silenciador Do Filtro De Partículas Diesel) / Muffler Pipe (Diesel Particulate Filter Muffler)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Diese L Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [C Omponent Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Cha Rger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Motor/Ecu) / Engine Electrical Parts (Engine/Ecu)
Componentes Electricos Motor (Panela Escape Sensor ) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combustivel / Fuel Tank Bracket
Fornecimento Combustivel / F Uel Supply
Tubo Combustivel (Enchimento ) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Bomba/Sepa Rador) / Fuel Pipe (Fuel Pump/Separator)
Tubo Combustivel (Deposito C Ombustivel Respiro) / Fuel Pipe (Fuel Tank Breather )
Tubo Combustivel (Arrefecedo R Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Componentes ] / Separator [Component Parts]
Filtro Gasoleo / Fuel Filter
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito R Eserva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Peças Compo Nentes] / Starter [Component Parts]
Interruptor/Sensor (Bloco M Otor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panela Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Capot ) / Switch/Sensor (Bonnet)
Interruptor/Sensor (Travão ) / Switch/Sensor (Brake)
Interruptor/Sensor (Traseir A) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Quadro Do Pain El) / Switch (Panel Board)
Comutador (Painel) / Switch (Panel)
Rele / Relay
Unidade Control Electrico ( Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico ( Corpo) / Electrical Control Unit (Body)
Quadro Do Painel / Panel Bo Ard
Luzes Frente / Head Light
Luzes Frente [Peças Compone Ntes] / Head Light [Component Parts]
Luzes Frontais / Front Comb Ination Light
Farois Trabalho (Grelha Fro Ntal) / Working Light (Front Grille)
Farois Trabalho (Cabine) / Work Light (Cab)
Braco Traseiro / Rear Combi Nation Light
Farol Matricula / License L Amp
Ficha Reboque / Trailer Soc Ket
Luz Interior / Room Light
Alta Voz Radio / Radio Spea Ker
Depósito De Lavagem / Washe R Tank
Escova Limpa Vidro Frontal / Front Wiper
Cablagem Eletrcia (Motor Di Reito) / Electrical Wiring (Engine Rh)
Cablagem Eletrcia (Motor Es Querdo) / Electrical Wiring (Engine Lh)
Cablagem Eletrcia (Lampada Cabeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Princip Al) Frente / Electrical Wiring (Main) Front
Cablagem Electrica (Princip Al) Traseira / Electrical Wiring (Main) Rear
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Cablagem Electrica (Cabine) / Electrical Wiring (Cab)
Valvula Inversor / S Huttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Valva Dupla Velocida Des / Dual Speed Valve
Caixa Da Transmissão / Transmission Case
Carter Transmissão / Transmission Case Rear Cover
Carter Eixo / Rear A Xle Case
Disco Amortecedor / Damper Disk
Pedal Embraiagem / C Lutch Pedal
Cabo Embraiagem / Cl Utch Cable
Valvula Alavanca (Em Braiagem) / Valve Lever (Clutch)
Veio Primario / Inpu T Shaft
Kit Embraiagem (Hi-L O) [Peças Componentes] / Clutch Pack (Hi-Lo) [Comp Onent Parts]
Veio Inversor / Shut Tle Shaft
Embraiagem Inversor (Inversor) [Peças Componentes] / Clutch Pack (Shutt Le) [Component Parts]
Primeiro Veio / Firs T Shaft
Secundario Veio / Se Cond Shaft
Terceiro Veio / Thir D Shaft
Veio Creeper / Creep Shaft
Veio De Acionamento / Drive Shaft
Grupo Conico / Bevel Gear
Embraiagem Bloqueio Diferencial Traseiro / Rear Differential Lock Clutc H
Veio Tdf / Pto Prope Ller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peça S Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem T Df / Pto Clutch Valve
Embraiagem Andamento / Front Drive Clutch
Embraiagem Andamento [Peças Componentes] / Front Drive Clutch [Componen T Parts]
Cobertura Da Embraia Gem De Transmissão Frontal / Front Drive Clutch Cov Er
Forqueta Velocidades / Range Gear Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Alvanca I Nversor / Shuttle Shift Lever
Gama Alav Anca De Velocidades / Range Gear Shift Lever
Alavanca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Pedal Bloqueio Diferencia L Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle Shaft
Travão / Brake
Veio Bloqueio / Parking B Rake Camshaft
Alavanca Travão Mao / Par King Brake Lever
Travão De Estacionamento / Secondary Brake
Pedal Travao / Brake Peda L
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compo Nent Parts]
Tubo Travao / Brake Pipe
Quadro Eixo Frente / F Ront Axle Frame
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Front Propeller Shaft
Caixa Diferencial Fren Te / Front Differential Case
Grupo Conico Frente / Bevel Gear Front
Diferencial Frente / D Ifferential Front
Caixas Engrenagens Con Ica Drt / Bevel Gear Case Rh
Caixas Engrenagens Con Ica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Dr T / Differential Gear Shaft Rh
Carreto Diferencial Es Q / Differential Gear Shaft Lh
Eixo Frente Drt / Fron T Axle Rh
Eixo Frente Esq / Fron T Axle Lh
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / S Teering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering C Ylinder
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico [Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hydra Ulic Pipe (Delivery)
Tubo Hidraulico (Travao Reb Oque) Frente / Hydraulic Pipe (Trailer Brake) Front
Tubo Hidraulico (Travao Reb Oque) Traseiro / Hydraulic Pipe (Trailer Brake) Rea R
Valvula Travao Reboque / Tr Ailer Brake Valve
Oleo Radiador / Oil Cooler
Tubo Oleo (Valva Dupla Velo Cidades) / Hydraulic Oil Line (Dual Speed Valve)
Circuito Oleo Direcção (Dir Ecção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direcção (Entrega) / S Teering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidráulic O / Hydraulic Lift Arm
Valvula Segurança/Descarga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Leve R
Valvula Control / Control V Alve
Puxar E Posicionar Alavanca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Posi Tion And Draft Shaft
Válvula De Controlo Auxilia R / Auxiliary Control Valve
Valvula Auxiliar (Scd) [Peç As Componentes] / Auxiliary Control Valve (Scd) [Co Mponent Parts]
Valvula Auxiliar (Fd) [Peça S Componentes] / Auxiliary Control Valve (Fd) [Comp Onent Parts]
Alavanca De Válvula De Cont Rolo Auxiliar (1.º) / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Control Au Xiliar (2.º) / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Elevac Ao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevac Ao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevac Ao [Peças Componentes] [Velho] / 3p-Lift Assist Cyl Inder [Component Parts] [Old]
Cilindro Auxiliar De Elevac Ao [Peças Componentes] [Novo] / 3p-Lift Assist Cyli Nder [Component Parts] [New]
Parte Superior / Top Link Bracket
Ligaca O Superior / Top Link
Ligaca O Inferior / Lower Link
Estabi Lizador / Stabilizer
Estabi Lizador Drt / Lift Rod Rh
Estabi Lizador Esq / Lift Rod Lh
Protec Cao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) (In Sulator)
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
E Strutura Cabine / Cab Frame
D Egrau / Step
C Apot Traseira (Cabine) / Hood (Bonnet) Rear (Cab)
V Idro Frente / Front Glass
P Orta Drt / Door Rh
P Orta Esq / Door Lh
T Rinco Porta Drt / Door Lock Rh
V Idro Traseiro Da Escotilha / Hatch Back Glass
T Ecto Interior / Inner Roof
T Ecto Abrir / Outer Roof
P Iso Tapete / Floor Mat
C Hapa Inspecção / Inspection Plate
C Obertura Guarda Lamas Drt / Fender Cover Rh
C Obertura Gurada Lamas Esq / Fender Cover Lh
G Uarda Lamas / Fender
S Uporte Cabine Frente / Cab Bracket Front
S Uporte Cabine Traseira / Cab Bracket Rear
C Aixa Ferramenta / Tool Box
Ar Condicionado / Air Condition Er
Tubo Ar Condicionado / Air Cond Itioner Duct
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaçao Ar Interior / Inner Air Recirculation
Condesador / Condenser
Tubo Ar Condicionado/Tubo Conde Nsador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Suporte Compressor / Compressor Bracket
Etiqueta (Frontal) / Label (Front)
Etiqueta (Painel) / Label (Panel)
Etiqueta (Cabine Interior) / Label (Cab Interi Or)
Etiqueta (Cabine Exterior) / Label (Cab Exteri Or)
Peça De Acessorio E Serviço Peças / Accessories An D Service Parts
Panela Escape [Opção] / Under Muffler Kit [Option]
Kit Farios Trabalho [Opção] / Working Light Kit [O Ption]
Desempanador (Vidro) [Opção] / Rear Defogger Kit ( Glass) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Kit [Option]
Kit De Lubrificaçao Para Terceiro Ponto [Opção] / Lubrication Kit For 3rd Shaft [Option]
Conjunto De Parafusos Para Montagem Da Carcaça Da Embreagem [Opção] / Bolt Kit For Clutch Housing Ass Embly [Option]
Kit Conversao Tdf (Engrenagem Box) (540/1000) [Opç Ão] / Pto Conversion Kit (Gear Case) (540/1000) [Op Tion]
Kit Conversao Tdf (Carreto) (540/1000) [Opção] / P To Conversion Kit (Gear) (540/1000) [Option]
Kit Apoio Peso Frente [Opção] / Front Bumper Kit [ Option]
Kit Valvula Control Auxiliar (Scd) [Opção] / Auxil Iary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fd) [Opção] / Auxili Ary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opção] / Auxili Ary Control Valve Kit (Fc) [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Opção] / Au Xiliary Control Valve Kit (Scd/Fc) [Option]
Kit Valvula Control Auxiliar (Scd) [Peças Componen Tes] [Opção] / Auxiliary Control Valve (Scd) [Compo Nent Parts] [Option]
Kit Valvula Control Auxiliar (Fd) [Peças Component Es] [Opção] / Auxiliary Control Valve (Fd) [Compone Nt Parts] [Option]
Kit Valvula Control Auxiliar (Fc) [Peças Component Es] [Opção] / Auxiliary Control Valve (Fc) [Compone Nt Parts] [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Peças Compo Nentes] [Opção] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3 ª) [Opção] / Auxiliary Control Valve Lever Kit (3rd ) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [Op Ção] / Trailer Brake Valve Mounting Kit (Pipe) [Opt Ion]
Montagem Da Válvula Do Freio Do Reboque (Valvula) [Opção] / Trailer Brake Valve Mounting Kit (Valve) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablagem Electrica) [Opção] / Trailer Brake Valve Mounting K It (Electrical Wiring) [Option]
Banco Passageiro (Banco) [Opção] / Instructional S Eat Kit (Seat) [Option]
Kit De Espelho De Sala [Opção] / Room Mirror Kit [ Option]
Carreto / Gear Case
Ventoinha / Fan
Rele / Relay
Tampa / Shift Cover
Travão / Brake
D Egrau / Step
