Kubota Tractor M5091UN Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5091UN Tractor
Number of Pages: 313 Pages
Itens Usados F Requentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Flange Filtro Ar / Air Cleaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [Compon Ent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cl Eaner)
Panela Escape (Silenciador Do Filtro De Partículas Diesel) / Muffler Pipe (Diesel Particulate Filter M Uffler)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peças C Omponentes] / Diesel Particulate Filter Muffler [Co Mponent Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Char Ger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Motor/Ecu) / Engine E Lectrical Parts (Engine/Ecu)
Componentes Electricos Motor (Panela Escape Sensor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combustivel / Fuel Tank Bracket
Fornecimento Combustivel / Fu El Filler
Tubo Combustivel / Fuel Pipe
Tubo Combustivel (Enchimento) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Bomba/Separ Ador) / Fuel Pipe (Fuel Pump/Separator)
Separador / Separator
Filtro Gasoleo / Fuel Filter
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito Re Serva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Compon Entes] / Starter [Component Parts]
Interruptor/Sensor (Bloco Mo Tor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panela E Scape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Capot ) / Switch/Sensor (Bonnet)
Interruptor/Sensor (Travão ) / Switch/Sensor (Brake)
Interruptor/Sensor (Traseira ) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter E Mbraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Quadro Do Paine L) / Switch (Panel Board)
Rele / Relay
Unidade Control Electrico (B Loco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (C Orpo) / Electrical Control Unit (Body)
Quadro Do Painel / Panel Boa Rd
Luzes Frente / Head Light
Luzes Frente [Peças Componen Tes] / Head Light [Component Parts]
Luzes Frontais / Front Combi Nation Lamp
Farois Trabalho (Grelha Fron Tal) / Work Light (Front Grille)
Braco Traseiro / Rear Combin Ation Lamp
Farol Matricula / License La Mp
Ficha Reboque / Trailer Sock Et
Cablagem Electrica (Frente D Rt) / Electrical Wiring (Front Rh)
Cablagem Electrica (Frente E Sq) / Electrical Wiring (Front Lh)
Cablagem Eletrcia (Lampada C Abeça) / Electrical Wiring (Head Light)
Cablagem Electrica (Traseira ) / Electrical Wiring (Rear)
Carter Embraiagem / C Lutch Housing
Valvula Inversor / Sh Uttle Valve
Carretos Inversor / S Huttle Gear Case
Tampa / Shift Cover
Caixa Da Transmissão / Transmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Ax Le Case
Disco Amortecedor / D Amper Disk
Cabo Embraiagem / Clu Tch Cable
Valvula Alavanca (Emb Raiagem) / Valve Lever (Clutch)
Veio Primario / Input Shaft
Kit Embraiagem Hi-Lo [Peças Componentes] / Clutch Pack (Hi-Lo) [Compone Nt Parts]
Veio Inversor / Shutt Le Shaft
Primeiro Veio / First Shaft
Secundario Veio / Sec Ond Shaft
Terceiro Veio / Third Shaft
Veio Creeper / Creep Shaft
Veio De Acionamento / Drive Shaft
Diferencial Traseiro / Rear Differential
Embraiagem Bloqueio D Iferencial Traseiro / Rear Differential Lock Clutch
Veio Tdf / Pto Propel Ler Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Td F / Pto Clutch Valve
Valvula Embraiagem Td F [Peças Componentes] / Pto Clutch Valve [Component Parts]
Embraiagem Andamento / Front Drive Clutch
Embraiagem Andamento [Peças Componentes] / Front Drive Clutch [Component Parts]
Cobertura Da Embraiag Em De Transmissão Frontal / Front Drive Clutch Cove R
Forqueta V Elocidades / Range Gear Shift Fork
Alavanca V Elocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Alvanca In Versor / Shuttle Shift Lever
Gama E Tir Ante Caixa Creep / Range And Creep Gear Shift Lever
Alavanca T Df / Pto Gear Shift Lever
Pedal Bloqueio Diferencial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle Shaft
Travão / Brake
Veio Bloqueio / Parking Br Ake Camshaft
Alavanca Travão Mao / Park Ing Brake Lever
Travão De Estacionamento / Secondary Brake
Pedal Travao / Brake Pedal
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compon Ent Parts]
Tubo Travao / Brake Pipe
Quadro Eixo Frente / Fr Ont Axle Frame
Suporte Eixo Frente / F Ront Axle Bracket
Veio Do Propulsor Frent E / Front Propeller Shaft
Caixa Diferencial Frent E / Front Differential Case
Grupo Conico Frente / B Evel Gear Front
Diferencial Frente / Di Fferential Front
Caixas Engrenagens Coni Ca Drt / Bevel Gear Case Rh
Caixas Engrenagens Coni Ca Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Esq / Front Axle Lh
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / St Eering Controller [Component Parts]
Suporte Da Direção / Steering Support
Rotula/Cilindro Direcção / Tie Rod/Steering Cy Linder
Cilindro Direcção [Peças Componentes] / Steeri Ng Cylinder [Component Parts]
Bomba Hidraulico [Peças Comp Onentes] / Hydraulic Pump [Component Parts]
Tampa Bomba Hidráulica [Velh O] / Hydraulic Pump Cover [Old]
Tampa Bomba Hidráulica [Novo ] / Hydraulic Pump Cover [New]
Tubo Oleo (Entrega) / Hydrau Lic Pipe (Delivery)
Tubo Hidraulico (Travao Rebo Que) (Frente) / Hydraulic Pipe (Trailer Brake) (Fro Nt)
Tubo Hidraulico (Travao Rebo Que) (Traseiro) / Hydraulic Pipe (Trailer Brake) (R Ear)
Valvula Travao Reboque / Tra Iler Brake Valve
Oleo Radiador / Oil Cooler
Circuito Oleo Direcção (Dire Cção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor) / Hydra Ulic Oil Line (Shuttle)
Tubo Direccao (Fornecimento) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Valvula Segurança/Descarga V Alvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Lever
Valvula Control / Control Va Lve
Puxar E Posicionar Alavanca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Posit Ion And Draft Shaft
Alavanca / Feed Back Lever
Válvula De Controlo Auxiliar / Auxiliary Control Valve
Valvula Auxiliar (Scd) [Peça S Componentes] / Auxiliary Control Valve (Scd) [Com Ponent Parts]
Valvula Auxiliar (Fd) [Peças Componentes] / Auxiliary Control Valve (Fd) [Compo Nent Parts]
Alavanca De Válvula De Contr Olo Auxiliar (1º) / Auxiliary Control Valve Lever ( 1st)
Alavanca Valvula Control Aux Iliar (2.º) / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Elevaca O Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevaca O Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevaca O [Peças Componentes] [Velho] / 3p-Lift Assist Cyli Nder [Component Parts] [Old]
Cilindro Auxiliar De Elevaca O [Peças Componentes] [Novo] / 3p-Lift Assist Cylin Der [Component Parts] [New]
Parte S Uperior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link
Estabil Izador Drt / Lift Rod Rh
Estabil Izador Esq / Lift Rod Lh
Protecc Ao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Isolador) / Hood (Bonnet) (Ins Ulator)
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Capot Traseiro(Isolante) / Hood(Bonnet) Rear ( Sound Absorber)
Guarda Lamas / Fender
Piso / Floor Sheet
Piso (Silenciador/Isolante) / Floor Sheet (Sou Ndproof Material/Insulator)
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Caixa Ferramenta / Tool Box
Caobertura / Guard
Est Rutura De Protecção (Superior) / Rops (Upper)
Est Rutura De Protecção (Inferior) / Rops (Lower)
Etiqueta (Dianteiro) / Label (Front)
Etiqueta (Traseiros) / Label (Rear)
Peça De Acessorio E Serviço Peças / Accessories And Service Parts
Panela Escape [Opçao] / Upper Muffler Kit [Option]
Kit Farios Trabalho [Opção] / Working Light Kit [Op Tion]
Conjunto De Parafusos Para Montagem Da Carcaça Da E Mbreagem [Opção] / Bolt Kit For Clutch Housing Asse Mbly [Option]
Kit Conversao Tdf (Engrenagem Box) (540/1000) [Opçã O] / Pto Conversion Kit (Gear Case) (540/1000) [Opt Ion]
Kit Conversao Tdf (Engrenagem) (540/1000) (Opção) / Pto Conversion Kit (Gear) (540/1000) [Option]
Kit Apoio Peso Frente [Opção] / Front Bumper Kit [O Ption]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Au Xiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Aux Iliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Aux Iliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Auxiliar Do Válvula De Controlo (Fd) [Peças Compone Ntes] [Opção] / Auxiliary Control Valve (Fd) [Compo Nent Parts] [Option]
Válvula De Controle Alavanca Kit (Fc) [Peças Compon Entes] [Opção] / Auxiliary Control Valve (Fc) [Comp Onent Parts] [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Peças Co Mponentes] [Opção] / Auxiliary Control Valve (Scd/F C) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª ) [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [Opç Ão] / Trailer Brake Valve Mounting Kit (Pipe) [Opti On]
Montagem Da Válvula Do Freio Do Reboque (Valvula) [ Opção] / Trailer Brake Valve Mounting Kit (Valve) [ Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [Op Ção] / Trailer Brake Valve Mounting Kit (Gasket) [O Ption]
Montagem Da Válvula Do Freio Do Reboque (Cablagem E Lectrica) [Opção] / Trailer Brake Valve Mounting Ki T (Electrical Wiring) [Option]
Carreto / Gear Case
Ventoinha / Fan
Rele / Relay
Tampa / Shift Cover
Travão / Brake
Piso / Floor Sheet
Degrau / Step
Banco / Seat
Caobertura / Guard
