Kubota Tractor M5091NC-PC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5091NC-PC Tractor
Number of Pages: 633 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Engranaje Caja / Gear Case
Compensador / Balancer
Volante / Flywheel
Carril Comun / Common Rail
Agua Bomba / Water Pump
Aire Limpiador Brida / Air Cleaner Flange And Throttle Valve
Valvula De Egr / Egr Valve
Aire Limpiador / Air Cleaner
Tubo De Entrada (Filtro De Aire) / Inlet Pipe (Air Cleaner)
Tubería / Muffler Pipe
Soporte Del Muflfer / Muffler Bracket
Piezas Electricas Del Motor (Silencioso Sensor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster
Varilla Acelerador / Accelerator Rod
Combustible Deposito Soporte / Fuel Tank Bracket
Deposito De Combustible Derecho / Fuel Tank Rh
Deposito De Combustible Izquierdo / Fuel Tank Lh
Llenador Del Combustible [Antiguo] / Fuel Supply [Old]
Llenador Del Combustible [Nuevo] / Fuel Supply [New]
Tubo De Combustible (Deposito Combustible) / Fuel Pipe (Fuel Tank)
Tubo De Combustible (Bomba De Combustible/Separador) / Fuel Pipe (Fuel Pump/Separator)
Tubo De Combustible (Deposito Combustible Respiradero) [Antiguo] / Fuel Pipe (Fuel Tank Breather) [Old]
Tubo De Combustible (Deposito Combustible Respiradero) [Nuevo] / Fuel Pipe (Fuel Tank Breather) [New]
Separador / Separator
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Silencioso) / Switch/Sensor (Muffler)
Conmutador/Sensor (Adelante) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) / Switch/Sensor (Rear)
Conmutador/Sensor (Embrague Carcasa) / Switch/Sensor (Clutch Housing)
Conmutador (Panel Tablero) [Antiguo] / Switch (Panel Board) [Old]
Conmutador (Panel Tablero) [Nuevo] / Switch (Panel Board) [New]
Conmutador (Interno Techo) / Switch (Inner Roof)
Conmutador (Lado Panel) / Switch (Side Panel)
Rele / Relay
Unidad De Control Electronico (Cuerpo) / Electronic Control Unit (Body)
Tablero De Instrumentos / Panel
Faro Delantero / Head Light
Trabajo Luz / Working Light
Luz Matricula / License Lamp
Limpiador Delantero / Front Wiper
Instalacion Electrica (Crs) / Electrical Wiring (Crs)
Instalacion Electrica (Motor) / Electrical Wiring (Engine)
Instalacion Electrica (Principal) / Electrical Wiring (Main)
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Instalacion Electrica (Cabina) / Electrical Wiring (Cab)
Manguera Del Respiradero (Transmision Caja) / Breather Hose (Transmission Case)
Cubierta De La Caja Del Eje Trasero / Rear Axle Case Cover
Cable De Embrague / Clutch Cable
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Entrada Eje / Input Shaft
Paquete Del Embrague (Hi-Lo) [Componente Piezas] / Clutch Pack (Hi-Lo) [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Propulsor / Drive Shaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Valvula De Embrague De Tdf [Componente Piezas] / Pto Clutch Valve [Component Parts]
Tdf Eje / Pto Shaft
Adelante Accionar Embrague [Componente Piezas] / Front Drive Clutch [Component Parts]
Embrague Hidraulico [Componente Piezas] / Hydraulic Clutch (Bi-Speed Turn) [Component Parts]
Palanca Cambio Inversor [Antiguo] / Shuttle Shift Lever [Old]
Palanca Cambio Inversor [Nuevo] / Shuttle Shift Lever [New]
Varilla De Cambios De Engranajes De La Tdf / Pto Gear Shift Rod
Trasero Eje / Rear Axle
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Arbol De Levas Del Freno De Estacionamiento / Parking Brake Camshaft
Eje De Freno De Estacionamiento / Parking Brake Shaft
Palanca De Freno Secundario / Secondary Brake Lever
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Caja De Engranaje Conico Derecho / Bevel Gear Case Rh
Caja De Engranaje Conico Izquierdo / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Cubierta Del Poste De Manejo / Steering Post Cover
Distribuidor De Direccion [Componente Piezas] / Steering Controller [Component Parts]
Atar Varilla/Cilindro De Direccion / Tie Rod/Steering Cylinder
Hidraulico Aceite Linea (Direccion/Tdf) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea (Inversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Brazo De Elevacion / Hydraulic Lift Arm
Distribuidor / Control Valve
Soporte De Control De Posicion [Nuevo] / Position Control Bracket [New]
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Montaje De Distribuidor De Servicios Externos / Auxiliary Control Valve Mounting Base
Distribuidor De Servicios Externos (Fd Con Fc/Scd Con Fc) / Auxiliary Control Valve (Fd With Fc/Scd With Fc)
Auxiliary Control Valve Mirada [Componente Piezas] / Auxiliary Control Valve Mounting Base [Component Parts]
Auxiliar Control Válvula [Componente Piezas] (Fd Con Fc) / Auxiliary Control Valve [Component Parts] (Fd With Fc)
Auxiliar Control Válvula [Componente Piezas] (Scd Con Fc) / Auxiliary Control Valve [Component Parts] (Scd With Fc)
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Auxiliar Control Control De Flujo De Cable / Auxiliary Control Flow Control Wire
Cilindro De Ayuda De Elevacion Izquierdo [Antiguo] / 3p-Lift Assist Cylinder Lh [Old]
Cilindro De Ayuda De Elevacion Izquierdo [Nuevo] / 3p-Lift Assist Cylinder Lh [New]
Cilindro De Ayuda De Elevacion Derecho [Antiguo] / 3p-Lift Assist Cylinder Rh [Old]
Cilindro De Ayuda De Elevacion Derecho [Nuevo] / 3p-Lift Assist Cylinder Rh [New]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Antiguo] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Nuevo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Manguera Del Respiradero (Cilindro De Ayuda De Elevacion) / Breather Hose (3p Cylinder)
Bajar Vinculo [Antiguo] / Lower Link [Old]
Bajar Vinculo [Nuevo] / Lower Link [New]
Varilla De Elevacion Derecho / Lift Rod Rh
Varilla De Elevacion Izquierdo / Lift Rod Lh
Barra De Remolque Oscilante [Antiguo] / Swinging Drawbar [Old]
Barra De Remolque Oscilante [Nuevo] / Swinging Drawbar [New]
Tdf Protector / Pto Protector
Capo / Hood (Bonnet) Upper
Capo Superior (Amortiguador Sano/Aislador) / Hood (Bonnet) (Sound Absorber/Insulator)
Capo Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte / Hood (Bonnet) Support
Cabina Bastidor [Antiguo] / Cab Frame [Old]
Cabina Bastidor [Nuevo] / Cab Frame [New]
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izquierdo / Door Lh
Cerradura De Puerta Derecho / Door Lock Rh
Lado Ventana Derecho / Side Window Rh
Lado Ventana Izquierdo / Side Window Lh
Trasero Ventana / Hatch Back Glass
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Soporte Del Asiento / Seat Bracket
Amortiguamiento Material/Piso Estera / Damp Material/Floor Mat
Guardabarros Cubierta Derecho / Fender Cover Rh
Guardabarros Cubierta Izquierdo / Fender Cover Lh
Cubierta De Montante / Pillar Cover
Guardabarros / Fender
Herramienta Caja / Tool Box
Conducto Aire Acondicionador / Air Conditioner Duct
Condensador / Condenser
Compressor Soporte / Compressor Bracket
Vaciar Manguito / Drain Hose
Estructura Del Lado Derecho (Power Crawler) / Frame Rh (Power Crawler)
Estructura Del Lado Izquierdo (Power Crawler) / Frame Lh (Power Crawler)
Soporte Para Sacudidas Del Lado Derecho (Power Crawler) / Shaking Bracket Rh (Power Crawler)
Soporte Para Sacudidas Del Lado Izquierdo (Power Crawler) / Shaking Bracket Lh (Power Crawler)
Rueda Loca Del Lado Derecho (Power Crawler) / Idler Rh (Power Crawler)
Rueda Loca Del Lado Izquierdo (Power Crawler) / Idler Lh (Power Crawler)
Rodillo Guía Del Lado Derecho (Power Crawler) / Truck Roller Rh (Power Crawler)
Rodillo Guía Del Lado Izquierdo (Power Crawler) / Truck Roller Lh (Power Crawler)
Rueda Dentada Y Oruga (Power Crawler) / Sppocket And Crawler (Power Crawler)
Etiquetta (Adelante) / Label (Front)
Etiquetta (Panel) / Label (Panel)
Etiquetta (Cabina) / Label (Cab Frame)
Etiquetta (Trasero) [Antiguo] / Label (Rear) [Old]
Etiquetta (Trasero) [Nuevo] / Label (Rear) [New]
Accesorio Y Pieza De Servicio / Accessories And Service Parts
Superior Silenciador Kit [Opcion] / Upper Muffler Kit [Option]
Kit De Alternador (Alternador) [Opcion] / Alternator Kit (Alternator) [Option]
Kit De Alternador (Instalacion Electrica) [Opcion] / Alternator Kit (Wire Harness) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Trasero Desempanador Kit [Opcion] / Rear Defogger Kit [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Tdf Conversion Kit (Engranaje) (540/540e/1000) [Opcion] / Pto Conversion Kit (Gear) (540/540e/1000) [Option]
Tdf Conversion Kit (Palanca) (540/540e/1000) [Opcion] / Pto Conversion Kit (Lever) (540/540e/1000) [Option]
Kit De Distribuidor De Servicios Externos (Fd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Kit De Distribuidor De Servicios Externos (Scd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Kit De Distribuidor De Servicios Externos (S/D Con Fc) [Opcion] / Auxiliary Control Valve Kit (S/D With Fc) [Option]
Distribuidor De Servicios Externos [Componente Piezas] (S/D Con Fc) [Opcion] / Auxiliary Control Valve [Component Parts] (S/D With Fc) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercera) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (4) [Opcion] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (5º) [Opcion] / Auxiliary Control Valve Lever Kit (5th) [Option]
Kit De Enganche Delantero (Primero) [Opcion] / Front Coupler Kit (1st) [Option]
Kit De Enganche Delantero (Segundo) [Opcion] / Front Coupler Kit (2nd) [Option]
Kit De Enganche Delantero (Tercero) [Opcion] / Front Coupler Kit (3rd) [Option]
Kit De Enganche Delantero (4º) [Opcion] / Front Coupler Kit (4th) [Option]
Kit De Enganche Delantero (5º) [Opcion] / Front Coupler Kit (5th) [Option]
Kit De Enganche Delantero (Desagüe) [Opcion] / Front Coupler Kit (Drain) [Option]
Kit De Drenaje Posterior [Opcion] / Rear Drain Kit [Option]
Kit De Valvulas De Freno De Remolque (Valvula) [Opcion] / Traler Brake Valve Kit (Valve) [Option]
Kit De Valvulas De Freno De Remolque (Linea De Aceite Hidraulico) [Opcion] / Traler Brake Valve Kit (Hydraulic Pipe) [Option]
Kit De Valvulas De Freno De Remolque (Acoplador) [Opcion] / Traler Brake Valve Kit (Coupler) [Option]
Estabilizador [Opción] / Stabilizer [Option]
Volante / Flywheel
Diagmaster
Ventilador / Fan
Rele / Relay
Tdf Eje / Pto Shaft
