Kubota Tractor M5091NC-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5091NC-EC Tractor
Number of Pages: 405 Pages
Itens Usado S Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Common Rail / Common Rail
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Thrott Le Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro Ar) / Inlet Pipe (Air Cl Eaner)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape Sens Or) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combustiv El / Fuel Tank Bracket
Deposito Combustivel Drt / Fuel Tank Rh
Fornecimento Combustivel [ Ec] / Fuel Supply [Ec]
Fornecimento Combustivel [ Ita] / Fuel Supply [Ita]
Tubo Combustivel (Deposito Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Combustivell (Enchime Nto Do Combustivel) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Bomba Do Combustivel/Separador) / Fuel Pipe (Fuel Pump/Sepa Rator)
Tubo Combustivel (Deposito Combustivel Respiro) [Antiga] / Fuel Pipe (Fuel Ta Nk Breather) [Old]
Tubo Combustivel (Deposito Combustivel Respiro) [Nova] / Fuel Pipe (Fuel Tank Breather) [New]
Tubo Combustivel (Arrefece Dor Gasoleo) [Ec] / Fuel Pipe (Fuel Cooler) [Ec]
Tubo Combustivel (Arrefece Dor Gasoleo) [Ita] / Fuel Pipe (Fuel Cooler) [Ita]
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Filtro Gasoleo / Fuel Filt Er
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panel A Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Frent E) / Switch/Sensor (Front)
Interruptor/Sensor (Trase Ira) [Ec] / Switch/Sensor (Rear) [Ec]
Interruptor/Sensor (Trase Ira) [Ita] / Switch/Sensor (Rear) [Ita]
Interruptor/Sensor (Carte R Embraiagem) [Ec] / Switch/Sensor (Clutch Housing) [Ec]
Interruptor/Sensor (Carte R Embraiagem) [Ita] / Switch/Sensor (Clutch Housing ) [Ita]
Interruptor (Painel) / Sw Itch (Panel Board)
Interruptor (Tecto Interi Or) / Switch (Inner Roof)
Interruptor (Lado Panel) / Switch (Side Panel)
Relé / Relay
Relé [Ita] / Relay [Ita]
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Painel [Antiga] / Panel [ Old]
Painel [Nova] / Panel [Ne W]
Luzes Frente [Ec] / Head Light [Ec]
Luzes Frente [Ita] / Head Light [Ita]
Luzes Frente [Peças Compo Nentes] / Head Light [Component Parts]
Luzes Frontais / Front Co Mbination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Com Bination Lamp
Farol Matricula/Lâmpada F Arol / License Lamp/Beacon Lamp
Ficha Reboque / Trailer S Ocket
Luz Interior / Room Light
Alta Voz Radio / Radio Sp Eaker
Depósito De Lavagem [Ec] / Washer Tank [Ec]
Depósito De Lavagem [Ita] / Washer Tank [Ita]
Escova Limpa Vidro Fronta L / Front Wiper
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Eletrcia (Princi Pal/Motor) [Ec] / Electrical Wiring (Main/Engine) [ Ec]
Cablagem Eletrcia (Princi Pal/Motor) [Ita] / Electrical Wiring (Main/Engine) [Ita]
Cablagem Electrica (Princ Ipal) [Ec] / Electrical Wiring (Main) [Ec]
Cablagem Electrica (Princ Ipal) [Ita] / Electrical Wiring (Main) [Ita]
Cablagem Electrica (Corpo ) [Ds] [Ec] / Electrical Wiring (Body) [Ds] [Ec]
Cablagem Electrica (Corpo ) [Ds] [Ita] / Electrical Wiring (Body) [Ds] [Ita]
Cablagem Electrica (Cabin E) [Ec] / Electrical Wiring (Cab) [Ec]
Cablagem Electrica (Cabin E) [Ita] / Electrical Wiring (Cab) [Ita]
Carter Embraiagem [Ds] [Ec] / Clutch Housing [Ds] [Ec]
Carter Embraiagem [Ds] [Ita] / Clutch Housing [Ds] [Ita]
Valvula Inversor / Shuttle Valve
Carretos Inversor [Ds] / Shuttle Gear Case [Ds]
Tampa / Shift Cove R
Valva Dupla Veloci Dades [Ds] / Dual Speed Valve [Ds]
Caixa Da Transmiss Ão [Ec] / Transmission Case [Ec]
Caixa Da Transmiss Ão [Ita] / Transmission Case [Ita]
Mangueira De Respi Ro (Caixa Velocidades) / Breather Hose (Transmissio N Case)
Carter Transmissao [Ec] / Transmission Case Rear Cover [Ec]
Carter Transmissao [Ita] / Transmission Case Rear Cover [Ita]
Carter Eixo / Rear Axle Case
Disco Amortecedor [Ds] / Damper Disk [Ds]
Disco Amortecedor [Exceto [Ds]] / Damper Disk [Except [Ds]]
Cabo Embraiagem / Clutch Cable
Valvula Alavanca ( Embraiagem) / Valve Lever (Clutch)
Primeiro Veio [Ds] / First Shaft [Ds]
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Veio De Acionament O / Drive Shaft
Grupo Conico [Ec] / Bevel Gear [Ec]
Grupo Conico [Ita] / Bevel Gear [Ita]
Diferencial Trasei Ro / Rear Differential
Veio Tdf / Pto Pro Peller Shaft
Embraiagem Tdf [Ec ] / Pto Clutch [Ec]
Embraiagem Tdf [It A] / Pto Clutch [Ita]
Embraiagem Tdf [Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compon Ent Parts]
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Embraiagem Andamen To [Peças Componentes] / Front Drive Clutch [Compon Ent Parts]
Embraiagem Hidraul Ica [Peças Componentes] / Hydraulic Clutch (Bi-Spee D Turn) [Component Parts]
Forquet A / Main Gear Shift Fork
Forquet A Velocidades / Range Gear Shift Fork
Forquil Ha Tdf [Ita] / Ground Pto Shift Fork [Ita]
Bloquei O Diferencial De Forqueta / Differential Lock Shift Fork
Alavanc A Velocidades [Ds] [Ec] / Main Gear Shift Lever [Ds ] [Ec]
Alavanc A Velocidades [Ds] [Ita] / Main Gear Shift Lever [D S] [Ita]
Tirante / Main Gear Shift Rod
Alvanca Inversor [Ec] / Shuttle Shift Lever [Ec]
Alvanca Inversor [Ita] / Shuttle Shift Lever [Ita]
Alavanc A Velocidades [Ec] / Range Gear Shift Lever [Ec]
Alavanc A Velocidades [Ita] / Range Gear Shift Lever [Ita]
Alavanc A De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Alavanc A [Ita] / Ground Pto Shift Lever [Ita]
Eixo Traseiro / Rear Ax Le
Travao Drt / Brake Rh
Travao Esq / Brake Lh
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / P Arking Brake Lever
Alavanca De Freio Secun Dária / Secondary Brake Lever
Pedal Travao [Ec] / Bra Ke Pedal [Ec]
Pedal Travao [Ita] / Br Ake Pedal [Ita]
Cilindro Travao Princip Al / Brake Master Cylinder
Cilindro Travao Princip Al [Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pip E
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Prop Eller Shaft
Caixa Diferencial Fr Ente / Front Differential Case
Grupo Conico (Frente ) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens C Onica Drt / Bevel Gear Case Rh
Caixas Engrenagens C Onica Esq / Bevel Gear Case Lh
Carter Eixo Frente D Rt / Front Axle Case Rh
Carter Eixo Frente E Sq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Drt / Fr Ont Axle Rh
Eixo Frente Esq / Fr Ont Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta Direcção / Steering Joint
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] [Ec] / Hydraulic Pump [Component Parts] [Ec]
Bomba Hidraulico [Peças C Omponentes] [Ita] / Hydraulic Pump [Component Parts ] [Ita]
Tubo Oleo (Entrega) / Hyd Raulic Pipe (Delivery)
Radiador Oleo [Antiga] / Oil Cooler [Old]
Radiador Oleo [Nova] / Oi L Cooler [New]
Circuito Oleo Direcção (V Alva Dupla Velocidades) [Ds] / Hydraulic Oil Line ( Dual Speed Valve) [Ds]
Circuito Oleo Direcção (D Irecção/Tdf) [Ds] / Hydraulic Oil Line (Steering/Pt O) [Ds]
Circuito Oleo Direcção (I Nversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidrául Ico / Hydraulic Lift Arm
Valvula Segurança/Descarg A Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Le Ver
Puxar E Posicionar Alavan Ca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Po Sition And Draft Shaft
Alavanca / Feed Back Leve R
Base De Montagem Da Válvu La De Controlo Auxiliar / Auxiliary Control Valve M Ounting Base
Válvula De Controle Alava Nca (Fd Com Fc/Scd Com Fc) / Auxiliary Control Valv E (Fd With Fc/Scd With Fc)
Base De Montagem Da Válvu La De Controlo Auxiliar [Peças Componentes] / Auxil Iary Control Valve Mounting Base [Component Parts]
Válvula De Controle Alava Nca [Peças Componentes] (Fd Com Fc) / Auxiliary Con Trol Valve [Component Parts] (Fd With Fc)
Válvula De Controle Alava Nca [Peças Componentes] (Scd Com Fc) / Auxiliary Co Ntrol Valve [Component Parts] (Scd With Fc)
Alavanca Valvula Control Auxiliar / Auxiliary Control Valve Lever
Fluir Fio De Controle Da Auxiliar Do Valvula De Controlo / Auxiliary Control Flow Control Wire
Cilindro Auxiliar De Elev Acao Esq [Antiga] / 3p-Lift Assist Cylinder Lh [Old ]
Cilindro Auxiliar De Elev Acao Esq [Nova] / 3p-Lift Assist Cylinder Lh [New]
Cilindro Auxiliar De Elev Acao Drt [Antiga] / 3p-Lift Assist Cylinder Rh [Old ]
Cilindro Auxiliar De Elev Acao Drt [Nova] / 3p-Lift Assist Cylinder Rh [New]
Cilindro Auxiliar De Elev Acao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Mangueira De Respiro (3p Cilindro) / Breather Hose (3p Cylinder)
Part E Superior / Top Link Bracket
Liga Cao Superior / Top Link
Liga Cao Inferior [Antiga] / Lower Link [Old]
Liga Cao Inferior [Nova] / Lower Link [New]
Esta Bilizador Drt / Lift Rod Rh
Esta Bilizador Esq / Lift Rod Lh
Barr A De Engate Oscilante [Antiga] / Swinging Drawbar [ Old]
Barr A De Engate Oscilante [Nova] / Swinging Drawbar [Ne W]
Prot Eccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / Hood (Bonnet) (Sound Absorber/Insulator)
Capot Lateral [Ec] / Hood (Bonnet) Side Cov Er [Ec]
Capot Lateral [Ita] / Hood (Bonnet) Side Co Ver [Ita]
Suporte Capot / Hood (Bonnet) Support
Estrutura Cabine [Ec] / Cab Frame [Ec]
Estrutura Cabine [Ita] / Cab Frame [Ita]
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro Drt / Side Window Rh
Lado Vidro Esq / Side Window Lh
Vidro Traseiro / Hatch Back Glass
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Suporte Do Assento / Seat Bracket
Składowanie Materiałów/Piso / Damp Material/Floor Mat
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Resguardo Coluna / Pillar Cover
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Conditi Oner
Tubo Ar Condicionado / Air Co Nditioner Duct
Tubo Aquecimento / Heater Hos E
Condesador / Condenser
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Suporte Compressor / Compress Or Bracket
Mangueira De Drenagem / Drain Hose
Etiqueta (Painel) / Label (Panel)
Etiqueta (Cabine) / Label (Cab Frame)
Etiqueta (Traseira) [Ec] / Label (Rear) [Ec]
Etiqueta (Traseira) [Ita] / Label (Rear) [It A]
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Panela Escape [Opçao] / Upper Muffler Kit [Optio N]
Alternador Kit (Alternador) [Opção] / Alternator Kit (Alternator) [Option]
Alternador Kit (Cablagem Electrica) [Opção] / Al Ternator Kit (Electrical Wiring) [Option]
Alternador [Peças Componentes] [Opção] / Alterna Tor [Component Parts] [Option]
Kit Interruptor (Bomba) [Opção] / Switch Kit (Pu Mpa) [Option]
Desempanador [Opção] / Rear Defogger Kit [Option ]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper K It [Option]
Kit Conversao Tdf (Carreto) (540/540e/1000) [Opç Ão] / Pto Conversion Kit (Gear) (540/540e/1000) [Op Tion]
Kit Conversao Tdf (Palanca) (540/540e/1000) [Opç Ão] / Pto Conversion Kit (Lever) (540/540e/1000) [O Ption]
Válvula De Controle Alavanca Kit (Fd Con Fc) [Op Ção] / Auxiliary Control Valve Kit (Fd With Fc) [Op Tion]
Válvula De Controle Alavanca Kit (Scd Con Fc) [O Pção] / Auxiliary Control Valve Kit (Scd With Fc) [ Option]
Válvula De Controle Alavanca Kit (S/D Con Fc) [O Pção] / Auxiliary Control Valve Kit (S/D With Fc) [ Option]
Válvula De Controle Alavanca [Peças Componentes] (S/D Con Fc) [Opção] / Auxiliary Control Valve [Co Mponent Parts] (S/D With Fc) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3 Rd) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (4ª) [Opção] / Auxiliary Control Valve Lever Kit (4 Th) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (5ª) [Opção] / Auxiliary Control Valve Lever Kit (5 Th) [Option]
Kit De Engate Dianteiro (1ª) [Opção] / Front Cou Pler Kit (1st) [Option]
Kit De Engate Dianteiro (2ª) [Opção] / Front Cou Pler Kit (2nd) [Option]
Kit De Engate Dianteiro (3ª) [Opção] / Front Cou Pler Kit (3rd) [Option]
Kit De Engate Dianteiro (4ª) [Opção] / Front Cou Pler Kit (4th) [Option]
Kit De Engate Dianteiro (5ª) [Opção] / Front Cou Pler Kit (5th) [Option]
Kit De Engate Dianteiro (Dreno) [Opção] / Front Coupler Kit (Drain) [Option]
Conjunto De Drenagem Traseira [Opção] / Rear Dra In Kit [Option]
Kit De Válvula Do Travão Do Reboque (Valvula) [O Pção] [Ec] / Traler Brake Valve Kit (Valve) [Option ] [Ec]
Kit De Válvula Do Travão Do Reboque (Valvula) [O Pção] [Ita] / Traler Brake Valve Kit (Valve) [Optio N] [Ita]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo) [Opção] [Ds] / Traler Brake Valve Kit (Hydraulic Pi Pe) [Option] [Ds]
Kit De Válvula Do Travão Do Reboque (Acoplamento ) [Opção] / Traler Brake Valve Kit (Coupler) [Optio N]
Montagem Da Válvula Do Freio Do Reboque (Valvula /Tubo) [Opção] / Trailer Brake Valve Mounting Kit ( Valve/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Acoplad Or/Tubo) [Opção] / Trailer Brake Valve Mounting Kit (Coupler/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablage M Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Estabilizador [Opção] / Stabilizer [Option]
Carreto / Gear Case
Ventoinh A / Fan
Relé / Relay
Porta Drt / Door Rh
Porta Esq / Door Lh
