Kubota Tractor M5091HC Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M5091HC Tractor
Number of Pages: 690 Pages
Engine 400000 Crankcase
Engine 401000 Oil Pan
Engine 402000 Cylinder Head
Engine 403000 Inlet Valve And Exhaust ValveValve
Engine 404000 Rocker Arm Shaft
Engine 405000 Head Cover
Engine 408000 Gear Case
Engine 411000 Piston Crankshaft Piston Crankshaft
Engine 412000 Camshaft And Idle Gear Shaft
Engine 413000 Balancer
Engine 415000 Flywheel
Engine 420000 Fuel Filter
Engine 421000 Supply Pump
Engine 426000 Injection Pipe
Engine 428000 Common Rail
Engine 430000 Water Flange And Thermostat Thermostat
Engine 431000 Water Pump
Engine 435000 Oil Cooler
Engine 436000 Oil Separator
Engine 436300 Oil Separator Component Parts Oil
Engine 436500 Oil Separator Pipe
Engine 437000 Oil Pipe (Turbo Charger)
Engine 440001 Air Cleaner Air Cleaner
Engine 440500 Air Cleaner Component Parts
Engine 441500 Inlet Pipe (Air Cleaner) Inlet Pipe (Air Cleaner)
Engine 442000 Turbo Charger
Engine 443001 Inter Cooler Inter Cooler
Engine 444000 Inlet Manifold
Engine 445000 Air Cleaner Flange And Throttle Valve
Engine 446000 EGR Valve
Engine 447000 EGR Cooler
Engine 450000 Exhaust Manifold
Engine 452000 Muffler Pipe
Engine 455000 Diesel Particulate Filter Muffler
Engine 455500 Diesel Particulate Filter Muffler Component Parts Filter
Engine 457500 Pressure Pipe
Engine 459000 Muffler Pipe (Diesel Particulate Filter)
Engine 460000 Selective Catalytic Reduction Muffler Reduction
Engine 462000 Selective Catalytic Reduction Frame Reduction
Engine 470000 Diesel Exhaust Fluid Pump Diesel
Engine 471000 Diesel Exhaust Fluid Tank Diesel
Engine 471500 Diesel Exhaust Fluid Tank Component Parts Diesel
Engine 472000 Diesel Exhaust Fluid Hose
Engine 495000 Engine Electrical Parts (Engine ECu) Engine Electrical Parts (
Engine 496000 Engine Electrical Parts (Muffler) (
Engine 497000 Injector Harness
Engine 499000 Diagmaster
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Engine A04000 Accelerator Rod Accelerator Rod
Fuel System A11001 Fuel Tank
Fuel System A11501 Fuel Tank Bracket
Fuel System A13500 Fuel Supply Fuel Supply
Fuel System A14100 Fuel Pipe (Fuel Filter)
Fuel System A14200 Fuel Pipe (Fuel Pump Separator) Fuel Pipe (Fuel Pump
Fuel System A14300 Fuel Pipe (Fuel Tank Breather)
Fuel System A14400 Fuel Pipe (Fuel Cooler)Cooler)
Fuel System A15100 Separator
Fuel System A16100 Separator Component Parts
Fuel System A16500 Fuel Pump Fuel Pump
Fuel System A16600 Fuel Pump Component Parts
Cooling Water System A41000 Fan
Cooling Water System A42000 Water Pipe Water Pipe
Cooling Water System A43000 Radiator
Cooling Water System A45000 Reserve Tank Reserve Tank
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter Starter
Electrical System A57000 Starter Component Parts
Electrical System A58000 Battery
Electrical System B00100 Switch Sensor (Engine) Switch Sensor
Electrical System B00200 Switch Sensor (Muffler) Switch Sensor
Electrical System B01101 Switch Sensor (Bonnet) Switch Sensor
Electrical System B01500 Switch Sensor (Brake) Switch Sensor
Electrical System B02001 Switch Sensor (Rear) Switch Sensor
Electrical System B03001 Switch Sensor (Clutch Housing) Switch Sensor
Electrical System B10500 Switch (Panel Board) Switch (Panel
Electrical System B11000 Switch (Panel) Switch (Panel)
Electrical System B13000 Relay Relay
Electrical System B13300 Electronic Control Unit (Engine) Electronic
Electrical System B13400 Electronic Control Unit (Body) Electronic
Electrical System B14000 Panel Board Panel Board
Electrical System B32000 Head Light
Electrical System B32100 Head Light Component Parts Head Light
Electrical System B33901 Front Combination Light Front Combination
Electrical System B35000 Working Light (Front Grille) Working Light (
Electrical System B35100 Work Light (Cab) Work Light (Cab)
Electrical System B36001 Rear Combination Light Rear Combination
Electrical System B36501 License Lamp Beacon Lamp License Lamp
Electrical System B37000 Trailer Socket Trailer
Electrical System B41000 Room Light Room Light
Electrical System B42501 Radio Speaker
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44100 Front Wiper Front Wiper
Electrical System B50501 Electrical Wiring (Engine Rh) Electrical
Electrical System B50601 Electrical Wiring (Engine Lh) Electrical Wiring
Electrical System B50700 Electrical Wiring (Head Light) Electrical Wiring
Wiring (Main) Front Old Electrical Wiring (Main) Front Old Chassis No. 52244 S.No. 52244 Note Order By
Electrical System B51002 Electrical Wiring (Main) Front New Electrical Wiring (Main) Front New
Wiring (Main) Rear Old Electrical Wiring (Main) Rear Old Chassis No. 52244 S.No. 52244 Note Order By Fig.
Electrical System B51102 Electrical Wiring (Main) Rear New Electrical Wiring (Main) Rear New Chassis
Electrical System B51501 Electrical Wiring (Body) Electrical Wiring
Electrical System B52001 Electrical Wiring (Cab) Electrical Wiring
Clutch Transmission C11001 Clutch Housing Housing
Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Transmission C11300 Shuttle Gear Case Gear
Clutch Transmission C12500 Shift Cover
Clutch Transmission C12700 Dual Speed Valve Dual Speed
Clutch Transmission C14001 Transmission Case
Clutch Transmission C15001 Transmission Case Rear Cover Transmission
Clutch Transmission C17001 Rear Axle Case
Clutch Transmission C22000 Damper Disk
Clutch Transmission C24000 Clutch Pedal
Clutch Transmission C26000 Clutch Cable Clutch Cable
Clutch Transmission C26500 Valve Lever (Clutch) Valve Lever
Clutch Transmission D21200 Input Shaft
Clutch Transmission D21300 Clutch Pack (Hi-Lo) Component Parts Clutch Pack
Clutch Transmission D21700 Shuttle Shaft
Clutch Transmission D21800 Clutch Pack (Shuttle) Component Parts Clutch Pack
Clutch Transmission D22500 First Shaft
Clutch Transmission D22700 Second Shaft
Clutch Transmission D23500 Third Shaft
Clutch Transmission D25600 Creep Shaft
Clutch Transmission D25800 Drive Shaft Drive Shaft
Clutch Transmission D26001 Bevel Gear Bevel Gear
Clutch Transmission D26200 Rear Differential Rear
Clutch Transmission D26300 Rear Differential Lock Clutch Rear Differential
Clutch Transmission D26500 PTO Propeller Shaft
Clutch Transmission D26601 PTO Clutch
Clutch Transmission D26700 PTO Clutch Component Parts
Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Transmission D26900 PTO Clutch Valve Component Parts
Clutch Transmission D27501 PTO Shaft PTO Shaft
Clutch Transmission D35001 Front Drive Clutch Front Drive
Clutch Transmission D35201 Front Drive Clutch Component Parts Front Drive
Clutch Transmission D35300 Front Drive Clutch Cover Front Drive
Speed Change Shift Fork D41000 Main Gear Shift Fork
Speed Change Shift Fork D43000 Range Gear Shift Fork
Speed Change Shift Fork F11001 Main Gear Shift Lever
Speed Change Shift Fork F11500 Main Gear Shift
Speed Change Shift Fork F12501 Shuttle Shift Lever
Speed Change Shift Fork F13600 Range Gear Shift Lever
Speed Change Shift Fork F15000 PTO Gear Shift Lever
Speed Change Shift Fork F15100 PTO Gear Shift Rod
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle Shaft Rear Axle Shaft
Rear Axle Brake F20501 Brake Brake
Rear Axle Brake F21500 Parking Brake Camshaft Parking Brake
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23000 Secondary Brake Secondary Brake
Rear Axle Brake F23501 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master
Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33000 Brake Pipe Brake Pipe
Front Axle Chassis G10500 Front Axle Frame
Front Axle Chassis G11000 Front Axle Bracket Front Axle
Front Axle Chassis G14000 Front Propeller Shaft Front Propeller
Front Axle Chassis G15000 Front Differential Case Front Differential
Front Axle Chassis G16000 Bevel Gear (Front) Bevel Gear (
Front Axle Chassis G17000 Differential Front Differential
Front Axle Chassis G22100 Bevel Gear Case Rh Case
Front Axle Chassis G22200 Bevel Gear Case Lh Case
Front Axle Chassis G22300 Front Axle Case Rh Front Axle Case
Front Axle Chassis G22400 Front Axle Case Lh Front Axle Case
Front Axle Chassis G22800 Differential Gear Shaft Rh Differential
Front Axle Chassis G22900 Differential Gear Shaft Lh Differential
Front Axle Chassis G24100 Front Axle Rh Front Axle Rh
Front Axle Chassis G24200 Front Axle Lh Front Axle Lh
Steering H11000 Steering Handle
Steering H11300 Steering Post Cover Steering Post Cover
Steering H12000 Tilt Pedal Tilt Pedal
Steering H13000 Steering Joint Steering Joint
Steering H14000 Steering Controller
Steering H15001 Steering Controller Component Parts
Steering H16000 Tie Rod Steering Cylinder Cylinder
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13000 Hydraulic Pump Pump
Hydraulic System J13501 Hydraulic Pump Component Parts Pump
Hydraulic System J22001 Hydraulic Pipe (Delivery) Hydraulic Pipe (
Hydraulic System J22300 Hydraulic Pipe (Trailer Brake) (Front) Hydraulic Pipe
Hydraulic System J23500 Hydraulic Pipe (Trailer Brake) (Rear) Hydraulic Pipe
Hydraulic System J23700 Trailer Brake Valve Trailer Brake
Hydraulic System J26500 Oil Cooler
Hydraulic System J27301 Hydraulic Oil Line (Dual Speed Valve) Hydraulic Oil
Hydraulic System J27501 Hydraulic Oil Line (Steering PTO) Hydraulic Oil
Hydraulic System J27601 Hydraulic Oil Line (Shuttle PTO) Hydraulic Oil
Hydraulic System J28000 Steering Hose (Delivery) Steering Hose (
Hydraulic System J30801 Hydraulic Cylinder Case Old Hydraulic Cylinder Case Old Chassis No.
Hydraulic System J30802 Hydraulic Cylinder Case New Hydraulic Cylinder Case New Chassis No.
Hydraulic System J31500 Lift Arm Lift Arm
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32300 Lowering Lock Lever Lowering Lock
Hydraulic System J35500 Control Valve Control Valve
Hydraulic System J38000 Draft And Position Control Lever Draft And Position
Hydraulic System J38200 Position And Draft Shaft Position And
Hydraulic System J39200 Feed Back Lever Feed Back Lever
Hydraulic System J44501 Auxiliary Control Valve Old Auxiliary Control Valve Old Chassis No.
Hydraulic System J44503 Auxiliary Control Valve New Auxiliary Control Valve New Chassis No.
System Hydraulic System J44701 Auxiliary Control Valve (SCD) Component Parts Auxiliary Control
System Hydraulic System J44702 Auxiliary Control Valve (FD) Component Parts Auxiliary Control
Hydraulic System J45400 Auxiliary Control Valve Lever (1st) Auxiliary Control
Hydraulic System J45500 Auxiliary Control Valve Lever (2nd) Auxiliary Control
Hydraulic System J47101 3p-Lift Assist Cylinder Lh 3p-Lift Assist
Hydraulic System J47201 3p-Lift Assist Cylinder Rh 3p-Lift Assist
Hydraulic System J47300 3p-Lift Assist Cylinder Component Parts 3p-Lift Assist
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K10500 Top Link Bracket Top
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K11000 Top Link Top
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K12500 Lower Link Lower
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K13300 Stabilizer
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K14000 Lift Rod Rh Lift
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K14300 Lift Rod Lh Lift
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch L17000 PTO Shaft Protector Pto
Hood Bonnet M11001 Front Grille Front Grille
Hood Bonnet M12000 Hood (Bonnet) Upper Hood (Bonnet) Upper
Hood Bonnet M12100 Hood (Bonnet) (Insulator) Hood (Bonnet) (Insulator)
Hood Bonnet M12300 Hood (Bonnet) Damper Hood (Bonnet) Damper
Hood Bonnet M12400 Hood (Bonnet) Lock Hood (Bonnet) Lock
Hood Bonnet M12500 Bonnet Side Bonnet Side
Hood Bonnet M12700 Hood (Bonnet) Side Cover Hood (Bonnet) Side
Hood Bonnet M14001 Bonnet Support
Cab N11001 Cab Frame Cab Frame
Cab N11401 Step
Cab N11700 Hood (Bonnet) Rear
Cab N12000 Front Glass Front Glass
Cab N12500 Door Rh
Cab N13000 Door Lh
Cab N13500 Door Lock Rh
Cab N14000 Door Lock Lh
Cab N14500 Side Window Side Window
Cab N15000 Rear Window
Cab N16000 Inner Roof
Cab N16500 Outer Roof
Cab N17501 Damp Material Floor Mat Damp Material Floor Mat
Cab N18001 Inspection Plate Inspection Plate
Cab N21000 Fender Cover Rh Fender Cover Rh
Cab N21500 Fender Cover Lh
Cab N22400 Fender Fender
Cab N24000 Cab Bracket Front
Cab N24501 Cab Bracket Rear
Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P14000 Air Conditioner Duct Air Conditioner
Air Conditioner P14100 Mode Case Mode Case
Air Conditioner P14300 Dashboard Air Outlets
Air Conditioner P14700 Inner Air Recirculation
Air Conditioner P15000 Heater Hose
Air Conditioner P15500 Condenser
Air Conditioner P15700 Air Conditioner Hose Condenser Hose
Air Conditioner P16000 Compressor (Air Conditioner) Compressor (Air
Air Conditioner P16500 Compressor Bracket Compressor Bracket
Labels S11000 Label (Front)
Labels S12000 Label (Panel) Label (Panel)
Labels S13001 Label (Cab Interior) Label (Cab Interior)
Labels S14001 Label (Cab Exterior) Label (Cab Exterior)
Accessories And Service Parts T11001 Accessories And Service Parts Old Accessories And Service
T11002 Accessories And Service Parts New Accessories And Service Parts New Chassis No. 53014 S.
Option U05000 Under Muffler Kit Option Under Muffler Kit Option
Option U07901 Diesel Exhaust Fluid Tank Cover Kit (Cover) Option Diesel Exhaust Fluid Tank
Option U07902 Diesel Exhaust Fluid Tank Cover Kit (Insulation) Option Diesel Exhaust Fluid Tank
Option U13000 Working Light Kit Option
Option U18200 Rear Defogger Kit (Glass) Option Rear Defogger Kit (Glass)
Option U19000 Rear Wiper Kit Option Rear Wiper Kit Option
Option U27200 Lubrication Kit For 3rd Shaft Option Lubrication Kit For 3rd Shaft
Option U27300 Bolt Kit For Clutch Housing Assembly Option Bolt Kit For Clutch Housing
Option U35000 PTO Conversion Kit (Gear Case) (540 1000) Option PTO Conversion Kit (Gear
Option U35100 PTO Conversion Kit (Gear) (540 1000) Option PTO Conversion Kit (Gear) (
Option U35200 PTO Conversion Kit (Gear) (540 1000) Option PTO Conversion Kit (Gear) (
Option U52500 Front Bumper Kit Option Front Bumper Kit Option
Option U70001 Auxiliary Control Valve Kit (SCD) Option Auxiliary Control Valve Kit
Option U70002 Auxiliary Control Valve Kit (FD) Option Auxiliary Control Valve Kit
Option U70003 Auxiliary Control Valve Kit (FC) Option Auxiliary Control Valve Kit
Option U70004 Auxiliary Control Valve Kit (SCD FC) Option Auxiliary Control Valve Kit
Option U70501 Auxiliary Control Valve (SCD) Component Parts Option Auxiliary Control Valve (
Option U70502 Auxiliary Control Valve (FD) Component Parts Option Auxiliary Control Valve (
Option U70503 Auxiliary Control Valve (FC) Component Parts Option Auxiliary Control Valve (
Option U70504 Auxiliary Control Valve (SCD FC) Component Parts Option Auxiliary Control Valve (
Option U71000 Auxiliary Control Valve Lever Kit (3rd) Option Auxiliary Control Valve
Option U75601 Trailer Brake Valve Mounting Kit (Pipe) Option Trailer Brake Valve Mounting
Option U75701 Trailer Brake Valve Mounting Kit (Valve) Option Trailer Brake Valve Mounting
Option U75801 Trailer Brake Valve Mounting Kit (Gasket) Option Trailer Brake Valve Mounting
Option U75901 Trailer Brake Valve Mounting Kit (Electrical Wiring) Option Trailer Brake Valve Mounting
Option U91000 Instructional Seat Kit (Seat) Option Instructional Seat Kit (Seat)
Option U91100 Instructional Seat Kit (Bracket) Option Instructional Seat Kit (
Option U94300 Room Mirror Kit Option Room Mirror Kit Option
Region: Turkey
Cab N11401 Step
Cab N12500 Door Rh
Cab N13000 Door Lh
Cab N25000 Tool Box
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
