Martin Welker
104
230,310
Kubota Tractor M5091 M5111 Workshop Manual 9Y111-20483
Type Of Manual: Workshop Manual
Model: Kubota M5091 M5111 Tractor
Parts Number: 9Y111-20483
Publication Date: 2022
Number Of Page: 942 Pages
Safety
Safety First
Preparing For Emergencies
Working Cautions
Starting Machine Safely
Preventing
Preventing Acid Burns
Avoiding High Pressure Fluid
Avoiding Hot Exhaust
Cleaning Exhaust Filter
Safety Labels
Rops Model
Cabin Model
Are Of Danger, Warning And Caution Labels
General
General Working Instructions
General Working Precautions
Tightening Bolts And Nuts
Applying Thread-Locking Fluid
Installing Circlips
Installing Spring Pins
Handling Split Pin
Handling Chain Joint And Split Pin
Handling Liquid Gasket
Replacing O-Rings
Replacing Oil Seals
Replacing Floating Seals
Connecting Hydraulic Hoses
Wrapping Thread Seal Tape
Installing Elbows With Male Seat
Connecting And Disconnecting Quick Hose Couplings
Handling The Battery
Handling Wire Harness
Handling Fuses
Handling Connectors
Wiring Color
Washing The Machine With A High Pressure Washer
Dispose Fluids Correctly
Tightening Torques
General Use Screws, Bolts And Nuts
Stud Bolts
Hydraulic Fitting
Metric Screws, Bolts And Nuts
American Standard Screws, Bolts And Nuts With Unc Or Unf Threads
Plugs
General Machine Information
Model Name And Serial Number
S Ecifications
Traveling Speeds
Dimensions
Tires
Wheel Adjustment
Wheel Hub
Tire Liquid Injection
Implement Limitations
Special Tools
Special Tools For Engine
Special Tools For Tractor
Special Tools For Air Conditioner Unit
Maintenance
Service Intervals
Maintenance Items Chart
Lubricants, Fuel And Coolant
Check And Maintenance
Daily Check
Initial 50 Hours
Eve
50 Hours
Every 100 Hour
Eve 200 Hours
Every 400 Hours
Every 500 Hours
Every 600 Hours
Eve
1000 Hours
Every 1000 Hours Or 1 Year
Every 1500 Hours
Every 2000 Hours Or 2 Years
Every 3000 Hours
Every 1 Year
Every 2 Years
Every 3 Years
Every 4 Year
Service As Required
Mechanism
Lubricating System
Cooling Syste
Common Rail System (Crs)
Egr System
Aftertreatment System
Troubleshooting For Engine
Service Specifications For Engine
Tightening Torques For Engine
Checking And Adjusting
Mechanism
Structure
Power Train For Traveling Gear
Lubrication For Transmission
Power Train For Pto System
Power Train For 4wd
Differential Lock
Troubleshooting For Transmission
Service Specifications For Transmission
Tightening Torques For Transmission
Rear Axle
Mechanism
Features Of Rear Axle
Servicin
Troubleshooting For Rear Axle
Service Specifications For Rear Axle
Tightening Torques For Rear Axle
Disassembling And Assembling
Servicing
Brakes
Mechanism
Traveling Brake
Parkin Brak
An
Ra E
Troubleshooting For Brakes
Service Specifications For Brakes
Tightening Torques For Brakes
Front Axle
Mechanism
Structure
Troubleshooting For Front Axle
Service Specifications For Front Axle
Tightening Torques For Front Axle
Steering
Mechanism
Mechanism Of Steering
Feature Of Steering Cylinder
Ervicin
Troubleshooting For Steering
Service Specifications For Steering
Tightening Torques For Steering
Erviang
Structure Of Fl 8/R18 Speed Transmission Model Hydraulic System
Hydraulic System Structure
Outline Of Hydraulic System
Hydraulic Circuit
Auxiliary Control Valve
3-Point Hitch Hydraulic System
Troubleshooting For Hydraulic System
Service Specifications For Hydraulic System
Tightening Torques For Hydraulic System
Servicing
Location Of Electrical Com Onents
Connector
Enaine Startingystem And Stoppi'pg,Spte
Instrument Panel
Advanced Controls
Li Htin S Stem
Troubleshooting For Electrical System
Diagnostic Trouble Code (Dtc)
Tightening Torques For Electrical System
Checkin And Ad'ustin
Ervicing
Cabin
Mechanism
Air Condiitioning System
Servicing
Troubleshooting For Cabin
Service Specifications For Cabin
Tightening Torques For Cabin
Precautions At Repairing Refrigerant Cycle
Checking And Charging Refrigerant Cycl
Hecking And Adjusting
Servicing
