Kubota Tractor M5071NC-NEC1 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5071NC-NEC1 Tractor
Number of Pages: 349 Pages
Itens Usa Dos Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Ex Haust Valve
Braço / Rocker Arm Shaft
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Compensador / Balancer
Volante Motor / Flywheel
Trilho Comum / Common Rail
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Thro Ttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [C Omponent Parts]
Tubo De Entrada (Filtro Ar) / Inlet Pipe (Air Cleaner)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / D Iesel Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Pe Ças Componentes] / Diesel Particulate Filter Muffle R [Component Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor/Ecu) / En Gine Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape Se Nsor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combust Ivel / Fuel Tank Bracket
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Fornecimento Combustivel / Fuel Supply
Tubo Combustivel (Deposi To Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Combustivel (Bomba Do Combustivel/Separador) / Fuel Pipe (Fuel Pump/Se Parator)
Tubo Combustivel (Deposi To Combustivel Respiro) / Fuel Pipe (Fuel Tank Brea Ther)
Tubo Combustivel (Arrefe Cedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Compone Ntes] / Separator [Component Parts]
Filtro Gasoleo / Fuel Fi Lter
Ventoi Nha / Fan
Tubo A Gua / Water Pipe
Radiad Or / Radiator
Deposi To Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Interruptor/Sensor (Blo Co Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Pan Ela Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Fre Nte) / Switch/Sensor (Front)
Interruptor/Sensor (Tra Seira) / Switch/Sensor (Rear)
Interruptor/Sensor (Car Ter Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Painel) / Switch (Panel Board)
Interruptor (Tecto Inte Rior) / Switch (Inner Roof)
Interruptor (Lado Panel ) / Switch (Side Panel)
Relé / Relay
Unidade Control Electri Co (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electri Co (Corpo) / Electronic Control Unit (Body)
Painel / Panel
Luzes Frente / Head Lig Ht
Luzes Frente [Peças Com Ponentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Luzes Trabalho / Workin G Light
Braco Traseiro / Rear C Ombination Lamp
Farol Matricula/Lâmpada Farol / License Lamp/Beacon Lamp
Luz Interior / Room Lig Ht
Alta Voz Radio / Radio Speaker
Depósito De Lavagem / W Asher Tank
Escova Limpa Vidro Fron Tal / Front Wiper
Cablagem Electrica (Crs ) / Electrical Wiring (Crs)
Cablagem Eletrcia (Prin Cipal/Motor) / Electrical Wiring (Main/Engine)
Cablagem Electrica (Pri Ncipal) / Electrical Wiring (Main)
Cablagem Electrica (Cor Po) / Electrical Wiring (Body)
Cablagem Electrica (Cab Ine) / Electrical Wiring (Cab)
Carter Embraiage M / Clutch Housing
Valvula Inversor / Shuttle Valve
Carretos Inverso R / Shuttle Gear Case
Tampa / Shift Co Ver
Caixa Da Transmi Ssão / Transmission Case
Carter Transmiss Ao / Transmission Case Rear Cover
Disco Amortecedo R / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula Alavanca (Embraiagem) / Valve Lever (Clutch)
Veio Primario / Input Shaft
Kit Embraiagem ( Hi-Lo) [Peças Componentes] / Clutch Pack (Hi-Lo) [C Omponent Parts]
Veio Inversor / Shuttle Shaft
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Creeper / C Reep Shaft
Veio De Acioname Nto / Drive Shaft
Grupo Conico / B Evel Gear
Diferencial Tras Eiro / Rear Differential
Veio Tdf / Pto P Ropeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [ Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiag Em Tdf / Pto Clutch Valve
Valvula Embraiag Em Tdf [Peças Componentes] / Pto Clutch Valve [Comp Onent Parts]
Veio Tdf / Pto S Haft
Embraiagem Andam Ento / Front Drive Clutch
Embraiagem Andam Ento [Peças Componentes] / Front Drive Clutch [Comp Onent Parts]
Embraiagem Hidra Ulica [Peças Componentes] / Hydraulic Clutch (Bi-Sp Eed Turn) [Component Parts]
Forqu Eta / Main Gear Shift Fork
Forqu Eta Velocidades / Range Gear Shift Fork
Bloqu Eio Diferencial De Forqueta / Differential Lock Shi Ft Fork
Alava Nca Velocidades / Main Gear Shift Lever
Tiran Te / Main Gear Shift Rod
Alvan Ca Inversor / Shuttle Shift Lever
Alava Nca Velocidades / Range Gear Shift Lever
Alava Nca De Mudança De Velocidades De Tomada De Força Td F / Pto Gear Shift Rod
Eixo Traseiro / Rear Axle
Travao Drt / Brake Rh
Travao Esq / Brake Lh
Veio Bloqueio / Parki Ng Brake Camshaft
Veio Travao Mao / Par King Brake Shaft
Alavanca De Freio Sec Undária / Secondary Brake Lever
Pedal Travao / Brake Pedal
Cilindro Travao Princ Ipal / Brake Master Cylinder
Cilindro Travao Princ Ipal [Peças Componentes] / Brake Master Cylinder [C Omponent Parts]
Tubo Travao / Brake P Ipe
Suporte Eixo Frent E / Front Axle Bracket
Veio Primario / Pr Opeller Shaft
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Fren Te) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencia L Drt / Differential Gear Shaft Rh
Carreto Diferencia L Esq / Differential Gear Shaft Lh
Eixo Frente Esq / Front Axle Lh
Tampa Coluna Direccao / Steering Post Cov Er
Junta Direcção / Steering Joint
Distribuidor Direcção / Steering Controll Er
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steeri Ng Cylinder
Cilindro Direcção [Peças Componentes] / S Teering Cylinder [Component Parts]
Bomba Hidraulico / Hydr Aulic Pump
Tubo Oleo (Entrega) / H Ydraulic Pipe (Delivery)
Radiador Oleo / Oil Coo Ler
Circuito Oleo Direcção (Direcção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Circuito Oleo Direcção (Inversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidrauli Co / Hydraulic Cylinder Case
Braço De Elevação Hidrá Ulico / Hydraulic Lift Arm
Valvula Segurança/Desca Rga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Lever
Valvula Control / Contr Ol Valve
Puxar E Posicionar Alav Anca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Position And Draft Shaft
Alavanca / Feed Back Le Ver
Válvula De Controle Ala Vanca [Peças Componentes] (Fd) / Auxiliary Control Valve [Component Parts] (Fd)
Válvula De Controle Ala Vanca [Peças Componentes] (Scd) / Auxiliary Control Valve [Component Parts] (Scd)
Alavanca Valvula Contro L Auxiliar / Auxiliary Control Valve Lever
Cilindro Auxiliar De El Evacao Esq [Antiga] / 3p-Lift Assist Cylinder Lh [O Ld]
Cilindro Auxiliar De El Evacao Esq [Nova] / 3p-Lift Assist Cylinder Lh [New ]
Cilindro Auxiliar De El Evacao Drt [Antiga] / 3p-Lift Assist Cylinder Rh [O Ld]
Cilindro Auxiliar De El Evacao Drt [Nova] / 3p-Lift Assist Cylinder Rh [New ]
Cilindro Auxiliar De El Evacao [Peças Componentes] [Velho] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro Auxiliar De El Evacao [Peças Componentes] [Novo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Mangueira De Respiro (3 P Cilindro) / Breather Hose (3p Cylinder)
Pa Rte Superior / Top Link Bracket
Li Gacao Superior / Top Link
Li Gacao Inferior [Antiga] / Lower Link [Old]
Li Gacao Inferior [Nova] / Lower Link [New]
Es Tabilizador Drt / Lift Rod Rh
Es Tabilizador Esq / Lift Rod Lh
Ba Rra De Engate Oscilante [Antiga] / Swinging Drawbar [Old]
Ba Rra De Engate Oscilante [Nova] / Swinging Drawbar [ New]
Pr Oteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Suporte Capot / Hood (Bonnet) Support
Estrutura Cabine / Cab Frame
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro Drt / Side Window Rh
Lado Vidro Esq / Side Window Lh
Vidro Traseiro / Hatch Back Glass
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Suporte Do Assento / Seat Bracket
Składowanie Materiałów/Piso / Damp Material/Floo R Mat
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Resguardo Coluna / Pillar Cover
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Condi Tioner
Tubo Ar Condicionado / Air Conditioner Duct
Tubo Aquecimento / Heater H Ose
Condesador / Condenser
Tubo Ar Condicionado/Tubo C Ondensador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condicionado ) / Compressor (Air Conditioner)
Suporte Compressor / Compre Ssor Bracket
Mangueira De Drenagem / Dra In Hose
Etiqueta (Painel) / Label (Panel)
Etiqueta (Cabine) / Label (Cab Frame)
Ac Essorios E Peças Serviço / Accessories And Service Parts
Panela Escape [Opçao] / Upper Muffler Kit [Opt Ion]
Alternador Kit (Alternador) [Opção] / Alternat Or Kit (Alternator) [Option]
Alternador Kit (Electrica Cablagem) [Opção] / Alternator Kit (Electrical Wiring) [Option]
Alternador [Peças Componentes] [Opção] / Alter Nator [Component Parts] [Option]
Kit Interruptor (Bomba) [Opção] / Switch Kit ( Pumpa) [Option]
Desempanador [Opção] / Rear Defogger Kit [Opti On]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Kit [Option]
Kit Conversao Tdf (Carreto) (540/540e/1000) [O Pção] / Pto Conversion Kit (Gear) (540/540e/1000) [ Option]
Kit Conversao Tdf (Palanca) (540/540e/1000) [O Pção] / Pto Conversion Kit (Lever) (540/540e/1000) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (S/D) [Opção] / Auxiliary Control Valve Kit (S/D) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca [Peças Componente S] (S/D) [Opção] / Auxiliary Control Valve [Compone Nt Parts] (S/D) [Option]
Válvula De Controle Alavanca Kit (Fc) [Peças C Omponentes] [Opção] / Auxiliary Control Valve [Comp Onent Parts] (Fc) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Ki T (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Ki T (4ª) [Opção] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit De Engate Dianteiro (1ª) [Opção] / Front C Oupler Kit (1st) [Option]
Kit De Engate Dianteiro (2ª) [Opção] / Front C Oupler Kit (2nd) [Option]
Kit De Engate Dianteiro (3ª) [Opção] / Front C Oupler Kit (3rd) [Option]
Kit De Engate Dianteiro (4ª) [Opção] / Front C Oupler Kit (4th) [Option]
Kit De Engate Dianteiro (5ª) [Opção] / Front C Oupler Kit (5th) [Option]
Kit De Engate Dianteiro (Dreno) [Opção] / Fron T Coupler Kit (Drain) [Option]
Conjunto De Drenagem Traseira [Opção] / Rear D Rain Kit [Option]
Kit De Válvula Do Travão Do Reboque (Valvula) [Opção] / Traler Brake Valve Kit (Valve) [Option]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo ) [Opção] / Trailer Brake Valve Kit (Hydraulic Pipe ) [Option]
Kit De Válvula Do Travão Do Reboque (Acoplamen To) [Opção] / Trailer Brake Valve Kit (Coupler) [Op Tion]
Montagem Da Válvula Do Freio Do Reboque (Supor Te) [Opção] / Trailer Brake Valve Mounting Kit (Bra Cket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvu La/Tubo) [Opção] / Trailer Brake Valve Mounting Kit (Valve/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Acopl Ador/Tubo) [Opção] / Trailer Brake Valve Mounting K It (Coupler/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cabla Gem Electrica) [Opção] / Trailer Brake Valve Mounti Ng Kit (Electrical Wiring) [Option]
Estabilizador [Opção] / Stabilizer [Option]
