Kubota Tractor M5071NC-ITA Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5071NC-ITA Tractor
Number of Pages: 345 Pages
Itens Usad Os Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exh Aust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Compensador / Balancer
Volante Motor / Flywheel
Trilho Comum / Common Rail
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throt Tle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [Co Mponent Parts]
Tubo De Entrada (Filtro Ar) / Inlet Pipe (Air C Leaner)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Di Esel Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peç As Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor/Ecu) / Eng Ine Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape Sen Sor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combusti Vel / Fuel Tank Bracket
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Fornecimento Combustivel / Fuel Supply
Tubo Combustivel (Deposit O Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Combustivell (Enchim Ento Do Combustivel) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Deposit O Combustivel Respiro) / Fuel Pipe (Fuel Tank Breat Her)
Tubo Combustivel (Arrefec Edor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Componen Tes] / Separator [Component Parts]
Filtro Gasoleo / Fuel Fil Ter
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor/Sensor (Bloc O Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Pane La Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Fren Te) / Switch/Sensor (Front)
Interruptor/Sensor (Tras Eira) / Switch/Sensor (Rear)
Interruptor/Sensor (Cart Er Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Painel) / S Witch (Panel Board)
Interruptor (Tecto Inter Ior) / Switch (Inner Roof)
Interruptor (Lado Panel) / Switch (Side Panel)
Relé / Relay
Unidade Control Electric O (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electric O (Corpo) / Electronic Control Unit (Body)
Painel / Panel
Luzes Frente / Head Ligh T
Luzes Frente [Peças Comp Onentes] / Head Light [Component Parts]
Luzes Frontais / Front C Ombination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Co Mbination Lamp
Farol Matricula/Lâmpada Farol / License Lamp/Beacon Lamp
Luz Interior / Room Ligh T
Alta Voz Radio / Radio S Peaker
Depósito De Lavagem / Wa Sher Tank
Escova Limpa Vidro Front Al / Front Wiper
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Eletrcia (Princ Ipal/Motor) / Electrical Wiring (Main/Engine)
Cablagem Electrica (Prin Cipal) / Electrical Wiring (Main)
Cablagem Electrica (Corp O) / Electrical Wiring (Body)
Cablagem Electrica (Cabi Ne) / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cov Er
Valva Dupla Veloc Idades / Dual Speed Valve
Caixa Da Transmis São / Transmission Case
Mangueira De Resp Iro (Caixa Velocidades) / Breather Hose (Transmissi On Case)
Carter Transmissa O / Transmission Case Rear Cover
Carter Eixo / Rea R Axle Case
Disco Amortecedor / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula Alavanca (Embraiagem) / Valve Lever (Clutch)
Veio Primario / I Nput Shaft
Kit Embraiagem (H I-Lo) [Peças Componentes] / Clutch Pack (Hi-Lo) [Co Mponent Parts]
Veio Inversor / S Huttle Shaft
Embraiagem (Lança Deira) [Peças Componentes] / Clutch Pack (Shuttle) [Component Parts]
Primeiro Veio / F Irst Shaft
Terceiro Veio / T Hird Shaft
Veio Creeper / Cr Eep Shaft
Veio De Acionamen To / Drive Shaft
Grupo Conico / Be Vel Gear
Diferencial Trase Iro / Rear Differential
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [P Eças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiage M Tdf / Pto Clutch Valve
Valvula Embraiage M Tdf [Peças Componentes] / Pto Clutch Valve [Compo Nent Parts]
Veio Tdf / Pto Sh Aft
Embraiagem Andame Nto / Front Drive Clutch
Embraiagem Andame Nto [Peças Componentes] / Front Drive Clutch [Compo Nent Parts]
Embraiagem Hidrau Lica [Peças Componentes] / Hydraulic Clutch (Bi-Spe Ed Turn) [Component Parts]
Forque Ta / Main Gear Shift Fork
Forque Ta Velocidades / Range Gear Shift Fork
Forqui Lha Tdf / Ground Pto Shift Fork
Bloque Io Diferencial De Forqueta / Differential Lock Shif T Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Tirant E / Main Gear Shift Rod
Alvanc A Inversor / Shuttle Shift Lever
Alavan Ca Velocidades / Range Gear Shift Lever
Alavan Ca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Alavan Ca / Ground Pto Shift Lever
Eixo Traseiro / Rear A Xle
Travao Drt / Brake Rh
Veio Bloqueio / Parkin G Brake Camshaft
Veio Travao Mao / Park Ing Brake Shaft
Alavanca De Freio Secu Ndária / Secondary Brake Lever
Pedal Travao / Brake P Edal
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal [Peças Componentes] / Brake Master Cylinder [Co Mponent Parts]
Tubo Travao / Brake Pi Pe
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Pro Peller Shaft
Caixa Diferencial F Rente / Front Differential Case
Grupo Conico (Frent E) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Drt / F Ront Axle Rh
Eixo Frente Esq / F Ront Axle Lh
Pedal Inclinacao / Tilt Pedal
Distribuidor Direcção / Steering Controlle R
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steerin G Cylinder
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Tubo Oleo (Entrega) / Hy Draulic Pipe (Delivery)
Radiador Oleo / Oil Cool Er
Circuito Oleo Direcção ( Valva Dupla Velocidades) / Hydraulic Oil Line (Dual Speed Valve)
Circuito Oleo Direcção ( Direcção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Circuito Oleo Direcção ( Inversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Caixa Cilindro Hidraulic O / Hydraulic Cylinder Case
Braço De Elevação Hidráu Lico / Hydraulic Lift Arm
Valvula Segurança/Descar Ga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock L Ever
Valvula Control / Contro L Valve
Puxar E Posicionar Alava Nca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / P Osition And Draft Shaft
Alavanca / Feed Back Lev Er
Base De Montagem Da Válv Ula De Controlo Auxiliar / Auxiliary Control Valve Mounting Base
Válvula De Controle Alav Anca (Fd Com Fc/Scd Com Fc) / Auxiliary Control Val Ve (Fd With Fc/Scd With Fc)
Base De Montagem Da Válv Ula De Controlo Auxiliar [Peças Componentes] / Auxi Liary Control Valve Mounting Base [Component Parts]
Auxiliar Do Válvula De C Ontrolo [Peças Componentes] (Fd Con Fc) / Auxiliary Control Valve [Component Parts] (Fd With Fc)
Auxiliar Do Válvula De C Ontrolo [Peças Componentes] (Scd Con Fc) / Auxiliar Y Control Valve [Component Parts] (Scd With Fc)
Alavanca Valvula Control Auxiliar / Auxiliary Control Valve Lever
Fluir Fio De Controle Da Auxiliar Do Valvula De Controlo / Auxiliary Contro L Flow Control Wire
Cilindro Auxiliar De Ele Vacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Ele Vacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Ele Vacao [Peças Componentes] [Velho] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro Auxiliar De Ele Vacao [Peças Componentes] [Novo] / 3p-Lift Assist C Ylinder [Component Parts] [New]
Mangueira De Respiro (3p Cilindro) / Breather Hose (3p Cylinder)
Par Te Superior / Top Link Bracket
Lig Acao Superior / Top Link
Lig Acao Inferior / Lower Link
Est Abilizador Drt / Lift Rod Rh
Est Abilizador Esq / Lift Rod Lh
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / Hood (Bonnet) (Sound Absorber/Insulator)
Suporte Capot / Hood (Bonnet) Support
Estrutura Cabine / Cab Frame
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro Drt / Side Window Rh
Lado Vidro Esq / Side Window Lh
Vidro Traseiro / Hatch Back Glass
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Suporte Do Assento / Seat Bracket
Składowanie Materiałów/Piso / Damp Material/Floor Mat
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Resguardo Coluna / Pillar Cover
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Condit Ioner
Tubo Ar Condicionado / Air C Onditioner Duct
Tubo Aquecimento / Heater Ho Se
Condesador / Condenser
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Suporte Compressor / Compres Sor Bracket
Etiqueta (Painel) / Label (Panel)
Etiqueta (Cabine) / Label (Cab Frame)
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Panela Escape [Opçao] / Upper Muffler Kit [Opti On]
Alternador Kit (Alternador) [Opção] / Alternato R Kit (Alternator) [Option]
Alternador Kit (Electrica Cablagem) [Opção] / A Lternator Kit (Electrical Wiring) [Option]
Alternador [Peças Componentes] [Opção] / Altern Ator [Component Parts] [Option]
Kit Interruptor (Bomba) [Opção] / Switch Kit (P Umpa) [Option]
Desempanador [Opção] / Rear Defogger Kit [Optio N]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Kit [Option]
Kit Conversao Tdf (Carreto) (540/540e/1000) [Op Ção] / Pto Conversion Kit (Gear) (540/540e/1000) [O Ption]
Kit Conversao Tdf (Palanca) (540/540e/1000) [Op Ção] / Pto Conversion Kit (Lever) (540/540e/1000) [ Option]
Válvula De Controle Alavanca Kit (Scd Con Fc) [ Opção] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Válvula De Controle Alavanca Kit (S/D Con Fc) [ Opção] / Auxiliary Control Valve Kit (S/D With Fc) [Option]
Válvula De Controle Alavanca [Peças Componentes ] (S/D Con Fc) [Opção] / Auxiliary Control Valve [C Omponent Parts] (S/D With Fc) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit ( 3rd) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (4ª) [Opção] / Auxiliary Control Valve Lever Kit ( 4th) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (5ª) [Opção] / Auxiliary Control Valve Lever Kit ( 5th) [Option]
Kit De Engate Dianteiro (1ª) [Opção] / Front Co Upler Kit (1st) [Option]
Kit De Engate Dianteiro (2ª) [Opção] / Front Co Upler Kit (2nd) [Option]
Kit De Engate Dianteiro (3ª) [Opção] / Front Co Upler Kit (3rd) [Option]
Kit De Engate Dianteiro (4ª) [Opção] / Front Co Upler Kit (4th) [Option]
Kit De Engate Dianteiro (5ª) [Opção] / Front Co Upler Kit (5th) [Option]
Kit De Engate Dianteiro (Dreno) [Opção] / Front Coupler Kit (Drain) [Option]
Conjunto De Drenagem Traseira [Opção] / Rear Dr Ain Kit [Option]
Kit De Válvula Do Travão Do Reboque (Valvula) [ Opção] / Trailer Brake Valve Kit (Valve) [Option]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo) [Opção] / Trailer Brake Valve Kit (Hydraulic Pipe) [Option]
Kit De Válvula Do Travão Do Reboque (Acoplament O) [Opção] / Trailer Brake Valve Kit (Coupler) [Opt Ion]
Montagem Da Válvula Do Freio Do Reboque (Suport E) [Opção] / Trailer Brake Valve Mounting Kit (Brac Ket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvul A/Tubo) [Opção] / Trailer Brake Valve Mounting Kit (Valve/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Acopla Dor/Tubo) [Opção] / Trailer Brake Valve Mounting Ki T (Coupler/Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablag Em Electrica) [Opção] / Trailer Brake Valve Mountin G Kit (Electrical Wiring) [Option]
Estabilizador [Opção] / Stabilizer [Option]
Carreto / Gear Case
Ventoin Ha / Fan
Relé / Relay
Painel / Panel
Porta Drt / Door Rh
Porta Esq / Door Lh
