Kubota Tractor M5071N-NEC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5071N-NEC Tractor
Number of Pages: 323 Pages
Itens Usado S Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Common Rail / Common Rail
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Thrott Le Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cleaner)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape Sens Or) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Suporte Deposito Combustiv El / Fuel Tank Bracket
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Fornecimento Combustivel [ Velho] / Fuel Supply [Old]
Fornecimento Combustivel [ Novo] / Fuel Supply [New]
Tubo Combustivel (Deposito Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Do Combustível (Enchi Mento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Do Combustível (Bomba Do Combustível/Separador) / Fuel Pipe (Fuel Pump/S Eparator)
Tubo Combustivel (Deposito Combustivel Respiro) / Fuel Pipe (Fuel Tank Breath Er)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Filtro Gasoleo / Fuel Filt Er
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panel A Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Frent E) / Switch/Sensor (Front)
Interruptor/Sensor (Trase Iro) / Switch/Sensor (Rear)
Interruptor/Sensor (Carte R Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Painel) [Exc Eto [Ds]] / Switch (Panel Board) [Except [Ds]]
Relé / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Painel [Velho] / Panel [O Ld]
Painel [Novo] / Panel [Ne W]
Luzes Frente / Head Light
Luzes Frente [Peças Compo Nentes] / Head Light [Component Parts]
Luzes Frontais / Front Co Mbination Lamp
Braco Traseiro / Rear Com Bination Lamp
Farol Matricula [Velho] / License Lamp [Old]
Farol Matricula [Novo] / License Lamp [New]
Ficha Reboque / Trailer S Ocket
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Electrica (Motor ) / Electrical Wiring (Engine)
Cablagem Electrica (Princ Ipal) / Electrical Wiring (Main)
Cablagem Electrica (Trase Ira) / Electrical Wiring (Rear)
Carter Embraiagem [Exceto [Ds]] / Clutch Housing [Except [Ds]]
Valvula Inversor / Shuttle Valve
Carretos Inversor [Exceto [Ds]] / Shuttle Gear Case [Except [Ds]]
Tampa / Shift Cove R
Caixa Da Transmiss Ão / Transmission Case
Mangueira De Respi Ro (Caixa Velocidades) / Breather Hose (Transmissio N Case)
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Axle Case
Cabo Embraiagem / Clutch Cable
Veio Primario [Exc Eto [Ds]] / Input Shaft [Except [Ds]]
Kit Embraiagem (Hi -Lo) [Peças Componentes] [Exceto [Ds]] / Clutch Pac K (Hi-Lo) [Component Parts] [Except [Ds]]
Veio Inversor [Exc Eto [Ds]] / Shuttle Shaft [Except [Ds]]
Primeiro Veio [Exc Eto [Ds]] / First Shaft [Except [Ds]]
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Veio De Acionament O / Drive Shaft
Grupo Conico / Bev El Gear
Diferencial Trasei Ro / Rear Differential
Veio Tdf / Pto Pro Peller Shaft
Embraiagem Tdf / P To Clutch
Embraiagem Tdf [Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compon Ent Parts]
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Embraiagem Andamen To [Peças Componentes] / Front Drive Clutch [Compon Ent Parts]
Embraiagem Hidraul Ica [Peças Componentes] / Hydraulic Clutch (Bi-Spee D Turn) [Component Parts]
Forque Ta / Main Gear Shift Fork
Forque Ta Velocidades / Range Gear Shift Fork
Bloque Io Diferencial De Forqueta / Rear Differential Lock Shift Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Tirant E / Main Gear Shift Rod
Alvanc A Inversor / Shuttle Shift Lever
Alavan Ca Velocidades / Range Gear Shift Lever
Alavan Ca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear Ax Le
Travao Drt / Brake Rh
Travao Esq / Brake Lh
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / P Arking Brake Lever
Veio Travao Mao / Parki Ng Brake Shaft
Alavanca De Freio Secun Dária / Secondary Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Travao Princip Al / Brake Master Cylinder
Cilindro Travao Princip Al [Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pip E
Suporte Eixo Frente / Front Axle Bracket
Caixa Diferencial Fr Ente / Front Differential Case
Grupo Conico (Frente ) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens C Onica Drt / Bevel Gear Case Rh
Caixas Engrenagens C Onica Esq / Bevel Gear Case Lh
Carter Eixo Frente E Sq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft Rh
Carreto Diferencial Esq / Differential Gear Shaft Lh
Eixo Frente Drt / Fr Ont Axle Rh
Eixo Frente Esq / Fr Ont Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hyd Raulic Pipe (Delivery)
Radiador Oleo / Oil Coole R
Circuito Oleo Direcção (D Irecção/Tdf) [Exceto [Ds]] / Hydraulic Oil Line (St Eering/Pto) [Except [Ds]]
Circuito Oleo Direcção (I Nversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidrául Ico / Hydraulic Lift Arm
Valvula Segurança/Descarg A Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Le Ver
Puxar E Posicionar Alavan Ca De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Po Sition And Draft Shaft
Alavanca / Feed Back Leve R
Válvula De Controle Alava Nca (Fd Com Scd) [Se] / Auxiliary Control Valve (Fd With Scd) [Se]
Válvula De Controle Alava Nca [Peças Componentes] (Fd) [Se] / Auxiliary Contr Ol Valve [Component Parts] (Fd) [Se]
Válvula De Controle Alava Nca [Peças Componentes] (Scd) [Se] / Auxiliary Cont Rol Valve [Component Parts] (Scd) [Se]
Alavanca Valvula Control Auxiliar / Auxiliary Control Valve Lever
Cilindro Auxiliar De Elev Acao Esq [Velho] / 3p-Lift Assist Cylinder Lh [Old]
Cilindro Auxiliar De Elev Acao Esq [Novo] / 3p-Lift Assist Cylinder Lh [New]
Cilindro Auxiliar De Elev Acao Drt [Velho] / 3p-Lift Assist Cylinder Rh [Old]
Cilindro Auxiliar De Elev Acao Drt [Novo] / 3p-Lift Assist Cylinder Rh [New]
Cilindro Auxiliar De Elev Acao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Mangueira De Respiro (3p Cilindro) / Breather Hose (3p Cylinder)
Part E Superior / Top Link Bracket
Liga Cao Superior / Top Link
Liga Cao Inferior / Lower Link
Esta Bilizador / Stabilizer
Esta Bilizador Esq / Lift Rod Lh
Prot Eccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / Hood (Bonnet) (Sound Absorber/Insulator)
Suporte Capot (Remador) / Bonnet Support (R Ower)
Suporte Capot (Superior) / Bonnet Support ( Upper)
Guarda Lamas (Inferior Posicao) [Velho] / F Ender (Lower Position) [Old]
Guarda Lamas (Inferior Posicao) [Novo] / Fe Nder (Lower Position) [New]
Guarda Lamas (Superior Posicao) / Fender (U Pper Position)
Tampa / Shift Cover
Piso / Floor Sheet
Degrau / Step
Degrau Superior Resguardo / Step Upper Cove R
Degrau Auxiliar / Auxiliary Step
Suporte Do Assento / Seat Bracket
Isolante / Soundproof Material
Caixa Ferramenta / Tool Box
Caobertura / Guard
Arco Seguranca 1 (Medio) / Rops 1 (Mid)
Arco Seguranca 2 (Traseiro) / Rops 2 (Rear)
Etiqueta (Painel) / Label (Panel)
Peça De Acessorio E Serviço Peças / Accessories And Service Parts
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Zestaw Do Konwersji Wom (Carreto) (540/540e/1000 ) [Opcja] / Pto Conversion Kit (Gear) (540/540e/100 0) [Option]
Zestaw Do Konwersji Wom (Alavanca) (540/540e/100 0) [Opcja] / Pto Conversion Kit (Lever) (540/540e/1 000) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] [S E] / Auxiliary Control Valve Kit (Fd) [Option] [Se]
Válvula De Controle Alavanca Kit (Scd) [Opção] [ Se] / Auxiliary Control Valve Kit (Scd) [Option] [S E]
Válvula De Controle Alavanca Kit (S/D) [Opção] [ Se] / Auxiliary Control Valve Kit (S/D) [Option] [S E]
Válvula De Controle Alavanca [Peças Componentes] (S/D) [Opção] [Se] / Auxiliary Control Valve [Comp Onent Parts] (S/D) [Option] [Se]
Válvula De Controle Alavanca [Peças Componentes] (Fc) [Opção] [Se] / Auxiliary Control Valve [Compo Nent Parts] (Fc) [Option] [Se]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] [Se] / Auxiliary Control Valve Lever K It (3rd) [Option] [Se]
Auxiliar Do Alavanca De Válvula De Controlo Kit (4ª) [Opção] [Se] / Auxiliary Control Valve Lever K It (4th) [Option] [Se]
Kit De Engate Dianteiro (1ª) [Opção] / Front Cou Pler Kit (1st) [Option]
Kit De Engate Dianteiro (2ª) [Opção] / Front Cou Pler Kit (2nd) [Option]
Kit De Engate Dianteiro (3ª) [Opção] / Front Cou Pler Kit (3rd) [Option]
Kit De Engate Dianteiro (Dreno) [Opção] / Front Coupler Kit (Drain) [Option]
Conjunto De Drenagem Traseira [Opção] / Rear Dra In Kit [Option]
Kit De Válvula Do Travão Do Reboque (Valvula) [O Pção] / Traler Brake Valve Kit (Valve) [Option]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo) [Opção][Exceto Ds] / Traler Brake Valve Kit (Hydrau Lic Pipe) [Option][Except Ds]
Kit De Válvula Do Travão Do Reboque (Acoplamento ) [Opção] / Traler Brake Valve Kit (Coupler) [Optio N]
Estabilizador [Opção] / Stabilizer [Option]
Kit De Suporte Da Escora [Opção] / Drawbar Brack Et Kit [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [O Ption]
Carreto / Gear Case
Ventoinh A / Fan
Relé / Relay
Tampa / Shift Cover
Piso / Floor Sheet
Degrau / Step
Caobertura / Guard
