Kubota Tractor M5071N-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M5071N-EC Tractor
Number of Pages: 339 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor / Flywheel
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throttl E Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cleaner)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Ch Arger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor/Ecu) / Engin E Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape Senso R) / Engine Electrical Parts (Muffler Sensor)
Suporte Deposito Combustive L / Fuel Tank Bracket
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Fornecimento Combustivel [V Elho] / Fuel Supply [Old]
Fornecimento Combustivel [N Ovo] / Fuel Supply [New]
Tubo Combustivel (Deposito Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Do Combustível (Enchim Ento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Do Combustível (Bomba Do Combustível/Separador) / Fuel Pipe (Fuel Pump/Se Parator)
Tubo Combustivel (Deposito Combustivel Respiro) / Fuel Pipe (Fuel Tank Breathe R)
Tubo Combustivel (Arrefeced Or Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Separador [Peças Componente S] / Separator [Component Parts]
Filtro Gasoleo / Fuel Filte R
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panela Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor (Frente ) / Switch/Sensor (Front)
Interruptor/Sensor (Trasei Ro) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Painel) [Ds] / Switch (Panel Board) [Ds]
Relé / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Painel [Velho] / Panel [Ol D]
Painel [Novo] / Panel [New ]
Luzes Frente / Head Light
Luzes Frente [Peças Compon Entes] / Head Light [Component Parts]
Luzes Frontais / Front Com Bination Lamp
Braco Traseiro / Rear Comb Ination Lamp
Farol Matricula [Velho] / License Lamp [Old]
Farol Matricula [Novo] / L Icense Lamp [New]
Ficha Reboque / Trailer So Cket
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Electrica (Princi Pal) / Electrical Wiring (Main)
Cablagem Electrica (Trasei Ra) / Electrical Wiring (Rear)
Carter Embraiagem [ Ds] / Clutch Housing [Ds]
Carretos Inversor [ Ds] / Shuttle Gear Case [Ds]
Tampa / Shift Cover
Valva Dupla Velocid Ades [Ds] / Dual Speed Valve [Ds]
Caixa Da Transmissã O / Transmission Case
Mangueira De Respir O (Caixa Velocidades) / Breather Hose (Transmission Case)
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Axle Case
Disco Amortecedor [ Ds] / Damper Disk [Ds]
Cabo Embraiagem / C Lutch Cable
Valvula Alavanca (E Mbraiagem) / Valve Lever (Clutch)
Veio Primario [Ds] / Input Shaft [Ds]
Kit Embraiagem (Hi- Lo) [Peças Componentes] [Ds] / Clutch Pack (Hi-Lo) [Component Parts] [Ds]
Veio Inversor [Ds] / Shuttle Shaft [Ds]
Kit Embraiagem (Inv Ersor) [Peças Componentes] [Ds] / Clutch Pack (Shut Tle) [Component Parts] [Ds]
Primeiro Veio [Ds] / First Shaft [Ds]
Secundario Veio / S Econd Shaft
Terceiro Veio / Thi Rd Shaft
Veio Creeper / Cree P Shaft
Veio De Acionamento / Drive Shaft
Grupo Conico / Beve L Gear
Diferencial Traseir O / Rear Differential
Veio Tdf / Pto Prop Eller Shaft
Embraiagem Tdf / Pt O Clutch
Embraiagem Tdf [Peç As Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compone Nt Parts]
Veio Tdf / Pto Shaf T
Embraiagem Andament O / Front Drive Clutch
Embraiagem Andament O [Peças Componentes] / Front Drive Clutch [Compone Nt Parts]
Embraiagem Hidrauli Ca [Peças Componentes] / Hydraulic Clutch (Bi-Speed Turn) [Component Parts]
Forquet A / Main Gear Shift Fork
Forquet A Velocidades / Range Gear Shift Fork
Bloquei O Diferencial De Forqueta / Rear Differential Lock Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Alavanc A Velocidades / Range Gear Shift Lever
Alavanc A De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear Axl E
Travao Drt / Brake Rh
Travao Esq / Brake Lh
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / Pa Rking Brake Lever
Veio Travao Mao / Parkin G Brake Shaft
Alavanca De Freio Secund Ária / Secondary Brake Lever
Pedal Travao / Brake Ped Al
Cilindro Travao Principa L / Brake Master Cylinder
Cilindro Travao Principa L [Peças Componentes] / Brake Master Cylinder [Comp Onent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Frente / Front Axle Bracket
Veio Primario / Prope Ller Shaft
Caixa Diferencial Fre Nte / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Co Nica Drt / Bevel Gear Case Rh
Caixas Engrenagens Co Nica Esq / Bevel Gear Case Lh
Carter Eixo Frente Dr T / Front Axle Case Rh
Carter Eixo Frente Es Q / Front Axle Case Lh
Carreto Diferencial D Rt / Differential Gear Shaft Rh
Carreto Diferencial E Sq / Differential Gear Shaft Lh
Eixo Frente Drt / Fro Nt Axle Rh
Eixo Frente Esq / Fro Nt Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hydr Aulic Pipe (Delivery)
Circuito Oleo Direcção (Va Lva Dupla Velocidades) [Ds] / Hydraulic Oil Line (D Ual Speed Valve) [Ds]
Circuito Oleo Direcção (Di Recção/Tdf) [Ds] / Hydraulic Oil Line (Steering/Pto ) [Ds]
Circuito Oleo Direcção (In Versor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Braço De Elevação Hidráuli Co / Hydraulic Lift Arm
Valvula Segurança/Descarga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Lev Er
Puxar E Posicionar Alavanc A De Controlo / Draft And Position Control Lever
Veio Posicao Esforço / Pos Ition And Draft Shaft
Alavanca / Feed Back Lever
Válvula De Controle Alavan Ca (Fd Com Fc/Scd Com Fc) [Ec] / Auxiliary Control Valve (Fd With Fc/Scd With Fc) [Ec]
Base De Montagem Da Válvul A De Controlo Auxiliar [Peças Componentes] [Ec] / A Uxiliary Control Valve Mounting Base [Component Par Ts] [Ec]
Válvula De Controle Alavan Ca [Peças Componentes] (Fd Com Fc) [Ec] / Auxiliary Control Valve [Component Parts] (Fd With Fc) [Ec]
Válvula De Controle Alavan Ca [Peças Componentes] (Scd Com Fc) [Ec] / Auxiliar Y Control Valve [Component Parts] (Scd With Fc) [Ec ]
Alavanca Valvula Control A Uxiliar / Auxiliary Control Valve Lever
Cilindro Auxiliar De Eleva Cao Esq [Velho] / 3p-Lift Assist Cylinder Lh [Old]
Cilindro Auxiliar De Eleva Cao Esq [Novo] / 3p-Lift Assist Cylinder Lh [New] # # N.º De Série>=50137 S.No.;>=50137 / S.No.>=50137 S.No.;>=50137
Cilindro Auxiliar De Eleva Cao Drt [Velho] / 3p-Lift Assist Cylinder Rh [Old]
Cilindro Auxiliar De Eleva Cao Drt [Novo] / 3p-Lift Assist Cylinder Rh [New] # # N.º De Série>=50137 S.No.;>=50137 / S.No.>=50137 S.No.;>=50137
Cilindro Auxiliar De Eleva Cao [Peças Componentes] / 3p-Lift Assist Cylinder [ Component Parts]
Mangueira De Respiro (3p C Ilindro) / Breather Hose (3p Cylinder)
Parte Superior / Top Link Bracket
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Estab Ilizador / Stabilizer
Estab Ilizador Drt / Lift Rod Rh
Estab Ilizador Esq / Lift Rod Lh
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / H Ood (Bonnet) (Sound Absorber/Insulator)
Suporte Capot (Remador) / Bonnet Support (Ro Wer)
Suporte Capot (Superior) / Bonnet Support (U Pper)
Guarda Lamas (Inferior Posicao) [Velho] / Fe Nder (Lower Position) [Old]
Guarda Lamas (Inferior Posicao) [Novo] / Fen Der (Lower Position) [New]
Guarda Lamas (Superior Posicao) / Fender (Up Per Position)
Piso / Floor Sheet
Degrau / Step
Degrau Superior Resguardo / Step Upper Cover
Degrau Auxiliar / Auxiliary Step
Suporte Do Assento / Seat Bracket
Isolante / Soundproof Material
Caixa Ferramenta / Tool Box
Caobertura / Guard
A Rco Seguranca 1 (Medio) / Rops 1 (Mid)
A Rco Seguranca 2 (Traseiro) / Rops 2 (Rear)
Etiqueta (Painel) / Label (Panel)
Peça De Acessorio E Serviço Peças / Accessories A Nd Service Parts
Kit Farios Trabalho [Opção] / Working Light Kit [ Option]
Zestaw Do Konwersji Wom (Carreto) (540/540e/1000) [Opcja] / Pto Conversion Kit (Gear) (540/540e/1000 ) [Option]
Zestaw Do Konwersji Wom (Alavanca) (540/540e/1000 ) [Opcja] / Pto Conversion Kit (Lever) (540/540e/10 00) [Option]
Válvula De Controle Alavanca Kit (Scd Con Fc) [Op Ção] [Ec] / Auxiliary Control Valve Kit (Scd With F C) [Option] [Ec]
Válvula De Controle Alavanca Kit (S/D Con Fc) [Op Ção] [Ec] / Auxiliary Control Valve Kit (S/D With F C) [Option] [Ec]
Válvula De Controle Alavanca [Peças Componentes] (S/D Con Fc) [Opção] [Ec] / Auxiliary Control Valve [Component Parts] (S/D With Fc) [Option] [Ec]
Auxiliar Do Alavanca De Válvula De Controlo Kit ( 3ª) [Opção] [Ec] / Auxiliary Control Valve Lever Ki T (3rd) [Option] [Ec]
Auxiliar Do Alavanca De Válvula De Controlo Kit ( 4ª) [Opção] [Ec] / Auxiliary Control Valve Lever Ki T (4th) [Option] [Ec]
Auxiliar Do Alavanca De Válvula De Controlo Kit ( 5ª) [Opção] [Ec] / Auxiliary Control Valve Lever Ki T (5th) [Option] [Ec]
Kit De Engate Dianteiro (1ª) [Opção] / Front Coup Ler Kit (1st) [Option]
Kit De Engate Dianteiro (2ª) [Opção] / Front Coup Ler Kit (2nd) [Option]
Kit De Engate Dianteiro (3ª) [Opção] / Front Coup Ler Kit (3rd) [Option]
Kit De Engate Dianteiro (Dreno) [Opção] / Front C Oupler Kit (Drain) [Option]
Conjunto De Drenagem Traseira [Opção] / Rear Drai N Kit [Option]
Kit De Válvula Do Travão Do Reboque (Valvula) [Op Ção] / Traler Brake Valve Kit (Valve) [Option]
Kit De Válvula Do Travão Do Reboque (Tubo Oleo) [ Opção][Ds] / Traler Brake Valve Kit (Hydraulic Pipe ) [Option][Ds]
Kit De Válvula Do Travão Do Reboque (Acoplamento) [Opção] / Traler Brake Valve Kit (Coupler) [Option ]
Kit De Suporte Da Escora [Opção] / Drawbar Bracke T Kit [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [Op Tion]
