Kubota Tractor M5071N-EC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M5071N-EC Tractor
Number of Pages: 554 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Engranaje Caja / Gear Case
Compensador / Balancer
Volante / Flywheel
Carril Comun / Common Rail
Agua Bomba / Water Pump
Aire Limpiador Brida / Air Cleaner Flange And Throttle Valve
Valvula De Egr / Egr Valve
Aire Limpiador / Air Cleaner
Tubo De Entrada (Filtro De Aire) / Inlet Pipe (Air Cleaner)
Soporte Del Muflfer / Muffler Bracket
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Piezas Electricas Del Motor (Silencioso Sensor) / Engine Electrical Parts (Muffler Sensor)
Diagmaster
Varilla Acelerador / Accelerator Rod
Combustible Deposito Soporte / Fuel Tank Bracket
Deposito De Combustible Derecho / Fuel Tank Rh
Deposito De Combustible Izquierdo / Fuel Tank Lh
Llenador Del Combustible [Antiguo] / Fuel Supply [Old]
Llenador Del Combustible [Nuevo] / Fuel Supply [New]
Tubo De Combustible (Deposito Combustible) / Fuel Pipe (Fuel Tank)
Tubo De Combustible (Bomba De Combustible/Separador) / Fuel Pipe (Fuel Pump/Separator)
Tubo De Combustible (Deposito Combustible Respiradero) / Fuel Pipe (Fuel Tank Breather)
Separador / Separator
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Silencioso) / Switch/Sensor (Muffler)
Conmutador/Sensor (Adelante) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) / Switch/Sensor (Rear)
Conmutador/Sensor (Embrague Carcasa) / Switch/Sensor (Clutch Housing)
Conmutador (Panel Tablero) [Ds] / Switch (Panel Board) [Ds]
Rele / Relay
Unidad De Control Electronico (Cuerpo) / Electronic Control Unit (Body)
Tablero De Instrumentos [Antiguo] / Panel [Old]
Tablero De Instrumentos [Nuevo] / Panel [New]
Faro Delantero / Head Light
Luz Matricula [Antiguo] / License Lamp [Old]
Luz Matricula [Nuevo] / License Lamp [New]
Instalacion Electrica (Crs) / Electrical Wiring (Crs)
Instalacion Electrica (Motor) / Electrical Wiring (Engine)
Instalacion Electrica (Principal) / Electrical Wiring (Main)
Electrico Cableado (Trasero) / Electrical Wiring (Rear)
Embrague Carcasa [Ds] / Clutch Housing [Ds]
Engranajes De Inversor Caja [Ds] / Shuttle Gear Case [Ds]
Valvula De Doble Velocidad [Ds] / Dual Speed Valve [Ds]
Manguera Del Respiradero (Transmision Caja) / Breather Hose (Transmission Case)
Amortiguador Disco [Ds] / Damper Disk [Ds]
Cable De Embrague / Clutch Cable
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Entrada Eje [Ds] / Input Shaft [Ds]
Paquete Del Embrague (Hi-Lo) [Componente Piezas] [Ds] / Clutch Pack (Hi-Lo) [Component Parts] [Ds]
Eje De Inversor [Ds] / Shuttle Shaft [Ds]
Paquete Del Embrague (Inversor) [Componente Piezas] [Ds] / Clutch Pack (Shuttle) [Component Parts] [Ds]
Primer Eje [Ds] / First Shaft [Ds]
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Propulsor / Drive Shaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Valvula De Embrague De Tdf [Componente Piezas] / Pto Clutch Valve [Component Parts]
Tdf Eje / Pto Shaft
Adelante Accionar Embrague [Componente Piezas] / Front Drive Clutch [Component Parts]
Embrague Hidraulico [Componente Piezas] / Hydraulic Clutch (Bi-Speed Turn) [Component Parts]
Horquilla Diferencial / Rear Differential Lock Shift Fork
Varilla De Cambios De Engranajes De La Tdf / Pto Gear Shift Lever
Trasero Eje / Rear Axle
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Arbol De Levas Del Freno De Estacionamiento / Parking Brake Camshaft
Eje De Freno De Estacionamiento / Parking Brake Shaft
Palanca De Freno Secundario / Secondary Brake Lever
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Caja De Engranaje Conico Derecho / Bevel Gear Case Rh
Caja De Engranaje Conico Izquierdo / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Cubierta Del Poste De Manejo / Steering Post Cover
Distribuidor De Direccion [Componente Piezas] / Steering Controller [Component Parts]
Atar Varilla/Cilindro De Direccion / Tie Rod/Steering Cylinder
Hidraulico Aceite Linea (Valvula De Doble Velocidad) [Ds] / Hydraulic Oil Line (Dual Speed Valve) [Ds]
Hidraulico Aceite Linea (Direccion/Tdf) [Ds] / Hydraulic Oil Line (Steering/Pto) [Ds]
Hidraulico Aceite Linea (Inversor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Brazo De Elevacion / Hydraulic Lift Arm
Distribuidor / Control Valve
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Montaje De Distribuidor De Servicios Externos [Ec] / Auxiliary Control Valve Mounting Base [Ec]
Distribuidor De Servicios Externos (Fd Con Fc/Scd Con Fc) [Ec] / Auxiliary Control Valve (Fd With Fc/Scd With Fc) [Ec]
Montaje De Distribuidor De Servicios Externos [Componente Piezas] [Ec] / Auxiliary Control Valve Mounting Base [Component Parts] [Ec]
Distribuidor De Servicios Externos [Componente Piezas] (Fd Con Fc) [Ec] / Auxiliary Control Valve [Component Parts] (Fd With Fc) [Ec]
Distribuidor De Servicios Externos [Componente Piezas] (Scd Con Fc) [Ec] / Auxiliary Control Valve [Component Parts] (Scd With Fc) [Ec]
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Cilindro De Ayuda De Elevacion Izquierdo [Antiguo] / 3p-Lift Assist Cylinder Lh [Old]
Cilindro De Ayuda De Elevacion Izquierdo [Nuevo] / 3p-Lift Assist Cylinder Lh [New]
Cilindro De Ayuda De Elevacion Derecho [Antiguo] / 3p-Lift Assist Cylinder Rh [Old]
Cilindro De Ayuda De Elevacion Derecho [Nuevo] / 3p-Lift Assist Cylinder Rh [New]
Manguera Del Respiradero (Cilindro De Ayuda De Elevacion) / Breather Hose (3p Cylinder)
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Varilla De Elevacion Izquierdo / Lift Rod Lh
Tdf Protector / Pto Protector
Capo Superior / Hood (Bonnet) Upper
Capo Superior (Amortiguador Sano/Aislador) / Hood (Bonnet) (Sound Absorber/Insulator)
Capo Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte (Inferior) / Bonnet Support (Rower)
Capo Soporte (Superior) / Bonnet Support (Upper)
Guardabarros (Inferior Posicion) [Antiguo] / Fender (Lower Position) [Old]
Guardabarros (Inferior Posicion) [Nuevo] / Fender (Lower Position) [New]
Guardabarros (Superior Posicion) / Fender (Upper Position)
Hoja De Piso / Floor Sheet
Peldano / Step
Cubierta Superior Del Paso / Step Upper Cover
Auxiliar Peldano / Auxiliary Step
Soporte Del Asiento / Seat Bracket
Material Insonoro / Soundproof Material
Herramienta Caja / Tool Box
Guardia / Guard
Rops 1 (Intermedia) / Rops 1 (Mid)
Rops 2 (Trasero) / Rops 2 (Rear)
Etiquetta (Adelante) / Label (Front)
Etiquetta (Panel) / Label (Panel)
Etiquetta (Trasero) / Label (Rear)
Accesorio Y Pieza De Servicio / Accessories And Service Parts
Tdf Conversion Kit (Engranaje) (540/540e/1000) [Opcion] / Pto Conversion Kit (Gear) (540/540e/1000) [Option]
Tdf Conversion Kit (Palanca) (540/540e/1000) [Opcion] / Pto Conversion Kit (Lever) (540/540e/1000) [Option]
Kit De Distribuidor De Servicios Externos (Fd Con Fc) [Opcion] [Ec] / Auxiliary Control Valve Kit (Fd With Fc) [Option] [Ec]
Kit De Distribuidor De Servicios Externos (Scd Con Fc) [Opcion] [Ec] / Auxiliary Control Valve Kit (Scd With Fc) [Option] [Ec]
Kit De Distribuidor De Servicios Externos (S/D Con Fc) [Opcion] [Ec] / Auxiliary Control Valve Kit (S/D With Fc) [Option] [Ec]
Distribuidor De Servicios Externos [Componente Piezas] (S/D Con Fc) [Opcion] [Ec] / Auxiliary Control Valve [Component Parts] (S/D With Fc) [Option] [Ec]
Kit De Palanca De Distribuidor De Servicios Externos (Tercera) [Opcion] [Ec] / Auxiliary Control Valve Lever Kit (3rd) [Option] [Ec]
Kit De Palanca De Distribuidor De Servicios Externos (4º) [Opcion] [Ec] / Auxiliary Control Valve Lever Kit (4th) [Option] [Ec]
Kit De Palanca De Distribuidor De Servicios Externos (5º) [Opcion] [Ec] / Auxiliary Control Valve Lever Kit (5th) [Option] [Ec]
Kit De Enganche Delantero (Primero) [Opcion] / Front Coupler Kit (1st) [Option]
Kit De Enganche Delantero (Segundo) [Opcion] / Front Coupler Kit (2nd) [Option]
Kit De Enganche Delantero (Tercero) [Opcion] / Front Coupler Kit (3rd) [Option]
Kit De Enganche Delantero (Desagüe) [Opcion] / Front Coupler Kit (Drain) [Option]
Kit De Drenaje Posterior [Opcion] / Rear Drain Kit [Option]
Kit De Valvulas De Freno De Remolque (Valvula) [Opcion] / Traler Brake Valve Kit (Valve) [Option]
Kit De Valvulas De Freno De Remolque (Linea De Aceite Hidraulico) [Opcion][Ds] / Traler Brake Valve Kit (Hydraulic Pipe) [Option][Ds]
Kit De Valvulas De Freno De Remolque (Acoplador) [Opcion] / Traler Brake Valve Kit (Coupler) [Option]
Estabilizador [Opción] / Stabilizer [Option]
Ayudar Cilindro Soporte [Opcion] / Drawbar Bracket Kit [Option]
Protector De Eje De Tdf [Opcion] / Pto Shaft Protector Kit [Option]
Volante / Flywheel
Diagmaster
Ventilador / Fan
Rele / Relay
Tdf Eje / Pto Shaft
Peldano / Step
Guardia / Guard
