Kubota Tractor M4900DT-CAB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4900DT-CAB Tractor
Number of Pages: 300 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head [Cab Type]
Carreto / Gear Case
Tampa Cabeça / Head Cover
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio / Fuel Camshaft
Regulador Velocidade / Engine Stop Lever
Vela Pre Aquecimento / Nozzle Holder And Glow P Lug [Cab Type]
Suporte Bico [Peças Componentes] / Nozzle Holde R [Component Parts]
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Colector Escape / Exhaust Manifold [Cab Type]
Filtro Ar / Air Cleaner [Cab Type]
Filtro Ar [Peças Componentes] / Air Cleaner [Co Mponent Parts]
Escpae / Muffler [Cab Type]
Kit De Junta Superior [Opção] / Upper Gasket Ki T [Option]
Kit De Junta Inferior [Opção / Lower Gasket Kit [Option]
Acelarador Mao / Hand Accelerator Lever [Cab Ty Pe]
Acelarador / Accelerator Pedal [Cab Type]
Tirante Do Acelerador / Accelerator Rod [Cab Ty Pe]
Stop Solenoid/Engine Stop Wire [Cab Type] / Sto P Solenoid/Engine Stop Wire [Cab Type]
Deposito Combustivel (Drt ) / Fuel Tank Rh [Cab Type]
Deposito Combustivel (Esq ) / Fuel Tank Lh [Cab Type]
Tubo Combustivel / Fuel P Ipe 1 (Rear) [Cab Type]
Tubo Combustivel / Fuel P Ipe 2 (Front) [Cab Type] [Old Type]
Tubo Combustivel / Fuel P Ipe 2 (Front) [Cab Type] [New Type]
Separador / Separator [Ca B Type]
Separador[Peças Component Es] / Separator [Component Parts] [Cab Type]
Filtro Gasoleo / Fuel Fil Ter [Component Parts] [Cab Type]
Ventoin Ha / Fan [Cab Type]
Tubo Ag Ua / Water Pipe [Cab Type]
Radiado R / Radiator [Cab Type]
Deposit O Reserva / Reserve Tank [Cab Type]
Alternador / Alternator [Cab Type]
Alternador [Peças Compon Entes] / Alternator [Component Parts] [Cab Type]
Motor Arranque / Starter
Motor Arranque [Componen Tes] / Starter [Component Parts]
Bateria / Battery [Cab T Ype]
Interruptor/Sensor / Swi Tch/Sensor [Cab Type]
Interruptor / Switch (Pa Nel Board) [Cab Type]
Interruptor / Switch [Ca B Type]
Rele / Relay [Cab Type]
Rele / Starter Relay [Ca B Type]
Painel / Panel Board [Ca B Type]
Painel[Peças Componentes ] / Panel Board [Component Parts] [Cab Type]
Farol Dianteiro / Head L Ight
Hazard Light [Cab Type] / Hazard Light [Cab Type]
Luzes Trabalho / Work Li Ght [Cab Type]
Braco Traseiro / Rear Co Mbination Light [Cab Type]
Luz Interior / Room Ligh T [Cab Type]
Deposito Limpa Parabris As / Washer Tank [Cab Type]
Escova Limpa Vidros / Wi Per [Cab Type]
Cablagem Electrica / Ele Ctrical Wiring 1 [Cab Type]
Cabalagem Eletrica(Cabin E)[Ec] [G] / Electrical Wiring (Cab) [Cab Type]
Carter Embraiagem / Clutch Housing [Cab Type]
Carretos Inversor / Shuttle Gear Case
Caixa Intermedia / Mid Case [Cab Type]
Caixa Velocidades / Transmission Case [Cab Type]
Carter Transmissa O / Transmission Case Rear Cover
Carter Eixo / Rea R Axle Case
Caixa Da Transmis São Dianteira / Front Drive Case
Compensador / Clu Tch
Forqueta Embraiag Em / Clutch Release Fork [Cab Type]
Pedal Embraiagem / Clutch Pedal [Cab Type]
Veio Primario / I Nput Shaft
Primeiro Veio / F Irst Shaft
Terceiro Veio / T Hird Shaft [Cab Type]
Back Idle Shaft / Back Idle Shaft
Veio Creeper / Cr Eep Shaft
Grupo Conico / Be Vel Gear [Old Type]
Grupo Conico / Be Vel Gear [New Type]
Diferencial Trase Iro / Differential Rear
Veio Tdf / Pto Pr Opeller Shaft [Cab Type]
Embraiagem Tdf[Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiage M Tdf / Pto Clutch Valve
Veio Tdf / Pto Sh Aft
Veio Primario (Tr Aseira) / Front Propeller Shaft (Rear)
Forqu Eta / Main Gear Shift Fork
Forqu Ilha Inversor / Shuttle Gear Shift Fork
Forqu Eta Velocidades / Range Gear Shift Fork [Cab Type]
Alvan Ca Tdf / Pto Shift Fork
Alava Nca / Rear Differential Lock Shift Fork
Alava Nca Velocidades / Main Gear Shift Lever [Cab Type]
Tiran Te / Main Gear Shift Rod [Cab Type]
Princ Ipal De Transmissão Eixo Da Alavanca / Main Gear Sh Ift Lever Shaft [Cab Type]
Alvan Ca Inversor / Shuttle Shift Lever [Cab Type]
Shutt Le Shift Rod [Cab Type] / Shuttle Shift Rod [Cab Ty Pe]
Alava Nca Velocidades / Range Gear Shift Lever [Cab Type]
Alava Nca Dupla Traccao / Front Wheel Drive Lever [Cab Ty Pe]
Eixo Traseiro / Rear A Xle
Travão / Brake
Brake Rod 1 [Cab Type] / Brake Rod 1 [Cab Type]
Brake Rod 2 [Cab Type] / Brake Rod 2 [Cab Type]
Alavanca Travao Mao / Parking Brake Lever [Cab Type]
Tirante Travao Mao / P Arking Brake Rod [Cab Type] [Old Type]
Tirante Travao Mao / P Arking Brake Rod [Cab Type] [New Type]
Pedal Travao / Brake P Edal [Cab Type]
Pedal Bloqueio Diferen Cial Traseiro / Rear Differential Lock Pedal [Cab T Ype]
Suporte Eixo Frente / Front Axle Frame [Cab Type]
Suporte Eixo Diante Iro / Front Axle Bracket
Veio Frontal / Fron T Propeller Shaft
Caixa Diferencial D Ianteiro / Front Differential Case
Engrenagem Cónica ( Dianteira) / Bevel Gear (Front)
Diferencial Diantei Ro / Differential Front
Carter Eixo / Front Axle Case
Grupo Conico / Diff Erential Gear Shaft
Eixo Dianteiro / Fr Ont Axle
Punho Volante / Steering Handle [Cab Type]
Junta / Steering Joint [Cab Type]
Distribuidor Direcção(Nova) / Steering Con Troller [Cab Type]
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts]
Cilindro Direcção[Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Bomba Hidraulico[Peças C Omponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydrau Lic Pipe (Suction) [Cab Type]
Tubo Oleo / Hydraulic Pi Pe (Delivery) [Cab Type]
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto) [Cab Type]
Tubo Direccao / Steering Hose (Delivery) [Cab Type]
Cilindro Hidraulico / Hy Draulic Cylinder [Cab Type]
Braço De Elevação Hidráu Lico / Hydraulic Lift Arm
Resguardo Cilindro Hidrá Ulico / Hydraulic Cylinder Cover [Cab Type]
Braco Hidraulico / Contr Ol Valve
Alavanca Control Esforço / Draft And Position Control Lever [Cab Type]
Puxar E Posicionar Supor Te De Alavanca De Controlo / Draft And Position Con Trol Lever Bracket
Position Control Shaft / Position Control Shaft
Draft Control Shaft / Dr Aft Control Shaft
Alavanca / Feed Back Lev Er
Distribuidor Auxiliar / Auxiliary Control Valve [Cab Type]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve[Component Pa Rts][Cab Type]
Alavanca Valvula Auxilia R 1 Pos / Auxiliary Contorol Valve Lever [Cab Type]
Par Te Superior / Top Link Bracket [Cab Type]
Lig Acao Superior / Top Link [Cab Type]
Lig Acao Inferior / Lower Link [Cab Type] [Old Type]
Lig Acao Inferior / Lower Link [Cab Type] [New Type]
Est Abilizador(Drt) / Lift Rod Rh
Est Abilizador(Esq) / Lift Rod Lh
Bar Ra De Engate Oscilante / Swinging Drawbar [Cab Type ]
Pro Teccao Tdf / Pto Shaft Protector
Hood(Bonnet) Front [Cab Type] / Hood(Bonne T) Front [Cab Type]
Capot Superior / Hood(Bonnet) Upper [Cab T Ype]
Lado Do Capot / Hood(Bonnet) Side [Cab Typ E]
Capot Lateral / Hood(Bonnet) Side Cover [C Ab Type]
Suporte Capot / Bonnet Support [Cab Type]
Estrutura Cabine / Cab Frame [Cab Type]
Vidro Frente E Traseiro / Front Glass [Cab Type]
Porta(Drt) / Door Rh [Cab Type]
Porta(Esq) / Door Lh [Cab Type]
Trinco Porta(Drt) / Door Lock Rh [Cab Type]
Trinco Porta(Esq) / Door Lock Lh [Cab Type]
Lado Vidro / Side Window [Cab Type]
Vidro Traseiro / Rear Window [Cab Type]
Espelho Rectrovisor / Rearview Mirror [Cab Type]
Tecto Interior / Inner Roof [Cab Type]
Tejadilho Exterior / Outer Roof [Cab Type]
Banco / Seat [Cab Type]
Piso / Floor Mat [Cab Type]
Chapa Inspecção(Frente) / Inspection Plate [Cab T Ype]
Cobertura Guarda Lamas(Drt) / Fender Cover Rh [Ca B Type]
Cobertura Gurada Lamas(Esq) / Fender Cover Lh [Ca B Type]
Resguardo Coluna / Pillar Cover [Cab Type]
Guarda Lamas(Drt) / Fender Rh [Cab Type]
Guarda Lamas(Esquerda) / Fender Lh [Cab Type]
Suporte Cabine(Dianteiro) / Cab Bracket Front [Ca B Type]
Suporte Cabine(Traseiro) / Cab Bracket Rear [Cab Type]
Caixa Ferramenta / Tool Box [Cab Type]
Air Condicionado / Air Cond Itioner [Cab Type]
Tubo Aquecimento / Heater H Ose [Cab Type]
Condesador / Condenser [Cab Type] [Old Type]
Condesador / Condenser [Cab Type] [New Type]
Compressor / Compressor [Ca B Type] [Old Type]
Compressor / Compressor [Ca B Type] [New Type]
Roda Frente / Front Wheel (9.5-2 2) [Option]
Roda Frente / Front Wheel (8.3-2 4) [Option]
Roda Traseira / Rear Wheel (16.9 -28) [Option]
Roda Traseira / Rear Wheel (14.9 -28) [Option]
Etiqueta (Dianteira) / Label 1 [Cab Type]
Etiqueta / Label 2 [Cab Type]
Acessorios / Accessories And Service Parts
Lever Joint Stay Kit / Lever Joint Stay Kit
Trailer Socket Kit [Cab Type] [Option] / Traile R Socket Kit [Cab Type] [Option]
Kit Radio Cassete / Radio Cassette Kit [Cab Typ E] [Option]
Rear Wiper Kit [Cab Type] [Old Type] [Option] / Rear Wiper Kit [Cab Type] [Old Type] [Option]
Rear Wiper Kit [Cab Type] [New Type] [Option] / Rear Wiper Kit [Cab Type] [New Type] [Option]
Auxiliary Control Valve Kit(Scd)[Cab Type] [Opt Ion] / Auxiliary Control Valve Kit(Scd)[Cab Type] [ Option]
Auxiliary Control Valve Kit(Fd) [Cab Type] [Opt Ion] / Auxiliary Control Valve Kit(Fd) [Cab Type] [ Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Control Valve Kit (Scd/Fc) [Cab Type] [Option]
Distribuidor Auxiliar[Peças Componentes] / Auxi Liary Control Valve(Scd)[Component Parts][Cab Type] [Option]
Distribuidor Auxiliar[Peças Componentes] / Auxi Liary Control Valve(Fd)[Component Parts][Cab Type][ Option]
Distribuidor Auxiliar[Peças Componentes] / Auxi Liary Control Valve (Scd/Fc) [Component Parts][Cab Type][Option]
Kit Alavancas Serviços Externos 2º Posição [Op Cao] / Auxilairy Control Valve Lever Kit (2nd)[Cab Type] [Option]
Kit Alavancas Serviços Externos 3º Posição [Op Cao] / Auxilairy Control Valve Lever Kit (3rd) [Cab Type] [Option]
